#include <ossimImageRenderer.h>
Classes | |
| class | ossimRendererSubRectInfo |
| ossimImageRenderer () | |
| ossimImageRenderer (ossimImageSource *inputSource, ossimImageViewTransform *imageViewTrans=NULL) | |
| virtual | ~ossimImageRenderer () |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &origin, ossim_uint32 resLevel=0) |
| the resampler will need the tile request to come from the view. More... | |
| m_Resampler will adjust the rect to whatever the view is. More... | |
| void | setImageViewTransform (ossimImageViewTransform *transform) |
| ossimImageViewTransform * | getImageViewTransform () |
| Returns instance to the input image geometry. More... | |
| virtual bool | setView (ossimObject *baseObject) |
| ossimFilterResampler * | getResampler () |
| virtual ossimObject * | getView () |
| virtual const ossimObject * | getView () const |
| virtual void | setAutoUpdateInputTransformFlag (bool flag) |
| void | setMaxLevelsToCompute (ossim_uint32 maxLevels) |
| ossim_uint32 | getMaxLevelsToCompute () const |
| void | connectInputEvent (ossimConnectionEvent &event) |
| void | disconnectInputEvent (ossimConnectionEvent &event) |
| void | propertyEvent (ossimPropertyEvent &event) |
| Enables source. More... | |
| Disables source. More... | |
| Sets the enable flag. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Public Member Functions inherited from ossimViewInterface | |
| ossimViewInterface () | |
| ossimViewInterface (ossimObject *base) | |
| virtual | ~ossimViewInterface () |
| virtual void | refreshView () |
| ossimObject * | getBaseObject () |
Private Member Functions | |
| void | recursiveResample (ossimRefPtr< ossimImageData > outputData, const ossimRendererSubRectInfo &rectInfo, ossim_uint32 level) |
| void | fillTile (ossimRefPtr< ossimImageData > outputData, const ossimRendererSubRectInfo &rectInfo) |
| ossimIrect | getBoundingImageRect () const |
| void | checkIVT () |
| this is called on a property event and on input connection changes. More... | |
| void | initializeBoundingRects () |
| Initializes m_inputR0Rect and m_viewBoundingRect and sets m_rectsDirty appropriately. More... | |
| ossimRefPtr< ossimImageData > | getTileAtResLevel (const ossimIrect &boundingRect, ossim_uint32 resLevel) |
| template<class T > | |
| void | resampleTileToDecimation (T dummyVariable, ossimRefPtr< ossimImageData > result, ossimRefPtr< ossimImageData > tile, ossim_uint32 multiplier) |
| long | computeClosestResLevel (const std::vector< ossimDpt > &decimationFactors, double scale) const |
| void | stretchQuadOut (const ossimDpt &amount, ossimDpt &ul, ossimDpt &ur, ossimDpt &lr, ossimDpt &ll) |
| void | allocate () |
| Called on first getTile, will initialize all data needed. More... | |
| void | deallocate () |
| Deletes all allocated tiles. More... | |
Private Attributes | |
| ossimFilterResampler * | m_Resampler |
| ossimRefPtr< ossimImageData > | m_BlankTile |
| ossimRefPtr< ossimImageData > | m_Tile |
| ossimRefPtr< ossimImageData > | m_TemporaryBuffer |
| ossim_uint32 | m_StartingResLevel |
| This is going to allow us to chain multiple renderers together. More... | |
| ossimRefPtr< ossimImageViewTransform > | m_ImageViewTransform |
| ossimIrect | m_inputR0Rect |
| ossimIrect | m_viewRect |
| bool | m_rectsDirty |
| ossim_uint32 | m_MaxRecursionLevel |
| bool | m_AutoUpdateInputTransform |
| ossim_uint32 | m_MaxLevelsToCompute |
| ossimPolyArea2d | m_viewArea |
| bool | m_crossesDateline |
Definition at line 26 of file ossimImageRenderer.h.
| ossimImageRenderer::ossimImageRenderer | ( | ) |
Definition at line 1039 of file ossimImageRenderer.cpp.
