#include <ossimGdalTileSource.h>
| ossimGdalTileSource () | |
| virtual | ~ossimGdalTileSource () |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual bool | open () |
| Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More... | |
| Returns the number of bands in the image. More... | |
| Returns the number of bands available from an image. More... | |
| Returns the number of reduced resolution data sets (rrds). More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
| Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. More... | |
| Returns the output pixel type of the tile source. More... | |
| ossimScalarType | getInputScalarType () const |
| Gets the input scalar type of the tile source. More... | |
| Returns the width of the output tile. More... | |
| Returns the height of the output tile. More... | |
| virtual void | getEntryNames (std::vector< ossimString > &entryStringList) const |
| Set propterty method. More... | |
| Get propterty method. More... | |
| Get propterty names. More... | |
| GDALDriverH | getDriver () |
| void | setPreservePaletteIndexesFlag (bool flag) |
| Sets preserve palette indexes flag. More... | |
| bool | getPreservePaletteIndexesFlag () const |
| Indicated data is indexed. More... | |
| ossimImageHandler () | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Private Member Functions | |
| ossimRefPtr< ossimImageData > | getTileBlockRead (const ossimIrect &tileRect, ossim_uint32 resLevel) |
| ossimString | filterSubDatasetsString (const ossimString &subString) const |
| Filters string from "GDALGetMetadata( theDataset, "SUBDATASETS" ) More... | |
| void | computeMinMax () |
| void | loadIndexTo3BandTile (const ossimIrect &clipRect, ossim_uint32 aGdalBandStart=1, ossim_uint32 anOssimBandStart=0) |
| template<class InputType , class OutputType > | |
| void | loadIndexTo3BandTileTemplate (InputType in, OutputType out, const ossimIrect &clipRect, ossim_uint32 aGdalBandStart=1, ossim_uint32 anOssimBandStart=0) |
| bool | isIndexTo3Band (int bandNumber=1) const |
| bool | isIndexTo1Band (int bandNumber=1) const |
| ossim_uint32 | getIndexBandOutputNumber (int bandNumber) const |
| bool | isIndexed (int aGdalBandNumber=1) const |
| void | getMaxSize (ossim_uint32 resLevel, int &maxX, int &maxY) const |
| bool | isBlocked (int band) const |
| void | populateLut () |
| GDALRasterBandH | resolveRasterBand (ossim_uint32 resLevel, int gdalBandIndex) const |
| For the given resolution level and GDAL band index, return a corresponding GDAL raster band. More... | |
| ossimRefPtr< ossimImageGeometry > | getExternalImageGeometryFromXml () const |
| void | deleteRlevelCache () |
| void | setRlevelCache () |
| void | getDefaults () |
| Checks prefences for default settings. More... | |
Private Attributes | |
| GDALDatasetH | theDataset |
| GDALDriverH | theDriver |
| ossimRefPtr< ossimImageData > | theTile |
| ossimRefPtr< ossimImageData > | theSingleBandTile |
| std::vector< ossim_uint8 > | theGdalBuffer |
| ossimIrect | theImageBound |
| GDALDataType | theGdtType |
| GDALDataType | theOutputGdtType |
| double * | theMinPixValues |
| double * | theMaxPixValues |
| double * | theNullPixValues |
| ossim_uint32 | theEntryNumberToRender |
| std::vector< ossimString > | theSubDatasets |
| bool | theIsComplexFlag |
| bool | theAlphaChannelFlag |
| bool | m_preservePaletteIndexesFlag |
| vector< ossim_uint32 > | m_outputBandList |
| bool | m_isBlocked |
| std::vector< ossimAppFixedTileCache::ossimAppFixedCacheId > | m_rlevelBlockCache |
Protected Attributes inherited from ossimImageHandler | |
| ossimFilename | theImageFile |
| ossimFilename | theOverviewFile |
| ossimFilename | theSupplementaryDirectory |
| ossimRefPtr< ossimImageHandler > | theOverview |
| vector< ossimIpt > | theValidImageVertices |
| ossimImageMetaData | theMetaData |
| ossimRefPtr< ossimImageGeometry > | theGeometry |
| ossimRefPtr< ossimNBandLutDataObject > | theLut |
