CIB/CADRG formats are encoded the same except that the CIB is a grey scale image and the CADRG is a color image. More...
#include <ossimCibCadrgTileSource.h>
Classes | |
| struct | ossimFrameEntryData |
| Protected structure that is only used internally by this class. More... | |
Public Types | |
| enum | ossimCibCadrgProductType { OSSIM_PRODUCT_TYPE_UNKNOWN = 0, OSSIM_PRODUCT_TYPE_CIB = 1, OSSIM_PRODUCT_TYPE_CADRG = 2 } |
| Basic enumeration. More... | |
| ossimCibCadrgTileSource () | |
| Default constructor. More... | |
| This method is defined in the base class ossimObject. More... | |
| virtual void | close () |
| Closes this image handler and deletes any allocated data. More... | |
| virtual bool | open () |
| Pure virtual open. More... | |
| void | setSkipEmptyCheck (bool bSkipEmptyCheck=false) |
| Changes the way the open() routine functions slightly. More... | |
| Returns a pointer to an ossimImageDataObject given a rectangluar region of interest. More... | |
| Satisfies pure virtual requirement from ImageHandler class. More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
| Method to load the state of an object from a keyword list. More... | |
Populates the geometry object with image geometry information. More... | |
| This method allows you to query the scalar type of the output data. More... | |
| This method allows you to query the number of input bands. More... | |
| This method allows one to query the number of output bands. More... | |
| Returns the width of the output tile. More... | |
| Returns the height of the output tile. More... | |
| virtual ossim_int32 | getCurrentEntryIndex () const |
| Returns -1 if invalid. More... | |
| virtual const ossimRpfTocEntry * | getCurrentTocEntry () const |
| virtual const ossimRpfToc * | getToc () const |
| bool | isValidRLevel (ossim_uint32 reduced_res_level) const |
| bool | isOpen () const |
| Determines if its open if there eists a table of contents object. More... | |
| bool | isCib () const |
| bool | isCadrg () const |
| ossimString | getProductScale () const |
| vector< ossimString > | getProductScaleList () const |
| This retrieves all product scales that are within the Table of contents. More... | |
| vector< ossim_int32 > | getProductEntryList (const ossimString &productScale) const |
| Using the product scales from getProductScaleList() you can pass each string in so you can get all associated indices for a given product. More... | |
| ossimString | getSecurityClassification () const |
| Gets a property for matching name. More... | |
| Gets a list of property names available. More... | |
| ossimImageHandler () | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Static Public Attributes | |
| static const ossim_uint32 | CIBCADRG_FRAME_WIDTH = 1536 |
| CONSTANT representing the width of a Frame. More... | |
| static const ossim_uint32 | CIBCADRG_FRAME_HEIGHT = 1536 |
| CONSTANT representing the height of a Frame. More... | |
| virtual | ~ossimCibCadrgTileSource () |
| Destructor. More... | |
| void | updatePropertiesToFirstValidFrame () |
| virtual void | setTocEntryToRender (const ossimRpfTocEntry *entry) |
| Sets the entry to be renderer. More... | |
| virtual bool | setEntryToRender (ossim_uint32 index) |
| Sets the entry to render. More... | |
| vector< ossimFrameEntryData > | getIntersectingEntries (const ossimIrect &rect) |
| It is important to note that each frame is organized into an easting northing type orientation. More... | |
| void | fillTile (const ossimIrect &tileRect, const vector< ossimFrameEntryData > &framesInvolved, ossimImageData *tile) |
| This is a wrapper for the fill cib and fill cadrg. More... | |
| void | fillSubTileCib (const ossimRpfFrame &aFrame, const ossimIrect &tileRect, const ossimFrameEntryData &frameEntryData, ossimImageData *tile) |
| Will uncompress the CIB file using a VQ decompression algorithm. More... | |
| void | fillSubTileCadrg (const ossimRpfFrame &aFrame, const ossimIrect &tileRect, const ossimFrameEntryData &frameEntryData, ossimImageData *tile) |
