OSSIM LAS LIDAR reader. More...
#include <ossimLasReader.h>
Classes | |
| class | Bucket |
| Container class to hold accumulated point data. More... | |
| ossimLasReader () | |
| virtual | ~ossimLasReader () |
| virtual bool | open () |
| open method. More... | |
| is open method. More... | |
| virtual void | close () |
| Close method. More... | |
| Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More... | |
| Gets bands. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| Gets lines. More... | |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| Gets samples. More... | |
| Gets tile width. More... | |
| Gets tile height. More... | |
| ossimScalarType | getOutputScalarType () const |
| Gets entry list. More... | |
| Set propterty method. More... | |
| Get propterty method. More... | |
| Get propterty names. More... | |
| ossimImageHandler () | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Private Member Functions | |
| bool | init () |
| void | initValues () |
| bool | initProjection () |
| void | initTile () |
| void | initUnits (const ossimKeywordlist &geomKwl) |
| bool | parseVarRecords () |
| bool | initFromExternalMetadata () |
| Looks for external FGDC text file to initialize projection from. More... | |
| void | getScale (ossimDpt &scale, ossim_uint32 resLevel) const |
| Get the scale for resLevel. More... | |
| void | setGsd (const ossim_float64 &gsd) |
| Sets m_gsd data member and projection if projection is set. More... | |
| void | convertToMeters (ossim_float64 &value) const |
| ossimLasPointRecordInterface * | getNewPointRecord () const |
| Returns a point of type. More... | |
Private Attributes | |
| std::ifstream | m_str |
| ossimLasHdr * | m_hdr |
| ossimRefPtr< ossimProjection > | m_proj |
| ossimDpt | m_ul |
| ossimDpt | m_lr |
| ossim_float64 | m_maxZ |
| ossim_float64 | m_minZ |
| ossimDpt | m_gsd |
| ossimRefPtr< ossimImageData > | m_tile |
| ossim_uint8 | m_entry |
| std::mutex | m_mutex |
| bool | m_scan |
| ossimUnitType | m_units |
| ossimUnitConversionTool * | m_unitConverter |
Definition at line 33 of file ossimLasReader.h.
| ossimLasReader::ossimLasReader | ( | ) |
default constructor
Definition at line 54 of file ossimLasReader.cpp.
References m_gsd, and ossimDpt::makeNan().
Close method.
Definition at line 154 of file ossimLasReader.cpp.
References ossimImageHandler::close(), isOpen(), m_entry, m_hdr, m_proj, m_str, and m_tile.
Referenced by ~ossimLasReader().
protectedvirtual |
Will complete the opening process.
Overrides ossimImageHandler::completeOpen() as we do not ever have overviews.
Definition at line 149 of file ossimLasReader.cpp.
References ossimImageHandler::establishDecimationFactors().
inlineprivate |
Definition at line 322 of file ossimLasReader.h.
References ossimUnitConversionTool::getMeters(), m_unitConverter, m_units, and ossimUnitConversionTool::setValue().
Referenced by getTile(), and initValues().
Definition at line 432 of file ossimLasReader.cpp.
References m_entry.
Gets entry list.
| entryList | This is the list to initialize with entry indexes. |
Definition at line 414 of file ossimLasReader.cpp.
References isOpen().
Referenced by setCurrentEntry().
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 469 of file ossimLasReader.cpp.
References ossimImageGeometryRegistry::extendGeometry(), ossimRefPtr< T >::get(), ossimMapProjection::getDatum(), ossimImageGeometry::getDegreesPerPixel(), ossimImageHandler::getExternalImageGeometry(), ossimImageGeometry::getMetersPerPixel(), getNumberOfLines(), getNumberOfSamples(), ossimImageGeometry::getProjection(), ossimImageHandler::initImageParameters(), initValues(), ossimImageGeometryRegistry::instance(), ossimMapProjection::isGeographic(), m_gsd, m_proj, m_ul, m_units, OSSIM_DEGREES, OSSIM_METERS, ossimImageGeometry::setImageSize(), ossimImageGeometry::setProjection(), ossimMapProjection::setUlTiePoints(), ossimImageHandler::theGeometry, true, ossimRefPtr< T >::valid(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Referenced by init().
Gets tile height.
Satisfies ossimImageHandler::getImageTileHeight pure virtual.
Implements ossimImageHandler.
Definition at line 387 of file ossimLasReader.cpp.
Gets tile width.
Satisfies ossimImageHandler::getImageTileWidth pure virtual.
Definition at line 382 of file ossimLasReader.cpp.
Definition at line 464 of file ossimLasReader.cpp.
Definition at line 554 of file ossimLasReader.cpp.
References m_maxZ.
Referenced by initTile().
Definition at line 549 of file ossimLasReader.cpp.
References m_minZ.
private |
Definition at line 1224 of file ossimLasReader.cpp.
References ossimLasHdr::getPointDataFormatId(), and m_hdr.
Definition at line 559 of file ossimLasReader.cpp.
Definition at line 564 of file ossimLasReader.cpp.
References getNumberOfLines(), and getNumberOfSamples().
Gets bands.
