#include <ossimH5Reader.h>
| ossimH5ImageHandler () | |
| virtual | ~ossimH5ImageHandler () |
| Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More... | |
| Returns the number of bands in the image. More... | |
| Returns the number of lines in the image. More... | |
| Returns the number of samples in the image. More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
| Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. More... | |
| Returns the output pixel type of the tile source. More... | |
| bool | isOpen () const |
| virtual void | close () |
| Close method. More... | |
| Set propterty method. More... | |
| Get propterty method. More... | |
| Get propterty names. More... | |
| virtual void | addMetadata (ossimKeywordlist *kwl, const std::string &prefix) const |
| Adds metadata to keyword list. More... | |
| ossimImageHandler () | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimMetadataInterface | |
| ossimMetadataInterface () | |
| virtual | ~ossimMetadataInterface () |
| virtual destructor. More... | |
| virtual ossimRefPtr< ossimImageGeometry > | getInternalImageGeometry () |
| Method to get geometry from hdf file. More... | |
| ossimRefPtr< ossimProjection > | processCoarseGridProjection (H5::DataSet &latDataSet, H5::DataSet &lonDataSet, const ossimIrect &validRect) const |
| Gets projection from Latitude, Longitude, Height datasets if present. More... | |
| bool | getLatLonDatasetNames (H5::H5File *h5File, std::string &latName, std::string &lonName) const |
| Get dataset names for Latiitude and Longitude datasets. More... | |
| bool | getLatLonDatasets (H5::H5File *h5File, H5::DataSet &latDataSet, H5::DataSet &lonDataSet) const |
| bool | getDataSetRect (std::string &name, std::string &lonName) const |
| virtual bool | open () |
| open method. More... | |
| void | allocate () |
| Allocates the tile. More... | |
| void | addImageDatasetEntries (const std::vector< std::string > &names) |
| Adds image datasets from list of names. More... | |
| bool | isNppMission (H5::H5File *h5File) const |
Definition at line 35 of file ossimH5Reader.h.
| ossimH5ImageHandler::ossimH5ImageHandler | ( | ) |
default constructor
Definition at line 61 of file ossimH5Reader.cpp.
virtual destructor
Definition at line 84 of file ossimH5Reader.cpp.
References close(), and isOpen().
protected |
| names | List of dataset paths from hdf5 file. |
Definition at line 370 of file ossimH5Reader.cpp.
References ossim_hdf5::getExtents(), ossimH5ImageDataset::initialize(), ossimH5Options::instance(), ossimH5Options::isDatasetRenderable(), m_entries, and m_h5File.
This will add metadata to keyword list if found. Implemented to pass specific data to keyword list if found, e.g. acquisition_date, sensor_id, country_code
Satisfies pure virtual ossimMetadataInterface::addMetadata(...)
| kwl | Initialized by this. |
| prefix | e.g. "image0." (can be empty) |
Implements ossimMetadataInterface.
Definition at line 920 of file ossimH5Reader.cpp.
References ossimKeywordlist::addPair(), ossim_hdf5::getDatasetAttributeValue(), ossim_hdf5::getGroupAttributeValue(), m_h5File, and ossimString::string().
protected |
Allocates the tile.
Definition at line 92 of file ossimH5Reader.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), m_mutex, and m_tile.
Referenced by getTile().
Close method.
Definition at line 511 of file ossimH5Reader.cpp.
References ossimImageHandler::close(), m_entries, m_h5File, m_projection, and m_tile.
Referenced by ~ossimH5ImageHandler().
Definition at line 469 of file ossimH5Reader.cpp.
Definition at line 602 of file ossimH5Reader.cpp.
References m_currentEntry.
protected |
| entryList | This is the list to initialize with entry indexes. |
Definition at line 545 of file ossimH5Reader.cpp.
References m_entries.
Get the name of entry as a string.
Example given from HDF5 file:
entry_name: /All_Data/VIIRS-IMG-GTM-EDR-GEO_All/QF1_VIIRSGTMGEO
| entryIdx | Zero based entry index. If out of range name will be cleared. |
| name | Initialized by this. |
Definition at line 536 of file ossimH5Reader.cpp.
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 607 of file ossimH5Reader.cpp.
References ossimImageGeometryRegistry::extendGeometry(), ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), getInternalImageGeometry(), ossimImageGeometry::getProjection(), ossimImageHandler::initImageParameters(), ossimImageGeometryRegistry::instance(), m_mutex, and ossimImageHandler::theGeometry.
Note that rrds 0 is the highest resolution rrds.
Definition at line 222 of file ossimH5Reader.cpp.
References getNumberOfLines(), and getNumberOfSamples().
Implements ossimImageHandler.
Definition at line 454 of file ossimH5Reader.cpp.
Definition at line 449 of file ossimH5Reader.cpp.
protectedvirtual |
Definition at line 647 of file ossimH5Reader.cpp.
References ossimRefPtr< T >::get(), ossim_hdf5::getBilinearProjection(), getLatLonDatasetNames(), isOpen(), m_currentEntry, m_entries, m_h5File, m_projection, processCoarseGridProjection(), ossimImageGeometry::setProjection(), and ossimRefPtr< T >::valid().
Referenced by getImageGeometry().
protected |
| h5File | Pointer to file. |
| latName | Initializes by this. |
| lonName | Initializes by this. |
Definition at line 729 of file ossimH5Reader.cpp.
References ossimString::contains(), and ossim_hdf5::getDatasetNames().
Referenced by getInternalImageGeometry(), and getLatLonDatasets().
protected |
| Initializes | lat and lon data sets. |
| latDataSet | Initialized by this. |
| lonDataSet | Initialized by this. |
Definition at line 774 of file ossimH5Reader.cpp.