| Will uncompress the CADRG file using a VQ decompression algorithm. More... | |
| void | allocateForProduct () |
| Will allocate an internal buffer for the given product. More... | |
| const ossimRpfTocEntry * | findFirstFrame () |
| This will search each entry in the table and look for a certain entry. More... | |
| void | deleteAll () |
| void | populateLut () |
Protected Attributes | |
| unsigned char * | theCompressedBuffer |
| This is for storage of a single compressed buffer. More... | |
| unsigned char * | theUncompressedBuffer |
| This is used as a buffer to uncompress the data to. More... | |
| ossim_uint32 | theNumberOfLines |
| This will be computed based on the frames organized within the directory. More... | |
| ossim_uint32 | theNumberOfSamples |
| ossimRefPtr< ossimImageData > | theTile |
| This is the actual data returned from a getTile request. More... | |
| ossimRpfToc * | theTableOfContents |
| Will own a table of contents. More... | |
| const ossimRpfTocEntry * | theEntryToRender |
| This is the actual frame file to render. More... | |
| ossim_int32 | theEntryNumberToRender |
| This will be the entry number that we are currently rendering. More... | |
| ossimCibCadrgProductType | theProductType |
| Holds the enumeration specifying the product type. More... | |
| ossimRpfFrame * | theWorkFrame |
| bool | theSkipEmptyCheck |
| If true during the call to open(), the RPF file is opened even if all the frame files are missing. More... | |
Protected Attributes inherited from ossimImageHandler | |
| ossimFilename | theImageFile |
| ossimFilename | theOverviewFile |
| ossimFilename | theSupplementaryDirectory |
| ossimRefPtr< ossimImageHandler > | theOverview |
| vector< ossimIpt > | theValidImageVertices |
| ossimImageMetaData | theMetaData |
| ossimRefPtr< ossimImageGeometry > | theGeometry |
| ossimRefPtr< ossimNBandLutDataObject > | theLut |
| std::vector< ossimDpt > | theDecimationFactors |
| ossimString | theImageID |
| ossim_uint32 | theStartingResLevel |
| theStartingResLevel If set to something other than zero(default) this is indicative that the reader is an overview. More... | |
| bool | theOpenOverviewFlag |
| If true opening of overviews will be attempted. More... | |
| ossimPixelType | thePixelType |
| std::shared_ptr< ossim::ImageHandlerState > | m_state |
Protected Attributes inherited from ossimSource | |
| bool | theEnableFlag |
| bool | theInitializedFlag |
Protected Attributes inherited from ossimConnectableObject | |
| ossimId | theId |
| ossimString | theDescription |
| ossimObject * | theOwner |
| bool | theInputListIsFixedFlag |
| Indicates whether the theInputObjectList is fixed. More... | |
| bool | theOutputListIsFixedFlag |
| Indicates whether the theOutputObjectList is fixed. More... | |
| ConnectableObjectList | theInputObjectList |
| Holds a list of input objects. More... | |
| ConnectableObjectList | theOutputObjectList |
| Holds a list of output objects. More... | |
Protected Attributes inherited from ossimListenerManager | |
| std::list< ossimListener * > | theListenerList |
| bool | theEnabledFlag |
| std::list< ossimListener * > | theDelayedAdd |
| std::list< ossimListener * > | theDelayedRemove |
| bool | theFireEventFlag |
Friends | |
| class | ossimMultiEntryCibCadrg |
Both are VQ compressed. The images are encoded into an NITF format with embedded RPF headers. It reads the embedded RPF tags from the NITF file and parses the data. It allows for you to select which CIB/CADRG entry to render. The handler is opened by giving it the associated a.toc file. This is a table of contents file that describes all the entries found in the CIB/CADRG product. You must set which entry you wish to render. By default it will render the first product it comes to.
Note: This handler will eventually merge into the nitf handler.
Definition at line 35 of file ossimCibCadrgTileSource.h.
Basic enumeration.
