#include <ossimKmlSuperOverlayReader.h>
| ossimKmlSuperOverlayReader () | |
| virtual | ~ossimKmlSuperOverlayReader () |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual bool | open () |
| virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
| ossimScalarType | getOutputScalarType () const |
| ossimMapProjection * | createDefaultProj (ossim_float64 north, ossim_float64 south, ossim_float64 east, ossim_float64 west) |
| ossimImageHandler () | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Private Member Functions | |
| bool | getCoordinate (std::vector< ossimRefPtr< ossimXmlNode > > nodes, ossim_float64 &north, ossim_float64 &south, ossim_float64 &east, ossim_float64 &west) |
| ossimRefPtr< ossimXmlNode > | findLatLonNode (std::vector< ossimRefPtr< ossimXmlNode > >nodes) |
| bool | isKmlSuperOverlayFile (std::vector< ossimRefPtr< ossimXmlNode > > nodes) |
| bool | getTopLevelKmlFileInfo () |
Private Attributes | |
| ossimRefPtr< ossimXmlDocument > | m_xmlDocument |
| ossimRefPtr< ossimImageGeometry > | theImageGeometry |
| ossimDrect | theImageBound |
Protected Attributes inherited from ossimImageHandler | |
| ossimFilename | theImageFile |
| ossimFilename | theOverviewFile |
| ossimFilename | theSupplementaryDirectory |
| ossimRefPtr< ossimImageHandler > | theOverview |
| vector< ossimIpt > | theValidImageVertices |
| ossimImageMetaData | theMetaData |
| ossimRefPtr< ossimImageGeometry > | theGeometry |
| ossimRefPtr< ossimNBandLutDataObject > | theLut |
| std::vector< ossimDpt > | theDecimationFactors |
| ossimString | theImageID |
| ossim_uint32 | theStartingResLevel |
| theStartingResLevel If set to something other than zero(default) this is indicative that the reader is an overview. More... | |
| bool | theOpenOverviewFlag |
| If true opening of overviews will be attempted. More... | |
| ossimPixelType | thePixelType |
| std::shared_ptr< ossim::ImageHandlerState > | m_state |
Protected Attributes inherited from ossimSource | |
| bool | theEnableFlag |
| bool | theInitializedFlag |
Protected Attributes inherited from ossimConnectableObject | |
| ossimId | theId |
| ossimString | theDescription |
| ossimObject * | theOwner |
| bool | theInputListIsFixedFlag |
| Indicates whether the theInputObjectList is fixed. More... | |
| bool | theOutputListIsFixedFlag |
| Indicates whether the theOutputObjectList is fixed. More... | |
| ConnectableObjectList | theInputObjectList |
| Holds a list of input objects. More... | |
| ConnectableObjectList | theOutputObjectList |
| Holds a list of output objects. More... | |
Protected Attributes inherited from ossimListenerManager | |
| std::list< ossimListener * > | theListenerList |
| bool | theEnabledFlag |
| std::list< ossimListener * > | theDelayedAdd |
| std::list< ossimListener * > | theDelayedRemove |
| bool | theFireEventFlag |
Definition at line 32 of file ossimKmlSuperOverlayReader.h.
| ossimKmlSuperOverlayReader::ossimKmlSuperOverlayReader | ( | ) |
Definition at line 45 of file ossimKmlSuperOverlayReader.cpp.
Definition at line 55 of file ossimKmlSuperOverlayReader.cpp.
References close().
Definition at line 182 of file ossimKmlSuperOverlayReader.cpp.
References m_xmlDocument, theImageGeometry, and ossimRefPtr< T >::valid().
Referenced by open(), and ~ossimKmlSuperOverlayReader().
| ossimMapProjection * ossimKmlSuperOverlayReader::createDefaultProj | ( | ossim_float64 | north, |
| ossim_float64 | south, | ||
| ossim_float64 | east, | ||
| ossim_float64 | west | ||
Definition at line 336 of file ossimKmlSuperOverlayReader.cpp.
