#include <ossimImageCacheBase.h>
Classes | |
| struct | ossimFrameEntryData |
| Protected structure that is only used internally by this class. More... | |
| ossimImageCacheBase () | |
| Default constructor. More... | |
| virtual void | close () |
| Closes this image handler and deletes any allocated data. More... | |
| virtual bool | open ()=0 |
| Pure virtual open. More... | |
| Satisfies pure virtual requirement from ImageHandler class. More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
| Method to load the state of an object from a keyword list. More... | |
| This method allows you to query the number of input bands. More... | |
| This method allows one to query the number of output bands. More... | |
| Returns the width of the output tile. More... | |
| Returns the height of the output tile. More... | |
| bool | isValidRLevel (ossim_uint32 reduced_res_level) const |
| bool | isOpen () const |
| Determines if its open if there eists a table of contents object. More... | |
Populates the geometry object with image geometry information. More... | |
| ossimImageHandler () | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual | ~ossimImageCacheBase () |
| Destructor. More... | |
| void | setActualImageRect () |
| Will shift the rect and clamp it so not to go outside the -180 to 180 degree range. More... | |
| void | checkLongitude (ossim_float64 &leftLon, const ossim_float64 &rightLon) const |
| Method to test for 180.0 <–> 180.00 and set leftLon to -180 if both left and right are 180.0 degrees. More... | |
| vector< ossimFrameEntryData > | getIntersectingEntries (const ossimIrect &rect) |
| It is important to note that each frame is organized into an easting northing type orientation. More... | |
| void | deleteAll () |
| bool | buildFrameEntryArray (ossimFilename imageFile, ossim_uint32 frameWidth, ossim_uint32 frameHeight) |
Definition at line 21 of file ossimImageCacheBase.h.
| ossimImageCacheBase::ossimImageCacheBase | ( | ) |
Initializes all internal attributes to a default state.
Definition at line 48 of file ossimImageCacheBase.cpp.
protectedvirtual |
Destructor.
Will return allocated memory back to the heap.
Definition at line 82 of file ossimImageCacheBase.cpp.
protected |
Definition at line 112 of file ossimImageCacheBase.cpp.
protected |
| leftLon | Left hand side longitude of scene. This is the value that will be flipped to -180 if test is true. |
| rightLon | Right hand side of scene. |
Definition at line 295 of file ossimImageCacheBase.cpp.
References ossim::almostEqual().
Reimplemented in ossimImageCacheTileSource.
Definition at line 92 of file ossimImageCacheBase.cpp.
protected |
Definition at line 437 of file ossimImageCacheBase.cpp.
protectedvirtual |
Virtual method determines the decimation factors at each resolution level.
This base class implementation computes the decimation by considering the ratios in image size between resolution levels, with fuzzy logic for rounding ratios to the nearest power of 2 if possible. Derived classes need to override this method if the decimations are provided as part of the image metadata.
Definition at line 501 of file ossimImageCacheBase.cpp.
References ossimImageHandler::establishDecimationFactors().
| entryList | This is the list to initialize with entry indexes. |
Definition at line 380 of file ossimImageCacheBase.cpp.
This method is used to relay projection/model information to users. Returns true if geometry info is present, false if not. Keywords supported by this class are:
* datum: // datum code> // Datum code * ul_lat: // upper left latitude * ul_lon: // upper left longitude * ll_lat: // lower left latitude * ll_lon: // lower left longitude * lr_lat: // lower right latitude * lr_lon: // lower right longitude * ur_lat: // upper right latitude * ur_lon: // upper right longitude * number_input_bands: * number_output_bands: * number_lines: * number_samples: * decimal_degrees_per_pixel_lat: // specifies the spacing per pixel along Y direction * decimal_degrees_per_pixel_lon: // specifies the spacing per pixel along X direction * origin_latitude: // specifies the origin or center of the projector for the latitude * central_meridian: // specifies the origin or center of the projector for the longitude * tie_point_lat: // tie point lat. Represents the latitude of the upper left center of pixel * tie_point_lon: // tie point lon. Represents the longitude of the upper left center of pixel * zone: // zone read from the CIB/CADRG boundary info * type: // class name of the object for factory driven reconstruction * map_scale: // Map scale of the image *
Definition at line 509 of file ossimImageCacheBase.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::CENTRAL_MERIDIAN_KW, ossimKeywordNames::DATUM_KW, ossimKeywordNames::DECIMAL_DEGREES_PER_PIXEL_LAT, ossimKeywordNames::DECIMAL_DEGREES_PER_PIXEL_LON, ossimDpt::lat, ossimGpt::latd(), ossimKeywordNames::LL_LAT_KW, ossimKeywordNames::LL_LON_KW, ossimImageGeometry::loadState(), ossimDpt::lon, ossimGpt::lond(), ossimKeywordNames::LR_LAT_KW, ossimKeywordNames::LR_LON_KW, ossimKeywordNames::NUMBER_INPUT_BANDS_KW, ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_OUTPUT_BANDS_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, ossimKeywordNames::ORIGIN_LATITUDE_KW, ossimKeywordNames::TIE_POINT_LAT_KW, ossimKeywordNames::TIE_POINT_LON_KW, ossimKeywordNames::TIE_POINT_XY_KW, ossimDpt::toString(), ossimKeywordNames::TYPE_KW, ossimKeywordNames::UL_LAT_KW, ossimKeywordNames::UL_LON_KW, ossimKeywordNames::UR_LAT_KW, and ossimKeywordNames::UR_LON_KW.
