#include <ossimGridRemapSource.h>
| ossimGridRemapSource () | |
| ossimGridRemapSource (ossimImageSource *inputSource, ossimGridRemapEngine *engine) | |
| void | setRemapEngine (ossimGridRemapEngine *engine) |
| ossimGridRemapEngine * | getRemapEngine () |
| virtual void | initialize (const ossimDrect &uv_rect, const ossimDpt &grid_spacing) |
| void | setGridNode (const ossimDpt &view_pt, const double *value) |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &origin, ossim_uint32 resLevel=0) |
| void | lock () |
| void | unlock () |
| bool | isLocked () const |
| ossimDblGrid * | getGrid (unsigned int index) |
| const ossimFilename & | getGridFilename () const |
| void | setGridFilename (const ossimFilename &grid_filename) |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimGridRemapSource () |
| void | deallocateGrids () |
| ossimGridRemapSource::ossimGridRemapSource | ( | ) |
Constructors:
Definition at line 47 of file ossimGridRemapSource.cpp.
References ossimSource::disableSource().
| ossimGridRemapSource::ossimGridRemapSource | ( | ossimImageSource * | inputSource, |
| ossimGridRemapEngine * | engine | ||
Definition at line 62 of file ossimGridRemapSource.cpp.
protectedvirtual |
Definition at line 78 of file ossimGridRemapSource.cpp.
References deallocateGrids(), and theRemapEngine.
protected |
Deallocates grid memory.
Definition at line 326 of file ossimGridRemapSource.cpp.
Referenced by initialize(), and ~ossimGridRemapSource().
| ossimDblGrid * ossimGridRemapSource::getGrid | ( | unsigned int | index | ) |
Provides access to individual grids (pointer) given an index. Null pointer returned if index out of range.
Definition at line 314 of file ossimGridRemapSource.cpp.
References theGrids.
inline |
Returns grid filename (may be empty)
Definition at line 120 of file ossimGridRemapSource.h.
References theGridFilename.
inline |
Provides access to the remap engine:
Definition at line 59 of file ossimGridRemapSource.h.
References theRemapEngine.
Implementation of virtual method to return remapped tile.
Definition at line 118 of file ossimGridRemapSource.cpp.
References ossimDataObject::getDataObjectStatus(), ossimImageSource::getTile(), ossimSource::isSourceEnabled(), OSSIM_EMPTY, OSSIM_NULL, ossimGridRemapEngine::remapTile(), theGridIsFilled, theGrids, ossimImageSourceFilter::theInputConnection, theRemapEngine, ossimIrect::ul(), ossimRefPtr< T >::valid(), and ossimImageData::validate().
Permits initializing the remap grid after construction.
Definition at line 88 of file ossimGridRemapSource.cpp.
References deallocateGrids(), ossimGridRemapEngine::getNumberOfParams(), theGridFilename, theGridIsFilled, theGrids, theRemapEngine, and ossimString::toString().
inline |
Returns the status of the lock flag.
Definition at line 109 of file ossimGridRemapSource.h.
References theRemapIsLockedFlag.
Restore the state of the object from a keywordlist.
Definition at line 169 of file ossimGridRemapSource.cpp.
inline |
Locks the image to prevent grid adjustment. The remapper continues to remap given the current grid (if enabled), but all target values computed are such that no change in the grids will occur in an adjsutment. If more than one overlapping image is locked, the target will may be influenced by all locked images, but the remap grids will not be updated.
Definition at line 99 of file ossimGridRemapSource.h.
Referenced by ossimAtbController::lockImage(), and ossimAtbController::unlockImage().
Save the state of the object to a keywordlist.
Definition at line 247 of file ossimGridRemapSource.cpp.
References ossimKeywordlist::add(), theGridFilename, and theRemapEngine.
| void ossimGridRemapSource::setGridFilename | ( | const ossimFilename & | grid_filename | ) |
Sets the grid filename and initiates read.
Definition at line 359 of file ossimGridRemapSource.cpp.
| void ossimGridRemapSource::setGridNode | ( | const ossimDpt & | view_pt, |
| const double * | value | ||
Sets a node of the member grid to the value specified. The grid is flagged as unfilled.
Definition at line 298 of file ossimGridRemapSource.cpp.
References theGridIsFilled, and theGrids.
| void ossimGridRemapSource::setRemapEngine | ( | ossimGridRemapEngine * | engine | ) |
ossimAtbPointSource Initializes the remap engine. This object implements specific algorithms for interpreting the grids owned by this remapper. It actually performs the remapping.
Definition at line 348 of file ossimGridRemapSource.cpp.
References theGridIsFilled, and theRemapEngine.
inline |
Unlocks the grids for adjustment.
Definition at line 104 of file ossimGridRemapSource.h.
protected |
Definition at line 136 of file ossimGridRemapSource.h.
Referenced by getGridFilename(), initialize(), saveState(), and setGridFilename().
protected |
Definition at line 139 of file ossimGridRemapSource.h.
Referenced by getTile(), initialize(), setGridNode(), and setRemapEngine().
protected |
Definition at line 135 of file ossimGridRemapSource.h.
Referenced by getGrid(), getTile(), initialize(), and setGridNode().
protected |
Definition at line 137 of file ossimGridRemapSource.h.
Referenced by getRemapEngine(), getTile(), initialize(), saveState(), setRemapEngine(), and ~ossimGridRemapSource().
protected |
Definition at line 138 of file ossimGridRemapSource.h.
Referenced by isLocked(), lock(), and unlock().
