class ossimWatermarkFilter Applies an image or watermark to image. More...
#include <ossimWatermarkFilter.h>
Public Types | |
| enum | WatermarkMode { UPPER_LEFT = 0, UPPER_CENTER = 1, UPPER_RIGHT = 2, CENTER = 3, LOWER_LEFT = 4, LOWER_CENTER = 5, LOWER_RIGHT = 6, UNIFORM_DENSE = 7, UNIFORM_SPARSE = 8, END = 9 } |
| ossimWatermarkFilter () | |
| contructor More... | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tile_rect, ossim_uint32 resLevel=0) |
| Initializes state of the object from the input connection. More... | |
| Method to the load (recreate) the state of the object from a keyword list. More... | |
| Set property. More... | |
| Adds this objects properties to the list. More... | |
| void | getModeList (vector< ossimString > &list) const |
| ossimWatermarkFilter::WatermarkMode | getMode () const |
| ossimString | getModeString () const |
| void | setFilename (const ossimFilename &file) |
| Sets theFilename to file. More... | |
| void | setMode (const ossimString &mode) |
| Sets the filter mode. More... | |
| void | setWeight (ossim_float64 weight) |
| Sets the weight. More... | |
| Print method. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimWatermarkFilter () |
| destructor More... | |
| bool | allocate () |
| Allocates / recomputes things that are needed. More... | |
| bool | openWatermarkFile () |
| Attempts to open "theFilename". More... | |
| template<class T > | |
| void | fill (T dummy) |
| Writes watermark(s) to theTile. More... | |
| void | getIntersectingRects (vector< ossimIrect > &rects) |
| Computes the bounding rectangles. More... | |
| void | getUpperLeftRect (vector< ossimIrect > &rects) |
| Addes upper left watermark rectangle to rects if it intersects theTile rect clipped to input bounding rect. More... | |
| void | getUpperCenterRect (vector< ossimIrect > &rects) |
| Addes upper center watermark rectangle to rects if it intersects theTile rect clipped to input bounding rect. More... | |
| void | getUpperRightRect (vector< ossimIrect > &rects) |
| Addes upper right watermark rectangle to rects if it intersects theTile rect clipped to input bounding rect. More... | |
| void | getCenterRect (vector< ossimIrect > &rects) |
| Addes center watermark rectangle to rects if it intersects theTile rect clipped to input bounding rect. More... | |
| void | getLowerLeftRect (vector< ossimIrect > &rects) |
| Addes lower left watermark rectangle to rects if it intersects theTile rect clipped to input bounding rect. More... | |
| void | getLowerCenterRect (vector< ossimIrect > &rects) |
| Addes lower center watermark rectangle to rects if it intersects theTile rect clipped to input bounding rect. More... | |
| void | getLowerRightRect (vector< ossimIrect > &rects) |
| Addes lower right watermark rectangle to rects if it intersects theTile rect clipped to input bounding rect. More... | |
| void | getUniformDenseRects (vector< ossimIrect > &rects) |
| Addes rectangles to rects if it intersects theTile rect clipped to input bounding rect. More... | |
| void | getUniformSparceRects (vector< ossimIrect > &rects) |
Protected Attributes | |
| ossimFilename | theFilename |
| File name of watermark image. More... | |
| ossim_float64 | theWatermarkWeight |
| Normalized between 0.0 and 1.0. More... | |
| ossimRefPtr< ossimImageData > | theTile |
| The returned tile. More... | |
| ossimRefPtr< ossimImageData > | theWatermark |
| Tile storage for watermark image. More... | |
| ossim_uint32 | theWatermarkNumberOfBands |
| The number of watermark bands. More... | |
| WatermarkMode | theMode |
| The filter mode. More... | |
| ossimIrect | theInputBoundingRect |
| The bounding rectangle of the input connection. More... | |
| ossim_uint32 | theInputNumberOfBands |
| The number of input bands. More... | |
| ossimScalarType | theInputScalarType |
| The input scalar type. More... | |
| bool | theDirtyFlag |
| Set in the initialize method this instructs the getTile that something has changes and it need to call initialize. More... | |
Protected Attributes inherited from ossimImageSourceFilter | |
| ossimImageSource * | theInputConnection |
Protected Attributes inherited from ossimSource | |
| bool | theEnableFlag |
| bool | theInitializedFlag |
Protected Attributes inherited from ossimConnectableObject | |
| ossimId | theId |
| ossimString | theDescription |
| ossimObject * | theOwner |
| bool | theInputListIsFixedFlag |
| Indicates whether the theInputObjectList is fixed. More... | |
| bool | theOutputListIsFixedFlag |
| Indicates whether the theOutputObjectList is fixed. More... | |
| ConnectableObjectList | theInputObjectList |
| Holds a list of input objects. More... | |
| ConnectableObjectList | theOutputObjectList |
| Holds a list of output objects. More... | |
Protected Attributes inherited from ossimListenerManager | |
| std::list< ossimListener * > | theListenerList |
| bool | theEnabledFlag |
| std::list< ossimListener * > | theDelayedAdd |
| std::list< ossimListener * > | theDelayedRemove |
| bool | theFireEventFlag |
Protected Attributes inherited from ossimListener | |
| bool | theListenerEnableFlag |
Positioning is based on mode. Density is base on alpha weight.
