This uses a derivative of Blinn's bump function to compute a 3-D looking image. More...
#include <ossimBumpShadeTileSource.h>
| ossimBumpShadeTileSource () | |
| ossimString | getShortName () const |
| ossimString | getLongName () const |
| ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | getTile (ossimImageData *tile, ossim_uint32 resLevel=0) |
| This should always return 3. More... | |
| The output scalar type should always be 8-bit. More... | |
| virtual double | getNullPixelValue () const |
| the null pixel is 0.0. More... | |
| the min pixel is 1.0. More... | |
| the max pixel is 255. More... | |
| virtual double | getAzimuthAngle () const |
| virtual double | getElevationAngle () const |
| virtual void | setAzimuthAngle (double angle) |
| virtual void | setElevationAngle (double angle) |
| void | computeLightDirection () |
| Will re-compute the light direction given the elevation angle and azimuth angle. More... | |
| void | setRgbColorSource (ossim_uint8 r, ossim_uint8 g, ossim_uint8 b) |
| Set the red, green and blue color source values. More... | |
| void | getRgbColorSource (ossim_uint8 &r, ossim_uint8 &g, ossim_uint8 &b) const |
| Gets the red, green and blue color source values. More... | |
Public Member Functions inherited from ossimImageCombiner | |
| ossimImageCombiner () | |
| ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag) | |
| ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual void | updateRects () |
| This will go through and precompute the bounding rects of each input image. More... | |
| Returns the number of bands available from the input. More... | |
| virtual ossim_uint32 | getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to retrieve the number of overlapping images withint the given rect. More... | |
| virtual void | getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to populate the result with the index of the overlapping images. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | hasDifferentInputs () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimBumpShadeTileSource () |
| void | allocate () |
| void | computeColor (ossim_uint8 &r, ossim_uint8 &g, ossim_uint8 &b, ossim_float64 normalX, ossim_float64 normalY, ossim_float64 normalZ, ossim_uint8 dr, ossim_uint8 dg, ossim_uint8 db) const |
Protected Member Functions inherited from ossimImageCombiner | |
| virtual | ~ossimImageCombiner () |
| void | precomputeBounds () const |
The elevation data can be from Grey Scale image or from a Dted file. This class can take one or two inputs. The First input is an elevation input that is used to compute a perturbed Normal which is used in a simple lambertian shading equation. The second input is some color source (Grey or RGB) that defines the diffuse color used within the illumination equation for each pixel. If the diffuse color input is not supplied then an all white color is used for the color. There are several adjustable parameters that can be set: 1) the Incident light vector described by the Azimuth and Elevation Angle, 2) the pixel scale used along the x and y direction, and 3) the partial derivative matrix used for the partial derivative computation along the x and y direction.
Some examples of good values:
If we are using dted 90 meters as input for shading then:
1) set pixel scale to 180. Since the partials do 2*dx and 2*dy then
the scale is 2*90meters = 180.
2) set azimuth angle to 45 and set elevation angle to 45 degrees. Change
them to see the effects.
3) use the following matrix -1 0 1
-1 0 1
-1 0 1
1 1 1
0 0 0
-1 -1 -1for the partials along x and y directions respectively. These matrices
(f(x+dx, y) - f(x-dx, y))/2*dx and (f(x, y+dy) - f(x, y-dy))/2*dy
for an apprximate derivative about some point x, y
If we are using pixel intesity (1 - 255) then set the scales to around 100.
Note: varying the scales will vary the smoothness/roughness of the surface
Smaller the scale the rougher the surface will look.The output of this source is always a 3-band 8-bit image.
Keywords: type: ossimBumpShadeTileSource azimuth_angle: 45.000000000000000 elevation_angle: 45.000000000000000 scale_per_pixel_x: 180.000000000000000 // this is the 2*dx defined above scale_per_pixel_y: 180.000000000000000 // this is the 2*dy defined above
the next set of keywords are optional and the default is as defined above. these define the matrix.
A typical chain would look something like this:
OrthoMosaicOfElevation–>Normals–>Renderer–>|
|–> BumpShade–>Output
ColorSource--------------------—>Renderer–>|NOTES:
1) "Normals" is an ossimImageToPlaneNormalFilter class
2) The bump map input source is used to bump or shade the input color source. The input color source currently must be a 1 or 3 band image. Note that the output of this source is always 3 bands (r, g, b).
3) If no color source (2nd input layer) is present the r,g,b values will be used. The method setRgbColorSource can be used to control this.
Definition at line 101 of file ossimBumpShadeTileSource.h.
| ossimBumpShadeTileSource::ossimBumpShadeTileSource | ( | ) |
Definition at line 35 of file ossimBumpShadeTileSource.cpp.
References initialize().
protectedvirtual |
Definition at line 48 of file ossimBumpShadeTileSource.cpp.
protected |
Definition at line 304 of file ossimBumpShadeTileSource.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), and m_tile.
Referenced by getTile().
required to be overriden by derived classes
Reimplemented from ossimImageCombiner.
Definition at line 451 of file ossimBumpShadeTileSource.cpp.
References PTR_CAST.
protected |
Definition at line 264 of file ossimBumpShadeTileSource.cpp.
References ossimRgbVector::clamp(), and m_lightDirection.
| void ossimBumpShadeTileSource::computeLightDirection | ( | ) |
Definition at line 310 of file ossimBumpShadeTileSource.cpp.
References ossimMatrix3x3::createRotationMatrix(), m_lightDirection, m_lightSourceAzimuthAngle, m_lightSourceElevationAngle, and ossimColumnVector3d::unit().
Referenced by initialize().
Definition at line 460 of file ossimBumpShadeTileSource.cpp.
Definition at line 465 of file ossimBumpShadeTileSource.cpp.
