Will combine the input data based on a supplied equation. More...
#include <ossimEquationCombiner.h>
Classes | |
| class | ossimBinaryOp |
| union | ossimEquDataType |
| struct | ossimEquValue |
| class | ossimUnaryOp |
| ossimEquationCombiner () | |
| ossimEquationCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &origin, ossim_uint32 resLevel=0) |
| virtual void | setEquation (const ossimString &equ) |
| virtual ossimString | getEquation () const |
| virtual void | setOutputScalarType (ossimScalarType scalarType) |
Public Member Functions inherited from ossimImageCombiner | |
| ossimImageCombiner () | |
| ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag) | |
| ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual void | updateRects () |
| This will go through and precompute the bounding rects of each input image. More... | |
| Returns the number of bands available from the input. More... | |
| virtual ossim_uint32 | getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to retrieve the number of overlapping images withint the given rect. More... | |
| virtual void | getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to populate the result with the index of the overlapping images. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | hasDifferentInputs () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Protected Types | |
| enum | ossimEquValueType { OSSIM_EQU_TYPE_UNKNOWN = 0, OSSIM_EQU_DOUBLE_TYPE = 1, OSSIM_EQU_IMAGE_DATA_TYPE = 2 } |
| virtual | ~ossimEquationCombiner () |
| virtual void | assignValue () |
| virtual void | clearStacks () |
| virtual void | clearArgList (vector< ossimEquValue > &argList) |
| virtual ossimRefPtr< ossimImageData > | getImageData (ossim_uint32 index) |
| virtual ossimRefPtr< ossimImageData > | getNewImageData (ossim_uint32 index) |
| virtual void | deleteArgList (vector< ossimEquValue > &args) |
| virtual bool | parseArgList (vector< ossimEquValue > &args, bool popValueStack=true) |
| virtual ossimRefPtr< ossimImageData > | parseEquation () |
| virtual bool | parseAssignBand () |
| virtual bool | parseExpression () |
| virtual bool | parseRestOfExp () |
| virtual bool | parseTerm () |
| virtual bool | parseRestOfTerm () |
| virtual bool | parseFactor () |
| virtual bool | parseStdFuncs () |
| virtual bool | parseUnaryFactor () |
| virtual bool | applyClamp (ossimImageData *&result, const vector< ossimEquValue > &argList) |
| virtual bool | applyConvolution (ossimImageData *&result, const vector< ossimEquValue > &argList) |
| virtual bool | applyBlurr (ossimImageData *&result, const vector< ossimEquValue > &argList) |
| virtual bool | applyShift (ossimImageData *&result, const vector< ossimEquValue > &argList) |
| virtual bool | applyOp (const ossimBinaryOp &op, ossimEquValue &result, ossimEquValue &v1, ossimEquValue &v2) |
| virtual bool | applyOp (const ossimBinaryOp &op, ossimImageData *v1, double v2) |
| virtual bool | applyOp (const ossimBinaryOp &op, double v1, ossimImageData *v2) |
| virtual bool | applyOp (const ossimBinaryOp &op, ossimImageData *v1, ossimImageData *v2) |
| virtual bool | applyOp (const ossimUnaryOp &op, ossimEquValue &result, ossimEquValue &v1) |
| virtual bool | applyOp (const ossimUnaryOp &op, ossimImageData *v) |
Protected Member Functions inherited from ossimImageCombiner | |
| virtual | ~ossimImageCombiner () |
| void | precomputeBounds () const |
This combiner uses the ossimEquTokenizer to create unique id's for all tokens in the formula. The parser is based on the following rules:
Prog -> Expr EOF Expr -> Term RestExpr RestExpr -> + Term RestExpr | - Term RestExpr | <null> Term -> Storable RestTerm RestTerm -> * Factor RestTerm | / Factor RestTerm | <null> Factor -> number | R | ( Expr )
The equation string represents input images as in[i] for i = 0, 1, ..., n. The following tokens are supported, where I, I1, I2, ..., In are inputs (either input images or image solutions of other equations):
sin(I) takes the sine of the input sind(I) takes the sin of the input and assumes degree input asin(I) computes the arc-sine of input in radians (input must be normalized) asind(I) computes the arc-sine of input in degrees (input must be normalized) cos(I) takes cosine of input cosd(I) takes the cosine of input and assumes input in degrees acos(I) computes the arc-cosine of input in radians (input must be normalized) acosd(I) computes the arc-cosine of input in degrees (input must be normalized) tan(I) takes tangent of input tand(I) takes the tangent of input and assumes input in degrees atan(I) computes the arc-tangent of input in radians atand(I) computes the arc-tangent of input in degrees sqrt(I) takes square root of input log(I) takes the natural log of input log10(I) takes the log base 10 of the input exp(I) takes the e raised to the passed in argument abs(I) takes the absolute value of the passed in value min(I1, I2, ... In) takes the min of all values in the list max(I1, I2, ... In) takes the max of all values in the list.
