#include <ossimCcfTileSource.h>
| ossimCcfTileSource () | |
| virtual bool | open () |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| Returns the number of bands in the image. More... | |
| Returns the number of lines in the image. More... | |
| Returns the number of samples in the image. More... | |
| Returns the number of reduced resolution data sets (rrds). More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
| Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. More... | |
| bool | setOutputBandList (const vector< ossim_uint32 > &outputBandList) |
| Set the output band list. More... | |
| Returns the output pixel type of the tile source. More... | |
| Returns the width of the output tile. More... | |
| Returns the height of the output tile. More... | |
| Gets a property for matching name. More... | |
| Gets a list of property names available. More... | |
| ossimImageHandler () | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual | ~ossimCcfTileSource () |
| void | initVerticesFromHeader () |
| ossimCcfTileSource (const ossimCcfTileSource &source) | |
| ossimCcfTileSource & | operator= (const ossimCcfTileSource &source) |
| bool | fillBuffer (const ossimIrect &tile_rect, const ossimIrect &clip_rect, const ossimIrect &image_rect, ossim_uint32 reduced_res_level, ossimImageData *tile) |
| Returns true on success, false on error. More... | |
| bool | fillUshortBuffer (const ossimIrect &tile_rect, const ossimIrect &clip_rect, const ossimIrect &image_rect, ossim_uint32 reduced_res_level, ossimImageData *tile) |
| bool | fillUcharBuffer (const ossimIrect &tile_rect, const ossimIrect &clip_rect, const ossimIrect &image_rect, ossim_uint32 reduced_res_level, ossimImageData *tile) |
| void | adjustToStartOfChunk (ossimIpt &pt) const |
| Adjust point to even 256 boundary. More... | |
| void | adjustToStartOfChip (ossimIpt &pt) const |
| Adjust point to even 32 boundary. More... | |
| bool | isEcgGeom (const ossimFilename &filename) const |
Definition at line 32 of file ossimCcfTileSource.h.
| ossimCcfTileSource::ossimCcfTileSource | ( | ) |
Definition at line 46 of file ossimCcfTileSource.cpp.
protectedvirtual |
Definition at line 57 of file ossimCcfTileSource.cpp.
References close().
protected |
protected |
Assumes 0,0 origin.
Definition at line 901 of file ossimCcfTileSource.cpp.
References ossimIpt::x, and ossimIpt::y.
protected |
Assumes 0,0 origin.
Definition at line 895 of file ossimCcfTileSource.cpp.
Referenced by fillUcharBuffer(), and fillUshortBuffer().
Definition at line 739 of file ossimCcfTileSource.cpp.
References theChipBuffer, theFileStr, and theTile.
Referenced by ~ossimCcfTileSource().
protected |
Definition at line 146 of file ossimCcfTileSource.cpp.
References fillUcharBuffer(), fillUshortBuffer(), ossimErrorCodes::OSSIM_ERROR, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, ossimCcfHead::pixelType(), status, theCcfHead, and ossimErrorStatusInterface::theErrorStatus.
Referenced by getTile().
protected |
Definition at line 193 of file ossimCcfTileSource.cpp.
References adjustToStartOfChunk(), ossimCcfHead::bytesPerChip(), ossimCcfHead::bytesPerChunk(), ossimCcfHead::chipSizePerBand(), ossimCcfHead::chunksInSampleDir(), ossimIrect::clipToRect(), ossimImageData::getBuf(), ossimImageData::getSizePerBand(), ossimImageData::getWidth(), ossimIrect::intersects(), isOpen(), ossimCcfHead::lineChipsPerChunk(), ossimCcfHead::linesPerChip(), ossimIrect::lr(), ossimCcfHead::numberOfBands(), ossimErrorCodes::OSSIM_ERROR, ossimCcfHead::sampleChipsPerChunk(), ossimCcfHead::samplesPerChip(), ossimCcfHead::startOfData(), theCcfHead, theChipBuffer, ossimErrorStatusInterface::theErrorStatus, theFileStr, ossimIrect::ul(), ossimIpt::x, x, ossimIpt::y, and y.
Referenced by fillBuffer().
protected |
Definition at line 384 of file ossimCcfTileSource.cpp.
References adjustToStartOfChunk(), ossimCcfHead::bytesPerChip(), ossimCcfHead::bytesPerChunk(), ossimCcfHead::chipSizePerBand(), ossimIrect::clipToRect(), ossimImageData::getBuf(), ossimImageData::getSizePerBand(), ossimImageData::getWidth(), ossimIrect::intersects(), ossimCcfHead::lineChipsPerChunk(), ossimCcfHead::linesPerChip(), ossimIrect::lr(), ossimCcfHead::numberOfBands(), ossimErrorCodes::OSSIM_ERROR, OSSIM_LITTLE_ENDIAN, ossimCcfHead::sampleChipsPerChunk(), ossimCcfHead::samplesPerChip(), ossimCcfHead::startOfData(), theByteOrder, theCcfHead, theChipBuffer, ossimErrorStatusInterface::theErrorStatus, theFileStr, ossimIrect::ul(), ossimIpt::x, x, ossimIpt::y, and y.
