This class imlements the fusion algorithm from the paper: More...
#include <ossimSFIMFusion.h>
| ossimSFIMFusion () | |
| virtual void | initAdjustableParameters () |
Public Member Functions inherited from ossimFusionCombiner | |
| ossimFusionCombiner () | |
| ossimFusionCombiner (ossimObject *owner) | |
| ossimScalarType | getOutputScalarType () const |
Public Member Functions inherited from ossimImageCombiner | |
| ossimImageCombiner () | |
| ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag) | |
| ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual void | updateRects () |
| This will go through and precompute the bounding rects of each input image. More... | |
| Returns the number of bands available from the input. More... | |
| virtual ossim_uint32 | getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to retrieve the number of overlapping images withint the given rect. More... | |
| virtual void | getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to populate the result with the index of the overlapping images. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | hasDifferentInputs () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Provides the derived adjustable class an opportunity to update its state after a param change. More... | |
| Dumps the currently active adjustment to ostream. More... | |
| virtual | ~ossimSFIMFusion () |
| void | setFilters () |
| bool | computeRegression (ossim_float64 &slopeResult, const ossimIpt &origin, ossimRefPtr< ossimImageData > panData, ossimRefPtr< ossimImageData > colorData, ossim_uint32 colorBandIdx) |
Protected Member Functions inherited from ossimFusionCombiner | |
| virtual | ~ossimFusionCombiner () |
| ossimRefPtr< ossimImageData > | getNormIntensity (const ossimIrect &rect, ossim_uint32 resLevel) |
| ossimRefPtr< ossimImageData > | getNormTile (const ossimIrect &rect, ossim_uint32 resLevel) |
Protected Member Functions inherited from ossimImageCombiner | |
| virtual | ~ossimImageCombiner () |
| void | precomputeBounds () const |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
"Smoothing Filter-based Intesity Modulation: a spectral preserve image fusion technique for improving spatial details"
Pulished in INT. J. Remote Sensing, 2000, Vol. 21 NO. 18, 3461-3472
By J. G. LIU
Auther: Garrett Potts LICENSE: MIT
Definition at line 31 of file ossimSFIMFusion.h.
| ossimSFIMFusion::ossimSFIMFusion | ( | ) |
Definition at line 29 of file ossimSFIMFusion.cpp.
References initAdjustableParameters(), setFilters(), theAutoAdjustScales, theHighPassFilter, and theLowPassFilter.
protectedvirtual |
Definition at line 42 of file ossimSFIMFusion.cpp.
Reimplemented from ossimAdjustableParameterInterface.
Definition at line 314 of file ossimSFIMFusion.cpp.
References ossimAdjustableParameterInterface::computeParameterOffset(), and theLowPassKernelWidth.
Referenced by initialize(), and loadState().
protected |
inlinevirtual |
Implements ossimAdjustableParameterInterface.
Definition at line 40 of file ossimSFIMFusion.h.
inlinevirtual |
Definition at line 44 of file ossimSFIMFusion.h.
Definition at line 345 of file ossimSFIMFusion.cpp.
References ossimAdjustableParameterInterface::computeParameterOffset(), and ossimString::toString().
Definition at line 375 of file ossimSFIMFusion.cpp.
References ossimImageSource::getPropertyNames().
Definition at line 46 of file ossimSFIMFusion.cpp.
References ossimImageData::copyNormalizedBufferToTile(), ossimImageData::copyTileBandToNormalizedBuffer(), ossimImageData::dup(), FLT_EPSILON, ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimConnectableObject::getInput(), ossimImageData::getMinPix(), ossimFusionCombiner::getNormTile(), ossimImageData::getNumberOfBands(), ossimImageSource::getTile(), ossimImageGaussianFilter::getTile(), ossimConvolutionSource::getTile(), ossimImageData::getWidth(), ossimIrect::height(), initialize(), ossimImageData::initialize(), ossimImageData::loadTile(), ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_NORMALIZED_FLOAT, ossimImageData::setImageRectangle(), theHighPassFilter, ossimFusionCombiner::theInputConnection, ossimFusionCombiner::theIntensityConnection, theLowPassFilter, theNormHighPassTile, theNormLowPassTile, ossimFusionCombiner::theTile, ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIrect::width(), x, and y.
Definition at line 287 of file ossimSFIMFusion.cpp.
References ossimAdjustableParameterInterface::resizeAdjustableParameterArray().
Referenced by ossimSFIMFusion().
Reimplemented from ossimFusionCombiner.
Definition at line 196 of file ossimSFIMFusion.cpp.
References ossimConnectableObject::accept(), adjustableParametersChanged(), ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::disconnectAllInputs(), ossimImageSource::getImageGeometry(), ossimConnectableObject::getInput(), ossimImageGeometry::getMetersPerPixel(), ossimImageSource::getObject(), ossimCollectionVisitor::getObjectAs(), ossimDpt::hasNans(), ossimFusionCombiner::initialize(), ossimImageGaussianFilter::initialize(), ossimConvolutionSource::initialize(), ossimDpt::length(), PTR_CAST, ossimCollectionVisitor::reset(), setFilters(), ossimAdjustableParameterInterface::setParameterOffset(), theAutoAdjustScales, theHighPassFilter, ossimFusionCombiner::theInputConnection, ossimFusionCombiner::theIntensityConnection, theLowPassFilter, and ossimRefPtr< T >::valid().
Referenced by getTile().
Reimplemented from ossimImageCombiner.
Definition at line 396 of file ossimSFIMFusion.cpp.
References adjustableParametersChanged(), ossimString::empty(), ossimKeywordlist::find(), ossimAdjustableParameterInterface::loadAdjustments(), ossimImageCombiner::loadState(), theAutoAdjustScales, and ossimString::toBool().
Definition at line 383 of file ossimSFIMFusion.cpp.
References ossimKeywordlist::add(), ossimAdjustableParameterInterface::saveAdjustments(), ossimImageCombiner::saveState(), and theAutoAdjustScales.
protected |
Definition at line 255 of file ossimSFIMFusion.cpp.
References ossimAdjustableParameterInterface::computeParameterOffset(), ossimImageGaussianFilter::setGaussStd(), theHighPassKernelWidth, theHighPassMatrix, theLowPassFilter, and theLowPassKernelWidth.
Referenced by initialize(), and ossimSFIMFusion().
Definition at line 320 of file ossimSFIMFusion.cpp.
References ossimAdjustableParameterInterface::setParameterOffset().
protected |
Definition at line 81 of file ossimSFIMFusion.h.
Referenced by initialize(), loadState(), ossimSFIMFusion(), and saveState().
protected |
Definition at line 75 of file ossimSFIMFusion.h.
Referenced by getTile(), initialize(), and ossimSFIMFusion().
protected |
Definition at line 71 of file ossimSFIMFusion.h.
Referenced by setFilters().
protected |
Definition at line 80 of file ossimSFIMFusion.h.
protected |
Definition at line 74 of file ossimSFIMFusion.h.
Referenced by getTile(), initialize(), ossimSFIMFusion(), and setFilters().
protected |
Definition at line 70 of file ossimSFIMFusion.h.
Referenced by adjustableParametersChanged(), and setFilters().
protected |
Definition at line 78 of file ossimSFIMFusion.h.
protected |
Definition at line 77 of file ossimSFIMFusion.h.
protected |
Definition at line 76 of file ossimSFIMFusion.h.