clamp(I, min, max) will clamp all data to be between the min max values.
will set anything less than min to min and anythin
larger than max to maxband(I, band_index) returns a single band image object
by selecting band num from input image I. Note
the first argument must be an image
and the second argument must be a numbershift(I, rows, cols)
currently, the first argument must be an image
variable and rows, cols must be numbers
indicating the delta in that direction to shift the
input.blurr(I, rows, cols) Will blurr the input image I with a
rows-by-cols kernel. All values are equal
weight. Note the fist argument must by an image
variable (ex: i1, i2,....in).conv(index, rows, cols, <row ordered list of values> )
this allows you to define an arbitrary matrix. The
<row ordered="" list="" of="" values>=""> is a comma separated
list of constant values.assign_band(I1, num1, I2, num2)
will take band num2 from image data I2 and assign it to
band num1 in image data I1.assign_band(I1, num1, I2)
will take band 1 from image data I2 and assign it to
band num1 in image data I1.assign_band(I, num1, num2)
will assin to band num1 of data I the value of num2I1 * I2 will multiply I1 and I2
I1 + I2 will add I1 and I2
I1 - I2 will subtract I1 and I2
I1 / I2 will divide I1 and I2
I1 ^ I2 will do a power, raises I1 to I2
I1 | I2 will do a bitwise or operation
( will do it in unisgned char precision)I1 & I2 will do a bitwise and operation
( will do it in unsigned char precision)~I1 will do the ones complement of the input
I1 xor I2 will do an exclusive or operation
(will do it in unsigned char precision)Boolean ops: 1=true, 0=false I1 > I2 I1 >= I2 I1 == I2 I1 <= I2 I1 < I2 I1 <> I2
Note:
Currently an image input is reference by the variable "in[i]" where i represents the input image index starting from 0. So in[1] referes to the second image in the input source list.
Some examples:
(in[0] + in[1])/2 Will take image 0 and add it to image 1 and average them.
exp(sqrt(in[0])/4) Will take the root of the image and divide by 4 and then raise e to that amount.
128 Will return a constant value of 128 for all input bands.
shift(0, 1, 1) - in[0] Will shift the first input (0) by 1 pixel along the diagonal and then subtract the original from the shifted (edge detect).
assign_band(in[1], 1, blurr(in[1], 5, 5), 2) Will assign to the first band of input 1 the 2nd band of the 5x5 blurr of same image.
conv(0, 3, 3, -1, -2, -1, 0, 0, 0, 1, 2, 1)
Will convolve the first input connection with a 3x3 matrix.
The args are row ordered:
-1, -2, -1
0, 0, 0
1, 2, 1NDVI: N=(in[0]-in[1])/(in[0]+in[1])
For indexed-type values,like NDVI, (with limited values) it is better to rescale between 0.0 and 1.0 and use type NormalizedFloat.
