#include <ossimImageSourceSequencer.h>
| ossimImageSourceSequencer (ossimImageSource *inputSource=NULL, ossimObject *owner=NULL) | |
| virtual | ~ossimImageSourceSequencer () |
| ossim_int64 | getNumberOfTiles () const |
| ossim_int64 | getNumberOfTilesHorizontal () const |
| ossim_int64 | getNumberOfTilesVertical () const |
| virtual void | setAreaOfInterest (const ossimIrect &areaOfInterest) |
| const ossimIrect & | getAreaOfInterest () const |
| virtual void | setToStartOfSequence () |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 resLevel=0) |
| virtual bool | getNextTileStream (std::ostream &bos) |
| virtual bool | getTileOrigin (ossim_int64 id, ossimIpt &origin) const |
| bool | getTileRect (ossim_int64 tile_id, ossimIrect &rect) const |
| Establishes a tile rect given tile ID. More... | |
| virtual ossimRefPtr< ossimImageData > | getTile (ossim_int64 id, ossim_uint32 resLevel=0) |
| virtual void | slaveProcessTiles () |
| virtual bool | isMaster () const |
| virtual ossimIpt | getTileSize () const |
| virtual void | setTileSize (const ossimIpt &tileSize) |
| virtual void | setTileSize (ossim_int32 width, ossim_int32 height) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| void | setCreateHistogram (bool create_histogram) |
| bool | loadState (const ossimKeywordlist &kwl, const char *prefix) |
| void | getBinInformation (ossim_uint32 &numberOfBins, ossim_float64 &minValue, ossim_float64 &maxValue, ossimScalarType stype) const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| virtual void | propertyEvent (ossimPropertyEvent &) |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual void | updateTileDimensions () |
Definition at line 22 of file ossimImageSourceSequencer.h.
| ossimImageSourceSequencer::ossimImageSourceSequencer | ( | ossimImageSource * | inputSource = NULL, |
| ossimObject * | owner = NULL |
Definition at line 30 of file ossimImageSourceSequencer.cpp.
References ossimListenerManager::addListener(), ossimConnectableObject::connectMyInputTo(), ossim::defaultTileSize(), initialize(), ossimIrect::makeNan(), theAreaOfInterest, theInputConnection, and theTileSize.
Definition at line 56 of file ossimImageSourceSequencer.cpp.
References ossimListenerManager::removeListener().
required to be overriden by derived classes
Implements ossimConnectableObject.
Definition at line 165 of file ossimImageSourceSequencer.cpp.
References PTR_CAST.
Reimplemented from ossimConnectableObjectListener.
Definition at line 171 of file ossimImageSourceSequencer.cpp.
References initialize().
Definition at line 176 of file ossimImageSourceSequencer.cpp.
References ossimConnectableObject::getInput(), PTR_CAST, and theInputConnection.
| const ossimIrect & ossimImageSourceSequencer::getAreaOfInterest | ( | ) | const |
Just returns the current area of interest.
Definition at line 238 of file ossimImageSourceSequencer.cpp.
References theAreaOfInterest.
Referenced by ossimArcInfoGridWriter::writeFile().
| void ossimImageSourceSequencer::getBinInformation | ( | ossim_uint32 & | numberOfBins, |
| ossim_float64 & | minValue, | ||
| ossim_float64 & | maxValue, | ||
| ossimScalarType | stype | ||
| ) | const |
Definition at line 503 of file ossimImageSourceSequencer.cpp.
References OSSIM_DEFAULT_MAX_PIX_SINT16, OSSIM_DEFAULT_MAX_PIX_UCHAR, OSSIM_DEFAULT_MAX_PIX_UINT11, OSSIM_DEFAULT_MAX_PIX_UINT12, OSSIM_DEFAULT_MAX_PIX_UINT13, OSSIM_DEFAULT_MAX_PIX_UINT14, OSSIM_DEFAULT_MAX_PIX_UINT15, OSSIM_DEFAULT_MAX_PIX_UINT16, OSSIM_DEFAULT_MIN_PIX_SINT16, OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SINT16, OSSIM_SINT32, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, and OSSIM_USHORT15.
Referenced by getTile().
This will return the bounding rect of the source.
We can have several sources which are in a chain to modify the bounding image rect. lets say you are next to an image handler then it will return the bounding rect for that image. If you are at the right side of a resampler then you will get a bounding rect along the image view plane. This is going to be a very import method for both image writers, mosaics or anything that needs to operate only within the bounds of an image.
