#include <ossimMG4LidarReader.h>
| ossimMG4LidarReader () | |
| default construtor More... | |
| virtual | ~ossimMG4LidarReader () |
| virtural destructor More... | |
| Returns short name. More... | |
| Returns long name. More... | |
| Returns class name. More... | |
| Method to grab a tile(rectangle) from image. More... | |
| Returns the number of bands in the image. More... | |
| Returns the output pixel type of the tile source. More... | |
| Returns the number of decimation levels. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| Gets number of lines for res level. More... | |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| Gets the number of samples for res level. More... | |
| virtual bool | open () |
| Open method. More... | |
| Method to test for open file stream. More... | |
| virtual void | closeEntry () |
| Method to close current entry. More... | |
| ossimImageHandler () | |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Private Member Functions | |
| ossimProjection * | getGeoProjection () |
| void | getDataType (ossim_int32 channelId) |
| void | openZoomLevel (ossim_int32 zoom) |
| template<typename DTYPE > | |
| const DTYPE | getChannelElement (const ChannelData *channel, size_t idx) |
Private Attributes | |
| MG4PointReader * | m_reader |
| Bounds | m_bounds |
| ossimIrect | m_imageRect |
| ossim_uint32 | m_numberOfSamples |
| Has sub image offset. More... | |
| ossim_uint32 | m_numberOfLines |
| ossimScalarType | m_scalarType |
| ossimRefPtr< ossimImageData > | m_tile |
Protected Attributes inherited from ossimImageHandler | |
| ossimFilename | theImageFile |
| ossimFilename | theOverviewFile |
| ossimFilename | theSupplementaryDirectory |
| ossimRefPtr< ossimImageHandler > | theOverview |
| vector< ossimIpt > | theValidImageVertices |
| ossimImageMetaData | theMetaData |
| ossimRefPtr< ossimImageGeometry > | theGeometry |
| ossimRefPtr< ossimNBandLutDataObject > | theLut |
| std::vector< ossimDpt > | theDecimationFactors |
| ossimString | theImageID |
| ossim_uint32 | theStartingResLevel |
| theStartingResLevel If set to something other than zero(default) this is indicative that the reader is an overview. More... | |
| bool | theOpenOverviewFlag |
| If true opening of overviews will be attempted. More... | |
| ossimPixelType | thePixelType |
| std::shared_ptr< ossim::ImageHandlerState > | m_state |
Protected Attributes inherited from ossimSource | |
| bool | theEnableFlag |
| bool | theInitializedFlag |
Protected Attributes inherited from ossimConnectableObject | |
| ossimId | theId |
| ossimString | theDescription |
| ossimObject * | theOwner |
| bool | theInputListIsFixedFlag |
| Indicates whether the theInputObjectList is fixed. More... | |
| bool | theOutputListIsFixedFlag |
| Indicates whether the theOutputObjectList is fixed. More... | |
| ConnectableObjectList | theInputObjectList |
| Holds a list of input objects. More... | |
| ConnectableObjectList | theOutputObjectList |
| Holds a list of output objects. More... | |
Protected Attributes inherited from ossimListenerManager | |
| std::list< ossimListener * > | theListenerList |
| bool | theEnabledFlag |
| std::list< ossimListener * > | theDelayedAdd |
| std::list< ossimListener * > | theDelayedRemove |
| bool | theFireEventFlag |
Definition at line 38 of file ossimMG4LidarReader.h.
| ossimMG4LidarReader::ossimMG4LidarReader | ( | ) |
default construtor
virtural destructor
Definition at line 71 of file ossimMG4LidarReader.cpp.
References closeEntry().
Definition at line 217 of file ossimMG4LidarReader.cpp.
References ossimImageHandler::close(), m_reader, and m_tile.
Referenced by ~ossimMG4LidarReader().
private |
Definition at line 561 of file ossimMG4LidarReader.cpp.
Returns class name.
Definition at line 86 of file ossimMG4LidarReader.cpp.
private |
Definition at line 411 of file ossimMG4LidarReader.cpp.
References m_reader, m_scalarType, OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_SCALAR_UNKNOWN, OSSIM_SINT16, OSSIM_SINT32, OSSIM_SINT8, OSSIM_UINT16, OSSIM_UINT32, and OSSIM_UINT8.
private |
Definition at line 467 of file ossimMG4LidarReader.cpp.
