#include <ossimPolyCutter.h>
Public Types | |
| enum | ossimPolyCutterCutType { OSSIM_POLY_NULL_INSIDE = 0, OSSIM_POLY_NULL_OUTSIDE = 1 } |
| ossimPolyCutter () | |
| ossimPolyCutter (ossimImageSource *inputSource, const ossimPolygon &polygon) | |
| virtual void | setPolygon (const vector< ossimDpt > &polygon, ossim_uint32 i=0) |
| virtual void | setPolygon (const vector< ossimIpt > &polygon, ossim_uint32 i=0) |
| virtual void | addPolygon (const vector< ossimIpt > &polygon) |
| virtual void | addPolygon (const vector< ossimDpt > &polygon) |
| virtual void | addPolygon (const ossimPolygon &polygon) |
| virtual void | setNumberOfPolygons (ossim_uint32 count) |
| virtual std::vector< ossimPolygon > & | getPolygonList () |
| virtual const std::vector< ossimPolygon > & | getPolygonList () const |
| void | setCutType (ossimPolyCutterCutType cutType) |
| ossimPolyCutterCutType | getCutType () const |
| void | clear () |
| const ossimIrect & | getRectangle () const |
| void | setRectangle (const ossimIrect &rect) |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimPolyCutter () |
| void | allocate () |
| Called on first getTile, will initialize all data needed. More... | |
| void | computeBoundingRect () |
Definition at line 22 of file ossimPolyCutter.h.
| Enumerator | |
| OSSIM_POLY_NULL_INSIDE | |
| OSSIM_POLY_NULL_OUTSIDE | |
Definition at line 25 of file ossimPolyCutter.h.
| ossimPolyCutter::ossimPolyCutter | ( | ) |
Definition at line 23 of file ossimPolyCutter.cpp.
| ossimPolyCutter::ossimPolyCutter | ( | ossimImageSource * | inputSource, |
| const ossimPolygon & | polygon | ||
Definition at line 35 of file ossimPolyCutter.cpp.
References computeBoundingRect(), initialize(), and thePolygonList.
protectedvirtual |
Definition at line 47 of file ossimPolyCutter.cpp.
Reimplemented in ossimGeoPolyCutter.
Definition at line 305 of file ossimPolyCutter.cpp.
References computeBoundingRect(), and thePolygonList.
Referenced by ossimGeoPolyCutter::addPolygon().
Definition at line 311 of file ossimPolyCutter.cpp.
Definition at line 317 of file ossimPolyCutter.cpp.
protected |
Definition at line 200 of file ossimPolyCutter.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimImageSourceFilter::theInputConnection, and theTile.
Referenced by getTile().
| void ossimPolyCutter::clear | ( | ) |
Definition at line 334 of file ossimPolyCutter.cpp.
References setNumberOfPolygons().
Referenced by ossimTilingPoly::nextFeature().
protected |
Definition at line 355 of file ossimPolyCutter.cpp.
References ossimIrect::combine(), ossimIrect::hasNans(), ossimIrect::makeNan(), theBoundingRect, and thePolygonList.
Referenced by addPolygon(), ossimPolyCutter(), setPolygon(), and ossimGeoPolyCutter::transformVertices().
This will return the bounding rect of the source.
We can have several sources which are in a chain to modify the bounding image rect. lets say you are next to an image handler then it will return the bounding rect for that image. If you are at the right side of a resampler then you will get a bounding rect along the image view plane. This is going to be a very import method for both image writers, mosaics or anything that needs to operate only within the bounds of an image.
Definition at line 151 of file ossimPolyCutter.cpp.
References ossimImageSource::getBoundingRect(), ossimImageSource::getDecimationFactor(), ossimDpt::hasNans(), ossimIrect::hasNans(), ossimSource::isSourceEnabled(), ossimIrect::makeNan(), OSSIM_POLY_NULL_OUTSIDE, theBoundingRect, theCutType, and ossimImageSourceFilter::theInputConnection.
| ossimPolyCutter::ossimPolyCutterCutType ossimPolyCutter::getCutType | ( | ) | const |
Definition at line 402 of file ossimPolyCutter.cpp.
References thePolygonList.
