This implements a Local correlation fusion based on the paper: More...
#include <ossimLocalCorrelationFusion.h>
| ossimLocalCorrelationFusion () | |
| virtual void | initAdjustableParameters () |
Public Member Functions inherited from ossimFusionCombiner | |
| ossimFusionCombiner () | |
| ossimFusionCombiner (ossimObject *owner) | |
| ossimScalarType | getOutputScalarType () const |
Public Member Functions inherited from ossimImageCombiner | |
| ossimImageCombiner () | |
| ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag) | |
| ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual void | updateRects () |
| This will go through and precompute the bounding rects of each input image. More... | |
| Returns the number of bands available from the input. More... | |
| virtual ossim_uint32 | getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to retrieve the number of overlapping images withint the given rect. More... | |
| virtual void | getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to populate the result with the index of the overlapping images. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | hasDifferentInputs () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Provides the derived adjustable class an opportunity to update its state after a param change. More... | |
| Dumps the currently active adjustment to ostream. More... | |
| virtual | ~ossimLocalCorrelationFusion () |
| void | setFilters () |
| bool | computeRegression (ossim_float64 &slopeResult, const ossimIpt &origin, ossimRefPtr< ossimImageData > panData, ossimRefPtr< ossimImageData > colorData, ossim_uint32 colorBandIdx) |
Protected Member Functions inherited from ossimFusionCombiner | |
| virtual | ~ossimFusionCombiner () |
| ossimRefPtr< ossimImageData > | getNormIntensity (const ossimIrect &rect, ossim_uint32 resLevel) |
| ossimRefPtr< ossimImageData > | getNormTile (const ossimIrect &rect, ossim_uint32 resLevel) |
Protected Member Functions inherited from ossimImageCombiner | |
| virtual | ~ossimImageCombiner () |
| void | precomputeBounds () const |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
"A Local Correlation Approach For the Fusion of Remote Sensing Data With Different Spatial Resolution In Forestry Applications" by J. Hill, C. Diemer, O. Stover, and Th. Udelhoven Published in: International Archives of Photogrammetry and Remote Sensing, Vol 32, Part 7-4-3 W6, Valladolid, Spain, 3-4 June, 1999
A new band is computed by the formula:
ColorHigh = ColorLow + RegressionSlope*(PanHigh-PanLow);
Adjustable paraemters have been added to clamp the regression slope and attenuate colorLowOffset value and blurring the Pan.
ColorHigh = ColorLow + Clamp(RegressionSlope)*Attenuator(PanHigh-PanLow);
The regression coefficient is coputed for each color band.
Definition at line 38 of file ossimLocalCorrelationFusion.h.
| ossimLocalCorrelationFusion::ossimLocalCorrelationFusion | ( | ) |
Definition at line 27 of file ossimLocalCorrelationFusion.cpp.
References initAdjustableParameters(), setFilters(), theHighPassFilter, and theLowPassFilter.
protectedvirtual |
Definition at line 40 of file ossimLocalCorrelationFusion.cpp.
Reimplemented from ossimAdjustableParameterInterface.
Definition at line 408 of file ossimLocalCorrelationFusion.cpp.
References ossimAdjustableParameterInterface::computeParameterOffset(), and theBlurrKernelWidth.
Referenced by loadState().
protected |
Definition at line 266 of file ossimLocalCorrelationFusion.cpp.
References ossim2dLinearRegression::addPoint(), ossimImageData::getBuf(), ossim2dLinearRegression::getEquation(), ossimImageData::getImageRectangle(), ossimImageData::getNullPix(), ossim2dLinearRegression::solve(), theRegressionWidth, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimIrect::width(), ossimIpt::x, x, ossimIpt::y, and y.
inlinevirtual |
Implements ossimAdjustableParameterInterface.
Definition at line 47 of file ossimLocalCorrelationFusion.h.
inlinevirtual |
Definition at line 51 of file ossimLocalCorrelationFusion.h.
Definition at line 44 of file ossimLocalCorrelationFusion.cpp.
References ossimAdjustableParameterInterface::computeParameterOffset(), ossimImageData::copyTileToNormalizedBuffer(), ossimImageData::dup(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimConnectableObject::getInput(), ossimFusionCombiner::getNormTile(), ossimImageData::getNumberOfBands(), ossimImageSource::getTile(), ossimImageGaussianFilter::getTile(), ossimConvolutionSource::getTile(), ossimImageData::getWidth(), initialize(), ossimImageData::initialize(), ossimImageData::loadTile(), ossimIrect::lr(), ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_NORMALIZED_FLOAT, ossimImageData::setImageRectangle(), theHighPassFilter, ossimFusionCombiner::theInputConnection, ossimFusionCombiner::theIntensityConnection, theLowPassFilter, theNormHighPassTile, theNormLowPassTile, theRegressionWidth, ossimFusionCombiner::theTile, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIpt::x, x, ossimIpt::y, and y.
Definition at line 359 of file ossimLocalCorrelationFusion.cpp.
References ossimAdjustableParameterInterface::resizeAdjustableParameterArray().
Referenced by ossimLocalCorrelationFusion().
Reimplemented from ossimFusionCombiner.
Definition at line 214 of file ossimLocalCorrelationFusion.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::disconnect(), ossimImageSource::getObject(), ossimFusionCombiner::initialize(), ossimImageGaussianFilter::initialize(), ossimConvolutionSource::initialize(), PTR_CAST, setFilters(), theHighPassFilter, ossimFusionCombiner::theIntensityConnection, and theLowPassFilter.
Referenced by getTile().
Reimplemented from ossimImageCombiner.
Definition at line 424 of file ossimLocalCorrelationFusion.cpp.
References adjustableParametersChanged(), ossimAdjustableParameterInterface::loadAdjustments(), and ossimImageCombiner::loadState().
Definition at line 415 of file ossimLocalCorrelationFusion.cpp.
References ossimAdjustableParameterInterface::saveAdjustments(), and ossimImageCombiner::saveState().
protected |
Definition at line 234 of file ossimLocalCorrelationFusion.cpp.
References ossimAdjustableParameterInterface::computeParameterOffset(), ossimImageGaussianFilter::setGaussStd(), theBlurrKernelWidth, theHighPassKernelWidth, theHighPassMatrix, and theLowPassFilter.
Referenced by initialize(), and ossimLocalCorrelationFusion().
protected |
Definition at line 72 of file ossimLocalCorrelationFusion.h.
Referenced by adjustableParametersChanged(), and setFilters().
protected |
Definition at line 78 of file ossimLocalCorrelationFusion.h.
Referenced by getTile(), initialize(), and ossimLocalCorrelationFusion().
protected |
Definition at line 73 of file ossimLocalCorrelationFusion.h.
Referenced by setFilters().
protected |
Definition at line 83 of file ossimLocalCorrelationFusion.h.
protected |
Definition at line 77 of file ossimLocalCorrelationFusion.h.
Referenced by getTile(), initialize(), ossimLocalCorrelationFusion(), and setFilters().
protected |
Definition at line 81 of file ossimLocalCorrelationFusion.h.
protected |
Definition at line 80 of file ossimLocalCorrelationFusion.h.
protected |
Definition at line 79 of file ossimLocalCorrelationFusion.h.
protected |
Definition at line 74 of file ossimLocalCorrelationFusion.h.
Referenced by computeRegression(), and getTile().