| std::vector< ossimDpt > | theDecimationFactors |
| ossimString | theImageID |
| ossim_uint32 | theStartingResLevel |
| theStartingResLevel If set to something other than zero(default) this is indicative that the reader is an overview. More... | |
| bool | theOpenOverviewFlag |
| If true opening of overviews will be attempted. More... | |
| ossimPixelType | thePixelType |
| std::shared_ptr< ossim::ImageHandlerState > | m_state |
Protected Attributes inherited from ossimSource | |
| bool | theEnableFlag |
| bool | theInitializedFlag |
Protected Attributes inherited from ossimConnectableObject | |
| ossimId | theId |
| ossimString | theDescription |
| ossimObject * | theOwner |
| bool | theInputListIsFixedFlag |
| Indicates whether the theInputObjectList is fixed. More... | |
| bool | theOutputListIsFixedFlag |
| Indicates whether the theOutputObjectList is fixed. More... | |
| ConnectableObjectList | theInputObjectList |
| Holds a list of input objects. More... | |
| ConnectableObjectList | theOutputObjectList |
| Holds a list of output objects. More... | |
Protected Attributes inherited from ossimListenerManager | |
| std::list< ossimListener * > | theListenerList |
| bool | theEnabledFlag |
| std::list< ossimListener * > | theDelayedAdd |
| std::list< ossimListener * > | theDelayedRemove |
| bool | theFireEventFlag |
Definition at line 31 of file ossimGdalTileSource.h.
| ossimGdalTileSource::ossimGdalTileSource | ( | ) |
Definition at line 64 of file ossimGdalTileSource.cpp.
References getDefaults().
Definition at line 89 of file ossimGdalTileSource.cpp.
References close().
Definition at line 94 of file ossimGdalTileSource.cpp.
References deleteRlevelCache(), m_preservePaletteIndexesFlag, theAlphaChannelFlag, theDataset, theIsComplexFlag, theMaxPixValues, theMinPixValues, theNullPixValues, theSingleBandTile, and theTile.
Referenced by ~ossimGdalTileSource().
private |
Definition at line 1616 of file ossimGdalTileSource.cpp.
References ossimString::contains(), ossim::defaultMax(), ossim::defaultMin(), ossim::defaultNull(), ossimImageMetaData::getMaxPix(), ossimImageMetaData::getMinPix(), ossimImageMetaData::getNullPix(), getOutputScalarType(), ossimImageHandler::hasMetaData(), isIndexTo1Band(), isIndexTo3Band(), theDataset, theDriver, theMaxPixValues, ossimImageHandler::theMetaData, theMinPixValues, and theNullPixValues.
private |
Definition at line 2467 of file ossimGdalTileSource.cpp.
References ossimAppFixedTileCache::deleteCache(), ossimAppFixedTileCache::instance(), and m_rlevelBlockCache.
Referenced by close(), and setRlevelCache().
private |
Definition at line 2165 of file ossimGdalTileSource.cpp.
References ossimString::begin(), ossimString::push_back(), and ossimString::size().
Definition at line 2107 of file ossimGdalTileSource.cpp.
Definition at line 2117 of file ossimGdalTileSource.cpp.
References theEntryNumberToRender.
| resLevel | Reduced resolution set for requested decimation. |
| result | ossimDpt to initialize with requested decimation. |
Definition at line 921 of file ossimGdalTileSource.cpp.
References getNumberOfLines(), ossimDpt::x, x, and ossimDpt::y.
private |
Definition at line 2458 of file ossimGdalTileSource.cpp.
References ossimPreferences::findPreference(), and ossimPreferences::instance().
Referenced by ossimGdalTileSource().
| GDALDriverH ossimGdalTileSource::getDriver | ( | ) |
Definition at line 951 of file ossimGdalTileSource.cpp.
References theDriver.
Referenced by ossimHdfReader::getDriverName().
| entryList | This is the list to initialize with entry indexes. |
Definition at line 2137 of file ossimGdalTileSource.cpp.
References theSubDatasets.
| entryStringList | List to initialize with strings associated with entries. |
Definition at line 2153 of file ossimGdalTileSource.cpp.
References ossimImageHandler::getEntryNames(), and theSubDatasets.
Referenced by ossimHdfReader::getEntryString().
private |
Definition at line 1072 of file ossimGdalTileSource.cpp.
