#include <ossimBlendMosaic.h>
| ossimBlendMosaic () | |
| ossimBlendMosaic (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual | ~ossimBlendMosaic () |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &origin, ossim_uint32 resLevel=0) |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| void | setWeight (ossim_uint32 index, double weight) |
| void | setWeights (const std::vector< double > &weights) |
| double | getWeight (ossim_uint32 index) const |
| const std::vector< double > & | getWeights () const |
| void | setNumberOfWeights (ossim_uint32 numberOfWeights) |
| void | setAllWeightsTo (double value) |
| void | normalizeWeights () |
| Will find the min and max values and then normalize all weights to be from 0 to 1. More... | |
| void | findMinMax (double &minValue, double &maxValue) const |
Public Member Functions inherited from ossimImageMosaic | |
| ossimImageMosaic () | |
| ossimImageMosaic (ossimConnectableObject::ConnectableObjectList &inputSources) | |
Public Member Functions inherited from ossimImageCombiner | |
| ossimImageCombiner () | |
| ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag) | |
| ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual void | updateRects () |
| This will go through and precompute the bounding rects of each input image. More... | |
| Returns the number of bands available from the input. More... | |
| virtual ossim_uint32 | getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to retrieve the number of overlapping images withint the given rect. More... | |
| virtual void | getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to populate the result with the index of the overlapping images. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | hasDifferentInputs () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| template<class T > | |
| ossimRefPtr< ossimImageData > | combine (T, const ossimIrect &tileRect, ossim_uint32) |
| If our inputs have output of different scalar types then we must normalize so we can blend different scalar data together. More... | |
| ossimRefPtr< ossimImageData > | combineNorm (T, const ossimIrect &tileRect, ossim_uint32) |
Protected Member Functions inherited from ossimImageMosaic | |
| virtual | ~ossimImageMosaic () |
| void | allocate () |
| Called on first getTile, will initialize all data needed. More... | |
| ossimRefPtr< ossimImageData > | combine (T, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| ossimRefPtr< ossimImageData > | combineNorm (T, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
Protected Member Functions inherited from ossimImageCombiner | |
| virtual | ~ossimImageCombiner () |
| void | precomputeBounds () const |
Definition at line 16 of file ossimBlendMosaic.h.
| ossimBlendMosaic::ossimBlendMosaic | ( | ) |
Definition at line 17 of file ossimBlendMosaic.cpp.
| ossimBlendMosaic::ossimBlendMosaic | ( | ossimConnectableObject::ConnectableObjectList & | inputSources | ) |
Definition at line 23 of file ossimBlendMosaic.cpp.
References initialize().
Definition at line 30 of file ossimBlendMosaic.cpp.
protected |
Definition at line 217 of file ossimBlendMosaic.cpp.
References ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageCombiner::getNextTile(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), ossimImageData::isNull(), OSSIM_EMPTY, OSSIM_NULL, OSSIM_PARTIAL, ossimImageCombiner::theLargestNumberOfInputBands, ossimImageMosaic::theTile, theWeights, and ossimImageData::validate().
Referenced by getTile().
protected |
Definition at line 338 of file ossimBlendMosaic.cpp.
References ossimImageData::copyNormalizedBufferToTile(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageCombiner::getNextNormTile(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), ossimImageData::isNull(), ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_NULL, OSSIM_PARTIAL, ossimImageCombiner::theLargestNumberOfInputBands, theNormResult, ossimImageMosaic::theTile, theWeights, and ossimImageData::validate().
| void ossimBlendMosaic::findMinMax | ( | double & | minValue, |
| double & | maxValue | ||
| ) | const |
Reimplemented from ossimImageMosaic.
Definition at line 60 of file ossimBlendMosaic.cpp.
References combine(), combineNorm(), ossimRefPtr< T >::get(), ossimConnectableObject::getNumberOfInputs(), ossimRectilinearDataObject::getScalarType(), ossimImageMosaic::getTile(), ossimImageCombiner::hasDifferentInputs(), initialize(), ossimSource::isSourceEnabled(), ossimImageData::makeBlank(), OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SCALAR_UNKNOWN, OSSIM_SINT16, OSSIM_SINT32, OSSIM_SINT8, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, ossimNotify(), ossimNotifyLevel_NOTICE, ossimImageData::setImageRectangle(), size, theNormResult, ossimImageMosaic::theTile, and ossimRefPtr< T >::valid().
| double ossimBlendMosaic::getWeight | ( | ossim_uint32 | index | ) | const |
| const vector< double > & ossimBlendMosaic::getWeights | ( | ) | const |
Definition at line 34 of file ossimBlendMosaic.cpp.
References ossimImageMosaic::allocate(), ossimImageCombiner::hasDifferentInputs(), ossimImageMosaic::initialize(), ossimImageData::initialize(), OSSIM_NORMALIZED_FLOAT, ossimConnectableObject::theInputObjectList, ossimImageCombiner::theLargestNumberOfInputBands, theNormResult, and theWeights.
Referenced by getTile(), and ossimBlendMosaic().
Definition at line 475 of file ossimBlendMosaic.cpp.
References ossimString::c_str(), ossimKeywordlist::find(), ossimKeywordlist::getNumberOfSubstringKeys(), ossimImageMosaic::loadState(), theWeights, and ossimString::toString().
| void ossimBlendMosaic::normalizeWeights | ( | ) |
Definition at line 537 of file ossimBlendMosaic.cpp.
References theWeights.
Definition at line 456 of file ossimBlendMosaic.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimImageMosaic::saveState(), theWeights, and ossimString::toString().
| void ossimBlendMosaic::setAllWeightsTo | ( | double | value | ) |
| void ossimBlendMosaic::setNumberOfWeights | ( | ossim_uint32 | numberOfWeights | ) |
| void ossimBlendMosaic::setWeight | ( | ossim_uint32 | index, |
| double | weight | ||
| void ossimBlendMosaic::setWeights | ( | const std::vector< double > & | weights | ) |
protected |
Definition at line 59 of file ossimBlendMosaic.h.
Referenced by combineNorm(), getTile(), and initialize().
protected |
Definition at line 58 of file ossimBlendMosaic.h.
Referenced by combine(), combineNorm(), findMinMax(), getWeight(), getWeights(), initialize(), loadState(), normalizeWeights(), saveState(), setAllWeightsTo(), setNumberOfWeights(), setWeight(), and setWeights().
