This class manages the sequencing of tile requests across multiple threads. More...
#include <ossimMultiThreadSequencer.h>
Classes | |
| class | ossimGetTileCallback |
| Private class for getTile job callbacks. More... | |
| class | ossimGetTileJob |
| Private class representing a getTile job. More... | |
| ossimMultiThreadSequencer (ossimImageSource *inputSource=NULL, ossim_uint32 num_threads=0, ossimObject *owner=NULL) | |
| virtual | ~ossimMultiThreadSequencer () |
| virtual void | setToStartOfSequence () |
| Overrides base class implementation. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 resLevel=0) |
| Overrides base class in order to implement multi-threaded tile requests. More... | |
| void | setNumberOfThreads (ossim_uint32 num_threads) |
| Specifies number of thread to support. More... | |
| ossim_uint32 | getNumberOfThreads () const |
| Fetches the number of threads being used. Useful when this object decides the quantity. More... | |
| ossim_uint32 | maxCacheSize () const |
| Accessed for performance logging. More... | |
| bool | loadState (const ossimKeywordlist &kwl, const char *prefix) |
| void | setUseSharedHandlers (bool use_shared_handlers) |
| void | setCacheTileSize (ossim_uint32 cache_tile_size) |
| void | setUseCache (bool use_cache) |
| double | handlerGetTileT () |
Public Member Functions inherited from ossimImageSourceSequencer | |
| ossimImageSourceSequencer (ossimImageSource *inputSource=NULL, ossimObject *owner=NULL) | |
| virtual | ~ossimImageSourceSequencer () |
| ossim_int64 | getNumberOfTiles () const |
| ossim_int64 | getNumberOfTilesHorizontal () const |
| ossim_int64 | getNumberOfTilesVertical () const |
| virtual void | setAreaOfInterest (const ossimIrect &areaOfInterest) |
| const ossimIrect & | getAreaOfInterest () const |
| virtual bool | getNextTileStream (std::ostream &bos) |
| virtual bool | getTileOrigin (ossim_int64 id, ossimIpt &origin) const |
| bool | getTileRect (ossim_int64 tile_id, ossimIrect &rect) const |
| Establishes a tile rect given tile ID. More... | |
| virtual ossimRefPtr< ossimImageData > | getTile (ossim_int64 id, ossim_uint32 resLevel=0) |
| virtual void | slaveProcessTiles () |
| virtual bool | isMaster () const |
| virtual ossimIpt | getTileSize () const |
| virtual void | setTileSize (const ossimIpt &tileSize) |
| virtual void | setTileSize (ossim_int32 width, ossim_int32 height) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| void | setCreateHistogram (bool create_histogram) |
| void | getBinInformation (ossim_uint32 &numberOfBins, ossim_float64 &minValue, ossim_float64 &maxValue, ossimScalarType stype) const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| virtual void | propertyEvent (ossimPropertyEvent &) |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Public Attributes | |
| ossim_uint32 | d_maxCacheUsed |
| ossim_uint32 | d_cacheEmptyCount |
| double | d_idleTime1 |
| double | d_idleTime2 |
| double | d_idleTime3 |
| double | d_idleTime4 |
| double | d_idleTime5 |
| double | d_idleTime6 |
| double | d_jobGetTileT |
| bool | d_useSharedHandlers |
| ossim_uint32 | d_cacheTileSize |
| bool | d_useCache |
Protected Types | |
| typedef std::map< ossim_uint32, ossimRefPtr< ossimImageData > > | TileCache |
| void | initJobs () |
| Queues up the optimum amount of jobs given the availability of thread chains and space in the output tile cache. More... | |
| void | setTileInCache (ossim_uint32 tile_id, ossimImageData *tile, ossim_uint32 chain_id, double dt) |
| Access method to tile cache with scope lock to avoid multiple threads writing to the cache simultaneously. More... | |
| void | nextJob (ossim_uint32 chain_id) |
| Method to job queue with scope lock to avoid multiple threads modifying the queue simultaneously. More... | |
| void | print (ostringstream &msg) const |
| For debug – thread-safe console output. More... | |
Protected Member Functions inherited from ossimImageSourceSequencer | |
| virtual void | updateTileDimensions () |
Friends | |
Note that multi- threading can only be achieved through the use of getNextTile() method for sequencing. Conventional getTiles will not be multi-threaded.