References ossim::cosd(), ossimMapProjection::setDecimalDegreesPerPixel(), ossimEquDistCylProjection::setOrigin(), and ossimMapProjection::setUlGpt().
Referenced by open().
private |
Definition at line 275 of file ossimKmlSuperOverlayReader.cpp.
References ossimRefPtr< T >::valid().
Referenced by getCoordinate().
private |
Definition at line 296 of file ossimKmlSuperOverlayReader.cpp.
References ossimString::downcase(), findLatLonNode(), ossimXmlNode::getChildNodes(), ossimString::toFloat64(), and ossimRefPtr< T >::valid().
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 235 of file ossimKmlSuperOverlayReader.cpp.
References theImageGeometry.
Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. Note that rrds 0 is the highest resolution rrds.
Definition at line 230 of file ossimKmlSuperOverlayReader.cpp.
References theImageBound.
Returns the tile width of the image or 0 if the image is not tiled. Note: this is not the same as the ossimImageSource::getTileWidth which returns the output tile width which can be different than the internal image tile width on disk.
Implements ossimImageHandler.
Definition at line 210 of file ossimKmlSuperOverlayReader.cpp.
Definition at line 215 of file ossimKmlSuperOverlayReader.cpp.
Definition at line 177 of file ossimKmlSuperOverlayReader.cpp.
Returns the number 0 for bands for kml super overlay Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 200 of file ossimKmlSuperOverlayReader.cpp.
Returns the number of bands in the image. Satisfies pure virtual from ImageHandler class.
Definition at line 220 of file ossimKmlSuperOverlayReader.cpp.
References ossimDrect::height(), and theImageBound.
Definition at line 205 of file ossimKmlSuperOverlayReader.cpp.
Returns the number of bands available from an image. Satisfies pure virtual from ImageHandler class.
Definition at line 225 of file ossimKmlSuperOverlayReader.cpp.
References theImageBound, and ossimDrect::width().
Definition at line 240 of file ossimKmlSuperOverlayReader.cpp.
References OSSIM_SCALAR_UNKNOWN.
Returns a null pointer for kml super overlay. Satisfies pure virtual from ImageHandler class.
Definition at line 194 of file ossimKmlSuperOverlayReader.cpp.
private |
Definition at line 365 of file ossimKmlSuperOverlayReader.cpp.
References ossimString::c_str(), ossimObject::getClassName(), m_xmlDocument, ossimFilename::noExtension(), ossimErrorCodes::OSSIM_ERROR, ossimSetError(), ossimXmlDocument::read(), ossimFilename::rename(), and ossimImageHandler::theImageFile.
private |
Definition at line 254 of file ossimKmlSuperOverlayReader.cpp.
Definition at line 245 of file ossimKmlSuperOverlayReader.cpp.
References ossimString::empty(), and ossimImageHandler::theImageFile.
Definition at line 172 of file ossimKmlSuperOverlayReader.cpp.
References ossimImageHandler::loadState().
Definition at line 63 of file ossimKmlSuperOverlayReader.cpp.
References close(), createDefaultProj(), ossimString::downcase(), ossimFilename::ext(), ossimXmlNode::getChildNodes(), getCoordinate(), ossimXmlDocument::getRoot(), getTopLevelKmlFileInfo(), isKmlSuperOverlayFile(), isOpen(), m_xmlDocument, ossimDrect::makeNan(), theImageBound, ossimImageHandler::theImageFile, theImageGeometry, ossimRefPtr< T >::valid(), and ossimImageGeometry::worldToLocal().
Definition at line 163 of file ossimKmlSuperOverlayReader.cpp.
References ossimImageHandler::saveState().
private |
Definition at line 146 of file ossimKmlSuperOverlayReader.h.
Referenced by close(), getTopLevelKmlFileInfo(), and open().
private |
Definition at line 148 of file ossimKmlSuperOverlayReader.h.
Referenced by getImageRectangle(), getNumberOfLines(), getNumberOfSamples(), and open().
private |
Definition at line 147 of file ossimKmlSuperOverlayReader.h.
Referenced by close(), getImageGeometry(), getInternalImageGeometry(), and open().