Note that rrds 0 is the highest resolution rrds.
Definition at line 585 of file ossimCcfTileSource.cpp.
References ossimCcfHead::imageRect(), and theCcfHead.
Implements ossimImageHandler.
Definition at line 785 of file ossimCcfTileSource.cpp.
Definition at line 780 of file ossimCcfTileSource.cpp.
Definition at line 844 of file ossimCcfTileSource.cpp.
Note: The full res image is counted as a data set so an image with no reduced resolution data set will have a count of one.
Definition at line 869 of file ossimCcfTileSource.cpp.
References ossimCcfHead::numberOfReducedResSets(), and theCcfHead.
Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 849 of file ossimCcfTileSource.cpp.
References ossimCcfHead::numberOfBands(), and theCcfHead.
Referenced by getNumberOfOutputBands().
Definition at line 859 of file ossimCcfTileSource.cpp.
References ossimCcfHead::numberOfLines(), and theCcfHead.
Definition at line 854 of file ossimCcfTileSource.cpp.
References getNumberOfInputBands().
Definition at line 864 of file ossimCcfTileSource.cpp.
References ossimCcfHead::numberOfSamples(), and theCcfHead.
Definition at line 759 of file ossimCcfTileSource.cpp.
References ossimCcfHead::pixelType(), and theCcfHead.
| name | The name of the property to get. |
Definition at line 879 of file ossimCcfTileSource.cpp.
References ossimImageHandler::getProperty().
| propertyNames | The list to push back names to. |
Definition at line 889 of file ossimCcfTileSource.cpp.
References ossimImageHandler::getPropertyNames().
Definition at line 839 of file ossimCcfTileSource.cpp.
Definition at line 62 of file ossimCcfTileSource.cpp.
References ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), theTile, and ossimRefPtr< T >::valid().
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands() |
Definition at line 82 of file ossimCcfTileSource.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), fillBuffer(), ossimImageData::getImageRectangle(), ossimImageData::getNumberOfBands(), getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), ossimCcfHead::imageRect(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), ossimImageData::makeBlank(), ossimReferenced::ref(), status, theCcfHead, ossimReferenced::unref(), and ossimImageData::validate().
Definition at line 775 of file ossimCcfTileSource.cpp.
References ossimImageData::getHeight(), theTile, and ossimRefPtr< T >::valid().
Definition at line 767 of file ossimCcfTileSource.cpp.
References ossimImageData::getWidth(), theTile, and ossimRefPtr< T >::valid().
protected |
Definition at line 790 of file ossimCcfTileSource.cpp.
References ossimCcfHead::getValidImageVertices(), theCcfHead, and ossimImageHandler::theValidImageVertices.
protected |
Definition at line 817 of file ossimCcfTileSource.cpp.
References ossimString::c_str(), ossimString::downcase(), ossimFilename::exists(), and ossimFilename::setExtension().
Definition at line 874 of file ossimCcfTileSource.cpp.
References theFileStr.
Referenced by fillUcharBuffer(), and getTile().
Definition at line 645 of file ossimCcfTileSource.cpp.
References ossimImageHandler::loadState(), and open().
Definition at line 662 of file ossimCcfTileSource.cpp.
Referenced by loadState().
protected |
Definition at line 635 of file ossimCcfTileSource.cpp.
References ossimImageHandler::saveState().
| bool ossimCcfTileSource::setOutputBandList | ( | const vector< ossim_uint32 > & | outputBandList | ) |
Use to set the number and order of output bands. Will set an error if out of range.
Definition at line 593 of file ossimCcfTileSource.cpp.
protected |
Definition at line 226 of file ossimCcfTileSource.h.
Referenced by fillUshortBuffer().
protected |
Definition at line 221 of file ossimCcfTileSource.h.
Referenced by fillBuffer(), fillUcharBuffer(), fillUshortBuffer(), getImageRectangle(), getNumberOfDecimationLevels(), getNumberOfInputBands(), getNumberOfLines(), getNumberOfSamples(), getOutputScalarType(), getTile(), and initVerticesFromHeader().
protected |
Definition at line 223 of file ossimCcfTileSource.h.
Referenced by close(), fillUcharBuffer(), and fillUshortBuffer().
protected |
Definition at line 224 of file ossimCcfTileSource.h.
Referenced by close(), fillUcharBuffer(), fillUshortBuffer(), and isOpen().
protected |
Definition at line 225 of file ossimCcfTileSource.h.
protected |
Definition at line 222 of file ossimCcfTileSource.h.
Referenced by close(), getTile(), getTileHeight(), and getTileWidth().