Rescaled NDVI between 0 and 1: (N+1)/2 = in[0]/(in[0]+in[1])
With an ossimImageToPlaneNormalFilter feeding the DEM-image input, the slope at each pixel, normalized so that 1.0 = 90 deg from vertical, is computed with: "acosd(band(in[0],2))/90"
Definition at line 171 of file ossimEquationCombiner.h.
protected |
| Enumerator | |
| OSSIM_EQU_TYPE_UNKNOWN | |
| OSSIM_EQU_DOUBLE_TYPE | |
| OSSIM_EQU_IMAGE_DATA_TYPE | |
Definition at line 230 of file ossimEquationCombiner.h.
| ossimEquationCombiner::ossimEquationCombiner | ( | ) |
Definition at line 379 of file ossimEquationCombiner.cpp.
References OSSIM_FLOAT64, ossimCastTileSourceFilter::setOutputScalarType(), theCastFilter, and theLexer.
| ossimEquationCombiner::ossimEquationCombiner | ( | ossimConnectableObject::ConnectableObjectList & | inputSources | ) |
Definition at line 395 of file ossimEquationCombiner.cpp.
protectedvirtual |
Definition at line 411 of file ossimEquationCombiner.cpp.
References clearStacks(), ossimConnectableObject::disconnect(), theCastFilter, theCastOutputFilter, theLexer, and ossimRefPtr< T >::valid().
protectedvirtual |
Definition at line 2999 of file ossimEquationCombiner.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::disconnect(), ossimImageData::dup(), ossimRefPtr< T >::get(), ossimImageData::getImageRectangle(), ossimConnectableObject::getInput(), ossimCastTileSourceFilter::getTile(), ossimCastTileSourceFilter::initialize(), OSSIM_EQU_DOUBLE_TYPE, theCastFilter, theCurrentResLevel, theTile, and ossimRefPtr< T >::valid().
Referenced by parseStdFuncs().
protectedvirtual |
Definition at line 2847 of file ossimEquationCombiner.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), OSSIM_EMPTY, OSSIM_EQU_DOUBLE_TYPE, OSSIM_NULL, OSSIM_PARTIAL, and status.
protectedvirtual |
Definition at line 2929 of file ossimEquationCombiner.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::disconnect(), ossimImageData::dup(), ossimRefPtr< T >::get(), ossimImageData::getImageRectangle(), ossimConnectableObject::getInput(), ossimCastTileSourceFilter::getTile(), OSSIM_EQU_DOUBLE_TYPE, theCastFilter, theCurrentResLevel, theTile, and ossimRefPtr< T >::valid().
protectedvirtual |
Definition at line 3108 of file ossimEquationCombiner.cpp.
References ossimEquationCombiner::ossimBinaryOp::apply(), ossimEquationCombiner::ossimEquValue::d, ossimEquationCombiner::ossimEquDataType::doubleValue, ossimEquationCombiner::ossimEquDataType::imageDataValue, OSSIM_EQU_DOUBLE_TYPE, OSSIM_EQU_IMAGE_DATA_TYPE, and ossimEquationCombiner::ossimEquValue::type.
Referenced by applyOp(), parseRestOfExp(), parseRestOfTerm(), parseStdFuncs(), and parseUnaryFactor().
protectedvirtual |
Definition at line 3176 of file ossimEquationCombiner.cpp.
References ossimEquationCombiner::ossimBinaryOp::apply(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getSize(), ossimImageData::getSizePerBand(), OSSIM_EMPTY, OSSIM_FULL, OSSIM_NULL, size, and status.
protectedvirtual |
Definition at line 3230 of file ossimEquationCombiner.cpp.
protectedvirtual |
Definition at line 3285 of file ossimEquationCombiner.cpp.
References ossimEquationCombiner::ossimBinaryOp::apply(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), max, min, OSSIM_EMPTY, OSSIM_FULL, OSSIM_PARTIAL, ossimDataObject::setDataObjectStatus(), and size.
protectedvirtual |
Definition at line 3454 of file ossimEquationCombiner.cpp.