This should be either a CIB or a CADRG product type.
| Enumerator | |
| OSSIM_PRODUCT_TYPE_UNKNOWN | |
| OSSIM_PRODUCT_TYPE_CIB | |
| OSSIM_PRODUCT_TYPE_CADRG | |
Definition at line 45 of file ossimCibCadrgTileSource.h.
| ossimCibCadrgTileSource::ossimCibCadrgTileSource | ( | ) |
Initializes all internal attributes to a default state.
Definition at line 51 of file ossimCibCadrgTileSource.cpp.
protectedvirtual |
Destructor.
Will return allocated memory back to the heap.
Definition at line 89 of file ossimCibCadrgTileSource.cpp.
References close(), theCompressedBuffer, theUncompressedBuffer, and theWorkFrame.
protected |
If the product is a CIB then it is a single band OSSIM_UCHAR buffer and if its a CADRG it is a 3 band OSSIM_UCHAR buffer.
Definition at line 1036 of file ossimCibCadrgTileSource.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), OSSIM_PRODUCT_TYPE_CIB, OSSIM_PRODUCT_TYPE_UNKNOWN, theCompressedBuffer, theProductType, theTile, theUncompressedBuffer, and theWorkFrame.
Referenced by getTile().
Definition at line 120 of file ossimCibCadrgTileSource.cpp.
References ossimImageHandler::close(), and deleteAll().
Referenced by ~ossimCibCadrgTileSource().
protected |
Definition at line 1098 of file ossimCibCadrgTileSource.cpp.
References ossimImageHandler::theOverview, and theTableOfContents.
Referenced by close().
protected |
| aFrame | Frame that overlaps the requested tile rect. |
| tileRect | The region requested to render. |
| frameEntryData | The frame entry data. |
Definition at line 757 of file ossimCibCadrgTileSource.cpp.
References CIBCADRG_FRAME_HEIGHT, CIBCADRG_FRAME_WIDTH, ossimIrect::clipToRect(), ossimRpfFrame::fillSubFrameBuffer(), ossimRpfFrame::getColorGrayscaleTable(), ossimRpfFrame::getCompressionSection(), ossimRpfCompressionSection::getTable(), ossimIrect::height(), ossimImageData::loadTile(), OSSIM_BSQ, theCompressedBuffer, ossimCibCadrgTileSource::ossimFrameEntryData::thePixelCol, ossimCibCadrgTileSource::ossimFrameEntryData::thePixelRow, theUncompressedBuffer, ossimIrect::ul(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Referenced by fillTile().
protected |
Definition at line 901 of file ossimCibCadrgTileSource.cpp.
protected |
It takes the frames involved that were found in the getIntersectingEntries and call the appropriate fill cib or fill cadrg on each frame entry data. It will loop through making sure that the frame file exists before calling the associated fill routines.
| tileRect | Region to fill. |
| framesInvolved | All intersecting frames used to render the region. |
Definition at line 723 of file ossimCibCadrgTileSource.cpp.
References fillSubTileCadrg(), fillSubTileCib(), ossimErrorCodes::OSSIM_OK, OSSIM_PRODUCT_TYPE_CIB, ossimRpfFrame::parseFile(), theProductType, and theWorkFrame.
protected |
The first entry it comes to that has Geographic coverage will be the frame to render. This method is best here instead of in the ossimRpfToc. I am not sure, but I feel these types of searches are specific to the product (CADRG, CIB ...). This is called immediately after a succesful open of the ossimRpfToc
Definition at line 1077 of file ossimCibCadrgTileSource.cpp.
References getProductEntryList(), getProductScaleList(), ossimRpfToc::getTocEntry(), theEntryNumberToRender, and theTableOfContents.
Definition at line 447 of file ossimCibCadrgTileSource.cpp.
References theEntryNumberToRender.
Definition at line 539 of file ossimCibCadrgTileSource.cpp.
Definition at line 544 of file ossimCibCadrgTileSource.cpp.
References theEntryToRender.
| entryList | This is the list to initialize with entry indexes. |
Definition at line 473 of file ossimCibCadrgTileSource.cpp.