References m_ImageViewTransform, m_Resampler, and ossimViewInterface::theObject.
| ossimImageRenderer::ossimImageRenderer | ( | ossimImageSource * | inputSource, |
| ossimImageViewTransform * | imageViewTrans = NULL |
Definition at line 1061 of file ossimImageRenderer.cpp.
References m_ImageViewTransform, m_Resampler, ossimViewInterface::theObject, and ossimRefPtr< T >::valid().
Definition at line 1086 of file ossimImageRenderer.cpp.
References m_ImageViewTransform, and m_Resampler.
private |
Definition at line 1764 of file ossimImageRenderer.cpp.
References ossimImageDataFactory::create(), deallocate(), ossimImageData::initialize(), ossimImageDataFactory::instance(), m_BlankTile, m_Tile, and ossimImageSourceFilter::theInputConnection.
private |
Definition at line 2037 of file ossimImageRenderer.cpp.
References ossimRefPtr< T >::get(), ossimImageViewProjectionTransform::getImageGeometry(), ossimImageSource::getImageGeometry(), ossimConnectableObject::getInput(), ossimSource::isSourceEnabled(), ossimImageViewTransform::isValid(), m_ImageViewTransform, and PTR_CAST.
Referenced by connectInputEvent(), getImageGeometry(), initialize(), propertyEvent(), setEnableFlag(), and setImageViewTransform().
private |
Definition at line 1940 of file ossimImageRenderer.cpp.
References checkIVT(), ossimConnectableObject::getInput(), initialize(), m_ImageViewTransform, PTR_CAST, ossimImageSourceFilter::theInputConnection, and ossimRefPtr< T >::valid().
private |
Definition at line 1757 of file ossimImageRenderer.cpp.
References m_BlankTile, m_TemporaryBuffer, and m_Tile.
Referenced by allocate(), and initialize().
Disables source.
Overrides ossimSource::disableSource so bounding rects are recomputed on state change.
Definition at line 2555 of file ossimImageRenderer.cpp.
References ossimSource::isSourceEnabled(), and setEnableFlag().
Definition at line 1950 of file ossimImageRenderer.cpp.
References ossimRefPtr< T >::get(), m_ImageViewTransform, ossimImageViewProjectionTransform::setImageGeometry(), and ossimImageSourceFilter::theInputConnection.
Enables source.
Overrides ossimSource::enableSource so bounding rects are recomputed on state change.
Definition at line 2547 of file ossimImageRenderer.cpp.
private |
Definition at line 1348 of file ossimImageRenderer.cpp.
References ossimImageRenderer::ossimRendererSubRectInfo::getAbsValueImageToViewScales(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageSource::getDecimationFactor(), ossimFilterResampler::getKernelSupport(), ossimImageSource::getNumberOfDecimationLevels(), getTileAtResLevel(), ossimImageRenderer::ossimRendererSubRectInfo::getViewRect(), ossimDpt::hasNans(), ossimDrect::height(), ossimImageRenderer::ossimRendererSubRectInfo::imageHasNans(), ossimDrect::lr(), ossimImageRenderer::ossimRendererSubRectInfo::m_Ill, ossimImageRenderer::ossimRendererSubRectInfo::m_Ilr, m_inputR0Rect, ossimImageRenderer::ossimRendererSubRectInfo::m_Iul, ossimImageRenderer::ossimRendererSubRectInfo::m_Iur, m_Resampler, m_StartingResLevel, ossimDpt::makeNan(), OSSIM_EMPTY, OSSIM_NULL, ossimFilterResampler::resample(), RSET_SEARCH_THRESHHOLD, ossimFilterResampler::setBoundingInputRect(), ossimFilterResampler::setScaleFactor(), status, ossimImageSourceFilter::theInputConnection, ossimDrect::ul(), ossimRefPtr< T >::valid(), ossimDrect::width(), ossimDpt::x, and ossimDpt::y.
Referenced by recursiveResample().
private |
So it will project the full image rect onto the view and return the upright bounding rect.
Definition at line 1554 of file ossimImageRenderer.cpp.
Gets the bounding rectangle of the source.
