#include <ossimRadarSat2TiffReader.h>
| ossimRadarSat2TiffReader () | |
| virtual | ~ossimRadarSat2TiffReader () |
| virtual bool | open (const ossimFilename &file) |
| This open take the product xml file. More... | |
| virtual void | close () |
| Close method. More... | |
Public Member Functions inherited from ossimTiffTileSource | |
| ossimTiffTileSource () | |
| bool | open (std::shared_ptr< ossim::istream > &str, const std::string &connectionString) |
| This open takes a stream and stores/captures the shared pointer on success. More... | |
| Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More... | |
| Returns the number of bands in the image. More... | |
| Initializes bandList to the zero based order of output bands. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| Returns the number of lines in the image. More... | |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| Returns the number of samples in the image. More... | |
| virtual ossim_uint32 | getNumberOfDirectories () const |
| Returns the number of image file directories in the tiff image. More... | |
| Returns the number of reduced resolution data sets (rrds). More... | |
| Returns the output pixel type of the tile source. More... | |
| Returns the width of the output tile. More... | |
| Returns the height of the output tile. More... | |
| bool | hasR0 () const |
| Returns true if the first directory of the tiff image did not have the reduced resolution file type set. More... | |
| virtual ossim_float64 | getMinPixelValue (ossim_uint32 band=0) const |
| virtual ossim_float64 | getMaxPixelValue (ossim_uint32 band=0) const |
| virtual ossim_float64 | getNullPixelValue (ossim_uint32 band=0) const |
| void | setApplyColorPaletteFlag (bool flag) |
| bool | getApplyColorPaletteFlag () const |
| bool | isColorMapped () const |
| virtual std::ostream & | print (std::ostream &os) const |
| TIFF * | tiffPtr () |
| ossimImageHandler () | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Private Member Functions | |
| bool | isRadarSat2ProductFile (const ossimFilename &file) const |
| Method to check file to see if it's a RS2 product xml file. More... | |
| bool | isRadarSat2ProductFile (const ossimXmlDocument *xdoc) const |
Private Attributes | |
| ossimFilename | theProductXmlFile |
Public Types inherited from ossimTiffTileSource | |
| enum | ReadMethod { UNKNOWN, READ_RGBA_U8_TILE, READ_RGBA_U8_STRIP, READ_RGBA_U8A_STRIP, READ_SCAN_LINE, READ_TILE, READ_U16_STRIP } |
Protected Member Functions inherited from ossimTiffTileSource | |
| virtual | ~ossimTiffTileSource () |
| bool | open () |
| Returns true if no errors initializing object. More... | |
Protected Attributes inherited from ossimTiffTileSource | |
| TIFF * | theTiffPtr |
Protected Attributes inherited from ossimImageHandler | |
| ossimFilename | theImageFile |
| ossimFilename | theOverviewFile |
| ossimFilename | theSupplementaryDirectory |
| ossimRefPtr< ossimImageHandler > | theOverview |
| vector< ossimIpt > | theValidImageVertices |
| ossimImageMetaData | theMetaData |
| ossimRefPtr< ossimImageGeometry > | theGeometry |
| ossimRefPtr< ossimNBandLutDataObject > | theLut |
| std::vector< ossimDpt > | theDecimationFactors |
| ossimString | theImageID |
| ossim_uint32 | theStartingResLevel |
| theStartingResLevel If set to something other than zero(default) this is indicative that the reader is an overview. More... | |
| bool | theOpenOverviewFlag |
| If true opening of overviews will be attempted. More... | |
| ossimPixelType | thePixelType |
| std::shared_ptr< ossim::ImageHandlerState > | m_state |
Protected Attributes inherited from ossimSource | |
| bool | theEnableFlag |
| bool | theInitializedFlag |
Protected Attributes inherited from ossimConnectableObject | |
| ossimId | theId |
| ossimString | theDescription |
| ossimObject * | theOwner |
| bool | theInputListIsFixedFlag |
| Indicates whether the theInputObjectList is fixed. More... | |
| bool | theOutputListIsFixedFlag |
| Indicates whether the theOutputObjectList is fixed. More... | |
| ConnectableObjectList | theInputObjectList |
| Holds a list of input objects. More... | |
| ConnectableObjectList | theOutputObjectList |
| Holds a list of output objects. More... | |
Protected Attributes inherited from ossimListenerManager | |
| std::list< ossimListener * > | theListenerList |
| bool | theEnabledFlag |
| std::list< ossimListener * > | theDelayedAdd |
| std::list< ossimListener * > | theDelayedRemove |
| bool | theFireEventFlag |
Definition at line 24 of file ossimRadarSat2TiffReader.h.
| ossimplugins::ossimRadarSat2TiffReader::ossimRadarSat2TiffReader | ( | ) |
default constructor
Definition at line 44 of file ossimRadarSat2TiffReader.cpp.
References ossimNotify(), and ossimNotifyLevel_DEBUG.
Close method.
Reimplemented from ossimTiffTileSource.
Definition at line 195 of file ossimRadarSat2TiffReader.cpp.
References ossimTiffTileSource::close().
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 201 of file ossimRadarSat2TiffReader.cpp.
References ossimImageGeometryRegistry::extendGeometry(), and ossimImageGeometryRegistry::instance().
| Method | to get geometry from the xml file or internal geotiff tags. |
Definition at line 240 of file ossimRadarSat2TiffReader.cpp.
References ossimRefPtr< T >::get(), ossimplugins::ossimRadarSat2Model::open(), ossimXmlDocument::openFile(), ossimNotify(), ossimNotifyLevel_DEBUG, and ossimImageGeometry::setProjection().
Definition at line 129 of file ossimRadarSat2TiffReader.cpp.
Definition at line 124 of file ossimRadarSat2TiffReader.cpp.
private |
| file | The file to check. |
Definition at line 280 of file ossimRadarSat2TiffReader.cpp.
References ossimString::downcase(), ossimFilename::ext(), and ossimXmlDocument::openFile().
private |
| xdoc | XML document opened up to product.xml file. |
Definition at line 302 of file ossimRadarSat2TiffReader.cpp.
References ossimplugins::ossimRadarSat2ProductDoc::isRadarSat2().
Definition at line 81 of file ossimRadarSat2TiffReader.cpp.
References ossimKeywordlist::find(), ossimTiffTileSource::loadState(), ossimNotify(), and ossimNotifyLevel_DEBUG.
| file | File to open. |
Definition at line 134 of file ossimRadarSat2TiffReader.cpp.
References ossimFilename::dirCat(), ossimString::downcase(), ossimFilename::expand(), ossimFilename::ext(), ossimplugins::ossimRadarSat2ProductDoc::getImageFile(), ossimTiffTileSource::open(), ossimXmlDocument::openFile(), ossimNotify(), ossimNotifyLevel_DEBUG, and ossimFilename::path().
Definition at line 63 of file ossimRadarSat2TiffReader.cpp.
References ossimKeywordlist::add(), ossimNotify(), ossimNotifyLevel_DEBUG, and ossimTiffTileSource::saveState().
private |
Definition at line 98 of file ossimRadarSat2TiffReader.h.
