This class supports multi-threading of image chain getTile() requests and associated chain updating. More...
#include <ossimImageChainMtAdaptor.h>
| ossimImageChainMtAdaptor () | |
| ossimImageChainMtAdaptor (ossimImageChain *original, ossim_uint32 num_threads=0, bool use_shared_handlers=false, bool use_cache=false, ossim_uint32 cache_tile_size=64) | |
| Full constructor accepts the original image chain to clone. More... | |
| ~ossimImageChainMtAdaptor () | |
| void | setNumberOfThreads (ossim_uint32 num_threads) |
| Alternate way of specifying number of threads to support. More... | |
| void | setUseSharedHandlers (bool use_shared_handlers) |
| void | setCacheTileSize (ossim_uint32 cache_tile_size) |
| void | setUseCache (bool use_cache) |
| void | setOriginalChain (ossimImageChain *original) |
| Alternate way of specifying the original chain being adapted for multi-threading. More... | |
| Intercepts the getTile because it should never be called directly. More... | |
| Adapts call to original chain so that all clones are initialized. More... | |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| Adapts call to original chain so that clones are replicated after original's loadState. More... | |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| Adapts call to original chain so that adapter-specific keywords can be added to KWL. More... | |
| Adapts the image chain event handler. More... | |
| ossimImageSource * | getClone (ossim_uint32 index) |
| Returns pointer to a specific clone image chain, or NULL if index exceeds the max available. More... | |
| ossim_uint32 | getNumberOfClones () const |
| Returns the number of clones available. The original chain always counts as the first clone. More... | |
| virtual ossimConnectableObject::ConnectableObjectList & | imageChainList () |
| These overriding access methods greatly facilitate the implementation of an image chain adapter class operating on the member original chain. More... | |
| virtual const ossimConnectableObject::ConnectableObjectList & | imageChainList () const |
| Overrides base class implementation in order to make the connection to each clone. More... | |
Public Member Functions inherited from ossimImageChain | |
| ossimImageChain () | |
| virtual | ~ossimImageChain () |
| ossimConnectableObject::ConnectableObjectList & | getChainList () |
| const ossimConnectableObject::ConnectableObjectList & | getChainList () const |
| ossimConnectableObject * | operator[] (ossim_uint32 index) |
| virtual ossimConnectableObject * | getConnectableObject (ossim_uint32 index) |
| Same as operator[](ossim_uint32 i) More... | |
| virtual ossim_int32 | indexOf (ossimConnectableObject *obj) const |
| virtual ossimImageSource * | getFirstSource () |
| Return the first source which is the one that first receives the getTile request. More... | |
| virtual const ossimImageSource * | getFirstSource () const |
| virtual ossimObject * | getFirstObject () |
| virtual ossimImageSource * | getLastSource () |
| Return the last source which is the one that last receives the getTile request. More... | |
| virtual const ossimImageSource * | getLastSource () const |
| virtual ossimObject * | getLastObject () |
| bool | addFirst (ossimConnectableObject *obj) |
| Adds it to the start of the chain. More... | |
| bool | addLast (ossimConnectableObject *obj) |
| Adds it to the end. More... | |
| bool | deleteFirst () |
| Deletes the first object. More... | |
| bool | deleteLast () |
| Deletes the last object. More... | |
| bool | insertRight (ossimConnectableObject *newObj, ossimConnectableObject *rightOfThisObj) |
| bool | insertRight (ossimConnectableObject *newObj, const ossimId &id) |
| bool | insertLeft (ossimConnectableObject *newObj, const ossimId &id) |
| bool | insertLeft (ossimConnectableObject *newObj, ossimConnectableObject *leftOfThisObj) |
| bool | replace (ossimConnectableObject *newObj, ossimConnectableObject *oldObj) |
| virtual bool | add (ossimConnectableObject *source) |
| Will return true or false if an image source was added to the chain. More... | |
| this call is passed to the head of the list. More... | |
| This call is passed to the head of the list. More... | |
| Will pass this call to the head of the list. More... | |
