#include <ossimGpkgReader.h>
| ossimGpkgReader () | |
| virtual | ~ossimGpkgReader () |
| Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More... | |
| Returns the number of bands in the image. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| Returns the number of lines in the image. More... | |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| Returns the number of samples in the image. More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. More... | |
| Set propterty method. More... | |
| Get propterty method. More... | |
| Get propterty names. More... | |
| Returns the output pixel type of the tile source. More... | |
| Returns the width of the output tile. More... | |
| Returns the height of the output tile. More... | |
| bool | isOpen () const |
| virtual void | close () |
| Close method. More... | |
| Gets the entry list. More... | |
| Get the list of entry names. More... | |
| Returns the number of decimation levels. More... | |
| virtual ossimRefPtr< ossimImageGeometry > | getInternalImageGeometry () |
| ossimImageHandler () | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual bool | open () |
| open method. More... | |
Private Member Functions | |
| bool | initImageParams () |
| void | allocate () |
| Allocates m_tile. More... | |
| void | fillTile (ossim_uint32 resLevel, const ossimIrect &tileRect, const ossimIrect &clipRect, ossimImageData *tile) |
| ossimRefPtr< ossimImageData > | getTile (ossim_uint32 resLevel, ossimIpt index) |
| ossimRefPtr< ossimImageData > | uncompressPngTile (const ossimGpkgTileRecord &tile, const ossimIpt &tileSize) |
| Uncompresses png tile to m_cacheTile. More... | |
| void | getTileIndexes (ossim_uint32 resLevel, const ossimIrect &clipRect, std::vector< ossimIpt > &tileIndexes) const |
| void | getTileSize (ossim_uint32 resLevel, ossimIpt &tileSize) const |
| ossim_uint32 | getNumberOfZoomLevels () const |
| void | computeGsd (ossimDpt &gsd) const |
Private Attributes | |
| ossimRefPtr< ossimImageHandler > | m_ih |
| ossimRefPtr< ossimImageData > | m_tile |
| ossimRefPtr< ossimImageData > | m_cacheTile |
| sqlite3 * | m_db |
| ossim_uint32 | m_currentEntry |
| ossim_uint32 | m_bands |
| ossimScalarType | m_scalar |
| ossim_uint32 | m_tileWidth |
| ossim_uint32 | m_tileHeight |
| std::vector< ossimGpkgTileEntry > | m_entries |
| ossimRefPtr< ossimCodecBase > | m_jpegCodec |
| ossimRefPtr< ossimCodecBase > | m_pngCodec |
Definition at line 27 of file ossimGpkgReader.h.
| ossimGpkgReader::ossimGpkgReader | ( | ) |
default constructor
Definition at line 57 of file ossimGpkgReader.cpp.
virtual destructor
Definition at line 82 of file ossimGpkgReader.cpp.
References close(), and isOpen().
private |
Allocates m_tile.
Called on first getTile.
Definition at line 90 of file ossimGpkgReader.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), and m_tile.
Referenced by getTile().
Close method.
Definition at line 474 of file ossimGpkgReader.cpp.
References ossimImageHandler::close(), isOpen(), m_db, and m_entries.
Referenced by ~ossimGpkgReader().
private |
Definition at line 994 of file ossimGpkgReader.cpp.
References m_currentEntry, and m_entries.
private |
Definition at line 168 of file ossimGpkgReader.cpp.
References ossimIrect::clipToRect(), ossimImageData::getBuf(), ossimImageData::getImageRectangle(), getTile(), getTileIndexes(), OSSIM_BSQ, and ossimImageData::validate().
Definition at line 449 of file ossimGpkgReader.cpp.
Definition at line 493 of file ossimGpkgReader.cpp.
References m_currentEntry.
| entryList | This is the list to initialize with entry indexes. |
Definition at line 498 of file ossimGpkgReader.cpp.
References m_entries.
This implementation uses the entry tile table name.
| getEntryNames | List to initialize with strings associated with entries. |
Definition at line 506 of file ossimGpkgReader.cpp.
Definition at line 589 of file ossimGpkgReader.cpp.
References ossimImageGeometryRegistry::extendGeometry(), ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), getInternalImageGeometry(), ossimImageGeometry::getProjection(), ossimImageHandler::initImageParameters(), ossimImageGeometryRegistry::instance(), and ossimImageHandler::theGeometry.
Note that rrds 0 is the highest resolution rrds.
Definition at line 245 of file ossimGpkgReader.cpp.
References getNumberOfLines(), and getNumberOfSamples().
Implements ossimImageHandler.
Definition at line 434 of file ossimGpkgReader.cpp.
References m_tileHeight.
Referenced by getTileHeight().
Definition at line 429 of file ossimGpkgReader.cpp.
References m_tileWidth.
Referenced by getTileWidth().
| Method | to get geometry from the embedded JP2 GeoTIFF Box. |
Definition at line 639 of file ossimGpkgReader.cpp.
Referenced by getImageGeometry().
Definition at line 444 of file ossimGpkgReader.cpp.
This returns the total number of decimation levels. It is important to note that res level 0 or full resolution is included in the list and has decimation values 1.0, 1.0
Definition at line 553 of file ossimGpkgReader.cpp.
References ossimImageHandler::getNumberOfDecimationLevels(), getNumberOfZoomLevels(), ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Definition at line 488 of file ossimGpkgReader.cpp.
Referenced by setCurrentEntry().
Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 454 of file ossimGpkgReader.cpp.
References m_bands.
Definition at line 396 of file ossimGpkgReader.cpp.
References ossimImageHandler::getNumberOfLines(), m_currentEntry, m_entries, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by getImageRectangle().
Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 459 of file ossimGpkgReader.cpp.
References m_bands.
Definition at line 413 of file ossimGpkgReader.cpp.
References ossimImageHandler::getNumberOfSamples(), m_currentEntry, m_entries, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
private |
Definition at line 567 of file ossimGpkgReader.cpp.
Referenced by getNumberOfDecimationLevels(), and getTile().
Definition at line 464 of file ossimGpkgReader.cpp.
References m_scalar.
Overrides ossimImageHandler::getProperty.
| name | Property name to get. |
Definition at line 275 of file ossimGpkgReader.cpp.
References ossimImageHandler::getProperty().
Overrides ossimImageHandler::getPropertyNames.
| propertyNames | Array to initialize. |
Definition at line 282 of file ossimGpkgReader.cpp.
References ossimImageHandler::getPropertyNames().
Satisfies pure virtual from TileSource class.
Definition at line 96 of file ossimGpkgReader.cpp.
References allocate(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), m_tile, ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), and ossimRefPtr< T >::valid().
Referenced by fillTile().
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands() |
Definition at line 121 of file ossimGpkgReader.cpp.
References ossimIrect::clipToRect(), fillTile(), getImageRectangle(), ossimImageData::getImageRectangle(), ossimImageData::getNumberOfBands(), getNumberOfOutputBands(), getNumberOfZoomLevels(), ossimImageHandler::getOverviewTile(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), m_tile, ossimImageData::makeBlank(), ossimReferenced::ref(), status, and ossimReferenced::unref().
private |
Definition at line 779 of file ossimGpkgReader.cpp.
Definition at line 384 of file ossimGpkgReader.cpp.
References ossim::defaultTileSize(), getImageTileHeight(), and ossimIpt::y.
private |
Definition at line 195 of file ossimGpkgReader.cpp.
References getTileSize(), ossimIrect::lr(), m_currentEntry, m_entries, ossimIrect::stretchToTileBoundary(), ossimIrect::ul(), ossimIpt::x, x, ossimIpt::y, and y.
private |
Definition at line 231 of file ossimGpkgReader.cpp.
References m_currentEntry, m_entries, ossimIpt::x, and ossimIpt::y.
Referenced by getTileIndexes().
Definition at line 372 of file ossimGpkgReader.cpp.
References ossim::defaultTileSize(), getImageTileWidth(), and ossimIpt::x.
private |
Definition at line 681 of file ossimGpkgReader.cpp.
Definition at line 469 of file ossimGpkgReader.cpp.
References m_db.
Referenced by close(), getTile(), setCurrentEntry(), and ~ossimGpkgReader().
Definition at line 259 of file ossimGpkgReader.cpp.
References ossimImageHandler::loadState(), and open().
protectedvirtual |
open method.
Definition at line 287 of file ossimGpkgReader.cpp.
References status.
Referenced by loadState().
Definition at line 253 of file ossimGpkgReader.cpp.
References ossimImageHandler::saveState().
| entryIdx | Entry number to select. |
Definition at line 516 of file ossimGpkgReader.cpp.
References ossimString::clear(), ossimImageHandler::completeOpen(), getNumberOfEntries(), initImageParams(), isOpen(), m_currentEntry, m_tile, ossimImageHandler::theGeometry, and ossimImageHandler::theOverviewFile.
Overrides ossimImageHandler::setProperty.
Current property name handled: "scale" One double value representing the scale in meters per pixel. It is assumed the scale is same for x and y direction.
| property | to set. |
Definition at line 270 of file ossimGpkgReader.cpp.
References ossimImageHandler::setProperty().
private |
| tile | Tile record. |
| tileSize | Size of tile. |
Definition at line 933 of file ossimGpkgReader.cpp.
References ossimRefPtr< T >::get(), ossimImageSource::getTile(), ossimImageHandlerRegistry::instance(), m_ih, ossimGpkgTileRecord::m_tile_data, ossimStreamReaderInterface::open(), ossimImageHandlerRegistry::open(), ossimRefPtr< T >::valid(), ossimIpt::x, and ossimIpt::y.
private |
Definition at line 279 of file ossimGpkgReader.h.
Referenced by getNumberOfInputBands(), and getNumberOfOutputBands().
private |
Definition at line 275 of file ossimGpkgReader.h.
private |
Definition at line 278 of file ossimGpkgReader.h.
Referenced by computeGsd(), getCurrentEntry(), getNumberOfLines(), getNumberOfSamples(), getNumberOfZoomLevels(), getTileIndexes(), getTileSize(), and setCurrentEntry().
private |
Definition at line 277 of file ossimGpkgReader.h.
private |
Definition at line 284 of file ossimGpkgReader.h.
Referenced by close(), computeGsd(), getEntryList(), getEntryNames(), getNumberOfEntries(), getNumberOfLines(), getNumberOfSamples(), getNumberOfZoomLevels(), getTileIndexes(), and getTileSize().
private |
Definition at line 272 of file ossimGpkgReader.h.
Referenced by uncompressPngTile().
mutableprivate |
Definition at line 286 of file ossimGpkgReader.h.
mutableprivate |
Definition at line 287 of file ossimGpkgReader.h.
private |
Definition at line 280 of file ossimGpkgReader.h.
Referenced by getOutputScalarType().
private |
Definition at line 274 of file ossimGpkgReader.h.
Referenced by allocate(), getTile(), and setCurrentEntry().
private |
Definition at line 282 of file ossimGpkgReader.h.
Referenced by getImageTileHeight().
private |
Definition at line 281 of file ossimGpkgReader.h.
Referenced by getImageTileWidth().
