This class provides piecewise linear remapping of input pixels to output pixels. More...
#include <ossimPiecewiseRemapper.h>
Classes | |
| class | ossimBandRemap |
| Private container class. More... | |
| class | ossimRemapSet |
Public Types | |
| enum | PiecewiseRemapType { UNKNOWN = 0, LINEAR_NATIVE = 1 } |
Public Types inherited from ossimTableRemapper | |
| enum | RemapTableType { UKNOWN = 0, NATIVE = 1, MIN_MAX = 2, NORMALIZED = 3 } |
| ossimPiecewiseRemapper () | |
| Get tile method. More... | |
| Initialization method. More... | |
| void | setRemapType (const std::string &type) |
| Sets remap type. More... | |
| Saves the state to a keyword list. More... | |
| Loads (recreates) the state of an object from a keyword list. More... | |
| virtual ostream & | print (ostream &os) const |
| Print method. More... | |
Public Member Functions inherited from ossimTableRemapper | |
| ossimTableRemapper () | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimPiecewiseRemapper () |
| Protected virtual destructor. More... | |
Protected Member Functions inherited from ossimTableRemapper | |
| virtual | ~ossimTableRemapper () |
| void | allocate (const ossimIrect &rect) |
| void | destroy () |
| void | remapFromNativeTable (ossimRefPtr< ossimImageData > &inputTile) |
| template<class T > | |
| void | remapFromNativeTable (T dummy, ossimRefPtr< ossimImageData > &inputTile) |
| void | remapFromNormalizedTable (ossimRefPtr< ossimImageData > &inputTile) |
| void | dumpTable (T dummy, ostream &os) const |
| ossimTableRemapper (const ossimTableRemapper &tr) | |
| ossimTableRemapper & | operator= (const ossimTableRemapper &tr) |
Private Member Functions | |
| void | getRemapTypeString (ossimPiecewiseRemapper::PiecewiseRemapType remapType, std::string &s) const |
| Gets a string from remap type. More... | |
| void | getLinearRemapSetString (const ossimPiecewiseRemapper::ossimRemapSet &set, std::string &s) const |
| Gets a string from remap set. More... | |
| void | buildTable () |
| Builds the table. More... | |
| void | buildLinearNativeTable () |
| Builds the linear native table. More... | |
| void | buildLinearNativeTable (T dummy) |
| Builds the linear native table for scalar type T. More... | |
| void | setupTable () |
| Initialized base class (ossimTableRemapper) values: More... | |
| void | initMinMax () |
| Computes min/max from remaps in m_bandRemap. More... | |
| ossimPiecewiseRemapper (const ossimPiecewiseRemapper &obj) | |
| (not allowed) copy constructor. More... | |
| ossimPiecewiseRemapper & | operator= (const ossimPiecewiseRemapper &hr) |
| (not allowed) assignment(operator=) More... | |
Private Attributes | |
| bool | m_dirty |
| Dirty flag to indicate table needs to be rebuilt. More... | |
| PiecewiseRemapType | m_remapType |
| std::vector< ossimPiecewiseRemapper::ossimBandRemap > | m_bandRemap |
| vector< ossim_float64 > | m_min |
| vector< ossim_float64 > | m_max |
The object's state is represented as:
band0.remap0: ( <segment0>, <segment1>, ...) band0.remap1: ( <segment0>, ... )
The vertices of each linear segment are specified as four numbers in parentheses:
(<min_in>, <max_in>, <min_out>, <max_out>)
A linear function is computed to map min_in to min_out and likewise max_in to max_out, with all intermediate points distributed linearly between the two extremes. Multiple remaps are cascaded: if an input pixel's value falls outside the ranges defined in the first remapper, then the second remapper's table is referenced. The cascading continues until a value is found. If no lookup is available, the output pixel is assigned to the NULL value.
Example: Given object2 with a state of:
object2.type: ossimPiecewiseRemapper object2.remap_type: linear_native object2.band0.remap0: ( (0, 127, 0, 127), (128, 255, 128, 382) ) object2.band0.remap1: ( (0, 382, 0, 255) )
remap0 applied:
The input range 0 <-> 127 passes through with a one-to-one mapping. 128 <-> 255 is stretched out to 128 <-> 382.
remap0 output is fed to remap1: 0 maps to 0 and 382 maps to 255 (compression).
Notes:
1) Currently there is only one remap type (linear_native) is supported so it's not needed but left in the code for future type remaps, e.g. a remap where there is a linear and a logarithmic section.
2) Any number of "remaps" are allowed.
Definition at line 63 of file ossimPiecewiseRemapper.h.
| ossimPiecewiseRemapper::ossimPiecewiseRemapper | ( | ) |
default constructor
Definition at line 287 of file ossimPiecewiseRemapper.cpp.
protectedvirtual |
This class is derived from ossimReferenced; hence, will auto destruct provided it is wrapped/stored in an ossimRefPtr. Example usage:
ossimRefPtr<ossimPiecewiseRemapper> pwr = new ossimPiecewiseRemapper();
Definition at line 307 of file ossimPiecewiseRemapper.cpp.
private |
Definition at line 939 of file ossimPiecewiseRemapper.cpp.
private |
Definition at line 720 of file ossimPiecewiseRemapper.cpp.