References getProductEntryList(), and getProductScaleList().
This method is used to relay projection/model information to users. Returns true if geometry info is present, false if not. Keywords supported by this class are:
* datum: // datum code> // Datum code * ul_lat: // upper left latitude * ul_lon: // upper left longitude * ll_lat: // lower left latitude * ll_lon: // lower left longitude * lr_lat: // lower right latitude * lr_lon: // lower right longitude * ur_lat: // upper right latitude * ur_lon: // upper right longitude * number_input_bands: * number_output_bands: * number_lines: * number_samples: * decimal_degrees_per_pixel_lat: // specifies the spacing per pixel along Y direction * decimal_degrees_per_pixel_lon: // specifies the spacing per pixel along X direction * origin_latitude: // specifies the origin or center of the projector for the latitude * central_meridian: // specifies the origin or center of the projector for the longitude * tie_point_lat: // tie point lat. Represents the latitude of the upper left center of pixel * tie_point_lon: // tie point lon. Represents the longitude of the upper left center of pixel * zone: // zone read from the CIB/CADRG boundary info * type: // class name of the object for factory driven reconstruction * map_scale: // Map scale of the image *
Definition at line 413 of file ossimCibCadrgTileSource.cpp.
References ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), ossimRpfTocEntry::getImageGeometry(), ossimImageHandler::initImageParameters(), theEntryToRender, and ossimImageHandler::theGeometry.
| reduced_res_level | Which res level to get the bounds for. 0 represents the default and is the full resolution. |
Definition at line 405 of file ossimCibCadrgTileSource.cpp.
References getNumberOfLines(), and getNumberOfSamples().
Referenced by getIntersectingEntries(), and getTile().
Implements ossimImageHandler.
Definition at line 1167 of file ossimCibCadrgTileSource.cpp.
Referenced by getTileHeight().
Definition at line 1162 of file ossimCibCadrgTileSource.cpp.
Referenced by getTileWidth().
protected |
This means that a frame at 0,0 is at the lower left corner. Each frame's pixel data is has 0,0 at the upper left.
It will take the curent region to render and then find all entries that intersect that region.
| rect | the current region to render. |
Definition at line 680 of file ossimCibCadrgTileSource.cpp.
References CIBCADRG_FRAME_HEIGHT, CIBCADRG_FRAME_WIDTH, ossimIrect::clipToRect(), ossimRpfTocEntry::getEntry(), getImageRectangle(), ossimRpfTocEntry::getNumberOfFramesVertical(), ossimIrect::intersects(), isOpen(), ossimIrect::lr(), theEntryToRender, ossimIrect::ul(), ossimIpt::x, and ossimIpt::y.
This class overrides the default implementation to return its own long name.
Definition at line 114 of file ossimCibCadrgTileSource.cpp.
If an image is band selectable this will allow one to select the bands you wish to read in. This indicates that the number of input bands might not match the number of output bands.
Implements ossimImageSource.
Definition at line 335 of file ossimCibCadrgTileSource.cpp.
References OSSIM_PRODUCT_TYPE_CADRG, OSSIM_PRODUCT_TYPE_CIB, OSSIM_PRODUCT_TYPE_UNKNOWN, and theProductType.
| reduced_res_level | The reduced res level to query number of lines from. |
Definition at line 377 of file ossimCibCadrgTileSource.cpp.
References ossimImageHandler::getNumberOfLines(), theNumberOfLines, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by getImageRectangle().
This might not be the same as the n umber of input bands.
Definition at line 356 of file ossimCibCadrgTileSource.cpp.
| reduced_res_level | The reduced res level to query number of samples from. |
Definition at line 391 of file ossimCibCadrgTileSource.cpp.
References ossimImageHandler::getNumberOfSamples(), theNumberOfSamples, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
This is simply the data type, i.e. whether its OSSIM_FLOAT, OSSIM_DOUBLE, OSSIM_UCHAR, ... etc. This means that if there are bands of different scalar types from a single image then they must be casted to the highest precision type.
