Image handler used for tiled Quickbird imagery. More...
#include <ossimQbTileFilesHandler.h>
| ossimQbTileFilesHandler () | |
| virtual | ~ossimQbTileFilesHandler () |
| Destructor: More... | |
| virtual bool | open () |
| Opens the image file given entry index. More... | |
| Fetch the tile-files common RPC data file and create the projection for this image. More... | |
Public Member Functions inherited from ossimTiledImageHandler | |
| ossimTiledImageHandler () | |
| virtual | ~ossimTiledImageHandler () |
| *virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| Returns the tile height of the image or 0 if the image is not tiled. More... | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &rect, ossim_uint32 resLevel) |
| Fills the requested tile by pulling pixels from multiple file tiles as needed. More... | |
| Returns scalar type of first tile (should be the same for all tiles) More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| Returns overall bounding rect in image space. More... | |
| ossimImageHandler () | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| bool | computeImageRects () |
| Initializes tile image rects by considering adjacent row/col offsets. More... | |
Protected Member Functions inherited from ossimTiledImageHandler | |
| void | allocate () |
| Initialize tile buffer to match image datatype. More... | |
Definition at line 20 of file ossimQbTileFilesHandler.h.
| ossimQbTileFilesHandler::ossimQbTileFilesHandler | ( | ) |
protected |
Called when TIL doesn't contain the info. Returns true if successful.
Definition at line 249 of file ossimQbTileFilesHandler.cpp.
References ossimQuickbirdMetaData::getImageSize(), ossimTiledImageHandler::m_fullImgRect, ossimTiledImageHandler::m_tileFiles, ossimQuickbirdMetaData::open(), ossimIrect::set_lr(), ossimIrect::set_ulx(), ossimIrect::set_uly(), ossimImageHandler::theImageFile, ossimIpt::x, and ossimIpt::y.
Definition at line 186 of file ossimQbTileFilesHandler.cpp.
References ossimFilename::exists(), ossimRefPtr< T >::get(), ossimErrorStatusInterface::getErrorStatus(), ossimImageHandler::getExternalImageGeometry(), ossimQuickbirdMetaData::getMapProjectionKwl(), ossimImageHandler::initImageParameters(), ossimProjectionFactoryRegistry::instance(), ossimTiledImageHandler::m_fullImgRect, ossimFilename::setExtension(), ossimImageGeometry::setProjection(), ossimImageGeometry::setTransform(), ossimImageHandler::theGeometry, ossimImageHandler::theImageFile, true, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimIpt::x, and ossimIpt::y.
This class does not support multiple entries.
| imageFile | File to open. |
| entryIndex |
Implements ossimTiledImageHandler.
Definition at line 61 of file ossimQbTileFilesHandler.cpp.
