Cache Tile Source. More...
#include <ossimCacheTileSource.h>
Public Types | |
| typedef std::vector< ossimAppFixedTileCache::ossimAppFixedCacheId > | RLevelCacheList |
| ossimCacheTileSource () | |
| Will construct a new Application cache. More... | |
| virtual | ~ossimCacheTileSource () |
| virtual void | flush () |
| virtual void | setCachingEnabledFlag (bool value) |
| virtual void | setEventProgressFlag (bool value) |
| void | getTileSize (ossimIpt &size) const |
| void | setTileSize (const ossimIpt &size) |
| Set the tile size. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Cache Tile Source.
Definition at line 19 of file ossimCacheTileSource.h.
| typedef std::vector<ossimAppFixedTileCache::ossimAppFixedCacheId> ossimCacheTileSource::RLevelCacheList |
Definition at line 22 of file ossimCacheTileSource.h.
| ossimCacheTileSource::ossimCacheTileSource | ( | ) |
Definition at line 30 of file ossimCacheTileSource.cpp.
References ossim::defaultTileSize(), theFixedTileSize, and theTileSizeXY.
Definition at line 44 of file ossimCacheTileSource.cpp.
References deleteRlevelCache().
protected |
Definition at line 71 of file ossimCacheTileSource.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimImageSourceFilter::theInputConnection, and theTile.
protected |
Definition at line 646 of file ossimCacheTileSource.cpp.
References ossimAppFixedTileCache::deleteCache(), ossimAppFixedTileCache::instance(), and theRLevelCacheList.
Referenced by initializeRlevelCache(), loadState(), and ~ossimCacheTileSource().
protectedvirtual |
Definition at line 264 of file ossimCacheTileSource.cpp.
References ossimAppFixedTileCache::addTile(), ossimIrect::clipToRect(), fireProgressEvent(), ossimRefPtr< T >::get(), ossimImageSource::getBoundingRect(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageSource::getTile(), ossimAppFixedTileCache::getTile(), ossimAppFixedTileCache::getTileSize(), ossimIrect::hasNans(), ossimIrect::height(), ossimAppFixedTileCache::instance(), ossimImageData::loadTile(), ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_NULL, ossimDataObject::setDataObjectStatus(), ossimImageData::setImageRectangle(), ossimIrect::stretchToTileBoundary(), theCachingEnabled, theFixedTileSize, ossimImageSourceFilter::theInputConnection, theTile, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
protectedvirtual |
Definition at line 595 of file ossimCacheTileSource.cpp.
References ossimListenerManager::fireEvent(), and theEventProgressFlag.
Referenced by fillTile().
Definition at line 53 of file ossimCacheTileSource.cpp.
References ossimAppFixedTileCache::flush(), ossimAppFixedTileCache::instance(), and theRLevelCacheList.
Referenced by initialize(), and setCachingEnabledFlag().
protected |
Definition at line 604 of file ossimCacheTileSource.cpp.
References ossimImageSource::getBoundingRect(), ossimImageSource::getTileHeight(), ossimImageSource::getTileWidth(), ossimIrect::height(), initializeRlevelCache(), ossimAppFixedTileCache::instance(), ossim::max(), ossim::min(), ossimAppFixedTileCache::newTileCache(), ossimIrect::stretchToTileBoundary(), theFixedTileSize, ossimImageSourceFilter::theInputConnection, theRLevelCacheList, theTileSizeXY, theUseInputTileSizeFlag, ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Definition at line 555 of file ossimCacheTileSource.cpp.
Definition at line 474 of file ossimCacheTileSource.cpp.
Definition at line 545 of file ossimCacheTileSource.cpp.
Definition at line 560 of file ossimCacheTileSource.cpp.
Definition at line 81 of file ossimCacheTileSource.cpp.
Referenced by ossimImageHandlerMtAdaptor::getTile().
Returns the default processing tile height.
Definition at line 415 of file ossimCacheTileSource.cpp.
References theFixedTileSize, and ossimIpt::y.
| void ossimCacheTileSource::getTileSize | ( | ossimIpt & | size | ) | const |
Definition at line 579 of file ossimCacheTileSource.cpp.
References size, and theFixedTileSize.
Returns the default processing tile width.
Definition at line 410 of file ossimCacheTileSource.cpp.
References theFixedTileSize, and ossimIpt::x.
Definition at line 64 of file ossimCacheTileSource.cpp.
References flush(), ossimImageSourceFilter::initialize(), and theTile.
protected |
Definition at line 656 of file ossimCacheTileSource.cpp.
References deleteRlevelCache(), ossimImageSource::getNumberOfDecimationLevels(), and theRLevelCacheList.
Referenced by getCacheId(), and setTileSize().
Definition at line 420 of file ossimCacheTileSource.cpp.
References deleteRlevelCache(), ossimKeywordNames::ENABLE_CACHE_KW, ossimKeywordlist::find(), theCachingEnabled, and ossimString::toBool().
Definition at line 455 of file ossimCacheTileSource.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::ENABLE_CACHE_KW, and theCachingEnabled.
Definition at line 574 of file ossimCacheTileSource.cpp.
References theEventProgressFlag.
Definition at line 503 of file ossimCacheTileSource.cpp.
| void ossimCacheTileSource::setTileSize | ( | const ossimIpt & | size | ) |
Set the tile size.
This changes underlying cache tile size.
| Size | of cache tile. |
Definition at line 584 of file ossimCacheTileSource.cpp.
References initializeRlevelCache(), size, theFixedTileSize, and theTile.
Referenced by ossimSingleImageChain::createRenderedChain(), and ossimImageHandlerMtAdaptor::setAdaptee().
protected |
Definition at line 80 of file ossimCacheTileSource.h.
Referenced by fillTile(), loadState(), saveState(), and setCachingEnabledFlag().
protected |
Definition at line 81 of file ossimCacheTileSource.h.
Referenced by fireProgressEvent(), and setEventProgressFlag().
protected |
Definition at line 79 of file ossimCacheTileSource.h.
Referenced by fillTile(), getCacheId(), getTileHeight(), getTileSize(), getTileWidth(), ossimCacheTileSource(), and setTileSize().
protected |
Definition at line 83 of file ossimCacheTileSource.h.
Referenced by deleteRlevelCache(), flush(), getCacheId(), and initializeRlevelCache().
protected |
Definition at line 78 of file ossimCacheTileSource.h.
Referenced by allocate(), fillTile(), initialize(), and setTileSize().
protected |
Definition at line 84 of file ossimCacheTileSource.h.
Referenced by getCacheId(), and ossimCacheTileSource().
protected |
Definition at line 82 of file ossimCacheTileSource.h.
Referenced by getCacheId().