Definition at line 181 of file ossimImageSourceSequencer.cpp.
References ossimImageSource::getBoundingRect(), ossimIrect::hasNans(), ossimDrect::makeNan(), theAreaOfInterest, and theInputConnection.
Referenced by ossimGdalWriter::buildGdalOverviews(), ossimImageFileWriter::initialize(), ossimTiffWriter::openTiff(), ossimImageFileWriter::setAreaOfInterest(), ossimArcInfoGridWriter::writeBinaryAigBounds(), ossimNitf20Writer::writeBlockBandSeparate(), ossimNitfWriter::writeBlockBandSeparate(), ossimNitf20Writer::writeBlockBandSequential(), ossimNitfWriter::writeBlockBandSequential(), ossimNitfWriterBase::writeGeometry(), ossimKakaduJp2Writer::writeGeotiffBox(), and ossimKakaduJp2Writer::writeGmlBox().
Will return the decimation factor for the given resolution level.
the decimation is the scale from Resolution 0 or full res. Usually this is a power of 2 decimation where the decimation result is 1.0/2^resoltion.
Definition at line 196 of file ossimImageSourceSequencer.cpp.
References ossimImageSource::getDecimationFactor(), ossimDpt::makeNan(), and theInputConnection.
Definition at line 206 of file ossimImageSourceSequencer.cpp.
References ossimImageSource::getDecimationFactors(), and theInputConnection.
Definition at line 464 of file ossimImageSourceSequencer.cpp.
References ossimImageSource::getMaxPixelValue(), and theInputConnection.
Referenced by ossimArcInfoGridWriter::writeBinaryAigStats(), ossimPngWriter::writeSignificantBits(), and ossimTiffWriter::writeTiffTags().
Definition at line 454 of file ossimImageSourceSequencer.cpp.
References ossimImageSource::getMinPixelValue(), and theInputConnection.
Referenced by ossimArcInfoGridWriter::writeBinaryAigStats(), and ossimTiffWriter::writeTiffTags().
Will allow you to get the next tile in the sequence. Note the last tile returned will be an invalid ossimRefPtr<ossimImageData>. Callers should be able to do:
ossimRefPtr<ossimImageData> id = sequencer->getNextTile(); while (id.valid()) { doSomething; id = sequencer->getNextTile(); }
Reimplemented in ossimImageMpiMWriterSequenceConnection, ossimMultiThreadSequencer, and ossimImageMpiSWriterSequenceConnection.
Definition at line 318 of file ossimImageSourceSequencer.cpp.
References ossimImageData::getBuf(), ossimImageSource::getTile(), getTileRect(), ossimImageData::setImageRectangle(), theBlankTile, theCurrentTileNumber, theInputConnection, and ossimRefPtr< T >::valid().
Referenced by ossimImageHistogramSource::computeNormalModeHistogram(), ossimImageStatisticsSource::computeStatisticsTemplate(), ossimPotraceTool::convertToBitmap(), ossimImageMpiMWriterSequenceConnection::getNextTile(), getTile(), while(), ossimNitf20Writer::writeBlockBandSeparate(), ossimNitfWriter::writeBlockBandSeparate(), ossimNitf20Writer::writeBlockBandSequential(), ossimNitfWriter::writeBlockBandSequential(), and ossimArcInfoGridWriter::writeFile().
Definition at line 338 of file ossimImageSourceSequencer.cpp.
Definition at line 444 of file ossimImageSourceSequencer.cpp.
References ossimImageSource::getNullPixelValue(), and theInputConnection.
Will return the number of resolution levels.
Note: resolution level 0 is included in the return count.
Definition at line 214 of file ossimImageSourceSequencer.cpp.
References ossimImageSource::getNumberOfDecimationLevels(), and theInputConnection.
Returns the number of bands available from the input.
Implements ossimImageSource.
Definition at line 474 of file ossimImageSourceSequencer.cpp.
References ossimImageSource::getNumberOfOutputBands(), and theInputConnection.
| ossim_int64 ossimImageSourceSequencer::getNumberOfTiles | ( | ) | const |
This will return the number of tiles within the area of interest.
Definition at line 61 of file ossimImageSourceSequencer.cpp.
References theNumberOfTilesHorizontal, and theNumberOfTilesVertical.