This is the output view bounds.
| rect | Initialized with bounding rectangle by this. |
| resLevel | Reduced resolution level if applicable. |
Definition at line 1576 of file ossimImageRenderer.cpp.
References ossimImageSource::getBoundingRect(), ossimSource::isSourceEnabled(), m_viewRect, ossimIrect::makeNan(), and ossimImageSourceFilter::theInputConnection.
Will return the decimation factor for the given resolution level.
the decimation is the scale from Resolution 0 or full res. Usually this is a power of 2 decimation where the decimation result is 1.0/2^resoltion.
Definition at line 2136 of file ossimImageRenderer.cpp.
References ossimImageSource::getDecimationFactor(), and ossimSource::isSourceEnabled().
Definition at line 2150 of file ossimImageRenderer.cpp.
References ossimImageSource::getDecimationFactors(), and ossimSource::isSourceEnabled().
This may be a NULL pointer. This is only valid if the IVT is a projection type IVT (IVPT)
Definition at line 1916 of file ossimImageRenderer.cpp.
References checkIVT(), ossimRefPtr< T >::get(), ossimImageSource::getImageGeometry(), ossimImageViewProjectionTransform::getViewGeometry(), ossimSource::isSourceEnabled(), ossimImageViewTransform::isValid(), m_ImageViewTransform, ossimImageSourceFilter::theInputConnection, and ossimRefPtr< T >::valid().
inline |
Definition at line 84 of file ossimImageRenderer.h.
Referenced by ossimIvtGeomXformVisitor::visit().
Definition at line 2515 of file ossimImageRenderer.cpp.
| ossim_uint32 ossimImageRenderer::getMaxLevelsToCompute | ( | ) | const |
Definition at line 2368 of file ossimImageRenderer.cpp.
References m_MaxLevelsToCompute.
Will return the number of resolution levels.
Note: resolution level 0 is included in the return count.
Definition at line 2162 of file ossimImageRenderer.cpp.
References ossimImageSource::getNumberOfDecimationLevels(), and ossimSource::isSourceEnabled().
Definition at line 1991 of file ossimImageRenderer.cpp.
References ossimProperty::clearChangeType(), ossimFilterResampler::getFilterTypes(), ossimFilterResampler::getMinifyFilterTypeAsString(), ossimImageSourceFilter::getProperty(), m_Resampler, ossimProperty::setCacheRefreshBit(), and ossimProperty::setReadOnlyFlag().
Definition at line 2026 of file ossimImageRenderer.cpp.
References ossimImageSourceFilter::getPropertyNames().
inline |
Definition at line 91 of file ossimImageRenderer.h.
Referenced by ossimKakaduJpipHandler::getTile().
Definition at line 2520 of file ossimImageRenderer.cpp.
It will use the view to transoform this to world and then use the image's projection to get it into final line sample. This way the resampler can fill a tile width by height on the screen correctly.
Definition at line 1097 of file ossimImageRenderer.cpp.
private |
Definition at line 2203 of file ossimImageRenderer.cpp.
References ossimImageData::dup(), ossimImageSource::getBoundingRect(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageSource::getNumberOfDecimationLevels(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimImageSource::getTileHeight(), ossimImageSource::getTileWidth(), ossimImageData::initialize(), ossimIrect::intersects(), ossimIrect::lr(), m_BlankTile, m_MaxLevelsToCompute, m_TemporaryBuffer, ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SCALAR_UNKNOWN, OSSIM_SINT16, OSSIM_UINT16, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, resampleTileToDecimation(), ossimImageData::setImageRectangle(), ossimIrect::stretchToTileBoundary(), ossimImageSourceFilter::theInputConnection, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIpt::x, and ossimIpt::y.
Referenced by fillTile().
ordering specifies how the vertices should be arranged.
valid image vertices is basically the tightly fit convex hull of the image. Usually an image has NULL values and are internally not upright rectangular. This can cause problems some spatial filters.
We need to make sure that the resampler overrides this method. it needs to transform the vertices to the view's side.
Definition at line 1884 of file ossimImageRenderer.cpp.