| bool | canConnectMyInputTo (ossim_int32 myInputIndex, const ossimConnectableObject *object) const |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject::ConnectableObjectList findAllObjectsOfType(const RTTItypeid &typeInfo, bool recurse=true)) | |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject::ConnectableObjectList findAllObjectsOfType(const ossimString &className, bool recurse=true)) | |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findFirstObjectOfType(const RTTItypeid &typeInfo, bool recurse=true)) | |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findFirstObjectOfType(const ossimString &className, bool recurse=true)) | |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObject(const ossimId &id, bool recurse=true)) | |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObject(const ossimConnectableObject *obj, bool recurse=true)) | |
| virtual void | makeUniqueIds () |
| Will cycle through all sources setting their ids. More... | |
| virtual ossim_uint32 | getNumberOfObjects (bool recurse=true) const |
| Returns the number of objects within this container and all child containers. More... | |
| virtual ossim_uint32 | getNumberOfSources () const |
| Deprecated! Please use getNumberOfObjects(false). More... | |
| virtual bool | addChild (ossimConnectableObject *attachableObject) |
| Will add an object to the container and then set the added objects owner to this. More... | |
| virtual bool | removeChild (ossimConnectableObject *object) |
| Will remove the child from the container. More... | |
| virtual ossimConnectableObject * | removeChild (const ossimId &id) |
| virtual void | getChildren (vector< ossimConnectableObject *> &children, bool immediateChildrenOnlyFlag) |
| virtual void | disconnectOutputEvent (ossimConnectionEvent &event) |
| virtual void | connectOutputEvent (ossimConnectionEvent &event) |
| virtual void | objectDestructingEvent (ossimObjectDestructingEvent &event) |
| void | deleteList () |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual void | propertyEvent (ossimPropertyEvent &) |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Public Member Functions inherited from ossimConnectableContainerInterface | |
| ossimConnectableContainerInterface (ossimObject *obj) | |
| virtual | ~ossimConnectableContainerInterface () |
| virtual ossimConnectableObject::ConnectableObjectList | findAllObjectsOfType (const RTTItypeid &typeInfo, bool recurse=true)=0 |
| virtual ossimConnectableObject::ConnectableObjectList | findAllObjectsOfType (const ossimString &className, bool recurse=true)=0 |
| virtual ossimConnectableObject * | findFirstObjectOfType (const RTTItypeid &typeInfo, bool recurse=true)=0 |
| virtual ossimConnectableObject * | findFirstObjectOfType (const ossimString &className, bool recurse=true)=0 |
| virtual ossimConnectableObject * | findObject (const ossimId &id, bool recurse=true)=0 |
| virtual ossimConnectableObject * | findObject (const ossimConnectableObject *obj, bool recurse=true)=0 |
| ossimObject * | getObject () |
| const ossimObject * | getObject () const |
| void | deleteAllChildren () |
| virtual void | getChildren (std::vector< ossimConnectableObject *> &children, bool immediateChildrenOnlyFlag)=0 |
Protected Types | |
| typedef std::vector< ossimRefPtr< ossimImageHandlerMtAdaptor > > | SharedHandlerList |
| List of handlers that are being shared among all clones (if requested). More... | |
| void | deleteReplicas () |
| Deletes instances of all replicas from the clone list and leaves only the original. More... | |
| bool | replicate () |
| Creates clones of original and pushes them onto the clone list. Returns TRUE if successful. More... | |
| bool | connectSharedHandlers (ossim_uint32 index) |
| Manages reconnecting shared image handlers to a cloned image chain (identified by index) after its creation. More... | |
Protected Member Functions inherited from ossimImageChain | |
| void | prepareForRemoval (ossimConnectableObject *connectableObject) |
| Inserts all of this object's children and inputs into the container provided. More... | |
| bool | addAllSources (map< ossimId, vector< ossimId > > &idMapping, const ossimKeywordlist &kwl, const char *prefix=NULL) |
| For dynamic loading to take place we must allocate all objects first and then assign id's later. More... | |
| void | findInputConnectionIds (vector< ossimId > &result, const ossimKeywordlist &kwl, const char *prefix=NULL) |
| bool | connectAllSources (const map< ossimId, vector< ossimId > > &idMapping) |
Friends | |
| class | ossimMultiThreadSequencer |
It accepts an original ossimImageChain object which is then cloned (replicated). One clone per thread is created, counting the original as clone(0), with all clones sharing a common input handler (if directed) so that disk access is serialized and thread-safe.
Definition at line 25 of file ossimImageChainMtAdaptor.h.
protected |
It is a list since the original chain may involve a combiner with multiple image inputs.