Referenced by ossimImageHistogramSource::computeNormalModeHistogram(), ossimImageMpiMWriterSequenceConnection::getNextTile(), getTile(), getTileOrigin(), ossimImageMpiSWriterSequenceConnection::slaveProcessTiles(), ossimNitf20Writer::writeBlockBandSeparate(), ossimNitfWriter::writeBlockBandSeparate(), ossimNitf20Writer::writeBlockBandSequential(), ossimNitfWriter::writeBlockBandSequential(), and ossimArcInfoGridWriter::writeFile().
| ossim_int64 ossimImageSourceSequencer::getNumberOfTilesHorizontal | ( | ) | const |
Will return the number of tiles along the x or horizontal direction.
Definition at line 67 of file ossimImageSourceSequencer.cpp.
References theNumberOfTilesHorizontal.
Referenced by ossimArcInfoGridWriter::writeBinaryAigHeader(), ossimNitfWriter::writeBlockBandSeparate(), ossimNitf20Writer::writeBlockBandSequential(), ossimNitfWriter::writeBlockBandSequential(), and ossimGpkgWriter::writeTiles().
| ossim_int64 ossimImageSourceSequencer::getNumberOfTilesVertical | ( | ) | const |
Will return the number of tiles along the y or vertical direction.
Definition at line 72 of file ossimImageSourceSequencer.cpp.
References theNumberOfTilesVertical.
Definition at line 77 of file ossimImageSourceSequencer.cpp.
References ossimImageSource::getOutputScalarType(), OSSIM_SCALAR_UNKNOWN, and theInputConnection.
Referenced by ossimGdalWriter::allocateGdalDriverOptions(), ossimWriter::getTiffSampleFormat(), ossimWriter::needsMinMax(), ossimTiffWriter::openTiff(), ossimPdfWriter::setupInputChain(), ossimArcInfoGridWriter::writeBinaryAigHeader(), ossimNitf20Writer::writeBlockBandSeparate(), ossimNitfWriter::writeBlockBandSeparate(), ossimNitf20Writer::writeBlockBandSequential(), ossimNitfWriter::writeBlockBandSequential(), ossimJpegWriter::writeFile(), ossimWriter::writeMinMaxTiffTags(), ossimPngWriter::writeSignificantBits(), ossimWriter::writeSMinSMaxTiffTags(), ossimWriter::writeTiffTags(), and ossimTiffWriter::writeTiffTags().
Definition at line 248 of file ossimImageSourceSequencer.cpp.
References ossimMultiBandHistogram::create(), ossimImageDataFactory::create(), ossimMultiResLevelHistogram::create(), ossimRefPtr< T >::get(), getBinInformation(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimMultiResLevelHistogram::getMultiBandHistogram(), getNextTile(), ossimImageData::getNumberOfBands(), getNumberOfTiles(), ossimRectilinearDataObject::getScalarType(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimImageData::loadTile(), ossimImageData::makeBlank(), OSSIM_EMPTY, ossimImageData::populateHistogram(), ossimImageData::setImageRectangle(), setToStartOfSequence(), theCreateHistogram, and theInputConnection.
Definition at line 343 of file ossimImageSourceSequencer.cpp.
Returns the default processing tile height.
Definition at line 489 of file ossimImageSourceSequencer.cpp.
References theTileSize, and ossimIpt::y.
Referenced by ossimArcInfoGridWriter::writeBinaryAigHeader(), ossimArcInfoGridWriter::writeFile(), and ossimWriter::writeStream().
Definition at line 395 of file ossimImageSourceSequencer.cpp.
References getNumberOfTiles(), OSSIM_DEFAULT_MAX_PIX_SINT32, theAreaOfInterest, theCurrentTileNumber, theNumberOfTilesHorizontal, theNumberOfTilesVertical, theTileSize, ossimIrect::ul(), ossimIpt::x, x, ossimIpt::y, and y.
Referenced by ossimImageMpiMWriterSequenceConnection::getNextTile(), and getTileRect().
| bool ossimImageSourceSequencer::getTileRect | ( | ossim_int64 | tile_id, |
| ossimIrect & | rect | ||
| ) | const |
| tile_id | |
| rect | Rectangle to initialize. |
Definition at line 429 of file ossimImageSourceSequencer.cpp.
References getTileOrigin(), ossimIrect::set_lrx(), ossimIrect::set_lry(), ossimIrect::set_ul(), theTileSize, ossimIpt::x, and ossimIpt::y.