References ossimEquationCombiner::ossimUnaryOp::apply(), applyOp(), ossimEquationCombiner::ossimEquValue::d, ossimEquationCombiner::ossimEquDataType::doubleValue, ossimEquationCombiner::ossimEquDataType::imageDataValue, OSSIM_EQU_DOUBLE_TYPE, OSSIM_EQU_IMAGE_DATA_TYPE, and ossimEquationCombiner::ossimEquValue::type.
protectedvirtual |
Definition at line 3481 of file ossimEquationCombiner.cpp.
References ossimEquationCombiner::ossimUnaryOp::apply(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getSize(), ossimImageData::getSizePerBand(), OSSIM_EMPTY, OSSIM_FULL, OSSIM_NULL, size, and status.
protectedvirtual |
Definition at line 3056 of file ossimEquationCombiner.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::disconnect(), ossimImageData::dup(), ossimRefPtr< T >::get(), ossimImageData::getImageRectangle(), ossimConnectableObject::getInput(), ossimCastTileSourceFilter::getTile(), OSSIM_EQU_DOUBLE_TYPE, theCastFilter, theCurrentResLevel, theTile, ossimRefPtr< T >::valid(), x, and y.
protectedvirtual |
Definition at line 659 of file ossimEquationCombiner.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getSize(), ossimImageData::getWidth(), min, OSSIM_EQU_IMAGE_DATA_TYPE, OSSIM_FULL, OSSIM_PARTIAL, size, theTile, and theValueStack.
Referenced by parseEquation().
protectedvirtual |
Definition at line 784 of file ossimEquationCombiner.cpp.
References OSSIM_EQU_IMAGE_DATA_TYPE.
Referenced by parseArgList(), and parseAssignBand().
protectedvirtual |
Definition at line 768 of file ossimEquationCombiner.cpp.
References OSSIM_EQU_IMAGE_DATA_TYPE, and theValueStack.
Referenced by parseEquation(), and ~ossimEquationCombiner().
protectedvirtual |
inlinevirtual |
Definition at line 186 of file ossimEquationCombiner.h.
protectedvirtual |
Definition at line 2765 of file ossimEquationCombiner.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimImageData::getImageRectangle(), ossimConnectableObject::getInput(), ossimImageData::getMaxPix(), ossimImageData::getMinPix(), ossimImageData::getNumberOfBands(), ossimCastTileSourceFilter::getTile(), ossimImageData::setMaxPix(), ossimImageData::setMinPix(), theCastFilter, theCurrentResLevel, theTile, and ossimRefPtr< T >::valid().
Referenced by getNewImageData().
Reimplemented from ossimImageCombiner.
Definition at line 467 of file ossimEquationCombiner.cpp.
References ossim::defaultMax(), ossimConnectableObject::getInput(), ossimImageSource::getMaxPixelValue(), getOutputScalarType(), PTR_CAST, and theEquation.
Definition at line 451 of file ossimEquationCombiner.cpp.
References ossim::defaultMin(), ossimConnectableObject::getInput(), ossimImageSource::getMinPixelValue(), getOutputScalarType(), PTR_CAST, and theEquation.
protectedvirtual |
Definition at line 2786 of file ossimEquationCombiner.cpp.
References ossimImageData::dup(), ossimImageData::getBuf(), getImageData(), and ossimRefPtr< T >::valid().
Referenced by parseFactor().
Definition at line 434 of file ossimEquationCombiner.cpp.
References ossim::defaultNull(), ossimConnectableObject::getInput(), ossimImageSource::getNullPixelValue(), getOutputScalarType(), PTR_CAST, and theEquation.
Definition at line 483 of file ossimEquationCombiner.cpp.
References ossimConnectableObject::getInput(), ossimImageSource::getOutputScalarType(), PTR_CAST, theEquation, and theOutputScalarType.
Referenced by getMaxPixelValue(), getMinPixelValue(), and getNullPixelValue().
Definition at line 598 of file ossimEquationCombiner.cpp.
References ossimProperty::clearChangeType(), ossimLookUpTable::getEntryString(), ossimImageSource::getProperty(), ossimLookUpTable::getTableSize(), ossimScalarTypeLut::instance(), ossimProperty::setCacheRefreshBit(), ossimProperty::setReadOnlyFlag(), theEquation, and theOutputScalarType.