Definition at line 116 of file ossimImageChainMtAdaptor.h.
| ossimImageChainMtAdaptor::ossimImageChainMtAdaptor | ( | ) |
Definition at line 30 of file ossimImageChainMtAdaptor.cpp.
References ossimMtDebug::chainDebugEnabled, d_debugEnabled, and ossimMtDebug::instance().
| ossimImageChainMtAdaptor::ossimImageChainMtAdaptor | ( | ossimImageChain * | original, |
| ossim_uint32 | num_threads = 0, |
| bool | use_shared_handlers = false, |
| bool | use_cache = false, |
| ossim_uint32 | cache_tile_size = 64 |
| num_threads | Total number of cloned chains to make available. |
Definition at line 47 of file ossimImageChainMtAdaptor.cpp.
References ossimMtDebug::chainDebugEnabled, d_debugEnabled, ossimMtDebug::instance(), setCacheTileSize(), setNumberOfThreads(), setOriginalChain(), setUseCache(), and setUseSharedHandlers().
| ossimImageChainMtAdaptor::~ossimImageChainMtAdaptor | ( | ) |
Definition at line 71 of file ossimImageChainMtAdaptor.cpp.
References d_useSharedHandlers, m_chainContainers, m_clones, m_sharedHandlers, and ossimListenerManager::removeListener().
This connection is typically to the multi-thread sequencer object.
Reimplemented from ossimConnectableObject.
Definition at line 473 of file ossimImageChainMtAdaptor.cpp.
References ossimConnectableObject::connectMyOutputTo(), and m_clones.
protected |
This is in support of shared image handlers. Returns TRUE if successful.
Definition at line 388 of file ossimImageChainMtAdaptor.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimId::getId(), ossimIdVisitor::getObject(), m_chainContainers, and m_sharedHandlers.
Referenced by replicate().
protected |
Definition at line 230 of file ossimImageChainMtAdaptor.cpp.
References m_clones, and m_numThreads.
Referenced by loadState().
| ossimImageSource * ossimImageChainMtAdaptor::getClone | ( | ossim_uint32 | index | ) |
The clone at index=0 corresponds to the original, though this detail should be ignored.
Definition at line 461 of file ossimImageChainMtAdaptor.cpp.
References m_clones.
Referenced by ossimMultiThreadSequencer::ossimGetTileJob::run().
inline |
Definition at line 73 of file ossimImageChainMtAdaptor.h.
The tile request must go to the specific chain clone.
Reimplemented from ossimImageChain.
Definition at line 371 of file ossimImageChainMtAdaptor.cpp.
References ossimImageChain::getTile(), m_adaptedChain, ossimNotify(), ossimNotifyLevel_WARN, and ossimRefPtr< T >::valid().
These methods really should be "protected" but the compiler complains if the base class declarations are "protected".
Definition at line 428 of file ossimImageChainMtAdaptor.cpp.
References ossimImageChain::imageChainList(), m_adaptedChain, ossimImageChain::theImageChainList, and ossimRefPtr< T >::valid().
Definition at line 441 of file ossimImageChainMtAdaptor.cpp.
Definition at line 361 of file ossimImageChainMtAdaptor.cpp.
Definition at line 264 of file ossimImageChainMtAdaptor.cpp.
References deleteReplicas(), and ossimKeywordlist::find().
If the event involves a change to the original image chain, then the clones will need to be regenerated here.
Definition at line 454 of file ossimImageChainMtAdaptor.cpp.
References ossimNotify(), and ossimNotifyLevel_WARN.
protected |
Definition at line 162 of file ossimImageChainMtAdaptor.cpp.
References ossimConnectableObject::changeOwner(), connectSharedHandlers(), d_cacheTileSize, d_useCache, d_useSharedHandlers, ossimRefPtr< T >::get(), ossimCollectionVisitor::getObjectAs(), loadState(), m_chainContainers, m_clones, m_numThreads, m_sharedHandlers, and saveState().
Referenced by setNumberOfThreads(), and setOriginalChain().
Definition at line 244 of file ossimImageChainMtAdaptor.cpp.
References ossimKeywordlist::add(), and m_chainContainers.
| void ossimImageChainMtAdaptor::setCacheTileSize | ( | ossim_uint32 | cache_tile_size | ) |
Definition at line 118 of file ossimImageChainMtAdaptor.cpp.
