#include <ossim3x3ConvolutionFilter.h>
| ossim3x3ConvolutionFilter (ossimObject *owner=NULL) | |
| virtual void | getKernel (double kernel[3][3]) |
| virtual void | setKernel (double kernel[3][3]) |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossim3x3ConvolutionFilter () |
| void | allocate () |
| Allocates theTile. More... | |
| void | clearNullMinMax () |
| Clears data members theNullPixValue, theMinPixValue, and theMaxPixValue. More... | |
| void | computeNullMinMax () |
| Computes null, min, and max considering input connection and theKernel. More... | |
| template<class T > | |
| void | convolveFull (T, ossimRefPtr< ossimImageData > inputData, ossimRefPtr< ossimImageData > outputData) |
| void | convolvePartial (T, ossimRefPtr< ossimImageData > inputData, ossimRefPtr< ossimImageData > outputData) |
Definition at line 17 of file ossim3x3ConvolutionFilter.h.
| ossim3x3ConvolutionFilter::ossim3x3ConvolutionFilter | ( | ossimObject * | owner = NULL | ) |
Definition at line 21 of file ossim3x3ConvolutionFilter.cpp.
References theKernel.
protectedvirtual |
Definition at line 34 of file ossim3x3ConvolutionFilter.cpp.
protected |
Allocates theTile.
Definition at line 370 of file ossim3x3ConvolutionFilter.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimImageSourceFilter::theInputConnection, and theTile.
Referenced by getTile().
protected |
Definition at line 561 of file ossim3x3ConvolutionFilter.cpp.
References theMaxPixValue, theMinPixValue, and theNullPixValue.
Referenced by initialize(), and setKernel().
protected |
Definition at line 568 of file ossim3x3ConvolutionFilter.cpp.
References ossim::defaultMax(), ossim::defaultMin(), ossim::defaultNull(), getMaxPixelValue(), ossimImageSource::getMaxPixelValue(), getMinPixelValue(), ossimImageSource::getMinPixelValue(), ossimImageSource::getNullPixelValue(), ossimImageSource::getNumberOfOutputBands(), ossimImageSource::getOutputScalarType(), ossimImageSourceFilter::theInputConnection, theKernel, theMaxPixValue, theMinPixValue, and theNullPixValue.
protected |
Convolve full means that the input data is full and has no null data. We don't have to compare for nulls here
Definition at line 275 of file ossim3x3ConvolutionFilter.cpp.
References abs, ossimImageData::getBuf(), ossimImageData::getHeight(), getMaxPixelValue(), getMinPixelValue(), ossimImageData::getNumberOfBands(), ossimImageData::getOrigin(), ossimImageData::getWidth(), theKernel, ossimIpt::x, and ossimIpt::y.
protected |
Convolve partial means that the input data is has some null data. We will have to compare nulls
Definition at line 177 of file ossim3x3ConvolutionFilter.cpp.
References abs, ossimImageData::getBuf(), ossimImageData::getHeight(), getMaxPixelValue(), getMinPixelValue(), ossimImageData::getNullPix(), getNullPixelValue(), ossimImageData::getNumberOfBands(), ossimImageData::getOrigin(), ossimImageData::getWidth(), theKernel, ossimIpt::x, and ossimIpt::y.
Definition at line 502 of file ossim3x3ConvolutionFilter.cpp.
inlinevirtual |
Definition at line 23 of file ossim3x3ConvolutionFilter.h.
Definition at line 551 of file ossim3x3ConvolutionFilter.cpp.
References ossimImageSource::getMaxPixelValue(), ossimSource::isSourceEnabled(), and theMaxPixValue.
Referenced by computeNullMinMax(), convolveFull(), and convolvePartial().
Definition at line 541 of file ossim3x3ConvolutionFilter.cpp.
References ossimImageSource::getMinPixelValue(), ossimSource::isSourceEnabled(), and theMinPixValue.
Definition at line 531 of file ossim3x3ConvolutionFilter.cpp.
References ossim::defaultNull(), ossimImageSource::getOutputScalarType(), ossimSource::isSourceEnabled(), and theNullPixValue.
Referenced by convolvePartial().
Definition at line 414 of file ossim3x3ConvolutionFilter.cpp.
References ossimImageSourceFilter::getProperty(), and theKernel.
Definition at line 436 of file ossim3x3ConvolutionFilter.cpp.
References ossimImageSourceFilter::getPropertyNames().
inlinevirtual |
Definition at line 22 of file ossim3x3ConvolutionFilter.h.
Definition at line 38 of file ossim3x3ConvolutionFilter.cpp.
References allocate(), computeNullMinMax(), convolveFull(), convolvePartial(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimSource::isSourceEnabled(), ossimIrect::lr(), ossimImageData::makeBlank(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_FULL, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setImageRectangle(), ossimImageSourceFilter::theInputConnection, theNullPixValue, theTile, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIpt::x, and ossimIpt::y.
Definition at line 357 of file ossim3x3ConvolutionFilter.cpp.
References clearNullMinMax(), and theTile.
Definition at line 474 of file ossim3x3ConvolutionFilter.cpp.
References ossimString::c_str(), ossimKeywordlist::find(), ossimImageSourceFilter::loadState(), theKernel, ossimString::toDouble(), and ossimString::toString().
Definition at line 442 of file ossim3x3ConvolutionFilter.cpp.
References ossimKeywordlist::add(), ossimImageSourceFilter::saveState(), theKernel, and ossimString::toString().
Definition at line 515 of file ossim3x3ConvolutionFilter.cpp.
References clearNullMinMax(), and theKernel.
Definition at line 383 of file ossim3x3ConvolutionFilter.cpp.
References ossimRefPtr< T >::get(), ossimProperty::getName(), PTR_CAST, ossimImageSourceFilter::setProperty(), and theKernel.
protected |
Definition at line 69 of file ossim3x3ConvolutionFilter.h.
Referenced by computeNullMinMax(), convolveFull(), convolvePartial(), getKernel(), getProperty(), loadState(), ossim3x3ConvolutionFilter(), saveState(), setKernel(), and setProperty().
protected |
Definition at line 73 of file ossim3x3ConvolutionFilter.h.
Referenced by clearNullMinMax(), computeNullMinMax(), and getMaxPixelValue().
protected |
Definition at line 72 of file ossim3x3ConvolutionFilter.h.
Referenced by clearNullMinMax(), computeNullMinMax(), and getMinPixelValue().
protected |
Definition at line 71 of file ossim3x3ConvolutionFilter.h.
Referenced by clearNullMinMax(), computeNullMinMax(), getNullPixelValue(), and getTile().
protected |
Definition at line 68 of file ossim3x3ConvolutionFilter.h.
Referenced by allocate(), getTile(), and initialize().