Definition at line 639 of file ossimEquationCombiner.cpp.
References ossimImageSource::getPropertyNames().
Definition at line 502 of file ossimEquationCombiner.cpp.
References ossimCastTileSourceFilter::applyCast(), ossimImageData::getHeight(), ossimConnectableObject::getInput(), ossimImageSource::getTile(), ossimImageData::getWidth(), ossimIrect::height(), initialize(), ossimImageData::initialize(), ossimImageData::makeBlank(), parseEquation(), PTR_CAST, ossimImageData::setImageRectangle(), theCastOutputFilter, theCurrentResLevel, theEquation, theTile, ossimRefPtr< T >::valid(), and ossimIrect::width().
Definition at line 647 of file ossimEquationCombiner.cpp.
References ossimImageDataFactory::create(), ossimImageSource::getNumberOfOutputBands(), ossimImageCombiner::getTileHeight(), ossimImageCombiner::getTileWidth(), ossimCastTileSourceFilter::initialize(), ossimImageCombiner::initialize(), ossimImageData::initialize(), ossimImageDataFactory::instance(), OSSIM_FLOAT64, theCastOutputFilter, theTile, and ossimRefPtr< T >::valid().
Referenced by getTile().
Definition at line 3554 of file ossimEquationCombiner.cpp.
References ossimKeywordlist::find().
protectedvirtual |
Definition at line 823 of file ossimEquationCombiner.cpp.
References clearArgList(), OSSIM_EQU_TOKEN_COMMA, OSSIM_EQU_TOKEN_LEFT_PAREN, OSSIM_EQU_TOKEN_RIGHT_PAREN, ossimNotify(), ossimNotifyLevel_WARN, parseExpression(), theCurrentId, theLexer, and theValueStack.
Referenced by parseAssignBand(), and parseStdFuncs().
protectedvirtual |
Definition at line 897 of file ossimEquationCombiner.cpp.
References ossimImageData::assignBand(), clearArgList(), ossimEquationCombiner::ossimEquValue::d, ossimEquationCombiner::ossimEquDataType::doubleValue, ossimImageData::dup(), ossimImageData::getBuf(), ossimImageData::getHeight(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), ossimEquationCombiner::ossimEquDataType::imageDataValue, OSSIM_EQU_DOUBLE_TYPE, OSSIM_EQU_IMAGE_DATA_TYPE, ossimNotify(), ossimNotifyLevel_WARN, parseArgList(), theValueStack, ossimEquationCombiner::ossimEquValue::type, and ossimImageData::validate().
protectedvirtual |
Definition at line 2818 of file ossimEquationCombiner.cpp.
References assignValue(), clearStacks(), ossimNotify(), ossimNotifyLevel_WARN, parseExpression(), theCurrentId, theEquation, theLexer, theTile, theValueStack, and ossimImageData::validate().
protectedvirtual |
Definition at line 2802 of file ossimEquationCombiner.cpp.
References parseRestOfExp(), and parseTerm().
Referenced by parseArgList(), parseEquation(), parseFactor(), and parseStdFuncs().
protectedvirtual |
Definition at line 2033 of file ossimEquationCombiner.cpp.
References ossimEquationCombiner::ossimEquValue::d, ossimEquationCombiner::ossimEquDataType::doubleValue, getNewImageData(), ossimEquationCombiner::ossimEquDataType::imageDataValue, M_PI, OSSIM_EQU_DOUBLE_TYPE, OSSIM_EQU_IMAGE_DATA_TYPE, OSSIM_EQU_TOKEN_CONSTANT, OSSIM_EQU_TOKEN_IMAGE_VARIABLE, OSSIM_EQU_TOKEN_LEFT_ARRAY_BRACKET, OSSIM_EQU_TOKEN_LEFT_PAREN, OSSIM_EQU_TOKEN_PI, OSSIM_EQU_TOKEN_RIGHT_ARRAY_BRACKET, OSSIM_EQU_TOKEN_RIGHT_PAREN, ossimNotify(), ossimNotifyLevel_WARN, parseExpression(), parseStdFuncs(), parseUnaryFactor(), ossimRefPtr< T >::release(), theCurrentId, theLexer, theValueStack, ossimEquationCombiner::ossimEquValue::type, and ossimRefPtr< T >::valid().
