ossimKakaduJ2kReader class for reading images with JPEG2000 (J2K) compressed blocks using kakadu library for decompression. More...
#include <ossimKakaduJ2kReader.h>
| ossimKakaduJ2kReader () | |
| default construtor More... | |
| virtual | ~ossimKakaduJ2kReader () |
| virtural destructor More... | |
| Returns short name. More... | |
| Returns long name. More... | |
| Method to grab a tile(rectangle) from image. More... | |
| Returns the number of bands in the image. More... | |
| Returns the output pixel type of the tile source. More... | |
| Gets the decimation factor for a resLevel. More... | |
| Get array of decimations for all levels. More... | |
| Returns the number of decimation levels. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| Gets number of lines for res level. More... | |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| Gets the number of samples for res level. More... | |
| virtual bool | open () |
| Open method. More... | |
| Method to test for open file stream. More... | |
| virtual void | closeEntry () |
| Method to close current entry. More... | |
| ossimImageHandler () | |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| Gets an overview tile. More... | |
| virtual ossim_int32 | get_capabilities () |
| Gets kdu source capability. More... | |
| virtual ossim_int32 | read (kdu_core::kdu_byte *buf, ossim_int32 num_bytes) |
| Read method. More... | |
| virtual bool | seek (kdu_core::kdu_long offset) |
| Seek method. More... | |
| virtual kdu_core::kdu_long | get_pos () |
| Get file position relative to the start of code stream offset. More... | |
Private Member Functions | |
| void | initializeTile () |
| Initializes data member "theTile". More... | |
| bool | loadTileFromCache (ossim_uint32 x, ossim_uint32 y, const ossimIrect &clipRect) |
| Loads a block of data to theCacheTile from the cache. More... | |
| bool | loadTile (ossim_uint32 x, ossim_uint32 y) |
| Loads a block of data to theCacheTile. More... | |
Private Attributes | |
| kdu_core::kdu_codestream | theCodestream |
| kdu_core::kdu_thread_env * | theThreadEnv |
| kdu_core::kdu_thread_queue * | theOpenTileThreadQueue |
| ossim_uint32 | theSourcePrecisionBits |
| ossim_uint32 | theMinDwtLevels |
| std::ifstream | theFileStr |
| ossimJ2kSizRecord | theSizRecord |
| ossimScalarType | theScalarType |
| ossimIrect | theImageRect |
| ossimRefPtr< ossimImageData > | theTile |
| ossimRefPtr< ossimImageData > | theCacheTile |
| ossim_uint32 | theTileSizeX |
| ossim_uint32 | theTileSizeY |
| ossimAppFixedTileCache::ossimAppFixedCacheId | theCacheId |
Definition at line 44 of file ossimKakaduJ2kReader.h.
| ossimKakaduJ2kReader::ossimKakaduJ2kReader | ( | ) |
default construtor
virtural destructor
Definition at line 73 of file ossimKakaduJ2kReader.cpp.
References closeEntry().
Definition at line 462 of file ossimKakaduJ2kReader.cpp.
References ossimImageHandler::close(), ossimAppFixedTileCache::deleteCache(), ossimAppFixedTileCache::instance(), theCacheId, theCacheTile, theCodestream, theFileStr, theOpenTileThreadQueue, theThreadEnv, theTile, theTileSizeX, and theTileSizeY.
Referenced by ~ossimKakaduJ2kReader().
inlineprotectedvirtual |
Overrides kdu_compressed_source::get_capabilities
Definition at line 316 of file ossimKakaduJ2kReader.h.
Overrides kdu_compressed_source::get_pos
Definition at line 344 of file ossimKakaduJ2kReader.h.
References theFileStr.
Returns short name.
Definition at line 88 of file ossimKakaduJ2kReader.cpp.
| resLevel | Reduced resolution set for requested decimation. |
| result | ossimDpt to initialize with requested decimation. |
Definition at line 93 of file ossimKakaduJ2kReader.cpp.