References ossimImageSource::getValidImageVertices(), ossimImageViewTransform::imageToView(), ossimSource::isSourceEnabled(), ossimImageViewTransform::isValid(), m_ImageViewTransform, ossimImageSourceFilter::theInputConnection, and ossimRefPtr< T >::valid().
Implements ossimViewInterface.
Definition at line 1866 of file ossimImageRenderer.cpp.
References ossimViewInterface::getView(), m_ImageViewTransform, and ossimRefPtr< T >::valid().
Definition at line 1875 of file ossimImageRenderer.cpp.
Definition at line 1735 of file ossimImageRenderer.cpp.
References checkIVT(), deallocate(), ossimImageSourceFilter::initialize(), initializeBoundingRects(), ossimSource::isSourceEnabled(), ossimImageViewTransform::isValid(), m_ImageViewTransform, m_rectsDirty, and ossimRefPtr< T >::valid().
Referenced by connectInputEvent(), ossimEquationUtil::initInputSources(), propertyEvent(), refreshEvent(), and setEnableFlag().
private |
Definition at line 1600 of file ossimImageRenderer.cpp.
References ossimPolyArea2d::add(), ossimIrect::combine(), ossimRefPtr< T >::get(), ossimImageSource::getBoundingRect(), ossimImageGeometry::getBoundingRect(), ossimImageGeometry::getCrossesDateline(), ossimImageViewProjectionTransform::getImageGeometry(), ossimImageViewTransform::getImageToViewBounds(), ossimImageGeometry::getMetersPerPixel(), ossimImageViewProjectionTransform::getViewGeometry(), ossimImageViewProjectionTransform::getViewSegments(), ossimDpt::hasNans(), ossimIrect::hasNans(), ossimDrect::height(), m_ImageViewTransform, m_inputR0Rect, m_rectsDirty, m_viewArea, m_viewRect, ossimIrect::makeNan(), ossim::max(), ossim::min(), ossimNotify(), ossimNotifyLevel_DEBUG, ossimImageSourceFilter::theInputConnection, ossimRefPtr< T >::valid(), ossimDrect::width(), and ossimDpt::y.
Referenced by initialize(), setImageViewTransform(), and setView().
Definition at line 1798 of file ossimImageRenderer.cpp.
Definition at line 1960 of file ossimImageRenderer.cpp.
References checkIVT(), and initialize().
private |
Definition at line 1250 of file ossimImageRenderer.cpp.
References fillTile(), ossimImageRenderer::ossimRendererSubRectInfo::getViewRect(), ossimIrect::height(), ossimImageRenderer::ossimRendererSubRectInfo::imageHasNans(), ossimImageRenderer::ossimRendererSubRectInfo::imageIsNan(), ossimPolyArea2d::intersects(), m_viewArea, ossimImageRenderer::ossimRendererSubRectInfo::splitView(), and ossimIrect::width().
Definition at line 2525 of file ossimImageRenderer.cpp.
References ossimRefPtr< T >::get(), ossimImageSource::getImageGeometry(), ossimEvent::getObject(), ossimRefreshEvent::getRefreshType(), ossimImageSourceFilter::initialize(), initialize(), m_ImageViewTransform, ossimRefreshEvent::REFRESH_GEOMETRY, ossimImageSourceFilter::refreshEvent(), ossimImageViewProjectionTransform::setImageGeometry(), and ossimImageSourceFilter::theInputConnection.
private |
Definition at line 2374 of file ossimImageRenderer.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getOrigin(), ossimImageData::getWidth(), min, OSSIM_EMPTY, OSSIM_FULL, ossimIpt::x, and ossimIpt::y.
Referenced by getTileAtResLevel().
Definition at line 1777 of file ossimImageRenderer.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), m_ImageViewTransform, m_MaxLevelsToCompute, m_Resampler, ossimFilterResampler::saveState(), ossimImageViewTransform::saveState(), ossimImageSource::saveState(), and ossimRefPtr< T >::valid().
inlinevirtual |
Definition at line 99 of file ossimImageRenderer.h.
| flag | True to enable, false to disable. |
Overrides ossimSource::setEnableFlag so bounding rects are recomputed on state change.
