This allows one to assign a value to a group of bands. More...
#include <ossimValueAssignImageSourceFilter.h>
Public Types | |
| enum | ossimValueAssignType { ossimValueAssignType_SEPARATE = 1, ossimValueAssignType_GROUP = 2 } |
| ossimValueAssignImageSourceFilter (ossimObject *owner=NULL) | |
| void | setInputOutputValues (const vector< double > &inputValues, const vector< double > &outputValues) |
| const vector< double > & | getInputValues () const |
| const vector< double > & | getOutputValues () const |
| ossimValueAssignType | getValueAssignType () const |
| void | setValueAssignType (ossimValueAssignType type) |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimValueAssignImageSourceFilter () |
| void | allocate () |
| Called on first getTile, will initialize all data needed. More... | |
| void | validateArrays () |
| template<class T > | |
| void | executeAssign (T, ossimRefPtr< ossimImageData > &data) |
| void | executeAssignSeparate (T, ossimRefPtr< ossimImageData > &data) |
| void | executeAssignGroup (T, ossimRefPtr< ossimImageData > &data) |
It will test for equality band separate or as group. For example:
if we are testing as a group then the assign will not happen unless all values equal theInputValue array
inputValue = <1, 2, 3> outputValue = <100, 100, 100>
then it will only convert to 100, 100, 100 if the input equals all values of the output.
input <1, 55, 3> would become <1, 55, 3> input <1, 2, 3> would become <100, 100, 100>
Now for band separate it means you want to change on a per band and not as a group. For example:
input <1, 55, 3> would become <100, 55, 100>
Definition at line 42 of file ossimValueAssignImageSourceFilter.h.
| Enumerator | |
| ossimValueAssignType_SEPARATE | |
| ossimValueAssignType_GROUP | |
Definition at line 45 of file ossimValueAssignImageSourceFilter.h.
| ossimValueAssignImageSourceFilter::ossimValueAssignImageSourceFilter | ( | ossimObject * | owner = NULL | ) |
Definition at line 20 of file ossimValueAssignImageSourceFilter.cpp.
protectedvirtual |
Definition at line 27 of file ossimValueAssignImageSourceFilter.cpp.
protected |
Definition at line 242 of file ossimValueAssignImageSourceFilter.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimImageSourceFilter::theInputConnection, and theTile.
Referenced by getTile().
protected |
Definition at line 157 of file ossimValueAssignImageSourceFilter.cpp.
References executeAssignGroup(), executeAssignSeparate(), ossimValueAssignType_SEPARATE, theAssignType, and theInputValueArray.
protected |
Definition at line 197 of file ossimValueAssignImageSourceFilter.cpp.
References ossimImageData::getBuf(), ossimImageData::getHeight(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), min, theInputValueArray, and theOutputValueArray.
Referenced by executeAssign().
protected |
Definition at line 173 of file ossimValueAssignImageSourceFilter.cpp.
| const vector< double > & ossimValueAssignImageSourceFilter::getInputValues | ( | ) | const |
Definition at line 365 of file ossimValueAssignImageSourceFilter.cpp.
References theInputValueArray.
| const vector< double > & ossimValueAssignImageSourceFilter::getOutputValues | ( | ) | const |
Definition at line 369 of file ossimValueAssignImageSourceFilter.cpp.
References theOutputValueArray.
Definition at line 31 of file ossimValueAssignImageSourceFilter.cpp.
References allocate(), executeAssign(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimSource::isSourceEnabled(), ossimImageData::loadTile(), ossimImageData::makeBlank(), OSSIM_DOUBLE, OSSIM_EMPTY, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_NULL, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setImageRectangle(), ossimImageSourceFilter::theInputConnection, theTile, ossimRefPtr< T >::valid(), and ossimImageData::validate().
| ossimValueAssignImageSourceFilter::ossimValueAssignType ossimValueAssignImageSourceFilter::getValueAssignType | ( | ) | const |
Definition at line 374 of file ossimValueAssignImageSourceFilter.cpp.
References theAssignType.
Definition at line 236 of file ossimValueAssignImageSourceFilter.cpp.
References ossimImageSourceFilter::initialize().
Definition at line 297 of file ossimValueAssignImageSourceFilter.cpp.
References ossimKeywordlist::find(), ossimKeywordlist::getNumberOfSubstringKeys(), ossimImageSourceFilter::loadState(), ossimValueAssignType_GROUP, ossimValueAssignType_SEPARATE, theAssignType, theInputValueArray, theOutputValueArray, ossimString::toString(), and validateArrays().
Definition at line 257 of file ossimValueAssignImageSourceFilter.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimValueAssignType_SEPARATE, ossimImageSourceFilter::saveState(), theAssignType, theInputValueArray, theOutputValueArray, and ossimString::toString().
| void ossimValueAssignImageSourceFilter::setInputOutputValues | ( | const vector< double > & | inputValues, |
| const vector< double > & | outputValues | ||
Definition at line 129 of file ossimValueAssignImageSourceFilter.cpp.
References theInputValueArray, theOutputValueArray, and validateArrays().
| void ossimValueAssignImageSourceFilter::setValueAssignType | ( | ossimValueAssignType | type | ) |
Definition at line 378 of file ossimValueAssignImageSourceFilter.cpp.
protected |
Definition at line 138 of file ossimValueAssignImageSourceFilter.cpp.
References min, theInputValueArray, and theOutputValueArray.
Referenced by loadState(), and setInputOutputValues().
protected |
Definition at line 85 of file ossimValueAssignImageSourceFilter.h.
Referenced by executeAssign(), getValueAssignType(), loadState(), saveState(), and setValueAssignType().
protected |
Definition at line 83 of file ossimValueAssignImageSourceFilter.h.
Referenced by executeAssign(), executeAssignGroup(), executeAssignSeparate(), getInputValues(), loadState(), saveState(), setInputOutputValues(), and validateArrays().
protected |
Definition at line 84 of file ossimValueAssignImageSourceFilter.h.
Referenced by executeAssignGroup(), executeAssignSeparate(), getOutputValues(), loadState(), saveState(), setInputOutputValues(), and validateArrays().
protected |
Definition at line 86 of file ossimValueAssignImageSourceFilter.h.
Referenced by allocate(), and getTile().