References getNumberOfDecimationLevels(), getNumberOfLines(), ossimImageHandler::getNumberOfLines(), getNumberOfSamples(), ossimImageHandler::getNumberOfSamples(), ossim::nan(), theMinDwtLevels, ossimImageHandler::theOverview, ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
Referenced by getDecimationFactors(), getNumberOfLines(), and getNumberOfSamples().
| decimations | Vector to initialize with decimations. |
Definition at line 148 of file ossimKakaduJ2kReader.cpp.
References getDecimationFactor(), and getNumberOfDecimationLevels().
Implements ossimImageHandler.
Definition at line 669 of file ossimKakaduJ2kReader.cpp.
References ossimJ2kSizRecord::m_XTsiz, ossimJ2kSizRecord::m_YTsiz, and theSizRecord.
Referenced by initializeTile().
Definition at line 659 of file ossimKakaduJ2kReader.cpp.
Returns long name.
Definition at line 83 of file ossimKakaduJ2kReader.cpp.
This returns the total number of decimation levels. It is important to note that res level 0 or full resolution is included in the list and has decimation values 1.0, 1.0
Definition at line 159 of file ossimKakaduJ2kReader.cpp.
References ossimImageHandler::getNumberOfDecimationLevels(), theMinDwtLevels, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by getDecimationFactor(), getDecimationFactors(), getNumberOfLines(), getNumberOfSamples(), and getOverviewTile().
Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 649 of file ossimKakaduJ2kReader.cpp.
References ossimJ2kSizRecord::m_Csiz, and theSizRecord.
Overrides ossimJ2kTileSource::getNumberOfLines
| resLevel | Reduced resolution level to return lines of. Default = 0 |
Definition at line 186 of file ossimKakaduJ2kReader.cpp.
References getDecimationFactor(), getNumberOfDecimationLevels(), ossimDpt::hasNans(), ossimJ2kSizRecord::m_Ysiz, theSizRecord, and ossimDpt::y.
Referenced by getDecimationFactor().
Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 654 of file ossimKakaduJ2kReader.cpp.
Referenced by getOverviewTile(), and initializeTile().
Overrides ossimJ2kTileSource::getNumberOfSamples
| resLevel | Reduced resolution level to return samples of. Default = 0 |
Definition at line 206 of file ossimKakaduJ2kReader.cpp.
References getDecimationFactor(), getNumberOfDecimationLevels(), ossimJ2kSizRecord::m_Xsiz, theSizRecord, and ossimDpt::x.
Definition at line 679 of file ossimKakaduJ2kReader.cpp.
References ossimJ2kSizRecord::getScalarType(), and theSizRecord.
protectedvirtual |
Overrides ossimImageHandler::getOverviewTile
| resLevel | The resolution level to pull from with resLevel 0 being full res. |
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. This method will subtract the subImageOffset if needed for external overview call since they do not know about the sub image offset. |
Definition at line 611 of file ossimKakaduJ2kReader.cpp.
References ossim::copyRegionToTile(), ossimImageData::getNumberOfBands(), getNumberOfDecimationLevels(), getNumberOfOutputBands(), ossimImageSource::getTile(), ossimNotify(), ossimNotifyLevel_WARN, status, theCodestream, theMinDwtLevels, theOpenTileThreadQueue, ossimImageHandler::theOverview, theThreadEnv, and ossimException::what().
Referenced by getTile(), and loadTile().
Returns short name.
Definition at line 78 of file ossimKakaduJ2kReader.cpp.
| rect | The zero based rectangle to grab. |
| resLevel | The reduced resolution level to grab from. |
Definition at line 515 of file ossimKakaduJ2kReader.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimImageData::getImageRectangle(), getOverviewTile(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), loadTile(), ossimImageData::loadTile(), loadTileFromCache(), ossimIrect::lr(), ossimImageData::makeBlank(), OSSIM_BSQ, ossimImageData::setImageRectangle(), ossimIrect::stretchToTileBoundary(), theCacheTile, theImageRect, theTile, theTileSizeX, theTileSizeY, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIpt::x, x, ossimIpt::y, and y.
private |
Definition at line 684 of file ossimKakaduJ2kReader.cpp.