Definition at line 2563 of file ossimImageRenderer.cpp.
References checkIVT(), ossimSource::getEnableFlag(), initialize(), and ossimSource::setEnableFlag().
Referenced by disableSource(), and enableSource().
| void ossimImageRenderer::setImageViewTransform | ( | ossimImageViewTransform * | transform | ) |
Definition at line 1836 of file ossimImageRenderer.cpp.
References checkIVT(), initializeBoundingRects(), ossimSource::isSourceEnabled(), ossimImageViewTransform::isValid(), m_ImageViewTransform, m_rectsDirty, and ossimRefPtr< T >::valid().
Referenced by ATP::AtpGenerator::constructChain(), ossimKakaduJpipHandler::getTile(), and ossimEquationUtil::initInputSources().
| void ossimImageRenderer::setMaxLevelsToCompute | ( | ossim_uint32 | maxLevels | ) |
Definition at line 2363 of file ossimImageRenderer.cpp.
Definition at line 1966 of file ossimImageRenderer.cpp.
References m_Resampler, ossimFilterResampler::setFilterType(), ossimImageSourceFilter::setProperty(), and ossimProperty::valueToString().
Referenced by ATP::AtpGenerator::constructChain().
The derived classes should overrid this method and return true or false whether it was able to cast the past in view to a view that it can interface to. So if you are a projective view you might cast to an ossimProjection. The ownsTheView specifies whether or not it owns the passed in view pointer. This will specifiy whether or not the derived classes need to re-allocate the pointer or just delete its old pointer and set it to the passed in pointer.
Definition at line 1853 of file ossimImageRenderer.cpp.
References initializeBoundingRects(), m_ImageViewTransform, ossimViewInterface::setView(), and ossimRefPtr< T >::valid().
Referenced by main(), and ossimChipProcTool::propagateGeometryToChains().
private |
Definition at line 2172 of file ossimImageRenderer.cpp.
References ossimDpt::length(), ossimDpt::x, and ossimDpt::y.
private |
Definition at line 336 of file ossimImageRenderer.h.
private |
Definition at line 315 of file ossimImageRenderer.h.
Referenced by allocate(), deallocate(), and getTileAtResLevel().
private |
Definition at line 340 of file ossimImageRenderer.h.
private |
Definition at line 329 of file ossimImageRenderer.h.
Referenced by checkIVT(), connectInputEvent(), disconnectInputEvent(), getImageGeometry(), getValidImageVertices(), getView(), initialize(), initializeBoundingRects(), ossimImageRenderer(), refreshEvent(), saveState(), setImageViewTransform(), setView(), and ~ossimImageRenderer().
private |
Definition at line 331 of file ossimImageRenderer.h.
Referenced by fillTile(), and initializeBoundingRects().
private |
Definition at line 337 of file ossimImageRenderer.h.
Referenced by getMaxLevelsToCompute(), getTileAtResLevel(), saveState(), and setMaxLevelsToCompute().
private |
Definition at line 335 of file ossimImageRenderer.h.
private |
Definition at line 333 of file ossimImageRenderer.h.
Referenced by initialize(), initializeBoundingRects(), and setImageViewTransform().
private |
Definition at line 314 of file ossimImageRenderer.h.
Referenced by fillTile(), getProperty(), ossimImageRenderer(), saveState(), setProperty(), and ~ossimImageRenderer().
private |
So if we have one renderer doing a scale and they pass an r-level down and we have another renderer within the chain he will be starting at a different r-level. The default will be r-level 0 request coming from the right.
Definition at line 328 of file ossimImageRenderer.h.
private |
Definition at line 317 of file ossimImageRenderer.h.
Referenced by deallocate(), and getTileAtResLevel().
private |
Definition at line 316 of file ossimImageRenderer.h.
Referenced by allocate(), and deallocate().
private |
Definition at line 339 of file ossimImageRenderer.h.
Referenced by initializeBoundingRects(), and recursiveResample().
private |
Definition at line 332 of file ossimImageRenderer.h.
Referenced by getBoundingRect(), and initializeBoundingRects().