Definition at line 26 of file ossimMultiThreadSequencer.h.
protected |
Definition at line 75 of file ossimMultiThreadSequencer.h.
| ossimMultiThreadSequencer::ossimMultiThreadSequencer | ( | ossimImageSource * | inputSource = NULL, |
| ossim_uint32 | num_threads = 0, |
| ossimObject * | owner = NULL |
Definition at line 80 of file ossimMultiThreadSequencer.cpp.
< Same as base class' theInputConnection
Definition at line 135 of file ossimMultiThreadSequencer.cpp.
References m_callback, m_inputChain, and m_jobMtQueue.
The output tile should be available in the tile cache, otherwise, method waits until it becomes available.
Reimplemented from ossimImageSourceSequencer.
Definition at line 231 of file ossimMultiThreadSequencer.cpp.
References ossim::Block::block(), d_cacheEmptyCount, d_debugEnabled, d_idleTime1, d_idleTime2, d_idleTime3, d_t1, d_timedBlocksDt, d_timeMetricsEnabled, ossimTimer::instance(), m_cacheMutex, m_getTileBlock, m_inputChain, m_nextJobBlock, m_nextTileID, m_tileCache, m_totalNumberOfTiles, print(), ossim::Block::release(), ossim::Block::reset(), setToStartOfSequence(), ossimImageSourceSequencer::theCurrentTileNumber, ossimTimer::time_s(), and ossimRefPtr< T >::valid().
inline |
Definition at line 48 of file ossimMultiThreadSequencer.h.
Referenced by ossimIgen::outputProduct().
| double ossimMultiThreadSequencer::handlerGetTileT | ( | ) |
Definition at line 465 of file ossimMultiThreadSequencer.cpp.
References ossimImageHandlerMtAdaptor::d_getTileT, m_inputChain, ossimImageChainMtAdaptor::m_sharedHandlers, and ossimRefPtr< T >::valid().
protected |
Definition at line 475 of file ossimMultiThreadSequencer.cpp.
References ossimKeywordlist::find(), ossimImageSourceSequencer::loadState(), setCacheTileSize(), setNumberOfThreads(), setUseCache(), setUseSharedHandlers(), status, ossimString::toBool(), and ossimString::toUInt32().
inline |
Definition at line 51 of file ossimMultiThreadSequencer.h.
protected |
Definition at line 401 of file ossimMultiThreadSequencer.cpp.
References ossim::Block::block(), d_debugEnabled, d_idleTime5, d_idleTime6, d_t1, d_timedBlocksDt, d_timeMetricsEnabled, ossimTimer::instance(), m_cacheMutex, m_callback, m_jobMtQueue, m_jobMutex, m_maxCacheSize, m_nextJobBlock, m_nextTileID, m_tileCache, m_totalNumberOfTiles, print(), ossim::Block::reset(), and ossimTimer::time_s().
Referenced by ossimMultiThreadSequencer::ossimGetTileJob::run().
protected |
Definition at line 460 of file ossimMultiThreadSequencer.cpp.
References d_printMutex.
Referenced by getNextTile(), nextJob(), ossimMultiThreadSequencer::ossimGetTileJob::run(), setTileInCache(), and setToStartOfSequence().
| void ossimMultiThreadSequencer::setCacheTileSize | ( | ossim_uint32 | cache_tile_size | ) |
Definition at line 353 of file ossimMultiThreadSequencer.cpp.