References ossimProjectionFactoryRegistry::createProjection(), ossimString::downcase(), ossimProjectionFactoryRegistry::instance(), ossimMapProjection::isGeographic(), m_numberOfLines, m_numberOfSamples, m_reader, MTRS_PER_FT, OSSIM_DEGREES, OSSIM_FEET, OSSIM_METERS, OSSIM_US_SURVEY_FEET, ossimMapProjection::setDecimalDegreesPerPixel(), ossimMapProjection::setMetersPerPixel(), ossimMapProjection::setUlTiePoints(), and US_METERS_PER_FT.
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 346 of file ossimMG4LidarReader.cpp.
References ossimImageGeometryRegistry::extendGeometry(), ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), getInternalImageGeometry(), ossimImageGeometry::getProjection(), ossimImageHandler::initImageParameters(), ossimImageGeometryRegistry::instance(), and ossimImageHandler::theGeometry.
Note: this is not the same as the ossimImageSource::getTileHeight which returns the output tile height which can be different than the internal image tile height on disk.
Implements ossimImageHandler.
Definition at line 336 of file ossimMG4LidarReader.cpp.
Definition at line 331 of file ossimMG4LidarReader.cpp.
| Method | to get geometry. |
Definition at line 379 of file ossimMG4LidarReader.cpp.
Referenced by getImageGeometry().
Returns long name.
Definition at line 81 of file ossimMG4LidarReader.cpp.
This returns the total number of decimation levels. It is important to note that res level 0 or full resolution is included in the list and has decimation values 1.0, 1.0
Definition at line 91 of file ossimMG4LidarReader.cpp.
References ossimImageHandler::getNumberOfDecimationLevels(), ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 321 of file ossimMG4LidarReader.cpp.
| resLevel | Reduced resolution level to return lines of. Default = 0 |
Definition at line 106 of file ossimMG4LidarReader.cpp.
References ossimImageHandler::getNumberOfSamples(), m_numberOfLines, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 326 of file ossimMG4LidarReader.cpp.
| resLevel | Reduced resolution level to return samples of. Default = 0 |
Definition at line 116 of file ossimMG4LidarReader.cpp.
References ossimImageHandler::getNumberOfSamples(), m_numberOfSamples, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Definition at line 341 of file ossimMG4LidarReader.cpp.
References m_scalarType.
Referenced by getTile().
Returns short name.
Definition at line 76 of file ossimMG4LidarReader.cpp.
| rect | The zero based rectangle to grab. |
| resLevel | The reduced resolution level to grab from. |
Definition at line 229 of file ossimMG4LidarReader.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), ossimImageHandler::getBoundingRect(), getOutputScalarType(), ossimImageSource::getTile(), ossimIrect::height(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), ossimImageData::loadBand(), m_bounds, m_reader, m_tile, ossimImageData::makeBlank(), ossimImageData::setImageRectangle(), ossimRectilinearDataObject::setScalarType(), ossimImageHandler::theOverview, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIrect::width(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Definition at line 212 of file ossimMG4LidarReader.cpp.
References ossimRefPtr< T >::get(), and m_tile.
Definition at line 398 of file ossimMG4LidarReader.cpp.
References ossimImageHandler::loadState(), and open().
Open method.
Definition at line 126 of file ossimMG4LidarReader.cpp.
Referenced by loadState().
private |
Definition at line 196 of file ossimMG4LidarReader.cpp.
References m_reader.
private |
Definition at line 195 of file ossimMG4LidarReader.h.
private |
Definition at line 196 of file ossimMG4LidarReader.h.
private |
Definition at line 199 of file ossimMG4LidarReader.h.
Referenced by getGeoProjection(), and getNumberOfLines().
private |
Definition at line 198 of file ossimMG4LidarReader.h.
Referenced by getGeoProjection(), and getNumberOfSamples().
private |
Definition at line 194 of file ossimMG4LidarReader.h.
Referenced by closeEntry(), getDataType(), getGeoProjection(), getTile(), and openZoomLevel().
private |
Definition at line 200 of file ossimMG4LidarReader.h.
Referenced by getDataType(), and getOutputScalarType().
private |
Definition at line 201 of file ossimMG4LidarReader.h.
Referenced by closeEntry(), getTile(), and isOpen().
