#include <ossimTrimFilter.h>
| ossimTrimFilter () | |
| ossimRefPtr< ossimImageData > | getTile (const ossimIrect &rect, ossim_uint32 resLevel=0) |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| Set property. More... | |
| Adds this objects properties to the list. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimTrimFilter () |
Definition at line 17 of file ossimTrimFilter.h.
| ossimTrimFilter::ossimTrimFilter | ( | ) |
Definition at line 25 of file ossimTrimFilter.cpp.
References theCutter.
protectedvirtual |
This will return the bounding rect of the source.
We can have several sources which are in a chain to modify the bounding image rect. lets say you are next to an image handler then it will return the bounding rect for that image. If you are at the right side of a resampler then you will get a bounding rect along the image view plane. This is going to be a very import method for both image writers, mosaics or anything that needs to operate only within the bounds of an image.
Definition at line 204 of file ossimTrimFilter.cpp.
References getValidImageVertices(), ossimIrect::makeNan(), and OSSIM_CLOCKWISE_ORDER.
Definition at line 287 of file ossimTrimFilter.cpp.
References ossimImageSourceFilter::getProperty(), ossimProperty::setFullRefreshBit(), theBottomPercent, theLeftPercent, theRightPercent, theTopPercent, and ossimString::toString().
| propertyNames | Array to add to. |
Definition at line 351 of file ossimTrimFilter.cpp.
Definition at line 40 of file ossimTrimFilter.cpp.
References ossimDataObject::getDataObjectStatus(), ossimPolyCutter::getTile(), ossimImageSource::getTile(), ossimSource::isSourceEnabled(), OSSIM_EMPTY, OSSIM_NULL, theCutter, ossimImageSourceFilter::theInputConnection, theValidVertices, and ossimRefPtr< T >::valid().
Definition at line 85 of file ossimTrimFilter.cpp.
References FLT_EPSILON, ossimImageSource::getValidImageVertices(), ossimDpt::length(), theBottomPercent, theLeftPercent, theRightPercent, theTopPercent, ossimDpt::x, and ossimDpt::y.
Referenced by getBoundingRect(), and initialize().
Definition at line 220 of file ossimTrimFilter.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::disconnectMyInput(), ossimConnectableObject::getInput(), getValidImageVertices(), ossimPolyCutter::initialize(), ossimPolyCutter::setNumberOfPolygons(), ossimPolyCutter::setPolygon(), theCutter, ossimImageSourceFilter::theInputConnection, and theValidVertices.
Definition at line 259 of file ossimTrimFilter.cpp.
References ossimKeywordlist::find(), ossimImageSourceFilter::loadState(), theBottomPercent, theLeftPercent, theRightPercent, theTopPercent, and ossimString::toDouble().
Definition at line 236 of file ossimTrimFilter.cpp.
References ossimKeywordlist::add(), ossimImageSourceFilter::saveState(), theBottomPercent, theLeftPercent, theRightPercent, and theTopPercent.
Set property.
| property | Property to set if property->getName() matches a property name of this object. |
Definition at line 324 of file ossimTrimFilter.cpp.
References ossimImageSourceFilter::setProperty(), theBottomPercent, theLeftPercent, theRightPercent, theTopPercent, and ossimRefPtr< T >::valid().
protected |
Definition at line 64 of file ossimTrimFilter.h.
Referenced by getProperty(), getValidImageVertices(), loadState(), saveState(), and setProperty().
protected |
Definition at line 66 of file ossimTrimFilter.h.
Referenced by getTile(), initialize(), ossimTrimFilter(), and ~ossimTrimFilter().
protected |
Definition at line 61 of file ossimTrimFilter.h.
protected |
Definition at line 62 of file ossimTrimFilter.h.
protected |
Definition at line 63 of file ossimTrimFilter.h.
protected |
Definition at line 65 of file ossimTrimFilter.h.
Referenced by getTile(), and initialize().