References d_cacheTileSize, m_inputChain, ossimImageChainMtAdaptor::setCacheTileSize(), and ossimRefPtr< T >::valid().
Referenced by loadState().
| void ossimMultiThreadSequencer::setNumberOfThreads | ( | ossim_uint32 | num_threads | ) |
Default behavior (if this method is never called) is to query the system for number of cores available.
Definition at line 331 of file ossimMultiThreadSequencer.cpp.
References m_inputChain, m_jobMtQueue, m_maxCacheSize, m_maxTileCacheFactor, m_nextTileID, m_numThreads, ossimImageChainMtAdaptor::setNumberOfThreads(), and ossimRefPtr< T >::valid().
protected |
NOTE: chain_id being passed only for debug. To be removed.
Definition at line 373 of file ossimMultiThreadSequencer.cpp.
References d_debugEnabled, d_idleTime4, d_jobGetTileT, d_maxCacheUsed, d_t1, d_timeMetricsEnabled, ossimTimer::instance(), m_cacheMutex, m_tileCache, print(), and ossimTimer::time_s().
This call initiates the multi-threaded getTile jobs for the first N tiles.
The base class should have successfully assigned its input:
Definition at line 145 of file ossimMultiThreadSequencer.cpp.
References ossimImageChain::add(), d_cacheTileSize, d_debugEnabled, d_useCache, d_useSharedHandlers, ossimConnectableObject::disconnectAllOutputs(), ossim::getNumberOfThreads(), m_callback, m_inputChain, m_jobMtQueue, m_maxCacheSize, m_maxTileCacheFactor, m_nextTileID, m_numThreads, m_totalNumberOfTiles, print(), ossimImageChainMtAdaptor::setCacheTileSize(), ossimImageChainMtAdaptor::setNumberOfThreads(), ossimImageChainMtAdaptor::setUseCache(), ossimImageChainMtAdaptor::setUseSharedHandlers(), ossimImageSourceSequencer::theCurrentTileNumber, ossimImageSourceSequencer::theInputConnection, ossimImageSourceSequencer::theNumberOfTilesHorizontal, ossimImageSourceSequencer::theNumberOfTilesVertical, and ossimRefPtr< T >::valid().
Referenced by getNextTile().
| void ossimMultiThreadSequencer::setUseCache | ( | bool | use_cache | ) |
Definition at line 361 of file ossimMultiThreadSequencer.cpp.
References d_useCache, m_inputChain, ossimImageChainMtAdaptor::setUseCache(), and ossimRefPtr< T >::valid().
| void ossimMultiThreadSequencer::setUseSharedHandlers | ( | bool | use_shared_handlers | ) |
Definition at line 345 of file ossimMultiThreadSequencer.cpp.
References d_useSharedHandlers, m_inputChain, ossimImageChainMtAdaptor::setUseSharedHandlers(), and ossimRefPtr< T >::valid().
friend |
Definition at line 97 of file ossimMultiThreadSequencer.h.
| ossim_uint32 ossimMultiThreadSequencer::d_cacheEmptyCount |
Definition at line 59 of file ossimMultiThreadSequencer.h.
Referenced by getNextTile(), and ossimIgen::outputProduct().
| ossim_uint32 ossimMultiThreadSequencer::d_cacheTileSize |
Definition at line 69 of file ossimMultiThreadSequencer.h.
Referenced by setCacheTileSize(), and setToStartOfSequence().
protected |
Definition at line 144 of file ossimMultiThreadSequencer.h.
| double ossimMultiThreadSequencer::d_idleTime1 |
Definition at line 60 of file ossimMultiThreadSequencer.h.
| double ossimMultiThreadSequencer::d_idleTime2 |
Definition at line 61 of file ossimMultiThreadSequencer.h.
| double ossimMultiThreadSequencer::d_idleTime3 |
Definition at line 62 of file ossimMultiThreadSequencer.h.
| double ossimMultiThreadSequencer::d_idleTime4 |
Definition at line 63 of file ossimMultiThreadSequencer.h.