Referenced by parseRestOfTerm(), parseTerm(), and parseUnaryFactor().
protectedvirtual |
Definition at line 2682 of file ossimEquationCombiner.cpp.
References applyOp(), OSSIM_EQU_TOKEN_MINUS, OSSIM_EQU_TOKEN_PLUS, parseTerm(), theCurrentId, theLexer, and theValueStack.
Referenced by parseExpression().
protectedvirtual |
Definition at line 2166 of file ossimEquationCombiner.cpp.
References applyOp(), OSSIM_EQU_TOKEN_AMPERSAND, OSSIM_EQU_TOKEN_BDIFFERENT, OSSIM_EQU_TOKEN_BEQUAL, OSSIM_EQU_TOKEN_BGREATER, OSSIM_EQU_TOKEN_BGREATEROREQUAL, OSSIM_EQU_TOKEN_BLESS, OSSIM_EQU_TOKEN_BLESSOREQUAL, OSSIM_EQU_TOKEN_DIV, OSSIM_EQU_TOKEN_MOD, OSSIM_EQU_TOKEN_MULT, OSSIM_EQU_TOKEN_OR_BAR, OSSIM_EQU_TOKEN_POWER, OSSIM_EQU_TOKEN_XOR, ossimNotify(), ossimNotifyLevel_WARN, parseFactor(), theCurrentId, theLexer, and theValueStack.
Referenced by parseTerm().
protectedvirtual |
Definition at line 1025 of file ossimEquationCombiner.cpp.
References applyBlurr(), applyClamp(), applyConvolution(), applyOp(), applyShift(), ossimImageData::assignBand(), ossimEquationCombiner::ossimEquValue::d, ossimEquationCombiner::ossimEquDataType::doubleValue, ossimImageData::getBuf(), ossimImageData::getHeight(), ossimImageData::getMaxPix(), ossimImageData::getMinPix(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getOrigin(), ossimImageData::getWidth(), ossimEquationCombiner::ossimEquDataType::imageDataValue, ossimImageData::initialize(), OSSIM_EQU_DOUBLE_TYPE, OSSIM_EQU_IMAGE_DATA_TYPE, OSSIM_EQU_TOKEN_ABS, OSSIM_EQU_TOKEN_ACOS, OSSIM_EQU_TOKEN_ACOSD, OSSIM_EQU_TOKEN_ASIN, OSSIM_EQU_TOKEN_ASIND, OSSIM_EQU_TOKEN_ASSIGN_BAND, OSSIM_EQU_TOKEN_ATAN, OSSIM_EQU_TOKEN_ATAND, OSSIM_EQU_TOKEN_BAND, OSSIM_EQU_TOKEN_BLURR, OSSIM_EQU_TOKEN_CLAMP, OSSIM_EQU_TOKEN_COMMA, OSSIM_EQU_TOKEN_CONV, OSSIM_EQU_TOKEN_COS, OSSIM_EQU_TOKEN_COSD, OSSIM_EQU_TOKEN_EXP, OSSIM_EQU_TOKEN_LEFT_PAREN, OSSIM_EQU_TOKEN_LOG, OSSIM_EQU_TOKEN_LOG10, OSSIM_EQU_TOKEN_MAX, OSSIM_EQU_TOKEN_MIN, OSSIM_EQU_TOKEN_RIGHT_PAREN, OSSIM_EQU_TOKEN_SHIFT, OSSIM_EQU_TOKEN_SIN, OSSIM_EQU_TOKEN_SIND, OSSIM_EQU_TOKEN_SQRT, OSSIM_EQU_TOKEN_TAN, OSSIM_EQU_TOKEN_TAND, OSSIM_FLOAT64, ossimNotify(), ossimNotifyLevel_WARN, parseArgList(), parseAssignBand(), parseExpression(), ossimImageData::setMaxPix(), ossimImageData::setMinPix(), ossimImageData::setNullPix(), ossimImageData::setOrigin(), ossimImageData::setWidthHeight(), theCurrentId, theLexer, theValueStack, ossimEquationCombiner::ossimEquValue::type, and ossimImageData::validate().
protectedvirtual |
Definition at line 2664 of file ossimEquationCombiner.cpp.