Definition at line 432 of file ossimCibCadrgTileSource.cpp.
References OSSIM_UCHAR.
| vector< ossim_int32 > ossimCibCadrgTileSource::getProductEntryList | ( | const ossimString & | productScale | ) | const |
Definition at line 626 of file ossimCibCadrgTileSource.cpp.
References ossimRpfTocEntry::getBoundaryInformation(), ossimRpfToc::getNumberOfEntries(), ossimRpfBoundaryRectRecord::getScale(), ossimRpfToc::getTocEntry(), ossimRpfTocEntry::isEmpty(), isOpen(), ossimString::push_back(), theSkipEmptyCheck, theTableOfContents, ossimString::trim(), and ossimString::upcase().
Referenced by findFirstFrame(), and getEntryList().
| ossimString ossimCibCadrgTileSource::getProductScale | ( | ) | const |
Definition at line 1182 of file ossimCibCadrgTileSource.cpp.
References ossimRpfTocEntry::getBoundaryInformation(), ossimRpfBoundaryRectRecord::getScale(), ossimRpfToc::getTocEntry(), theEntryNumberToRender, and theTableOfContents.
| vector< ossimString > ossimCibCadrgTileSource::getProductScaleList | ( | ) | const |
I make no assumptions that a CIB/CADRG has only one product. A product here is 1meter, 5 meter, 10 meter ... etc for CIB and 1:24000, 1:50000, ... etc for CADRG.
Definition at line 570 of file ossimCibCadrgTileSource.cpp.
References ossimString::begin(), ossimString::end(), ossimRpfTocEntry::getBoundaryInformation(), ossimRpfToc::getNumberOfEntries(), ossimRpfBoundaryRectRecord::getScale(), ossimRpfToc::getTocEntry(), isOpen(), ossimString::push_back(), ossimString::size(), theTableOfContents, ossimString::trim(), and ossimString::upcase().
| name | The name of the property to get. |
Definition at line 1212 of file ossimCibCadrgTileSource.cpp.
References ossimImageHandler::getProperty(), OSSIM_PRODUCT_TYPE_CADRG, OSSIM_PRODUCT_TYPE_CIB, and theProductType.
| propertyNames | The list to push back names to. |
This code is crashing and not sure why in here. Looks like a bad GeoEye baseline merge.
Definition at line 1229 of file ossimCibCadrgTileSource.cpp.
References ossimString::c_str(), ossimImageHandler::getPropertyNames(), ossimRpfToc::getRpfHeader(), ossimImageHandler::theImageFile, and theTableOfContents.
| ossimString ossimCibCadrgTileSource::getSecurityClassification | ( | ) | const |
Definition at line 1197 of file ossimCibCadrgTileSource.cpp.
References ossimRpfToc::getRpfHeader(), ossimRpfHeader::getSecurityClassification(), and theTableOfContents.
This class overrides the default implementation to return its own short name.
Definition at line 109 of file ossimCibCadrgTileSource.cpp.
| rect | The region of interest to return. |
| resLevel | From which resolution set are we querying (default is 0 full res). |
Definition at line 237 of file ossimCibCadrgTileSource.cpp.
References allocateForProduct(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), theTile, and ossimRefPtr< T >::valid().
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands() |
Definition at line 263 of file ossimCibCadrgTileSource.cpp.
References allocateForProduct(), fillTile(), getImageRectangle(), ossimImageData::getImageRectangle(), getIntersectingEntries(), ossimImageData::getNumberOfBands(), getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), isValidRLevel(), ossimImageData::makeBlank(), OSSIM_PRODUCT_TYPE_UNKNOWN, status, theCompressedBuffer, theProductType, and ossimImageData::validate().
Definition at line 442 of file ossimCibCadrgTileSource.cpp.
References getImageTileHeight().
Definition at line 437 of file ossimCibCadrgTileSource.cpp.
References getImageTileWidth().
Definition at line 549 of file ossimCibCadrgTileSource.cpp.