Satisfies ossimImageSource::getNumberOfInputBands pure virtual.
Number of bands.
Implements ossimImageSource.
Definition at line 349 of file ossimLasReader.cpp.
Gets lines.
Satisfies ossimImageHandler::getNumberOfLines pure virtual.
| resLevel | Reduced resolution level to return lines of. Default = 0 |
Definition at line 360 of file ossimLasReader.cpp.
References isOpen(), m_gsd, m_lr, m_ul, and ossimDpt::y.
Referenced by getImageGeometry(), and getNumberOfDecimationLevels().
Definition at line 354 of file ossimLasReader.cpp.
References m_entry.
Referenced by getTile(), and initTile().
Gets samples.
Satisfies ossimImageHandler::getNumberOfSamples
| resLevel | Reduced resolution level to return samples of. Default = 0 |
Definition at line 371 of file ossimLasReader.cpp.
References isOpen(), m_gsd, m_lr, m_ul, and ossimDpt::x.
Definition at line 406 of file ossimLasReader.cpp.
References m_entry, OSSIM_FLOAT32, and OSSIM_UINT16.
Overrides ossimImageHandler::getProperty.
| name | Property name to get. |
Definition at line 638 of file ossimLasReader.cpp.
Overrides ossimImageHandler::getPropertyNames.
| propertyNames | Array to initialize. |
Definition at line 657 of file ossimLasReader.cpp.
private |
Definition at line 1264 of file ossimLasReader.cpp.
References m_gsd, ossimDpt::x, and ossimDpt::y.
Referenced by getTile().
Satisfies pure virtual from TileSource class.
Definition at line 168 of file ossimLasReader.cpp.
References ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), initTile(), m_tile, ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), and ossimRefPtr< T >::valid().
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands() |
Definition at line 193 of file ossimLasReader.cpp.
References ossimIrect::area(), convertToMeters(), ossimLasPointRecordInterface::getBlue(), ossimDataObject::getDataObjectStatus(), ossimImageData::getFloatBuf(), ossimLasPointRecordInterface::getGreen(), ossimImageData::getImageRectangle(), ossimLasPointRecordInterface::getIntensity(), getNewPointRecord(), getNumberOfOutputBands(), ossimLasHdr::getOffsetToPointData(), ossimLasHdr::getOffsetX(), ossimLasHdr::getOffsetY(), ossimLasHdr::getOffsetZ(), ossimLasPointRecordInterface::getRed(), ossimRectilinearDataObject::getScalarType(), getScale(), ossimLasHdr::getScaleFactorX(), ossimLasHdr::getScaleFactorY(), ossimLasHdr::getScaleFactorZ(), ossimImageData::getUshortBuf(), ossimLasPointRecordInterface::getX(), ossimLasPointRecordInterface::getY(), ossimLasPointRecordInterface::getZ(), ossimDpt::hasNans(), ossimIrect::height(), ossimImageData::loadTile(), m_entry, m_gsd, m_hdr, m_str, m_ul, m_unitConverter, ossimImageData::makeBlank(), OSSIM_BIP, OSSIM_FLOAT32, OSSIM_NULL, OSSIM_RIGHT_HANDED, OSSIM_UINT16, ossimDrect::pointWithin(), ossimLasPointRecordInterface::readStream(), status, ossimIrect::ul(), ossimImageData::validate(), ossimIrect::width(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Definition at line 399 of file ossimLasReader.cpp.
References ossim::defaultTileSize(), and ossimIpt::y.
Definition at line 392 of file ossimLasReader.cpp.
References ossim::defaultTileSize(), and ossimIpt::x.
private |
Definition at line 664 of file ossimLasReader.cpp.
References ossimFilename::exists(), ossimRefPtr< T >::get(), ossimImageHandler::getFilenameWithThisExt(), getImageGeometry(), ossimImageGeometry::getProjection(), initFromExternalMetadata(), isOpen(), parseVarRecords(), true, and ossimRefPtr< T >::valid().
private |
Definition at line 1166 of file ossimLasReader.cpp.
private |
Definition at line 707 of file ossimLasReader.cpp.
References ossimRefPtr< T >::get(), ossimMapProjection::getDatum(), ossimMapProjection::getDecimalDegreesPerPixel(), ossimMapProjection::getMetersPerPixel(), ossimDpt::hasNans(), ossimMapProjection::isGeographic(), m_gsd, m_lr, m_proj, m_ul, ossimDpt::makeNan(), ossimNotify(), ossimNotifyLevel_WARN, ossimMapProjection::setDecimalDegreesPerPixel(), ossimMapProjection::setMetersPerPixel(), ossimMapProjection::setUlTiePoints(), ossimDpt::x, and ossimDpt::y.
private |
Definition at line 770 of file ossimLasReader.cpp.
References getMaxPixelValue(), getMinPixelValue(), getNullPixelValue(), getNumberOfOutputBands(), getOutputScalarType(), getTileHeight(), getTileWidth(), ossimImageData::initialize(), m_entry, m_tile, ossimImageData::setMaxPix(), ossimImageData::setMinPix(), and ossimImageData::setNullPix().