References parseFactor(), and parseRestOfTerm().
Referenced by parseExpression(), and parseRestOfExp().
protectedvirtual |
Definition at line 1965 of file ossimEquationCombiner.cpp.
References applyOp(), OSSIM_EQU_TOKEN_MINUS, OSSIM_EQU_TOKEN_TILDE, parseFactor(), theCurrentId, theLexer, and theValueStack.
Definition at line 3534 of file ossimEquationCombiner.cpp.
References ossimKeywordlist::add(), ossimLookUpTable::getEntryString(), ossimScalarTypeLut::instance(), and theOutputScalarType.
inlinevirtual |
Definition at line 182 of file ossimEquationCombiner.h.
Referenced by ossimShorelineTool::initProcessingChain().
Definition at line 554 of file ossimEquationCombiner.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimCastTileSourceFilter::initialize(), OSSIM_FLOAT64, OSSIM_SCALAR_UNKNOWN, ossimCastTileSourceFilter::setOutputScalarType(), theCastOutputFilter, theOutputScalarType, and ossimRefPtr< T >::valid().
Referenced by ossimShorelineTool::initProcessingChain(), and setProperty().
Definition at line 579 of file ossimEquationCombiner.cpp.
References ossimProperty::getName(), ossimScalarTypeLut::instance(), setOutputScalarType(), ossimImageSource::setProperty(), theEquation, and ossimProperty::valueToString().
protected |
Definition at line 256 of file ossimEquationCombiner.h.
Referenced by applyBlurr(), applyConvolution(), applyShift(), getImageData(), ossimEquationCombiner(), and ~ossimEquationCombiner().
protected |
Definition at line 257 of file ossimEquationCombiner.h.
Referenced by getTile(), initialize(), setOutputScalarType(), and ~ossimEquationCombiner().
mutableprotected |
Definition at line 259 of file ossimEquationCombiner.h.
Referenced by parseArgList(), parseEquation(), parseFactor(), parseRestOfExp(), parseRestOfTerm(), parseStdFuncs(), and parseUnaryFactor().
protected |
Definition at line 261 of file ossimEquationCombiner.h.
Referenced by applyBlurr(), applyConvolution(), applyShift(), getImageData(), and getTile().
protected |
Definition at line 253 of file ossimEquationCombiner.h.
Referenced by getMaxPixelValue(), getMinPixelValue(), getNullPixelValue(), getOutputScalarType(), getProperty(), getTile(), parseEquation(), and setProperty().
mutableprotected |
Definition at line 254 of file ossimEquationCombiner.h.
Referenced by ossimEquationCombiner(), parseArgList(), parseEquation(), parseFactor(), parseRestOfExp(), parseRestOfTerm(), parseStdFuncs(), parseUnaryFactor(), and ~ossimEquationCombiner().
protected |
Definition at line 252 of file ossimEquationCombiner.h.
Referenced by getOutputScalarType(), getProperty(), saveState(), and setOutputScalarType().
protected |
Definition at line 255 of file ossimEquationCombiner.h.
Referenced by applyBlurr(), applyConvolution(), applyShift(), assignValue(), getImageData(), getTile(), initialize(), and parseEquation().
mutableprotected |
Definition at line 260 of file ossimEquationCombiner.h.
Referenced by assignValue(), clearStacks(), parseArgList(), parseAssignBand(), parseEquation(), parseFactor(), parseRestOfExp(), parseRestOfTerm(), parseStdFuncs(), and parseUnaryFactor().