References ossimFilename::exists(), ossimRefPtr< T >::get(), ossimFgdcXmlDoc::getProjection(), ossimFilename::noExtension(), ossimFgdcXmlDoc::open(), ossimImageGeometry::setProjection(), ossimImageHandler::theImageFile, and ossimRefPtr< T >::valid().
Referenced by getImageGeometry().
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 1025 of file ossimGdalTileSource.cpp.
References ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), getExternalImageGeometryFromXml(), getInternalImageGeometry(), ossimImageHandler::initImageParameters(), ossimImageGeometryRegistry::instance(), and ossimImageHandler::theGeometry.
Referenced by ossimHdfReader::getImageGeometry().
Note that rrds 0 is the highest resolution rrds.
Definition at line 895 of file ossimGdalTileSource.cpp.
References ossimImageHandler::getImageRectangle(), getMaxSize(), ossimIrect::hasNans(), ossimIrect::makeNan(), x, and y.
Implements ossimImageHandler.
Definition at line 2027 of file ossimGdalTileSource.cpp.
Referenced by ossimHdfReader::getImageTileHeight().
Definition at line 2022 of file ossimGdalTileSource.cpp.
Referenced by ossimHdfReader::getImageTileWidth().
private |
Definition at line 1978 of file ossimGdalTileSource.cpp.
References isIndexed(), and theDataset.
Referenced by getNumberOfInputBands().
| ossimScalarType ossimGdalTileSource::getInputScalarType | ( | ) | const |
Note this could be different than the output scalar type if for instance the input is lut data or complex data.
Definition at line 1465 of file ossimGdalTileSource.cpp.
References OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_SCALAR_UNKNOWN, OSSIM_SINT16, OSSIM_SINT32, OSSIM_SSHORT16, OSSIM_UINT32, OSSIM_UINT8, OSSIM_USHORT16, and theGdtType.
Referenced by getOutputScalarType(), and loadIndexTo3BandTile().
Definition at line 1102 of file ossimGdalTileSource.cpp.
References isOpen(), theDataset, and theDriver.
Definition at line 2102 of file ossimGdalTileSource.cpp.
Definition at line 1598 of file ossimGdalTileSource.cpp.
References ossim::defaultMax(), ossimImageHandler::getMaxPixelValue(), ossimImageMetaData::getNumberOfBands(), ossimNBandLutDataObject::getNumberOfEntries(), getNumberOfOutputBands(), getOutputScalarType(), m_preservePaletteIndexesFlag, ossimImageHandler::theLut, theMaxPixValues, ossimImageHandler::theMetaData, and ossimRefPtr< T >::valid().
private |
Definition at line 2032 of file ossimGdalTileSource.cpp.
References ossimImageHandler::getBoundingRect(), ossimIrect::hasNans(), ossimIrect::height(), ossimImageHandler::isValidRLevel(), resolveRasterBand(), theDataset, ossimImageHandler::theOverview, ossimRefPtr< T >::valid(), and ossimIrect::width().
Referenced by getImageRectangle(), getNumberOfLines(), and getNumberOfSamples().
Retuns the min pixel value.
If there was an external eta data file then use the meta data from that file. If not given then we will return the default min
Definition at line 1580 of file ossimGdalTileSource.cpp.
References ossim::defaultMin(), ossimImageHandler::getMinPixelValue(), ossimImageMetaData::getNumberOfBands(), getNumberOfOutputBands(), getOutputScalarType(), ossimImageHandler::theLut, ossimImageHandler::theMetaData, theMinPixValues, and ossimRefPtr< T >::valid().
Definition at line 1553 of file ossimGdalTileSource.cpp.
References ossim::defaultNull(), ossimNBandLutDataObject::getNullPixelIndex(), ossimImageHandler::getNullPixelValue(), ossimImageMetaData::getNumberOfBands(), getNumberOfOutputBands(), getOutputScalarType(), ossimImageHandler::theLut, ossimImageHandler::theMetaData, theNullPixValues, and ossimRefPtr< T >::valid().
Note: The full res image is counted as a data set so an image with no reduced resolution data set will have a count of one.
Definition at line 1734 of file ossimGdalTileSource.cpp.