References ossim::defaultTileSize(), getImageTileHeight(), getImageTileWidth(), getNumberOfOutputBands(), getOutputScalarType(), ossimImageData::initialize(), ossimImageDataFactory::instance(), theCacheTile, theTile, theTileSizeX, theTileSizeY, ossimIpt::x, and ossimIpt::y.
Definition at line 454 of file ossimKakaduJ2kReader.cpp.
References theTile, and ossimRefPtr< T >::valid().
Referenced by getTile().
Definition at line 501 of file ossimKakaduJ2kReader.cpp.
References ossimImageHandler::loadState(), and open().
private |
| x | Starting x position of block to load. |
| y | Starting y position of block to load. |
Definition at line 748 of file ossimKakaduJ2kReader.cpp.
References ossimAppFixedTileCache::addTile(), ossimRefPtr< T >::get(), getOverviewTile(), ossimAppFixedTileCache::instance(), ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setImageRectangle(), theCacheId, theCacheTile, theTileSizeX, theTileSizeY, ossimIpt::x, x, ossimIpt::y, and y.
private |
| clipRect | The rectangle to fill. |
Definition at line 719 of file ossimKakaduJ2kReader.cpp.
References ossimIrect::clipToRect(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimImageData::getImageRectangle(), ossimAppFixedTileCache::getTile(), ossimAppFixedTileCache::instance(), ossimImageData::loadTile(), OSSIM_BSQ, theCacheId, theTile, ossimRefPtr< T >::valid(), x, and y.
Open method.
Definition at line 223 of file ossimKakaduJ2kReader.cpp.
Referenced by loadState().
Read method.
Implements pure virtual kdu_compressed_source::read
| buf | Buffer to fill. |
| num_bytes | Bytes to read. |
Definition at line 321 of file ossimKakaduJ2kReader.h.
Seek method.
Overrides kdu_compressed_source::seek
| offset | Seek position relative to the start of code stream offset. |
Definition at line 328 of file ossimKakaduJ2kReader.h.
private |
Definition at line 311 of file ossimKakaduJ2kReader.h.
Referenced by closeEntry(), loadTile(), and loadTileFromCache().
private |
Definition at line 306 of file ossimKakaduJ2kReader.h.
Referenced by closeEntry(), getTile(), initializeTile(), and loadTile().
private |
Definition at line 296 of file ossimKakaduJ2kReader.h.
Referenced by closeEntry(), and getOverviewTile().
private |
Definition at line 301 of file ossimKakaduJ2kReader.h.
Referenced by closeEntry(), get_pos(), read(), and seek().
private |
Definition at line 304 of file ossimKakaduJ2kReader.h.
private |
Definition at line 300 of file ossimKakaduJ2kReader.h.
Referenced by getDecimationFactor(), getNumberOfDecimationLevels(), and getOverviewTile().
private |
Definition at line 298 of file ossimKakaduJ2kReader.h.
private |
Definition at line 303 of file ossimKakaduJ2kReader.h.
private |
Definition at line 302 of file ossimKakaduJ2kReader.h.
Referenced by getImageTileHeight(), getImageTileWidth(), getNumberOfInputBands(), getNumberOfLines(), getNumberOfOutputBands(), getNumberOfSamples(), and getOutputScalarType().
private |
Definition at line 299 of file ossimKakaduJ2kReader.h.
private |
Definition at line 297 of file ossimKakaduJ2kReader.h.
private |
Definition at line 305 of file ossimKakaduJ2kReader.h.
Referenced by closeEntry(), getTile(), initializeTile(), isOpen(), and loadTileFromCache().
private |
Definition at line 307 of file ossimKakaduJ2kReader.h.
private |
Definition at line 308 of file ossimKakaduJ2kReader.h.