Referenced by getNextTile(), and ossimMultiThreadSequencer::ossimGetTileJob::run().
Definition at line 87 of file ossimImageSourceSequencer.cpp.
References theTileSize.
Returns the default processing tile width.
Definition at line 484 of file ossimImageSourceSequencer.cpp.
References theTileSize, and ossimIpt::x.
This must be called. We can only initialize this object completely if we know all connections are valid. Some other object drives this and so the connection's initialize will be called after. The job of this connection is to set up the sequence. It will default to the bounding rect. The area of interest can be set to some other rectagle (use setAreaOfInterest).
Reimplemented in ossimImageMpiMWriterSequenceConnection, and ossimImageMpiSWriterSequenceConnection.
Definition at line 132 of file ossimImageSourceSequencer.cpp.
References ossimImageDataFactory::create(), ossimImageSource::getBoundingRect(), ossimConnectableObject::getInput(), ossimImageSource::getTileHeight(), ossimImageSource::getTileWidth(), ossimIpt::hasNans(), ossimDrect::hasNans(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimIrect::makeNan(), PTR_CAST, setAreaOfInterest(), ossimDrect::stretchOut(), theAreaOfInterest, theBlankTile, theInputConnection, theTileSize, updateTileDimensions(), ossimRefPtr< T >::valid(), ossimIpt::x, and ossimIpt::y.
Referenced by ossimImageHistogramSource::computeNormalModeHistogram(), connectInputEvent(), ossimImageMpiSWriterSequenceConnection::initialize(), ossimImageMpiMWriterSequenceConnection::initialize(), ossimImageFileWriter::initialize(), ossimImageSourceSequencer(), ossimGpkgWriter::setView(), ossimArcInfoGridWriter::writeFile(), and ossimJpegWriter::writeFile().
Definition at line 498 of file ossimImageSourceSequencer.cpp.
Referenced by ossimNitf20Writer::writeFile(), ossimGeneralRasterWriter::writeFile(), ossimJpegWriter::writeFile(), ossimKmlSuperOverlayWriter::writeFile(), ossimNitfWriter::writeFile(), ossimWriter::writeFile(), ossimPngWriter::writeFile(), and ossimGeneralRasterWriter::writeStream().
Reimplemented in ossimMultiThreadSequencer.
Definition at line 603 of file ossimImageSourceSequencer.cpp.
References ossimKeywordlist::find(), ossimImageSource::loadState(), setCreateHistogram(), status, and ossimString::toBool().
Referenced by ossimMultiThreadSequencer::loadState().
Will set the current area of interest.
Definition at line 224 of file ossimImageSourceSequencer.cpp.
References ossimIrect::hasNans(), ossimIrect::makeNan(), theAreaOfInterest, theNumberOfTilesHorizontal, theNumberOfTilesVertical, and updateTileDimensions().
Referenced by ossimImageHistogramSource::computeNormalModeHistogram(), initialize(), ossimImageFileWriter::initialize(), ossimImageFileWriter::setAreaOfInterest(), ossimGdalWriter::writeBlockFile(), ossimArcInfoGridWriter::writeFile(), ossimKmlSuperOverlayWriter::writeFile(), and ossimGpkgWriter::writeTiles().
| void ossimImageSourceSequencer::setCreateHistogram | ( | bool | create_histogram | ) |
Definition at line 617 of file ossimImageSourceSequencer.cpp.
References theCreateHistogram.
Referenced by loadState().
Definition at line 92 of file ossimImageSourceSequencer.cpp.
References theTileSize, and updateTileDimensions().
Referenced by ossimImageFileWriter::setTileSize(), setTileSize(), ossimNitf20Writer::writeBlockBandSeparate(), ossimNitfWriter::writeBlockBandSeparate(), ossimNitf20Writer::writeBlockBandSequential(), ossimNitfWriter::writeBlockBandSequential(), ossimArcInfoGridWriter::writeFile(), ossimKakaduJp2Writer::writeFile(), ossimKakaduNitfWriter::writeFile(), and ossimWriter::writeStream().
Definition at line 99 of file ossimImageSourceSequencer.cpp.
References setTileSize().
Will set the internal pointers to the upperleft tile number. To go to the next tile in the sequence just call getNextTile.
Definition at line 243 of file ossimImageSourceSequencer.cpp.
References theCurrentTileNumber.
