#include <ossimMemoryImageSource.h>
| ossimMemoryImageSource () | |
| ossimMemoryImageSource (const ossimMemoryImageSource &src) | |
| ossimMemoryImageSource * | dup () const |
| void | setImage (ossimRefPtr< ossimImageData > image) |
| void | setImage (ossimScalarType scalarType, ossim_uint32 numberOfBands, ossim_uint32 width, ossim_uint32 height) |
| void | setRect (ossim_uint32 ulx, ossim_uint32 uly, ossim_uint32 width, ossim_uint32 height) |
| virtual bool | canConnectMyInputTo (ossim_int32 myInputIndex, const ossimConnectableObject *object) const |
| save state is not implemented for this source and only passes to the base. More... | |
| loadState is here so one can construct a memory source as a blank tile. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Definition at line 17 of file ossimMemoryImageSource.h.
| ossimMemoryImageSource::ossimMemoryImageSource | ( | ) |
Definition at line 16 of file ossimMemoryImageSource.cpp.
References m_boundingRect, and ossimIrect::makeNan().
inline |
Definition at line 21 of file ossimMemoryImageSource.h.
required to be overriden by derived classes
Implements ossimConnectableObject.
Definition at line 162 of file ossimMemoryImageSource.cpp.
inlinevirtual |
Definition at line 29 of file ossimMemoryImageSource.h.
This will return the bounding rect of the source.
We can have several sources which are in a chain to modify the bounding image rect. lets say you are next to an image handler then it will return the bounding rect for that image. If you are at the right side of a resampler then you will get a bounding rect along the image view plane. This is going to be a very import method for both image writers, mosaics or anything that needs to operate only within the bounds of an image.
Definition at line 126 of file ossimMemoryImageSource.cpp.
References ossimImageSource::getBoundingRect(), m_boundingRect, m_image, and ossimRefPtr< T >::valid().
Will return the decimation factor for the given resolution level.
the decimation is the scale from Resolution 0 or full res. Usually this is a power of 2 decimation where the decimation result is 1.0/2^resoltion.
Definition at line 178 of file ossimMemoryImageSource.cpp.
References ossimDpt::x, and ossimDpt::y.
Will return an array of all decimations for each resolution level.
Definition at line 193 of file ossimMemoryImageSource.cpp.
inlinevirtual |
Returns the image geometry object associated with this tile source or NULL if not defined.
The geometry contains full-to-local image transform as well as projection (image-to-world) Default implementation returns the image geometry object associated with the next
(left) input source (if any) connected to this source in the chain, or NULL.
Definition at line 67 of file ossimMemoryImageSource.h.
Definition at line 114 of file ossimMemoryImageSource.cpp.
References ossimImageData::getMaxPix(), ossimImageSource::getMaxPixelValue(), getNumberOfInputBands(), m_image, and ossimRefPtr< T >::valid().
Definition at line 102 of file ossimMemoryImageSource.cpp.
References ossimImageData::getMinPix(), ossimImageSource::getMinPixelValue(), getNumberOfInputBands(), m_image, and ossimRefPtr< T >::valid().
Definition at line 90 of file ossimMemoryImageSource.cpp.
References ossimImageData::getNullPix(), ossimImageSource::getNullPixelValue(), getNumberOfInputBands(), m_image, and ossimRefPtr< T >::valid().
Will return the number of resolution levels.
Note: resolution level 0 is included in the return count.
Definition at line 173 of file ossimMemoryImageSource.cpp.
Returns the number of bands available from the input.
Implements ossimImageSource.
Definition at line 66 of file ossimMemoryImageSource.cpp.
References ossimImageData::getNumberOfBands(), m_image, and ossimRefPtr< T >::valid().
Referenced by getMaxPixelValue(), getMinPixelValue(), getNullPixelValue(), and getNumberOfOutputBands().
Definition at line 75 of file ossimMemoryImageSource.cpp.
References getNumberOfInputBands().
Referenced by getTile().
Definition at line 80 of file ossimMemoryImageSource.cpp.