References ossimImageHandler::getNumberOfDecimationLevels(), theDataset, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by setRlevelCache().
Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 792 of file ossimGdalTileSource.cpp.
References getIndexBandOutputNumber(), isIndexed(), isOpen(), m_outputBandList, theDataset, and theIsComplexFlag.
Referenced by getNumberOfOutputBands().
Definition at line 849 of file ossimGdalTileSource.cpp.
References getMaxSize(), ossimImageHandler::getNumberOfLines(), isOpen(), ossimImageHandler::isValidRLevel(), ossimImageHandler::theOverview, ossimRefPtr< T >::valid(), x, and y.
Referenced by getDecimationFactor(), and ossimHdfReader::getNumberOfLines().
Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Returns the number of bands in a tile returned from this TileSource. Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 820 of file ossimGdalTileSource.cpp.
References getNumberOfInputBands(), isIndexTo3Band(), m_preservePaletteIndexesFlag, and theAlphaChannelFlag.
Referenced by getMaxPixelValue(), getMinPixelValue(), getNullPixelValue(), and loadIndexTo3BandTileTemplate().
Definition at line 873 of file ossimGdalTileSource.cpp.
Referenced by ossimHdfReader::getNumberOfSamples().
Definition at line 1441 of file ossimGdalTileSource.cpp.
References getInputScalarType(), m_preservePaletteIndexesFlag, OSSIM_UINT8, ossimImageHandler::theLut, and ossimRefPtr< T >::valid().
Referenced by computeMinMax(), getMaxPixelValue(), getMinPixelValue(), getNullPixelValue(), ossimHdfReader::getOutputScalarType(), getTile(), and loadIndexTo3BandTile().
| bool ossimGdalTileSource::getPreservePaletteIndexesFlag | ( | ) | const |
Definition at line 2444 of file ossimGdalTileSource.cpp.
References m_preservePaletteIndexesFlag.
Overrides ossimImageHandler::getProperty.
| name | Property name to get. |
Definition at line 2349 of file ossimGdalTileSource.cpp.
Overrides ossimImageHandler::getPropertyNames.
| propertyNames | Array to initialize. |
Definition at line 2380 of file ossimGdalTileSource.cpp.
Definition at line 2087 of file ossimGdalTileSource.cpp.
Satisfies pure virtual from TileSource class.
Definition at line 477 of file ossimGdalTileSource.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), ossimImageHandler::getBoundingRect(), ossimImageData::getBuf(), ossimImageData::getHeight(), ossimImageData::getImageRectangle(), getOutputScalarType(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), getTileBlockRead(), ossimImageData::getWidth(), ossimIrect::height(), ossimIrect::intersects(), isIndexed(), isIndexTo1Band(), isIndexTo3Band(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), ossimImageData::loadBand(), loadIndexTo3BandTile(), m_isBlocked, m_outputBandList, m_preservePaletteIndexesFlag, ossimImageData::makeBlank(), ossimImageData::nullTileAlpha(), resolveRasterBand(), ossim::scalarSizeInBytes(), ossimImageData::setImageRectangle(), ossimRectilinearDataObject::setScalarType(), theAlphaChannelFlag, theDataset, theGdalBuffer, theIsComplexFlag, theOutputGdtType, ossimImageHandler::theOverview, theSingleBandTile, theTile, true, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Referenced by ossimHdfReader::getTile().
private |
| clipRect | The requested tile rectangle clipped to the image bounds. |
| resLevel | Reduced resolution level to load from. |
Definition at line 694 of file ossimGdalTileSource.cpp.
References ossimAppFixedTileCache::addTile(), ossimIrect::clipToRect(), ossimIrect::completely_within(), ossimImageDataFactory::create(), ossimRefPtr< T >::get(), ossimImageHandler::getBoundingRect(), ossimImageData::getBuf(), ossimImageData::getImageRectangle(), ossimAppFixedTileCache::getTile(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimAppFixedTileCache::instance(), ossimImageData::loadBand(), ossimImageData::loadTile(), ossimIrect::lr(), m_isBlocked, m_outputBandList, m_rlevelBlockCache, ossimImageData::makeBlank(), OSSIM_BSQ, resolveRasterBand(), ossimImageData::setImageRectangle(), ossimIrect::stretchToTileBoundary(), theDataset, theSingleBandTile, theTile, true, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIpt::x, x, ossimIpt::y, and y.