References ossimFilename::dirCat(), ossimFilename::exists(), ossim_hdf5::getGroupAttributeValue(), getLatLonDatasetNames(), ossimFilename::path(), status, ossimString::string(), and ossimImageHandler::theImageFile.
Definition at line 464 of file ossimH5Reader.cpp.
Definition at line 853 of file ossimH5Reader.cpp.
References ossimImageHandler::getNullPixelValue(), getOutputScalarType(), and OSSIM_FLOAT32.
Definition at line 531 of file ossimH5Reader.cpp.
Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 474 of file ossimH5Reader.cpp.
References m_currentEntry, and m_entries.
Referenced by getNumberOfOutputBands(), and getTile().
Definition at line 417 of file ossimH5Reader.cpp.
References ossimImageHandler::getNumberOfLines(), m_currentEntry, m_entries, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by getImageRectangle().
Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 486 of file ossimH5Reader.cpp.
References getNumberOfInputBands().
Definition at line 433 of file ossimH5Reader.cpp.
References ossimImageHandler::getNumberOfSamples(), m_currentEntry, m_entries, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Definition at line 492 of file ossimH5Reader.cpp.
References m_currentEntry, m_entries, and OSSIM_SCALAR_UNKNOWN.
Referenced by getNullPixelValue().
Overrides ossimImageHandler::getProperty.
| name | Property name to get. |
Definition at line 895 of file ossimH5Reader.cpp.
References ossimString::string().
Overrides ossimImageHandler::getPropertyNames.
| propertyNames | Array to initialize. |
Definition at line 913 of file ossimH5Reader.cpp.
References ossimImageHandler::getPropertyNames().
Satisfies pure virtual from TileSource class.
Definition at line 100 of file ossimH5Reader.cpp.
References allocate(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), m_mutex, m_tile, ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), and ossimRefPtr< T >::valid().
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands() |
Definition at line 129 of file ossimH5Reader.cpp.
References ossimIrect::area(), ossimIrect::clipToRect(), ossimIrect::completely_within(), getImageRectangle(), ossimImageData::getImageRectangle(), getNullPixelValue(), ossimImageData::getNumberOfBands(), getNumberOfInputBands(), getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), ossim_hdf5::getScalarType(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), ossimImageData::loadBand(), m_currentEntry, m_entries, m_mutex, ossimImageData::makeBlank(), OSSIM_FLOAT32, ossimReferenced::ref(), ossim::scalarSizeInBytes(), status, ossimReferenced::unref(), and ossimImageData::validate().
protected |
Definition at line 833 of file ossimH5Reader.cpp.
References ossim_hdf5::getGroupAttributeValue().
Definition at line 504 of file ossimH5Reader.cpp.
References m_currentEntry, m_entries, m_h5File, and true.
Referenced by getInternalImageGeometry(), getTile(), setCurrentEntry(), and ~ossimH5ImageHandler().
Definition at line 236 of file ossimH5Reader.cpp.
References ossimImageHandler::loadState(), and open().
protectedvirtual |
open method.
Definition at line 247 of file ossimH5Reader.cpp.
Referenced by loadState().
protected |
| latDataSet | H5::DataSet& to layer, e.g. /All_Data/VIIRS-DNB-GEO_All/Latitude |
| lonDataSet | H5::DataSet& to layer, e.g. /All_Data/VIIRS-DNB-GEO_All/Longitude |
Definition at line 698 of file ossimH5Reader.cpp.
References ossimRefPtr< T >::get().
Referenced by getInternalImageGeometry().
Definition at line 230 of file ossimH5Reader.cpp.
References ossimImageHandler::saveState().
| entryIdx | Entry number to select. |
Definition at line 555 of file ossimH5Reader.cpp.
References ossimString::clear(), ossimImageHandler::completeOpen(), isOpen(), m_currentEntry, m_entries, m_tile, ossimImageHandler::theGeometry, and ossimImageHandler::theOverviewFile.
Overrides ossimImageHandler::setProperty.
Current property name handled: "scale" One double value representing the scale in meters per pixel. It is assumed the scale is same for x and y direction.
| property | to set. |
Definition at line 871 of file ossimH5Reader.cpp.
References ossimProperty::getName(), ossimString::string(), and ossimRefPtr< T >::valid().
protected |
Definition at line 290 of file ossimH5Reader.h.
Referenced by getCurrentEntry(), getInternalImageGeometry(), getNumberOfInputBands(), getNumberOfLines(), getNumberOfSamples(), getOutputScalarType(), getTile(), isOpen(), and setCurrentEntry().
protected |
Definition at line 289 of file ossimH5Reader.h.
Referenced by addImageDatasetEntries(), close(), getEntryList(), getEntryNames(), getInternalImageGeometry(), getNumberOfEntries(), getNumberOfInputBands(), getNumberOfLines(), getNumberOfSamples(), getOutputScalarType(), getTile(), isOpen(), and setCurrentEntry().
protected |
Definition at line 288 of file ossimH5Reader.h.
Referenced by addImageDatasetEntries(), addMetadata(), close(), getInternalImageGeometry(), and isOpen().
protected |
Definition at line 293 of file ossimH5Reader.h.
Referenced by allocate(), getImageGeometry(), and getTile().
protected |
Definition at line 292 of file ossimH5Reader.h.
Referenced by close(), and getInternalImageGeometry().
protected |
Definition at line 291 of file ossimH5Reader.h.
Referenced by allocate(), close(), getTile(), and setCurrentEntry().
