#include <ossimRLevelFilter.h>
| ossimRLevelFilter () | |
| ossimRefPtr< ossimImageGeometry > | getImageGeometry () |
| Returns a pointer reference to the active image geometry at this filter. More... | |
| virtual void | setCurrentRLevel (ossim_uint32 rlevel) |
| virtual ossim_uint32 | getCurrentRLevel () const |
| virtual bool | getOverrideGeometryFlag () const |
| virtual void | setOverrideGeometryFlag (bool override) |
| Returns the bounding rectangle. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimRLevelFilter () |
| virtual destructor. More... | |
| void | getSummedDecimation (ossimDpt &result) const |
| void | updateGeometry () |
| If this object is maintaining an ossimImageGeometry, this method needs to be called after a scale change so that the geometry's projection is modified accordingly. More... | |
This filter is used to adjust the RLevel. If you would like to continually change between RLevels or Reslolutions then you can use this filter to do so. You can also specify whether or not the rLevel passed in from the getTile request is added to this classes current Rlevel. This is so if you concatenate multiple filters that reduce the RLevels then it will keep reducing. For example if I have 2 filters that both go to RLevel 1 then it actually will go to 2 since there are 2 decimations happening. This can be turned off by specifying the Rlevel not to be additive.
Definition at line 27 of file ossimRLevelFilter.h.
| ossimRLevelFilter::ossimRLevelFilter | ( | ) |
default constructor
Definition at line 27 of file ossimRLevelFilter.cpp.
protectedvirtual |
| resLevel | This argument is only passed onto the input connection if this filter is disabled. |
To get the bounding rectangle of an rlevel when source is enabled do: myRLevelFilter->setCurrentRLevel(level); myRLevelFilter->getBoundingRect();
Definition at line 168 of file ossimRLevelFilter.cpp.
References ossimImageSource::getBoundingRect(), ossimSource::isSourceEnabled(), ossimIrect::makeNan(), theCurrentRLevel, and ossimImageSourceFilter::theInputConnection.
Definition at line 72 of file ossimRLevelFilter.cpp.
References theCurrentRLevel.
Referenced by getImageGeometry(), and getSummedDecimation().
Will return the decimation factor for the given resolution level.
the decimation is the scale from Resolution 0 or full res. Usually this is a power of 2 decimation where the decimation result is 1.0/2^resoltion.
Definition at line 40 of file ossimRLevelFilter.cpp.
References ossimImageSource::getDecimationFactor(), ossimDpt::makeNan(), and ossimImageSourceFilter::theInputConnection.
Referenced by getSummedDecimation(), and updateGeometry().
The input source geometry is modified, so we need to maintain our own geometry object as a data member.
Definition at line 81 of file ossimRLevelFilter.cpp.
References getCurrentRLevel(), ossimSource::getEnableFlag(), ossimImageSource::getImageGeometry(), m_ScaledGeometry, ossimImageSourceFilter::theInputConnection, updateGeometry(), and ossimRefPtr< T >::valid().
Get/set of the data member "theOverrideGeometryFlag". If set this will override the "getImageGeometry" method and adjust the getMetersPerPixel or the getDecimalDegreesPerPixel. Default behavior is to not override method.
Definition at line 53 of file ossimRLevelFilter.cpp.
References theOverrideGeometryFlag.
protected |
Initializes result with the sum of decimations from rlevel one to theCurrentRLevel.
Definition at line 128 of file ossimRLevelFilter.cpp.
References getCurrentRLevel(), getDecimationFactor(), ossimDpt::hasNans(), ossimDpt::makeNan(), ossimNotify(), ossimNotifyLevel_WARN, ossimDpt::x, and ossimDpt::y.
Definition at line 182 of file ossimRLevelFilter.cpp.
References ossimImageSource::getTile(), ossimSource::isSourceEnabled(), theCurrentRLevel, and ossimImageSourceFilter::theInputConnection.
Definition at line 201 of file ossimRLevelFilter.cpp.
References ossimKeywordlist::find().
Definition at line 220 of file ossimRLevelFilter.cpp.
References ossimKeywordlist::add().
Definition at line 65 of file ossimRLevelFilter.cpp.
References theCurrentRLevel, and updateGeometry().
Definition at line 59 of file ossimRLevelFilter.cpp.
protected |
Definition at line 107 of file ossimRLevelFilter.cpp.
References ossimMapProjection::applyScale(), getDecimationFactor(), ossimImageGeometry::getProjection(), m_ScaledGeometry, PTR_CAST, theCurrentRLevel, ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
Referenced by getImageGeometry(), and setCurrentRLevel().
protected |
The input image geometry, altered by the scale.
Definition at line 94 of file ossimRLevelFilter.h.
Referenced by getImageGeometry(), and updateGeometry().
protected |
Definition at line 92 of file ossimRLevelFilter.h.
Referenced by getBoundingRect(), getCurrentRLevel(), getTile(), setCurrentRLevel(), and updateGeometry().
protected |
Definition at line 93 of file ossimRLevelFilter.h.
Referenced by getOverrideGeometryFlag(), and setOverrideGeometryFlag().