Referenced by getTile().
Definition at line 1436 of file ossimGdalTileSource.cpp.
References ossimImageData::getHeight(), theTile, and ossimRefPtr< T >::valid().
Definition at line 1428 of file ossimGdalTileSource.cpp.
References ossimImageData::getWidth(), theTile, and ossimRefPtr< T >::valid().
private |
private |
Definition at line 2006 of file ossimGdalTileSource.cpp.
References theDataset.
Referenced by getIndexBandOutputNumber(), getNumberOfInputBands(), getTile(), and populateLut().
Overrides ossimImageSource::isIndexedData to indicate we are passing palette indexes not rgb pixel data down the stream.
Definition at line 2453 of file ossimGdalTileSource.cpp.
private |
Definition at line 1962 of file ossimGdalTileSource.cpp.
Referenced by computeMinMax(), and getTile().
private |
Definition at line 1944 of file ossimGdalTileSource.cpp.
Referenced by computeMinMax(), getNumberOfOutputBands(), and getTile().
Definition at line 2112 of file ossimGdalTileSource.cpp.
Referenced by getInternalImageGeometry(), getNumberOfInputBands(), getNumberOfLines(), getNumberOfSamples(), loadState(), setCurrentEntry(), and setPreservePaletteIndexesFlag().
private |
Definition at line 1760 of file ossimGdalTileSource.cpp.
References getInputScalarType(), getOutputScalarType(), loadIndexTo3BandTileTemplate(), OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_SINT16, OSSIM_UINT16, OSSIM_UINT8, ossimNotify(), and ossimNotifyLevel_WARN.
private |
Definition at line 1837 of file ossimGdalTileSource.cpp.
References ossimImageData::getBuf(), ossimImageData::getImageRectangle(), ossimImageData::getMinPix(), ossimImageData::getNullPix(), getNumberOfOutputBands(), ossimImageData::getWidth(), ossimIrect::height(), theDataset, theSingleBandTile, theTile, ossimIrect::ul(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Referenced by loadIndexTo3BandTile().
Definition at line 991 of file ossimGdalTileSource.cpp.
References ossimKeywordlist::find(), isOpen(), ossimImageHandler::loadState(), setCurrentEntry(), and ossimString::toUInt32().
Definition at line 130 of file ossimGdalTileSource.cpp.
Referenced by setCurrentEntry().
private |
Definition at line 2196 of file ossimGdalTileSource.cpp.
References isIndexed(), m_preservePaletteIndexesFlag, OSSIM_UINT8, ossimNBandLutDataObject::setEntryLables(), ossimNBandLutDataObject::setNullPixelIndex(), theDataset, and ossimImageHandler::theLut.
private |
Definition at line 2068 of file ossimGdalTileSource.cpp.
Referenced by getMaxSize(), getTile(), getTileBlockRead(), and setRlevelCache().
Definition at line 959 of file ossimGdalTileSource.cpp.
References ossimKeywordlist::add(), ossimImageHandler::saveState(), theEntryNumberToRender, and theSubDatasets.
| entryIdx | Entry number to select. This will set the data member "theEntryNumberToRender", then call open(). |
Definition at line 2122 of file ossimGdalTileSource.cpp.
References ossimString::clear(), isOpen(), m_outputBandList, open(), ossimImageHandler::theDecimationFactors, theEntryNumberToRender, ossimImageHandler::theGeometry, ossimImageHandler::theOverview, and ossimImageHandler::theOverviewFile.
Referenced by loadState().
If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled.
This method returns false. Derived classes that are band selectors should override.
| band_list | Requested bands. |
Definition at line 2387 of file ossimGdalTileSource.cpp.
References m_outputBandList, and theDataset.
Referenced by ossimHdfReader::setOutputBandList().
| void ossimGdalTileSource::setPreservePaletteIndexesFlag | ( | bool | flag | ) |
If true and the image is paletted, the tile returned will contain the indexes instead of the LUT values. Default=false.
| flag |
Definition at line 2406 of file ossimGdalTileSource.cpp.