Definition at line 31 of file ossimWatermarkFilter.h.
| Enumerator | |
| UPPER_LEFT | |
| UPPER_CENTER | |
| UPPER_RIGHT | |
| CENTER | |
| LOWER_LEFT | |
| LOWER_CENTER | |
| LOWER_RIGHT | |
| UNIFORM_DENSE | |
| UNIFORM_SPARSE | |
| END | |
Definition at line 35 of file ossimWatermarkFilter.h.
| ossimWatermarkFilter::ossimWatermarkFilter | ( | ) |
contructor
Definition at line 45 of file ossimWatermarkFilter.cpp.
References ossimSource::theEnableFlag.
protectedvirtual |
destructor
Definition at line 68 of file ossimWatermarkFilter.cpp.
References theTile, and theWatermark.
protected |
Clears theDirtyFlag by setting it to false on success.
Definition at line 730 of file ossimWatermarkFilter.cpp.
References ossimImageDataFactory::create(), ossimImageSource::getBoundingRect(), ossimImageData::getNumberOfBands(), ossimImageSource::getNumberOfOutputBands(), ossimImageSource::getOutputScalarType(), ossimRectilinearDataObject::getScalarType(), ossimImageData::initialize(), ossimImageDataFactory::instance(), openWatermarkFile(), theDirtyFlag, theInputBoundingRect, ossimImageSourceFilter::theInputConnection, theInputNumberOfBands, theInputScalarType, theTile, theWatermark, and ossimRefPtr< T >::valid().
Referenced by getTile().
protected |
Performs theTile->validate() at the end if theTile was touched.
Definition at line 226 of file ossimWatermarkFilter.cpp.
References ossimIrect::clipToRect(), ossimImageData::getBuf(), ossimImageData::getImageRectangle(), getIntersectingRects(), ossimImageData::getMaxPix(), ossimImageData::getMinPix(), ossimImageData::getNullPix(), ossimImageData::getWidth(), ossimIrect::height(), theInputBoundingRect, theInputNumberOfBands, theTile, theWatermark, theWatermarkNumberOfBands, theWatermarkWeight, ossimIrect::ul(), ossimImageData::validate(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
protected |
| rects | Array to add rect to. |
Definition at line 468 of file ossimWatermarkFilter.cpp.
References ossimIrect::clipToRect(), ossimImageData::getImageRectangle(), ossimIrect::height(), ossimIrect::intersects(), ossimImageData::setOrigin(), theInputBoundingRect, theTile, theWatermark, ossimIrect::ul(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Referenced by getIntersectingRects().
Reimplemented from ossimConnectableObject.
Definition at line 85 of file ossimWatermarkFilter.cpp.
References getLongName(), and getModeList().
protected |
These are the rectangles in image space of the input connection to paint the watermark(s) on. The start of each rectangle will be the start of where "theWatermark" is painted.
Definition at line 365 of file ossimWatermarkFilter.cpp.
References CENTER, getCenterRect(), getLowerCenterRect(), getLowerLeftRect(), getLowerRightRect(), getUniformDenseRects(), getUniformSparceRects(), getUpperCenterRect(), getUpperLeftRect(), getUpperRightRect(), LOWER_CENTER, LOWER_LEFT, LOWER_RIGHT, theMode, UNIFORM_DENSE, UNIFORM_SPARSE, UPPER_CENTER, UPPER_LEFT, and UPPER_RIGHT.