References ossimImageSource::getOutputScalarType(), ossimRectilinearDataObject::getScalarType(), m_image, and ossimRefPtr< T >::valid().
Definition at line 139 of file ossimMemoryImageSource.cpp.
References ossimIrect::clipToRect(), ossimImageData::getBuf(), ossimImageData::getImageRectangle(), getNumberOfOutputBands(), getOutputScalarType(), ossimIrect::hasNans(), ossimIrect::height(), ossimImageData::initialize(), ossimSource::isSourceEnabled(), ossimImageData::loadTile(), m_boundingRect, m_image, m_result, ossimImageData::makeBlank(), OSSIM_BSQ, ossimImageData::setImageRectangle(), ossimRefPtr< T >::valid(), ossimImageData::validate(), and ossimIrect::width().
Definition at line 168 of file ossimMemoryImageSource.cpp.
References m_result.
Definition at line 215 of file ossimMemoryImageSource.cpp.
References ossimString::c_str(), ossimString::empty(), ossimKeywordlist::find(), ossimImageData::getImageRectangle(), ossimImageData::initialize(), ossimImageSource::loadState(), ossimImageGeometry::loadState(), ossimImageData::loadState(), m_boundingRect, m_geometry, m_image, and m_result.
Definition at line 199 of file ossimMemoryImageSource.cpp.
References m_geometry, m_image, ossimImageSource::saveState(), ossimImageGeometry::saveState(), ossimImageData::saveState(), and ossimRefPtr< T >::valid().
| void ossimMemoryImageSource::setImage | ( | ossimRefPtr< ossimImageData > | image | ) |
Definition at line 22 of file ossimMemoryImageSource.cpp.
References ossimRefPtr< T >::get(), ossimImageData::getImageRectangle(), m_boundingRect, m_image, m_result, ossimIrect::makeNan(), and ossimRefPtr< T >::valid().
Referenced by ossimHlzTool::computeHLZ(), ossimViewshedTool::computeViewshed(), ossimTiffWriter::dumpTileToFile(), ossimBitMaskWriter::generateMask(), ossimKakaduJpipHandler::getTile(), ossimHlzTool::initProcessingChain(), and ossimViewshedTool::initProcessingChain().
| void ossimMemoryImageSource::setImage | ( | ossimScalarType | scalarType, |
| ossim_uint32 | numberOfBands, | ||
| ossim_uint32 | width, | ||
| ossim_uint32 | height | ||
Definition at line 36 of file ossimMemoryImageSource.cpp.
References ossimImageData::getImageRectangle(), ossimImageData::initialize(), m_boundingRect, m_image, and m_result.
inlinevirtual |
Default implementation sets geometry of the first input to the geometry specified.
Definition at line 73 of file ossimMemoryImageSource.h.
Referenced by ossimHlzTool::initProcessingChain(), and ossimViewshedTool::initProcessingChain().
| void ossimMemoryImageSource::setRect | ( | ossim_uint32 | ulx, |
| ossim_uint32 | uly, | ||
Definition at line 52 of file ossimMemoryImageSource.cpp.
References ossimImageData::getImageRectangle(), m_boundingRect, m_image, ossimImageData::setImageRectangle(), and ossimRefPtr< T >::valid().
protected |
Definition at line 92 of file ossimMemoryImageSource.h.
Referenced by getBoundingRect(), getTile(), loadState(), ossimMemoryImageSource(), setImage(), and setRect().
protected |
Definition at line 91 of file ossimMemoryImageSource.h.
Referenced by loadState(), and saveState().
protected |
Definition at line 89 of file ossimMemoryImageSource.h.
Referenced by getBoundingRect(), getMaxPixelValue(), getMinPixelValue(), getNullPixelValue(), getNumberOfInputBands(), getOutputScalarType(), getTile(), loadState(), saveState(), setImage(), and setRect().
protected |
Definition at line 90 of file ossimMemoryImageSource.h.
Referenced by getTile(), initialize(), loadState(), and setImage().
