#include <ossimIndexToRgbLutFilter.h>
Public Types | |
| enum | Mode { LITERAL = 0, VERTICES = 1, REGULAR = 2 } |
| ossimIndexToRgbLutFilter () | |
| virtual | ~ossimIndexToRgbLutFilter () |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &origin, ossim_uint32 resLevel=0) |
| ossim_uint32 | getNumberOfOutputBands () const |
| void | setMode (Mode mode) |
| Mode | getMode () const |
| void | setLut (const ossimFilename &file) |
| Set lookup table(lut) method. More... | |
| double | getMinValue () const |
| double | getMaxValue () const |
| void | setMinValue (double value) |
| void | setMaxValue (double value) |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| void | allocate () |
| Called on first getTile, will initialize all data needed. More... | |
| bool | initializeLut (const ossimKeywordlist *kwl, const char *prefix=0) |
Definition at line 103 of file ossimIndexToRgbLutFilter.h.
| ossimIndexToRgbLutFilter::ossimIndexToRgbLutFilter | ( | ) |
Definition at line 29 of file ossimIndexToRgbLutFilter.cpp.
References ossimConnectableObject::setDescription().
Definition at line 42 of file ossimIndexToRgbLutFilter.cpp.
protected |
Definition at line 176 of file ossimIndexToRgbLutFilter.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimImageSourceFilter::theInputConnection, theTile, and ossimRefPtr< T >::valid().
Referenced by getTile().
Definition at line 467 of file ossimIndexToRgbLutFilter.cpp.
| double ossimIndexToRgbLutFilter::getMaxValue | ( | ) | const |
Definition at line 462 of file ossimIndexToRgbLutFilter.cpp.
| double ossimIndexToRgbLutFilter::getMinValue | ( | ) | const |
inline |
Definition at line 120 of file ossimIndexToRgbLutFilter.h.
Definition at line 457 of file ossimIndexToRgbLutFilter.cpp.
Definition at line 408 of file ossimIndexToRgbLutFilter.cpp.
References ossimImageSource::getNumberOfOutputBands(), and ossimSource::isSourceEnabled().
Definition at line 417 of file ossimIndexToRgbLutFilter.cpp.
References ossimImageSource::getOutputScalarType(), ossimSource::isSourceEnabled(), and OSSIM_UCHAR.
Definition at line 46 of file ossimIndexToRgbLutFilter.cpp.
References allocate(), ossimRgbVector::getB(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimRgbVector::getG(), ossimImageData::getHeight(), ossimImageData::getNullPix(), ossimImageSource::getNullPixelValue(), ossimRgbVector::getR(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimImageData::getWidth(), LITERAL, ossimImageData::makeBlank(), OSSIM_DOUBLE, OSSIM_EMPTY, OSSIM_FLOAT, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, REGULAR, ossimRgbVector::setB(), ossimRgbVector::setG(), ossimImageData::setImageRectangle(), ossimRgbVector::setR(), ossimImageSourceFilter::theInputConnection, theLut, theMaxValue, theMinValue, theMode, theTile, and ossimImageData::validate().
Definition at line 187 of file ossimIndexToRgbLutFilter.cpp.
References ossimImageSource::getMaxPixelValue(), ossimImageSource::getMinPixelValue(), ossimImageSourceFilter::initialize(), ossimImageSource::initialize(), ossimImageSourceFilter::theInputConnection, theMaxValue, theMaxValueOverride, theMinValue, theMinValueOverride, and theTile.
Referenced by ossimPointCloudTool::execute().
protected |
Definition at line 313 of file ossimIndexToRgbLutFilter.cpp.
References ossimString::chars(), ossimString::empty(), ossimKeywordlist::find(), ossimString::length(), LITERAL, ossimNotify(), ossimNotifyLevel_WARN, REGULAR, ossimRgbVector::setB(), ossimRgbVector::setG(), ossimRgbVector::setR(), ossimString::split(), theLut, theMaxValue, theMinValue, theMode, ossimString::toDouble(), ossimString::toString(), and VERTICES.
Definition at line 267 of file ossimIndexToRgbLutFilter.cpp.
References ossimKeywordlist::find(), and theLutFile.
Referenced by ossimPointCloudTool::execute(), and setLut().
Definition at line 208 of file ossimIndexToRgbLutFilter.cpp.
References ossimKeywordlist::add(), and theMinValueOverride.
| void ossimIndexToRgbLutFilter::setLut | ( | const ossimFilename & | file | ) |
This opens the keyword list and initializes lut.
CAUTION: Requires theMinValue, theMaxValue, and theMode to be set. Typically a connection is made prior to this call. If not connected to an input, "min", "max" and "mode" keywords should be passed in the keyword list file.
| file | Keyword list containing lut. |
Definition at line 427 of file ossimIndexToRgbLutFilter.cpp.
References ossimFilename::exists(), loadState(), and theLutFile.
| void ossimIndexToRgbLutFilter::setMaxValue | ( | double | value | ) |
| void ossimIndexToRgbLutFilter::setMinValue | ( | double | value | ) |
inline |
Definition at line 119 of file ossimIndexToRgbLutFilter.h.
protected |
Definition at line 158 of file ossimIndexToRgbLutFilter.h.
Referenced by getTile(), and initializeLut().
protected |
Definition at line 166 of file ossimIndexToRgbLutFilter.h.
Referenced by loadState(), and setLut().
protected |
Definition at line 161 of file ossimIndexToRgbLutFilter.h.
Referenced by getMaxValue(), getTile(), initialize(), initializeLut(), and setMaxValue().
protected |
Definition at line 163 of file ossimIndexToRgbLutFilter.h.
Referenced by initialize().
protected |
Definition at line 160 of file ossimIndexToRgbLutFilter.h.
Referenced by getMinValue(), getTile(), initialize(), initializeLut(), and setMinValue().
protected |
Definition at line 162 of file ossimIndexToRgbLutFilter.h.
Referenced by initialize(), and saveState().
protected |
Definition at line 164 of file ossimIndexToRgbLutFilter.h.
protected |
Definition at line 165 of file ossimIndexToRgbLutFilter.h.
Referenced by allocate(), getTile(), and initialize().