Definition at line 431 of file ossimBumpShadeTileSource.cpp.
References m_lightSourceAzimuthAngle.
Definition at line 436 of file ossimBumpShadeTileSource.cpp.
References m_lightSourceElevationAngle.
Definition at line 401 of file ossimBumpShadeTileSource.cpp.
Definition at line 426 of file ossimBumpShadeTileSource.cpp.
Definition at line 421 of file ossimBumpShadeTileSource.cpp.
Definition at line 416 of file ossimBumpShadeTileSource.cpp.
Definition at line 406 of file ossimBumpShadeTileSource.cpp.
Definition at line 411 of file ossimBumpShadeTileSource.cpp.
References OSSIM_UCHAR.
Definition at line 497 of file ossimBumpShadeTileSource.cpp.
References ossimImageSource::getProperty(), m_lightSourceAzimuthAngle, m_lightSourceElevationAngle, ossimProperty::setCacheRefreshBit(), and ossimString::toString().
Definition at line 515 of file ossimBumpShadeTileSource.cpp.
References ossimImageSource::getPropertyNames().
| void ossimBumpShadeTileSource::getRgbColorSource | ( | ossim_uint8 & | r, |
| ossim_uint8 & | g, | ||
| ossim_uint8 & | b | ||
| ) | const |
| r | red |
| g | green |
| b | blue |
Definition at line 531 of file ossimBumpShadeTileSource.cpp.
Definition at line 396 of file ossimBumpShadeTileSource.cpp.
Definition at line 52 of file ossimBumpShadeTileSource.cpp.
References allocate(), ossimRefPtr< T >::get(), ossimConnectableObject::getInput(), ossimImageData::initialize(), m_tile, ossimImageData::setImageRectangle(), and ossimRefPtr< T >::valid().
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. This is the default implementation that is not thread-friendly as it uses the object's tile then simply copies its buffer to the provided tile. Eventually, all image sources should override this method. |
Definition at line 75 of file ossimBumpShadeTileSource.cpp.
References computeColor(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getImageRectangle(), ossimConnectableObject::getInput(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageSource::getNumberOfOutputBands(), ossimImageSource::getOutputScalarType(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimImageData::getWidth(), ossimSource::isSourceEnabled(), m_b, m_g, m_r, m_tile, ossimImageData::makeBlank(), OSSIM_DOUBLE, OSSIM_EMPTY, OSSIM_NULL, OSSIM_UCHAR, ossimNotify(), ossimNotifyLevel_NOTICE, PTR_CAST, ossimImageData::setImageRectangle(), status, ossimImageData::validate(), x, and y.
Definition at line 283 of file ossimBumpShadeTileSource.cpp.
References computeLightDirection(), ossimConnectableObject::getInput(), ossimImageCombiner::initialize(), ossimImageSource::initialize(), and m_tile.
Referenced by connectInputEvent(), disconnectInputEvent(), ossimBumpShadeTileSource(), propertyEvent(), and refreshEvent().
Definition at line 329 of file ossimBumpShadeTileSource.cpp.
References ossimKeywordNames::AZIMUTH_ANGLE_KW, ossimKeywordNames::ELEVATION_ANGLE_KW, ossimKeywordlist::find(), m_lightSourceAzimuthAngle, m_lightSourceElevationAngle, and ossimString::toDouble().
Definition at line 470 of file ossimBumpShadeTileSource.cpp.
Definition at line 475 of file ossimBumpShadeTileSource.cpp.
Definition at line 376 of file ossimBumpShadeTileSource.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::AZIMUTH_ANGLE_KW, ossimKeywordNames::ELEVATION_ANGLE_KW, m_lightSourceAzimuthAngle, and m_lightSourceElevationAngle.
Definition at line 441 of file ossimBumpShadeTileSource.cpp.
Referenced by ossimHillshadeTool::initProcessingChain().
Definition at line 446 of file ossimBumpShadeTileSource.cpp.
Definition at line 480 of file ossimBumpShadeTileSource.cpp.
References m_lightSourceAzimuthAngle, m_lightSourceElevationAngle, and ossimImageSource::setProperty().
| void ossimBumpShadeTileSource::setRgbColorSource | ( | ossim_uint8 | r, |
| ossim_uint8 | g, | ||
| ossim_uint8 | b | ||
This sets the rgb value used when no second layer is present.
The default is: r = 255, g = 255, b = 255
| r | red |
| g | green |
| b | blue |
Definition at line 522 of file ossimBumpShadeTileSource.cpp.
protected |
Definition at line 268 of file ossimBumpShadeTileSource.h.
Referenced by getRgbColorSource(), getTile(), and setRgbColorSource().
protected |
Definition at line 267 of file ossimBumpShadeTileSource.h.
protected |
This is computed from the elevation and azimuth angles of the light source.
Definition at line 261 of file ossimBumpShadeTileSource.h.
Referenced by computeColor(), and computeLightDirection().
protected |
Used for the light vector computation.
Definition at line 255 of file ossimBumpShadeTileSource.h.
Referenced by computeLightDirection(), getAzimuthAngle(), getProperty(), loadState(), saveState(), setAzimuthAngle(), and setProperty().
protected |
Definition at line 250 of file ossimBumpShadeTileSource.h.
Referenced by computeLightDirection(), getElevationAngle(), getProperty(), loadState(), saveState(), setElevationAngle(), and setProperty().
protected |
rgb values used when no color source (2nd layer) is present.
Definition at line 266 of file ossimBumpShadeTileSource.h.
protected |
The result of the illumination equation is stored in here.
This is populated on each call to getTile.
Definition at line 245 of file ossimBumpShadeTileSource.h.
Referenced by allocate(), getTile(), and initialize().