Referenced by ossimImageHistogramSource::computeNormalModeHistogram(), ossimImageStatisticsSource::computeStatisticsTemplate(), getTile(), ossimImageMpiSWriterSequenceConnection::setToStartOfSequence(), ossimImageMpiMWriterSequenceConnection::setToStartOfSequence(), ossimNitf20Writer::writeBlockBandSeparate(), ossimNitfWriter::writeBlockBandSeparate(), ossimNitf20Writer::writeBlockBandSequential(), ossimNitfWriter::writeBlockBandSequential(), ossimGdalWriter::writeBlockFile(), ossimArcInfoGridWriter::writeFile(), ossimKmlSuperOverlayWriter::writeFile(), and ossimGpkgWriter::writeTiles().
Reimplemented in ossimImageMpiSWriterSequenceConnection.
Definition at line 494 of file ossimImageSourceSequencer.cpp.
Referenced by ossimNitf20Writer::writeFile(), ossimKmlSuperOverlayWriter::writeFile(), ossimNitfWriter::writeFile(), and ossimGeneralRasterWriter::writeStream().
protectedvirtual |
Definition at line 104 of file ossimImageSourceSequencer.cpp.
References ossimIpt::hasNans(), ossimIrect::hasNans(), ossimIrect::height(), status, theAreaOfInterest, theNumberOfTilesHorizontal, theNumberOfTilesVertical, theTileSize, ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Referenced by initialize(), setAreaOfInterest(), and setTileSize().
protected |
Is the area of interest. The default will
Definition at line 158 of file ossimImageSourceSequencer.h.
Referenced by getAreaOfInterest(), getBoundingRect(), getTileOrigin(), initialize(), ossimImageSourceSequencer(), setAreaOfInterest(), and updateTileDimensions().
protected |
Definition at line 152 of file ossimImageSourceSequencer.h.
Referenced by getNextTile(), initialize(), and ossimMultiThreadSequencer::ossimGetTileJob::run().
protected |
Definition at line 172 of file ossimImageSourceSequencer.h.
Referenced by getTile(), and setCreateHistogram().
protected |
Definition at line 171 of file ossimImageSourceSequencer.h.
Referenced by ossimMultiThreadSequencer::getNextTile(), ossimImageMpiMWriterSequenceConnection::getNextTile(), getNextTile(), getTileOrigin(), ossimImageMpiSWriterSequenceConnection::initialize(), ossimImageMpiMWriterSequenceConnection::initialize(), ossimImageMpiMWriterSequenceConnection::ossimImageMpiMWriterSequenceConnection(), ossimImageMpiSWriterSequenceConnection::ossimImageMpiSWriterSequenceConnection(), ossimImageMpiSWriterSequenceConnection::setToStartOfSequence(), ossimMultiThreadSequencer::setToStartOfSequence(), ossimImageMpiMWriterSequenceConnection::setToStartOfSequence(), and setToStartOfSequence().
protected |
Definition at line 153 of file ossimImageSourceSequencer.h.
protected |
Definition at line 151 of file ossimImageSourceSequencer.h.
Referenced by disconnectInputEvent(), getBoundingRect(), getDecimationFactor(), getDecimationFactors(), getMaxPixelValue(), getMinPixelValue(), getNextTile(), getNullPixelValue(), getNumberOfDecimationLevels(), getNumberOfInputBands(), getOutputScalarType(), getTile(), ossimImageMpiSWriterSequenceConnection::initialize(), ossimImageMpiMWriterSequenceConnection::initialize(), initialize(), ossimImageSourceSequencer(), and ossimMultiThreadSequencer::setToStartOfSequence().
protected |
Definition at line 169 of file ossimImageSourceSequencer.h.
Referenced by getNumberOfTiles(), getNumberOfTilesHorizontal(), getTileOrigin(), setAreaOfInterest(), ossimMultiThreadSequencer::setToStartOfSequence(), and updateTileDimensions().
protected |
Definition at line 170 of file ossimImageSourceSequencer.h.
Referenced by getNumberOfTiles(), getNumberOfTilesVertical(), getTileOrigin(), setAreaOfInterest(), ossimMultiThreadSequencer::setToStartOfSequence(), and updateTileDimensions().
protected |
Called during initialize.
Definition at line 163 of file ossimImageSourceSequencer.h.
Referenced by getTileHeight(), getTileOrigin(), getTileRect(), getTileSize(), getTileWidth(), initialize(), ossimImageSourceSequencer(), setTileSize(), and updateTileDimensions().
