#include <ossimOgrVectorTileSource.h>
| ossimOgrVectorTileSource () | |
| virtual | ~ossimOgrVectorTileSource () |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual bool | open () |
| virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
| ossimProjection * | createProjFromReference (OGRSpatialReference *reference) const |
| ossimMapProjection * | createDefaultProj () |
| bool | isOgrVectorDataSource () const |
| ossimImageHandler () | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Private Attributes | |
| std::vector< ossimOgrVectorLayerNode * > | theLayerVector |
| OGRDataSource * | theDataSource |
| ossimRefPtr< ossimImageGeometry > | theImageGeometry |
| ossimDrect | theImageBound |
| OGREnvelope | theBoundingExtent |
Protected Attributes inherited from ossimImageHandler | |
| ossimFilename | theImageFile |
| ossimFilename | theOverviewFile |
| ossimFilename | theSupplementaryDirectory |
| ossimRefPtr< ossimImageHandler > | theOverview |
| vector< ossimIpt > | theValidImageVertices |
| ossimImageMetaData | theMetaData |
| ossimRefPtr< ossimImageGeometry > | theGeometry |
| ossimRefPtr< ossimNBandLutDataObject > | theLut |
| std::vector< ossimDpt > | theDecimationFactors |
| ossimString | theImageID |
| ossim_uint32 | theStartingResLevel |
| theStartingResLevel If set to something other than zero(default) this is indicative that the reader is an overview. More... | |
| bool | theOpenOverviewFlag |
| If true opening of overviews will be attempted. More... | |
| ossimPixelType | thePixelType |
| std::shared_ptr< ossim::ImageHandlerState > | m_state |
Protected Attributes inherited from ossimSource | |
| bool | theEnableFlag |
| bool | theInitializedFlag |
Protected Attributes inherited from ossimConnectableObject | |
| ossimId | theId |
| ossimString | theDescription |
| ossimObject * | theOwner |
| bool | theInputListIsFixedFlag |
| Indicates whether the theInputObjectList is fixed. More... | |
| bool | theOutputListIsFixedFlag |
| Indicates whether the theOutputObjectList is fixed. More... | |
| ConnectableObjectList | theInputObjectList |
| Holds a list of input objects. More... | |
| ConnectableObjectList | theOutputObjectList |
| Holds a list of output objects. More... | |
Protected Attributes inherited from ossimListenerManager | |
| std::list< ossimListener * > | theListenerList |
| bool | theEnabledFlag |
| std::list< ossimListener * > | theDelayedAdd |
| std::list< ossimListener * > | theDelayedRemove |
| bool | theFireEventFlag |
Definition at line 41 of file ossimOgrVectorTileSource.h.
| ossimOgrVectorTileSource::ossimOgrVectorTileSource | ( | ) |
Definition at line 74 of file ossimOgrVectorTileSource.cpp.
Definition at line 85 of file ossimOgrVectorTileSource.cpp.
References close().
Definition at line 293 of file ossimOgrVectorTileSource.cpp.
References theDataSource, and theLayerVector.
Referenced by ~ossimOgrVectorTileSource().
| ossimMapProjection * ossimOgrVectorTileSource::createDefaultProj | ( | ) |
Definition at line 488 of file ossimOgrVectorTileSource.cpp.
References ossim::cosd(), ossimMapProjection::setDecimalDegreesPerPixel(), ossimEquDistCylProjection::setOrigin(), ossimMapProjection::setUlGpt(), and theBoundingExtent.
| ossimProjection * ossimOgrVectorTileSource::createProjFromReference | ( | OGRSpatialReference * | reference | ) | const |
Definition at line 456 of file ossimOgrVectorTileSource.cpp.
| entryList | This is the list to initialize with entry indexes. |
Definition at line 441 of file ossimOgrVectorTileSource.cpp.
References ossimImageHandler::getEntryList(), getNumberOfEntries(), and theLayerVector.
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 358 of file ossimOgrVectorTileSource.cpp.
References theImageGeometry.
Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. Note that rrds 0 is the highest resolution rrds.
Definition at line 353 of file ossimOgrVectorTileSource.cpp.
References theImageBound.