Referenced by fill().
Definition at line 80 of file ossimWatermarkFilter.cpp.
Referenced by getDescription().
protected |
Definition at line 529 of file ossimWatermarkFilter.cpp.
protected |
Definition at line 503 of file ossimWatermarkFilter.cpp.
References ossimIrect::clipToRect(), ossimImageData::getImageRectangle(), ossimIrect::height(), ossimIrect::intersects(), ossimImageData::setOrigin(), theInputBoundingRect, theTile, theWatermark, ossimIrect::ul(), and ossimIpt::y.
protected |
Definition at line 563 of file ossimWatermarkFilter.cpp.
| ossimWatermarkFilter::WatermarkMode ossimWatermarkFilter::getMode | ( | ) | const |
Definition at line 1034 of file ossimWatermarkFilter.cpp.
References theMode.
| void ossimWatermarkFilter::getModeList | ( | vector< ossimString > & | list | ) | const |
| list | List initialized with watermark mode strings. |
Definition at line 1019 of file ossimWatermarkFilter.cpp.
References END.
| ossimString ossimWatermarkFilter::getModeString | ( | ) | const |
Definition at line 1039 of file ossimWatermarkFilter.cpp.
References CENTER, LOWER_CENTER, LOWER_LEFT, LOWER_RIGHT, theMode, UNIFORM_DENSE, UNIFORM_SPARSE, UPPER_CENTER, UPPER_LEFT, and UPPER_RIGHT.
Referenced by print().
| The | property to get as a string like "watermark_mode". |
Definition at line 948 of file ossimWatermarkFilter.cpp.
References ossimKeywordNames::FILENAME_KW, ossimFilenameProperty::ossimFilenamePropertyIoType_INPUT, ossimProperty::setCacheRefreshBit(), ossimFilenameProperty::setIoType(), and theFilename.
| propertyNames | Array to add to. |
Definition at line 1010 of file ossimWatermarkFilter.cpp.
References ossimKeywordNames::FILENAME_KW.
Definition at line 75 of file ossimWatermarkFilter.cpp.
| tile_rect | Rectangle to fill tile with. |
| resLevel | Reduced resolution level to grab from. |
Definition at line 106 of file ossimWatermarkFilter.cpp.
References allocate(), fill(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimIrect::intersects(), ossimImageData::loadTile(), ossimImageData::makeBlank(), OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_NULL, OSSIM_SCALAR_UNKNOWN, OSSIM_SINT16, OSSIM_SINT32, OSSIM_SINT8, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setImageRectangle(), theDirtyFlag, ossimSource::theEnableFlag, theInputBoundingRect, ossimImageSourceFilter::theInputConnection, theTile, theWatermarkWeight, and ossimRefPtr< T >::valid().
protected |
This will repeat the watermark throughout the input bounding rect.
Definition at line 598 of file ossimWatermarkFilter.cpp.
References ossimIrect::clipToRect(), ossimImageData::getImageRectangle(), ossimIrect::height(), ossimIrect::intersects(), ossimImageData::setOrigin(), theInputBoundingRect, theTile, theWatermark, ossimIrect::ul(), ossimIrect::width(), ossimIpt::x, x, ossimIpt::y, and y.
protected |
This will repeat the watermark sparsly throughout the input bounding rect.
Definition at line 636 of file ossimWatermarkFilter.cpp.
protected |
Definition at line 414 of file ossimWatermarkFilter.cpp.
References ossimIrect::clipToRect(), ossimImageData::getImageRectangle(), ossimIrect::intersects(), ossimImageData::setOrigin(), theInputBoundingRect, theTile, theWatermark, ossimIrect::ul(), ossimIrect::width(), and ossimIpt::x.
protected |
Definition at line 401 of file ossimWatermarkFilter.cpp.
References ossimIrect::clipToRect(), ossimImageData::getImageRectangle(), ossimIrect::intersects(), ossimImageData::setOrigin(), theInputBoundingRect, theTile, theWatermark, and ossimIrect::ul().
protected |
Definition at line 440 of file ossimWatermarkFilter.cpp.
Definition at line 676 of file ossimWatermarkFilter.cpp.