References d_cacheTileSize.
Referenced by ossimImageChainMtAdaptor(), ossimMultiThreadSequencer::setCacheTileSize(), and ossimMultiThreadSequencer::setToStartOfSequence().
| void ossimImageChainMtAdaptor::setNumberOfThreads | ( | ossim_uint32 | num_threads | ) |
This is the same as the number of clones that will be available after replicating the original chain.
Definition at line 90 of file ossimImageChainMtAdaptor.cpp.
References ossimString::empty(), ossimPreferences::findPreference(), ossimPreferences::instance(), m_chainContainers, m_numThreads, replicate(), and ossimString::toUInt32().
Referenced by ossimImageChainMtAdaptor(), ossimMultiThreadSequencer::setNumberOfThreads(), and ossimMultiThreadSequencer::setToStartOfSequence().
| void ossimImageChainMtAdaptor::setOriginalChain | ( | ossimImageChain * | original | ) |
| original | Image chain to be adapted. |
Definition at line 131 of file ossimImageChainMtAdaptor.cpp.
References ossimConnectableObject::fillContainer(), ossimImageChain::getFirstSource(), m_adaptedChain, m_chainContainers, m_clones, m_numThreads, and replicate().
Referenced by ossimImageChainMtAdaptor().
| void ossimImageChainMtAdaptor::setUseCache | ( | bool | use_cache | ) |
Definition at line 123 of file ossimImageChainMtAdaptor.cpp.
References d_useCache.
Referenced by ossimImageChainMtAdaptor(), ossimMultiThreadSequencer::setToStartOfSequence(), and ossimMultiThreadSequencer::setUseCache().
| void ossimImageChainMtAdaptor::setUseSharedHandlers | ( | bool | use_shared_handlers | ) |
Definition at line 113 of file ossimImageChainMtAdaptor.cpp.
References d_useSharedHandlers.
Referenced by ossimImageChainMtAdaptor(), ossimMultiThreadSequencer::setToStartOfSequence(), and ossimMultiThreadSequencer::setUseSharedHandlers().
friend |
Definition at line 27 of file ossimImageChainMtAdaptor.h.
protected |
Definition at line 122 of file ossimImageChainMtAdaptor.h.
Referenced by replicate(), and setCacheTileSize().
protected |
Definition at line 124 of file ossimImageChainMtAdaptor.h.
protected |
Definition at line 123 of file ossimImageChainMtAdaptor.h.
Referenced by replicate(), and setUseCache().
protected |
Definition at line 121 of file ossimImageChainMtAdaptor.h.
Referenced by replicate(), setUseSharedHandlers(), and ~ossimImageChainMtAdaptor().
protected |
This is the adaptee image chain.
Definition at line 99 of file ossimImageChainMtAdaptor.h.
Referenced by getTile(), imageChainList(), and setOriginalChain().
protected |
The container objects must be kept alive in this vector while their child chains in m_clones are used.
Containers are used because they are the only way of "duping" a complete chain with all connections properly done. The containers need to persist in order for the chain connections to be maintained (apparent bug in connectable object code). I found it impossible to dissociate the chain from its container. As soon as the container disappeared, the chain's internal connections would be disrupted. (OLK 11/11)
Definition at line 112 of file ossimImageChainMtAdaptor.h.
Referenced by connectSharedHandlers(), replicate(), saveState(), setNumberOfThreads(), setOriginalChain(), and ~ossimImageChainMtAdaptor().
protected |
List of replicated child chains' first source (the one receiving the getTile call).
The first in the list is always the original (adaptee) source. These are owned by the m_chainContainers that are maintained here.
Definition at line 104 of file ossimImageChainMtAdaptor.h.
Referenced by connectMyOutputTo(), deleteReplicas(), getClone(), initialize(), replicate(), setOriginalChain(), and ~ossimImageChainMtAdaptor().
protected |
Definition at line 119 of file ossimImageChainMtAdaptor.h.
Referenced by deleteReplicas(), replicate(), setNumberOfThreads(), and setOriginalChain().
protected |
Definition at line 117 of file ossimImageChainMtAdaptor.h.
Referenced by connectSharedHandlers(), ossimMultiThreadSequencer::handlerGetTileT(), replicate(), and ~ossimImageChainMtAdaptor().