Definition at line 407 of file ossimPolyCutter.cpp.
Definition at line 344 of file ossimPolyCutter.cpp.
References ossimImageSourceFilter::getProperty().
Definition at line 350 of file ossimPolyCutter.cpp.
References ossimImageSourceFilter::getPropertyNames().
| const ossimIrect & ossimPolyCutter::getRectangle | ( | ) | const |
Definition at line 378 of file ossimPolyCutter.cpp.
References theBoundingRect.
Referenced by ossimTilingPoly::next(), and ossimTilingPoly::setRect().
Definition at line 51 of file ossimPolyCutter.cpp.
References allocate(), ossimImageDataHelper::copyInputToThis(), ossimImageDataHelper::fill(), ossimRefPtr< T >::get(), getBoundingRect(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageSource::getDecimationFactor(), ossimImageData::getNullPix(), ossimImageSource::getTile(), ossimDpt::hasNans(), ossimIrect::hasNans(), ossimIrect::intersects(), ossimSource::isSourceEnabled(), ossimImageData::loadTile(), ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_NULL, OSSIM_POLY_NULL_INSIDE, OSSIM_POLY_NULL_OUTSIDE, ossimDataObject::setDataObjectStatus(), ossimImageDataHelper::setImageData(), ossimImageData::setImageRectangle(), theBoundingRect, theCutType, theHelper, ossimImageSourceFilter::theInputConnection, thePolygonList, theTile, ossimRefPtr< T >::valid(), and ossimImageData::validate().
Referenced by ossimTrimFilter::getTile().
Definition at line 191 of file ossimPolyCutter.cpp.
References ossimImageSourceFilter::initialize(), and theTile.
Referenced by ossimTrimFilter::initialize(), and ossimPolyCutter().
Definition at line 241 of file ossimPolyCutter.cpp.
References ossimKeywordlist::find().
Definition at line 212 of file ossimPolyCutter.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), thePolygonList, and ossimString::toString().
| void ossimPolyCutter::setCutType | ( | ossimPolyCutterCutType | cutType | ) |
Definition at line 324 of file ossimPolyCutter.cpp.
References theCutType.
Definition at line 389 of file ossimPolyCutter.cpp.
Referenced by clear(), ossimTrimFilter::initialize(), and ossimGeoPolyCutter::setNumberOfPolygons().
Definition at line 283 of file ossimPolyCutter.cpp.
Referenced by ossimTrimFilter::initialize(), and ossimGeoPolyCutter::setPolygon().
Definition at line 295 of file ossimPolyCutter.cpp.
Definition at line 339 of file ossimPolyCutter.cpp.
References ossimImageSourceFilter::setProperty().
| void ossimPolyCutter::setRectangle | ( | const ossimIrect & | rect | ) |
Definition at line 383 of file ossimPolyCutter.cpp.
References m_boundingOverwrite, and theBoundingRect.
Referenced by ossimTilingPoly::setRect().
protected |
Definition at line 104 of file ossimPolyCutter.h.
Referenced by setRectangle().
protected |
Will hold a pre-computed bounding rect of the polygon data.
Definition at line 95 of file ossimPolyCutter.h.
Referenced by computeBoundingRect(), getBoundingRect(), getRectangle(), getTile(), and setRectangle().
protected |
theDefault fill will be outside.
Definition at line 102 of file ossimPolyCutter.h.
Referenced by getBoundingRect(), getCutType(), getTile(), ossimGeoPolyCutter::loadState(), and setCutType().
protected |
Definition at line 103 of file ossimPolyCutter.h.
protected |
Definition at line 97 of file ossimPolyCutter.h.
Referenced by addPolygon(), ossimGeoPolyCutter::addPolygon(), computeBoundingRect(), getPolygonList(), getTile(), ossimGeoPolyCutter::invertPolygon(), ossimGeoPolyCutter::loadState(), ossimPolyCutter(), saveState(), ossimGeoPolyCutter::saveState(), setNumberOfPolygons(), setPolygon(), and ossimGeoPolyCutter::transformVertices().
protected |
Definition at line 89 of file ossimPolyCutter.h.
Referenced by allocate(), getTile(), and initialize().