References ossimTableRemapper::getOutputScalarType(), OSSIM_SCALAR_UNKNOWN, OSSIM_SINT16, OSSIM_SINT32, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, and OSSIM_USHORT15.
Referenced by buildTable().
private |
Definition at line 770 of file ossimPiecewiseRemapper.cpp.
References getMaxPixelValue(), getMinPixelValue(), ossimImageSource::getNullPixelValue(), ossimImageSource::getNumberOfOutputBands(), m_bandRemap, ossimTableRemapper::print(), ossimTableRemapper::theTable, and ossimTableRemapper::theTableBinCount.
private |
Builds the table.
Definition at line 693 of file ossimPiecewiseRemapper.cpp.
References buildLinearNativeTable(), ossimImageSource::getNumberOfOutputBands(), LINEAR_NATIVE, m_bandRemap, m_dirty, m_remapType, setupTable(), and ossimTableRemapper::theTable.
Referenced by getTile().
Definition at line 583 of file ossimPiecewiseRemapper.cpp.
private |
Example output: ((0, 127, 0, 127), (128, 255, 128, 382))
| set | |
| s | Initialized by this. |
Referenced by ossimPiecewiseRemapper::ossimBandRemap::getRemapSetString().
Definition at line 588 of file ossimPiecewiseRemapper.cpp.
Definition at line 608 of file ossimPiecewiseRemapper.cpp.
References ossimImageSource::getMaxPixelValue(), m_max, and ossimSource::theEnableFlag.
Referenced by buildLinearNativeTable().
Definition at line 598 of file ossimPiecewiseRemapper.cpp.
References ossimImageSource::getMinPixelValue(), m_min, and ossimSource::theEnableFlag.
private |
| remapType | |
Definition at line 377 of file ossimPiecewiseRemapper.cpp.
References LINEAR_NATIVE.
Referenced by saveState().
Definition at line 593 of file ossimPiecewiseRemapper.cpp.
Get tile method.
| tileRect | Region of interest. |
| resLevel | Resolution level. |
| The | requested region of interest for resolution level. |
Reimplemented from ossimTableRemapper.
Definition at line 345 of file ossimPiecewiseRemapper.cpp.
References buildTable(), ossimImageSource::getTile(), ossimTableRemapper::getTile(), m_dirty, ossimSource::theEnableFlag, ossimImageSourceFilter::theInputConnection, and ossimTableRemapper::theTable.
Called on state change of chain.
Definition at line 311 of file ossimPiecewiseRemapper.cpp.
private |
Definition at line 618 of file ossimPiecewiseRemapper.cpp.
References ossim::defaultMin(), ossimImageSource::getNumberOfOutputBands(), LINEAR_NATIVE, m_bandRemap, m_max, m_min, m_remapType, and OSSIM_SCALAR_UNKNOWN.
Definition at line 390 of file ossimPiecewiseRemapper.cpp.
private |
Definition at line 946 of file ossimPiecewiseRemapper.cpp.
Print method.
Called by ossimObject::operator<<.
Definition at line 570 of file ossimPiecewiseRemapper.cpp.
References saveState().
Definition at line 514 of file ossimPiecewiseRemapper.cpp.
References ossimKeywordlist::addPair(), ossimImageSource::getNumberOfOutputBands(), getRemapTypeString(), m_bandRemap, m_remapType, ossimKeywordNames::NUMBER_BANDS_KW, ossimString::string(), ossimString::toString(), and UNKNOWN.
Referenced by print().
| void ossimPiecewiseRemapper::setRemapType | ( | const std::string & | type | ) |
Sets remap type.
Current types: "linear_native"
| type |
Definition at line 332 of file ossimPiecewiseRemapper.cpp.
References LINEAR_NATIVE, m_remapType, and UNKNOWN.
private |
Definition at line 858 of file ossimPiecewiseRemapper.cpp.
References ossimImageSource::getNumberOfOutputBands(), ossimTableRemapper::NATIVE, ossimTableRemapper::NORMALIZED, OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SINT16, OSSIM_SINT32, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, ossimTableRemapper::theOutputScalarType, ossimTableRemapper::theTable, ossimTableRemapper::theTableBandCount, ossimTableRemapper::theTableBinCount, and ossimTableRemapper::theTableType.
private |
Definition at line 261 of file ossimPiecewiseRemapper.h.
Referenced by buildLinearNativeTable(), buildTable(), initMinMax(), and saveState().
private |
Definition at line 256 of file ossimPiecewiseRemapper.h.
Referenced by buildTable(), and getTile().
private |
Definition at line 266 of file ossimPiecewiseRemapper.h.
Referenced by getMaxPixelValue(), and initMinMax().
private |
Definition at line 265 of file ossimPiecewiseRemapper.h.
Referenced by getMinPixelValue(), and initMinMax().
private |
Definition at line 258 of file ossimPiecewiseRemapper.h.
Referenced by buildTable(), initMinMax(), saveState(), and setRemapType().
