This implements a closest to center combiner. More...
#include <ossimClosestToCenterCombiner.h>
Classes | |
| class | ossimClosestToCenterCombinerInfo |
| ossimClosestToCenterCombiner () | |
| Executes the ossimClosestToCenterCombiner algorithm. More... | |
Public Member Functions inherited from ossimImageMosaic | |
| ossimImageMosaic () | |
| ossimImageMosaic (ossimConnectableObject::ConnectableObjectList &inputSources) | |
Public Member Functions inherited from ossimImageCombiner | |
| ossimImageCombiner () | |
| ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag) | |
| ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual void | updateRects () |
| This will go through and precompute the bounding rects of each input image. More... | |
| Returns the number of bands available from the input. More... | |
| virtual ossim_uint32 | getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to retrieve the number of overlapping images withint the given rect. More... | |
| virtual void | getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to populate the result with the index of the overlapping images. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | hasDifferentInputs () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| ossim_int32 | findIdx (const std::vector< ossimClosestToCenterCombinerInfo > &normTileList, const ossimIpt &pt, ossim_uint32 offset) const |
Protected Member Functions inherited from ossimImageMosaic | |
| virtual | ~ossimImageMosaic () |
| void | allocate () |
| Called on first getTile, will initialize all data needed. More... | |
| template<class T > | |
| ossimRefPtr< ossimImageData > | combine (T, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| ossimRefPtr< ossimImageData > | combineNorm (T, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
Protected Member Functions inherited from ossimImageCombiner | |
| virtual | ~ossimImageCombiner () |
| void | precomputeBounds () const |
It will first grab all images overlapping a given rectangle query. The first non-null closest pixel to the center of the image is used. This basically uses only pixels along the "sweet" spot of the image. This combiner is typically used when there is overlapping sensor data.
Definition at line 25 of file ossimClosestToCenterCombiner.h.
| ossimClosestToCenterCombiner::ossimClosestToCenterCombiner | ( | ) |
Definition at line 17 of file ossimClosestToCenterCombiner.cpp.
protected |
Definition at line 114 of file ossimClosestToCenterCombiner.cpp.
References distance(), ossimDataObject::getDataObjectStatus(), ossimImageData::isNull(), ossimIrect::midPoint(), OSSIM_FULL, ossimImageCombiner::theFullResBounds, and ossimImageMosaic::theTile.
Referenced by getTile().
sets the pixels to the closest Valid value. This simulates a sweet spot cutter.
| rect | The region of interest. |
| resLevel. | For this combiner this is assumed to always be 0 |
Reimplemented from ossimImageMosaic.
Definition at line 22 of file ossimClosestToCenterCombiner.cpp.
References ossimImageMosaic::allocate(), ossimImageData::copyNormalizedBufferToTile(), ossimImageDataFactory::create(), ossimImageData::dup(), findIdx(), ossimImageData::getBuf(), ossimImageCombiner::getNextNormTile(), ossimImageData::getNumberOfBands(), ossimImageSource::getNumberOfOutputBands(), ossimImageMosaic::getTile(), ossimIrect::height(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimSource::isSourceEnabled(), ossimImageData::makeBlank(), ossim::min(), OSSIM_NORMALIZED_FLOAT, ossimImageData::setImageRectangle(), ossimImageData::setImageRectangleAndBands(), ossimImageMosaic::theTile, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