References theTableOfContents.
| bool ossimCibCadrgTileSource::isCadrg | ( | ) | const |
Definition at line 1177 of file ossimCibCadrgTileSource.cpp.
References OSSIM_PRODUCT_TYPE_CADRG, and theProductType.
| bool ossimCibCadrgTileSource::isCib | ( | ) | const |
Definition at line 1172 of file ossimCibCadrgTileSource.cpp.
References OSSIM_PRODUCT_TYPE_CIB, and theProductType.
Definition at line 126 of file ossimCibCadrgTileSource.cpp.
Referenced by getIntersectingEntries(), getProductEntryList(), getProductScaleList(), getTile(), setEntryToRender(), and setTocEntryToRender().
| reduced_res_level | passed in resolution level. |
Definition at line 554 of file ossimCibCadrgTileSource.cpp.
References ossimImageHandler::isValidRLevel(), ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Loading with a prefix.
Loading without a prefix.
Since all objects are factory created you can go through the registry and pass the keyword list in.
| kwl | Keywordlist that holds the state information for this object. |
| prefix | prefix value prepended to all keywords to uniquely locate the state attributes for this object. |
Definition at line 1121 of file ossimCibCadrgTileSource.cpp.
Pure virtual open.
Derived classes must implement.
Definition at line 131 of file ossimCibCadrgTileSource.cpp.
protected |
Definition at line 1248 of file ossimCibCadrgTileSource.cpp.
References ossimFilename::exists(), ossimRpfFrame::getColorGrayscaleTable(), ossimRpfTocEntry::getEntry(), ossimRpfFrameEntry::getFullPath(), ossimRpfTocEntry::getNumberOfFramesHorizontal(), ossimRpfTocEntry::getNumberOfFramesVertical(), ossimErrorCodes::OSSIM_OK, OSSIM_PRODUCT_TYPE_CADRG, OSSIM_PRODUCT_TYPE_CIB, OSSIM_UINT8, ossimRpfFrame::parseFile(), theEntryToRender, ossimImageHandler::theLut, and theProductType.
Referenced by setEntryToRender().
Saving data without a prefix.
and saving data with a prefix.
Saving with a prefix will help uniquely identify objects in the kwl. To see what is in the keywordlist after a save state then do:
There is only 1 keyword for this object:
entry: <entry number>="">
where <entry number>=""> is the index value for the current entry.
| kwl | Keywordlist to save the state of the object to. |
| prefix | prefix to prepend to the keywords. This will help uniquely identify each keyword if multiple objects are saved to the same list. |
Definition at line 1108 of file ossimCibCadrgTileSource.cpp.
References ossimKeywordlist::add(), ossimImageHandler::saveState(), and theEntryNumberToRender.
| entryIdx | Entry number to select. |
Definition at line 452 of file ossimCibCadrgTileSource.cpp.
References ossimString::clear(), ossimImageHandler::completeOpen(), setEntryToRender(), ossimImageHandler::theDecimationFactors, ossimImageHandler::theGeometry, and ossimImageHandler::theOverviewFile.
protectedvirtual |
Definition at line 490 of file ossimCibCadrgTileSource.cpp.
References ossimRpfTocEntry::getBoundaryInformation(), ossimRpfBoundaryRectRecord::getCoverage(), ossimRpfTocEntry::getProductType(), ossimRpfToc::getTocEntry(), ossimRpfCoverageSection::isGeographicRectNull(), isOpen(), OSSIM_PRODUCT_TYPE_CADRG, OSSIM_PRODUCT_TYPE_CIB, OSSIM_PRODUCT_TYPE_UNKNOWN, populateLut(), setTocEntryToRender(), theEntryNumberToRender, theEntryToRender, theProductType, theTableOfContents, ossimString::trim(), and ossimString::upcase().
Referenced by setCurrentEntry().
| void ossimCibCadrgTileSource::setSkipEmptyCheck | ( | bool | bSkipEmptyCheck = false | ) |
| bSkipEmptyCheck | If true, the RPF file is opened even if all the frame files are missing. By default this is set to false. |
Definition at line 232 of file ossimCibCadrgTileSource.cpp.