Returns the tile width of the image or 0 if the image is not tiled. Note: this is not the same as the ossimImageSource::getTileWidth which returns the output tile width which can be different than the internal image tile width on disk.
Implements ossimImageHandler.
Definition at line 283 of file ossimOgrVectorTileSource.cpp.
Definition at line 278 of file ossimOgrVectorTileSource.cpp.
Definition at line 288 of file ossimOgrVectorTileSource.cpp.
Definition at line 412 of file ossimOgrVectorTileSource.cpp.
Retuns the min pixel value.
If there was an external eta data file then use the meta data from that file. If not given then we will return the default min
Definition at line 407 of file ossimOgrVectorTileSource.cpp.
Definition at line 402 of file ossimOgrVectorTileSource.cpp.
Returns the number of reduced resolution data sets (rrds).
Note: Shape files should never have reduced res sets so this method is returns "8" to avoid the question of "Do you want to build res sets".
Definition at line 348 of file ossimOgrVectorTileSource.cpp.
Definition at line 436 of file ossimOgrVectorTileSource.cpp.
References theLayerVector.
Referenced by getEntryList().
Returns the number of bands in the image. Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 318 of file ossimOgrVectorTileSource.cpp.
Definition at line 328 of file ossimOgrVectorTileSource.cpp.
References ossimDrect::hasNans(), ossimDrect::height(), theImageBound, ossimDrect::ul(), and ossimDpt::x.
Returns the number of bands in a tile returned from this TileSource. Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 323 of file ossimOgrVectorTileSource.cpp.
Returns the number of bands available from an image. Satisfies pure virtual from ImageHandler class.
Definition at line 338 of file ossimOgrVectorTileSource.cpp.
References ossimDrect::hasNans(), theImageBound, ossimDrect::ul(), ossimDrect::width(), and ossimDpt::y.
Definition at line 363 of file ossimOgrVectorTileSource.cpp.
References OSSIM_SCALAR_UNKNOWN.
Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. Satisfies pure virtual from TileSource class.
Definition at line 312 of file ossimOgrVectorTileSource.cpp.
Returns the height of the output tile.
Definition at line 373 of file ossimOgrVectorTileSource.cpp.
Returns the width of the output tile.
Definition at line 368 of file ossimOgrVectorTileSource.cpp.
| bool ossimOgrVectorTileSource::isOgrVectorDataSource | ( | ) | const |
Definition at line 383 of file ossimOgrVectorTileSource.cpp.
References ossimString::before(), ossimString::downcase(), ossimString::empty(), ossimFilename::ext(), ossimImageHandler::theImageFile, and ossimString::upcase().
Definition at line 378 of file ossimOgrVectorTileSource.cpp.
References theDataSource.
Definition at line 267 of file ossimOgrVectorTileSource.cpp.
References ossimImageGeometry::loadState(), ossimImageHandler::loadState(), and theImageGeometry.
Definition at line 93 of file ossimOgrVectorTileSource.cpp.
Definition at line 249 of file ossimOgrVectorTileSource.cpp.
References ossimImageGeometry::saveState(), ossimImageHandler::saveState(), theImageGeometry, theLayerVector, and ossimRefPtr< T >::valid().
| entryIdx | Entry number to select. |
Definition at line 417 of file ossimOgrVectorTileSource.cpp.
References ossimDrect::makeNan(), theImageBound, theImageGeometry, theLayerVector, and ossimRefPtr< T >::valid().
private |
Definition at line 191 of file ossimOgrVectorTileSource.h.
Referenced by createDefaultProj().
private |
Definition at line 188 of file ossimOgrVectorTileSource.h.
private |
Definition at line 190 of file ossimOgrVectorTileSource.h.
Referenced by getImageRectangle(), getNumberOfLines(), getNumberOfSamples(), and setCurrentEntry().
private |
Definition at line 189 of file ossimOgrVectorTileSource.h.
Referenced by getImageGeometry(), getInternalImageGeometry(), loadState(), saveState(), and setCurrentEntry().
private |
Definition at line 187 of file ossimOgrVectorTileSource.h.
Referenced by close(), getEntryList(), getNumberOfEntries(), saveState(), and setCurrentEntry().