| reduced_res_level | Which res level to get the bounds for. 0 represents the default and is the full resolution. |
Definition at line 360 of file ossimImageCacheBase.cpp.
Implements ossimImageHandler.
Definition at line 496 of file ossimImageCacheBase.cpp.
Definition at line 491 of file ossimImageCacheBase.cpp.
protected |
This means that a frame at 0,0 is at the lower left corner. Each frame's pixel data is has 0,0 at the upper left.
It will take the curent region to render and then find all entries that intersect that region.
| rect | the current region to render. |
Definition at line 401 of file ossimImageCacheBase.cpp.
References ossimIrect::clipToRect(), ossimRpfFrameEntry::exists(), ossimIrect::intersects(), ossimIrect::lr(), ossimIrect::ul(), ossimIpt::x, and ossimIpt::y.
If an image is band selectable this will allow one to select the bands you wish to read in. This indicates that the number of input bands might not match the number of output bands.
Implements ossimImageSource.
Definition at line 317 of file ossimImageCacheBase.cpp.
| reduced_res_level | The reduced res level to query number of lines from. |
Definition at line 327 of file ossimImageCacheBase.cpp.
This might not be the same as the n umber of input bands.
Definition at line 322 of file ossimImageCacheBase.cpp.
| reduced_res_level | The reduced res level to query number of samples from. |
Definition at line 341 of file ossimImageCacheBase.cpp.
Definition at line 375 of file ossimImageCacheBase.cpp.
Definition at line 370 of file ossimImageCacheBase.cpp.
Definition at line 97 of file ossimImageCacheBase.cpp.
References ossimString::downcase().
| reduced_res_level | passed in resolution level. |
Definition at line 385 of file ossimImageCacheBase.cpp.
Loading with a prefix.
Loading without a prefix.
Since all objects are factory created you can go through the registry and pass the keyword list in.
| kwl | Keywordlist that holds the state information for this object. |
| prefix | prefix value prepended to all keywords to uniquely locate the state attributes for this object. |
Definition at line 450 of file ossimImageCacheBase.cpp.
pure virtual |
Pure virtual open.
Derived classes must implement.
Implemented in ossimImageCacheTileSource.
| kwl | Keywordlist to save the state of the object to. |
| prefix | prefix to prepend to the keywords. This will help uniquely identify each keyword if multiple objects are saved to the same list. |
Definition at line 442 of file ossimImageCacheBase.cpp.
References ossimImageHandler::saveState().
protected |
Definition at line 355 of file ossimImageCacheBase.cpp.
protected |
This holds the image bounds for the current entry.
Definition at line 288 of file ossimImageCacheBase.h.
protected |
Definition at line 324 of file ossimImageCacheBase.h.
protected |
Definition at line 323 of file ossimImageCacheBase.h.
protected |
Definition at line 326 of file ossimImageCacheBase.h.
protected |
Definition at line 325 of file ossimImageCacheBase.h.
protected |
The size of the input frames.
Definition at line 312 of file ossimImageCacheBase.h.
protected |
Definition at line 330 of file ossimImageCacheBase.h.
protected |
Definition at line 329 of file ossimImageCacheBase.h.
protected |
Definition at line 332 of file ossimImageCacheBase.h.
protected |
This is the actual data returned from a getTile request.
Definition at line 307 of file ossimImageCacheBase.h.
protected |
This will be computed based on the frames organized within the directory.
The CibCadrg have fixed size frames of 1536x1536 and we must count how many there are.
Definition at line 295 of file ossimImageCacheBase.h.
protected |
Definition at line 302 of file ossimImageCacheBase.h.
protected |
Definition at line 328 of file ossimImageCacheBase.h.
protected |
Definition at line 327 of file ossimImageCacheBase.h.
protected |
The size of the output tile.
Definition at line 317 of file ossimImageCacheBase.h.
mutableprotected |
Definition at line 319 of file ossimImageCacheBase.h.