Referenced by setTileInCache().
| double ossimMultiThreadSequencer::d_idleTime5 |
Definition at line 64 of file ossimMultiThreadSequencer.h.
Referenced by nextJob(), and ossimIgen::outputProduct().
| double ossimMultiThreadSequencer::d_idleTime6 |
Definition at line 65 of file ossimMultiThreadSequencer.h.
Referenced by nextJob().
| double ossimMultiThreadSequencer::d_jobGetTileT |
Definition at line 66 of file ossimMultiThreadSequencer.h.
Referenced by ossimIgen::outputProduct(), and setTileInCache().
| ossim_uint32 ossimMultiThreadSequencer::d_maxCacheUsed |
Definition at line 58 of file ossimMultiThreadSequencer.h.
mutableprotected |
Definition at line 142 of file ossimMultiThreadSequencer.h.
Referenced by print().
protected |
Definition at line 147 of file ossimMultiThreadSequencer.h.
Referenced by getNextTile(), nextJob(), and setTileInCache().
protected |
Definition at line 145 of file ossimMultiThreadSequencer.h.
Referenced by getNextTile(), and nextJob().
protected |
Definition at line 146 of file ossimMultiThreadSequencer.h.
mutableprotected |
Definition at line 143 of file ossimMultiThreadSequencer.h.
| bool ossimMultiThreadSequencer::d_useCache |
Definition at line 70 of file ossimMultiThreadSequencer.h.
Referenced by setToStartOfSequence(), and setUseCache().
| bool ossimMultiThreadSequencer::d_useSharedHandlers |
Definition at line 68 of file ossimMultiThreadSequencer.h.
Referenced by setToStartOfSequence(), and setUseSharedHandlers().
mutableprotected |
Definition at line 135 of file ossimMultiThreadSequencer.h.
protected |
Definition at line 130 of file ossimMultiThreadSequencer.h.
Referenced by nextJob(), setToStartOfSequence(), and ~ossimMultiThreadSequencer().
protected |
Definition at line 138 of file ossimMultiThreadSequencer.h.
Referenced by getNextTile(), and ossimMultiThreadSequencer::ossimGetTileJob::run().
protected |
Same as base class' theInputConnection.
Definition at line 127 of file ossimMultiThreadSequencer.h.
Referenced by getNextTile(), handlerGetTileT(), ossimMultiThreadSequencer::ossimGetTileJob::run(), setCacheTileSize(), setNumberOfThreads(), setToStartOfSequence(), setUseCache(), setUseSharedHandlers(), and ~ossimMultiThreadSequencer().
protected |
Definition at line 128 of file ossimMultiThreadSequencer.h.
Referenced by nextJob(), setNumberOfThreads(), setToStartOfSequence(), and ~ossimMultiThreadSequencer().
mutableprotected |
Definition at line 136 of file ossimMultiThreadSequencer.h.
protected |
Definition at line 133 of file ossimMultiThreadSequencer.h.
Referenced by nextJob(), setNumberOfThreads(), and setToStartOfSequence().
protected |
Definition at line 134 of file ossimMultiThreadSequencer.h.
Referenced by setNumberOfThreads(), and setToStartOfSequence().
protected |
Definition at line 139 of file ossimMultiThreadSequencer.h.
protected |
ID of next tile to be threaded, different from base class' theCurrentTileNumber.
Definition at line 131 of file ossimMultiThreadSequencer.h.
Referenced by getNextTile(), nextJob(), setNumberOfThreads(), and setToStartOfSequence().
protected |
Definition at line 129 of file ossimMultiThreadSequencer.h.
protected |
Saves tiles output by threaded jobs.
Definition at line 132 of file ossimMultiThreadSequencer.h.
protected |
Definition at line 137 of file ossimMultiThreadSequencer.h.
Referenced by getNextTile(), nextJob(), and setToStartOfSequence().