References ossimImageSource::getBoundingRect(), ossimImageSource::getNumberOfOutputBands(), ossimImageSource::getOutputScalarType(), ossimImageSourceFilter::initialize(), theDirtyFlag, theInputBoundingRect, ossimImageSourceFilter::theInputConnection, theInputNumberOfBands, and theInputScalarType.
| kwl | Keyword list to initialize from. |
| prefix | Usually something like: "object1." |
Keywords picked up by loadState:
filename: my_colormap_file.jpg
weight: .25
watermark_mode: upper_left
Definition at line 908 of file ossimWatermarkFilter.cpp.
References ossimKeywordlist::find(), and ossimImageSourceFilter::loadState().
protected |
This will load "theWatermark" with the image converting it to the scalar type of the input connection.
Definition at line 800 of file ossimWatermarkFilter.cpp.
Referenced by allocate().
Print method.
Called by: friend operator<<
Definition at line 1154 of file ossimWatermarkFilter.cpp.
References getModeString(), ossimSource::print(), theFilename, and theWatermarkWeight.
Keywords picked saved by saveState
weight: .25
Definition at line 892 of file ossimWatermarkFilter.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimKeywordNames::FILENAME_KW, and theFilename.
| void ossimWatermarkFilter::setFilename | ( | const ossimFilename & | file | ) |
| file | The watermark image file. |
Definition at line 1068 of file ossimWatermarkFilter.cpp.
References theDirtyFlag, theFilename, and theWatermark.
Referenced by setProperty().
| void ossimWatermarkFilter::setMode | ( | const ossimString & | mode | ) |
| mode | String representing mode. |
Definition at line 1085 of file ossimWatermarkFilter.cpp.
References CENTER, ossimString::downcase(), LOWER_CENTER, LOWER_LEFT, LOWER_RIGHT, theMode, UNIFORM_DENSE, UNIFORM_SPARSE, UPPER_CENTER, UPPER_LEFT, and UPPER_RIGHT.
Set property.
| property | Property to set if property->getName() matches a property name of this object. |
Definition at line 985 of file ossimWatermarkFilter.cpp.
References ossimKeywordNames::FILENAME_KW, and setFilename().
| void ossimWatermarkFilter::setWeight | ( | ossim_float64 | weight | ) |
Sets the weight.
| weight | Weight to use for watermark pixels normalize between 0.0 and 1.0. |
Definition at line 1139 of file ossimWatermarkFilter.cpp.
References theWatermarkWeight.
protected |
Definition at line 340 of file ossimWatermarkFilter.h.
Referenced by allocate(), getTile(), initialize(), and setFilename().
protected |
Definition at line 310 of file ossimWatermarkFilter.h.
Referenced by getProperty(), print(), saveState(), and setFilename().
protected |
Definition at line 328 of file ossimWatermarkFilter.h.
Referenced by allocate(), fill(), getCenterRect(), getLowerCenterRect(), getLowerLeftRect(), getLowerRightRect(), getTile(), getUniformDenseRects(), getUniformSparceRects(), getUpperCenterRect(), getUpperLeftRect(), getUpperRightRect(), and initialize().
protected |
Definition at line 331 of file ossimWatermarkFilter.h.
Referenced by allocate(), fill(), and initialize().
protected |
Definition at line 334 of file ossimWatermarkFilter.h.
Referenced by allocate(), and initialize().
protected |
The filter mode.
Definition at line 325 of file ossimWatermarkFilter.h.
Referenced by getIntersectingRects(), getMode(), getModeString(), and setMode().
protected |
The returned tile.
Definition at line 316 of file ossimWatermarkFilter.h.
Referenced by allocate(), fill(), getCenterRect(), getLowerCenterRect(), getLowerLeftRect(), getLowerRightRect(), getTile(), getUniformDenseRects(), getUniformSparceRects(), getUpperCenterRect(), getUpperLeftRect(), getUpperRightRect(), and ~ossimWatermarkFilter().
protected |
Definition at line 319 of file ossimWatermarkFilter.h.
Referenced by allocate(), fill(), getCenterRect(), getLowerCenterRect(), getLowerLeftRect(), getLowerRightRect(), getUniformDenseRects(), getUniformSparceRects(), getUpperCenterRect(), getUpperLeftRect(), getUpperRightRect(), setFilename(), and ~ossimWatermarkFilter().
protected |
Definition at line 322 of file ossimWatermarkFilter.h.
protected |
Definition at line 313 of file ossimWatermarkFilter.h.
Referenced by fill(), getTile(), print(), and setWeight().