Referenced by getTile(), and setCurrentEntry().
private |
Definition at line 793 of file ossimLasReader.cpp.
References ossimKeywordlist::find(), ossimRefPtr< T >::get(), ossimMapProjection::isGeographic(), m_proj, m_unitConverter, m_units, OSSIM_DEGREES, OSSIM_FEET, OSSIM_METERS, OSSIM_US_SURVEY_FEET, ossimNotify(), and ossimNotifyLevel_DEBUG.
private |
Definition at line 837 of file ossimLasReader.cpp.
References convertToMeters(), ossimLasHdr::getMaxX(), ossimLasHdr::getMaxY(), ossimLasHdr::getMaxZ(), ossimLasHdr::getMinX(), ossimLasHdr::getMinY(), ossimLasHdr::getMinZ(), getNewPointRecord(), ossimLasHdr::getOffsetToPointData(), ossimLasHdr::getOffsetX(), ossimLasHdr::getOffsetY(), ossimLasHdr::getOffsetZ(), ossimLasHdr::getScaleFactorX(), ossimLasHdr::getScaleFactorY(), ossimLasHdr::getScaleFactorZ(), ossimLasPointRecordInterface::getX(), ossimLasPointRecordInterface::getY(), ossimLasPointRecordInterface::getZ(), m_hdr, m_lr, m_maxZ, m_minZ, m_scan, m_str, m_ul, m_unitConverter, max, min, ossimNotify(), ossimNotifyLevel_DEBUG, ossimLasPointRecordInterface::print(), ossimLasPointRecordInterface::readStream(), ossimDpt::x, x, ossimDpt::y, and y.
Referenced by getImageGeometry().
inlinevirtual |
is open method.
Satisfies ossimImageHandler::isOpen pure virtual.
Definition at line 317 of file ossimLasReader.h.
Referenced by close(), getEntryList(), getNumberOfLines(), getNumberOfSamples(), init(), and setCurrentEntry().
Definition at line 586 of file ossimLasReader.cpp.
References ossimKeywordlist::find(), ossimImageHandler::loadState(), and open().
open method.
Satisfies ossimImageHandler::open pure virtual.
Definition at line 83 of file ossimLasReader.cpp.
Referenced by loadState().
private |
Definition at line 965 of file ossimLasReader.cpp.
Definition at line 579 of file ossimLasReader.cpp.
References ossimKeywordlist::add().
| entryIdx | Entry number to select. |
Definition at line 437 of file ossimLasReader.cpp.
References getEntryList(), initTile(), isOpen(), and m_entry.
private |
Definition at line 1272 of file ossimLasReader.cpp.
References ossimRefPtr< T >::get(), ossimDpt::hasNans(), ossimMapProjection::isGeographic(), m_gsd, m_proj, ossimMapProjection::setDecimalDegreesPerPixel(), ossimMapProjection::setMetersPerPixel(), ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
Overrides ossimImageHandler::setProperty.
Current property name handled: "scale" One double value representing the scale in meters per pixel. It is assumed the scale is same for x and y direction.
| property | to set. |
Definition at line 611 of file ossimLasReader.cpp.
References ossimProperty::getName(), and ossimRefPtr< T >::valid().
private |
Definition at line 309 of file ossimLasReader.h.
Referenced by close(), getCurrentEntry(), getNumberOfOutputBands(), getOutputScalarType(), getTile(), initTile(), and setCurrentEntry().
private |
Definition at line 307 of file ossimLasReader.h.
Referenced by getImageGeometry(), getNumberOfLines(), getNumberOfSamples(), getScale(), getTile(), initProjection(), ossimLasReader(), and setGsd().
private |
Definition at line 301 of file ossimLasReader.h.
Referenced by close(), getNewPointRecord(), getTile(), initValues(), and isOpen().
private |
Definition at line 304 of file ossimLasReader.h.
Referenced by getNumberOfLines(), getNumberOfSamples(), initProjection(), and initValues().
private |
Definition at line 305 of file ossimLasReader.h.
Referenced by getMaxPixelValue(), and initValues().
private |
Definition at line 306 of file ossimLasReader.h.
Referenced by getMinPixelValue(), and initValues().
private |
Definition at line 310 of file ossimLasReader.h.
private |
Definition at line 302 of file ossimLasReader.h.
Referenced by close(), getImageGeometry(), initProjection(), initUnits(), and setGsd().
private |
Definition at line 311 of file ossimLasReader.h.
Referenced by initValues().
private |
Definition at line 300 of file ossimLasReader.h.
Referenced by close(), getTile(), initValues(), and isOpen().
private |
Definition at line 308 of file ossimLasReader.h.
Referenced by close(), getTile(), and initTile().
private |
Definition at line 303 of file ossimLasReader.h.
Referenced by getImageGeometry(), getNumberOfLines(), getNumberOfSamples(), getTile(), initProjection(), and initValues().
private |
Definition at line 313 of file ossimLasReader.h.
Referenced by convertToMeters(), getTile(), initUnits(), and initValues().
private |
Definition at line 312 of file ossimLasReader.h.
Referenced by convertToMeters(), getImageGeometry(), and initUnits().