References theSkipEmptyCheck.
protectedvirtual |
The entry within the table of contents are stored in an Toc entry object.
| entry | the Rpf toc entry object to set to. |
Definition at line 528 of file ossimCibCadrgTileSource.cpp.
References ossimRpfTocEntry::getNumberOfLines(), ossimRpfTocEntry::getNumberOfSamples(), ossimRpfToc::getTocEntryIndex(), isOpen(), theEntryNumberToRender, theEntryToRender, theNumberOfLines, theNumberOfSamples, and theTableOfContents.
protected |
Definition at line 1330 of file ossimCibCadrgTileSource.cpp.
References ossimFilename::exists(), ossimRpfTocEntry::getEntry(), ossimRpfFrameEntry::getFullPath(), ossimRpfTocEntry::getNumberOfFramesHorizontal(), ossimRpfTocEntry::getNumberOfFramesVertical(), ossimErrorCodes::OSSIM_OK, ossimRpfFrame::parseFile(), and theEntryToRender.
friend |
Definition at line 38 of file ossimCibCadrgTileSource.h.
static |
This should be 1536.
Definition at line 393 of file ossimCibCadrgTileSource.h.
Referenced by fillSubTileCadrg(), fillSubTileCib(), and getIntersectingEntries().
static |
Definition at line 388 of file ossimCibCadrgTileSource.h.
protected |
Definition at line 536 of file ossimCibCadrgTileSource.h.
Referenced by allocateForProduct(), fillSubTileCadrg(), fillSubTileCib(), getTile(), and ~ossimCibCadrgTileSource().
protected |
This will mainly be used when using overviews.
Definition at line 580 of file ossimCibCadrgTileSource.h.
Referenced by findFirstFrame(), getCurrentEntry(), getCurrentEntryIndex(), getProductScale(), saveState(), setEntryToRender(), and setTocEntryToRender().
protected |
This should be divided into frames where each frame is 1536x1536 in size.
Definition at line 573 of file ossimCibCadrgTileSource.h.
Referenced by getCurrentTocEntry(), getImageGeometry(), getIntersectingEntries(), populateLut(), setEntryToRender(), setTocEntryToRender(), and updatePropertiesToFirstValidFrame().
protected |
The CibCadrg have fixed size frames of 1536x1536 and we must count how many there are.
Definition at line 548 of file ossimCibCadrgTileSource.h.
Referenced by getNumberOfLines(), and setTocEntryToRender().
protected |
Definition at line 555 of file ossimCibCadrgTileSource.h.
Referenced by getNumberOfSamples(), and setTocEntryToRender().
protected |
The product type can be a CIB or a CADRG product.
Definition at line 586 of file ossimCibCadrgTileSource.h.
Referenced by allocateForProduct(), fillTile(), getNumberOfInputBands(), getNumberOfOutputBands(), getProperty(), getTile(), isCadrg(), isCib(), populateLut(), and setEntryToRender().
protected |
Definition at line 594 of file ossimCibCadrgTileSource.h.
Referenced by getProductEntryList(), and setSkipEmptyCheck().
protected |
This describes all entries within the CIB/CADRG.
Definition at line 566 of file ossimCibCadrgTileSource.h.
Referenced by deleteAll(), findFirstFrame(), getProductEntryList(), getProductScale(), getProductScaleList(), getPropertyNames(), getSecurityClassification(), getToc(), isOpen(), setEntryToRender(), and setTocEntryToRender().
protected |
Definition at line 560 of file ossimCibCadrgTileSource.h.
Referenced by allocateForProduct(), and getTile().
protected |
Definition at line 541 of file ossimCibCadrgTileSource.h.
Referenced by allocateForProduct(), fillSubTileCadrg(), fillSubTileCib(), and ~ossimCibCadrgTileSource().
mutableprotected |
Definition at line 588 of file ossimCibCadrgTileSource.h.
Referenced by allocateForProduct(), fillTile(), and ~ossimCibCadrgTileSource().