References ossimImageDataFactory::create(), ossimNBandLutDataObject::getFirstNullAlphaIndex(), ossimImageData::initialize(), ossimImageDataFactory::instance(), isOpen(), m_preservePaletteIndexesFlag, ossimImageData::setIndexedFlag(), ossimNBandLutDataObject::setNullPixelIndex(), ossimImageHandler::theLut, theSingleBandTile, theTile, and ossimRefPtr< T >::valid().
Overrides ossimImageHandler::setProperty.
Current property name handled: "scale" One double value representing the scale in meters per pixel. It is assumed the scale is same for x and y direction.
| property | to set. |
Definition at line 2333 of file ossimGdalTileSource.cpp.
References ossimProperty::getName().
private |
Definition at line 2478 of file ossimGdalTileSource.cpp.
References deleteRlevelCache(), ossimImageHandler::getBoundingRect(), getNumberOfDecimationLevels(), ossimAppFixedTileCache::instance(), m_isBlocked, m_rlevelBlockCache, ossimAppFixedTileCache::newTileCache(), resolveRasterBand(), and ossimIrect::stretchToTileBoundary().
private |
Definition at line 339 of file ossimGdalTileSource.h.
Referenced by getTile(), getTileBlockRead(), isBlocked(), and setRlevelCache().
private |
Definition at line 338 of file ossimGdalTileSource.h.
Referenced by getNumberOfInputBands(), getTile(), getTileBlockRead(), setCurrentEntry(), and setOutputBandList().
private |
Definition at line 337 of file ossimGdalTileSource.h.
Referenced by close(), getMaxPixelValue(), getNumberOfOutputBands(), getOutputScalarType(), getPreservePaletteIndexesFlag(), getTile(), isIndexedData(), populateLut(), and setPreservePaletteIndexesFlag().
private |
Definition at line 341 of file ossimGdalTileSource.h.
Referenced by deleteRlevelCache(), getTileBlockRead(), and setRlevelCache().
private |
Definition at line 336 of file ossimGdalTileSource.h.
Referenced by close(), getNumberOfOutputBands(), and getTile().
private |
Definition at line 321 of file ossimGdalTileSource.h.
Referenced by close(), computeMinMax(), getIndexBandOutputNumber(), getInternalImageGeometry(), getMaxSize(), getNumberOfDecimationLevels(), getNumberOfInputBands(), getTile(), getTileBlockRead(), isIndexed(), isIndexTo1Band(), isIndexTo3Band(), isOpen(), loadIndexTo3BandTileTemplate(), populateLut(), resolveRasterBand(), and setOutputBandList().
private |
Definition at line 322 of file ossimGdalTileSource.h.
Referenced by computeMinMax(), getDriver(), getInternalImageGeometry(), and getShortName().
private |
Definition at line 333 of file ossimGdalTileSource.h.
Referenced by getCurrentEntry(), saveState(), and setCurrentEntry().
private |
Definition at line 326 of file ossimGdalTileSource.h.
mutableprivate |
Definition at line 328 of file ossimGdalTileSource.h.
Referenced by getInputScalarType().
private |
Definition at line 327 of file ossimGdalTileSource.h.
private |
Definition at line 335 of file ossimGdalTileSource.h.
Referenced by close(), getNumberOfInputBands(), and getTile().
private |
Definition at line 331 of file ossimGdalTileSource.h.
Referenced by close(), computeMinMax(), and getMaxPixelValue().
private |
Definition at line 330 of file ossimGdalTileSource.h.
Referenced by close(), computeMinMax(), and getMinPixelValue().
private |
Definition at line 332 of file ossimGdalTileSource.h.
Referenced by close(), computeMinMax(), and getNullPixelValue().
mutableprivate |
Definition at line 329 of file ossimGdalTileSource.h.
private |
Definition at line 325 of file ossimGdalTileSource.h.
Referenced by close(), getTile(), getTileBlockRead(), loadIndexTo3BandTileTemplate(), and setPreservePaletteIndexesFlag().
private |
Definition at line 334 of file ossimGdalTileSource.h.
Referenced by getEntryList(), getEntryNames(), and saveState().
private |
Definition at line 324 of file ossimGdalTileSource.h.
Referenced by close(), getTile(), getTileBlockRead(), getTileHeight(), getTileWidth(), loadIndexTo3BandTileTemplate(), and setPreservePaletteIndexesFlag().
