ossimKakaduJp2Reader class for reading images with JPEG2000 (J2K) compressed blocks using kakadu library for decompression. More...
#include <ossimKakaduJp2Reader.h>
Public Types | |
| enum | { SIGNATURE_BOX_SIZE = 12, GEOTIFF_UUID_SIZE = 16 } |
| Anonymous enumerations: More... | |
| ossimKakaduJp2Reader () | |
| default construtor More... | |
| virtual | ~ossimKakaduJp2Reader () |
| virtural destructor More... | |
| Returns short name. More... | |
| Returns long name. More... | |
| Returns class name. More... | |
| Method to grab a tile(rectangle) from image. More... | |
| Returns the number of bands in the image. More... | |
| Returns the output pixel type of the tile source. More... | |
| Returns the number of decimation levels. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| Gets number of lines for res level. More... | |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| Gets the number of samples for res level. More... | |
| virtual bool | open () |
| Open method. More... | |
| Method to test for open file stream. More... | |
| virtual void | closeEntry () |
| Method to close current entry. More... | |
| ossimImageHandler () | |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| Gets an overview tile. More... | |
Private Member Functions | |
| virtual ossimRefPtr< ossimImageGeometry > | getInternalImageGeometry () |
| virtual ossimRefPtr< ossimImageGeometry > | getImageGeometryFromGeotiffBox () |
| virtual ossimRefPtr< ossimImageGeometry > | getImageGeometryFromGmlBox () |
| ossimRefPtr< ossimImageGeometry > | getMetadataImageGeometry () const |
| bool | isJp2 () |
| Test first 12 bytes of file for the jp2 signature block. More... | |
| bool | openJp2File () |
| Opens the jp2 and initializes this object. More... | |
| void | initializeTile () |
| Initializes data member "theTile". More... | |
| bool | loadTileFromCache (const ossimIpt &origin, const ossimIrect &clipRect) |
| Loads a block of data to theCacheTile from the cache. More... | |
| bool | loadTile (const ossimIpt &origin) |
| Loads a block of data to theCacheTile. More... | |
| bool | configureChannelMapping () |
| Initializes m_channels to be used with copyRegionToTile if it makes sense. More... | |
Private Attributes | |
| kdu_supp::jp2_family_src * | theJp2FamilySrc |
| kdu_core::kdu_compressed_source * | theJp2Source |
| kdu_supp::kdu_channel_mapping * | theChannels |
| kdu_core::kdu_codestream | theCodestream |
| kdu_core::kdu_thread_env * | theThreadEnv |
| kdu_core::kdu_thread_queue * | theOpenTileThreadQueue |
| ossim_uint32 | theMinDwtLevels |
| ossim_uint32 | theNumberOfBands |
| ossimIpt | theCacheSize |
| ossimScalarType | theScalarType |
| ossimIrect | theImageRect |
| std::vector< ossimIrect > | theJp2Dims |
| Has sub image offset. More... | |
| std::vector< ossimIrect > | theJp2TileDims |
| Tile dimensions for each level. More... | |
| ossimRefPtr< ossimImageData > | theTile |
| ossimRefPtr< ossimImageData > | theCacheTile |
| ossimAppFixedTileCache::ossimAppFixedCacheId | theCacheId |
| Cache initialized to image rect with sub image offset. More... | |
Definition at line 54 of file ossimKakaduJp2Reader.h.
| anonymous enum |
| Enumerator | |
| SIGNATURE_BOX_SIZE | |
| GEOTIFF_UUID_SIZE | |
Definition at line 186 of file ossimKakaduJp2Reader.h.
| ossimKakaduJp2Reader::ossimKakaduJp2Reader | ( | ) |
default construtor
virtural destructor
Definition at line 90 of file ossimKakaduJp2Reader.cpp.
References closeEntry().
Definition at line 518 of file ossimKakaduJp2Reader.cpp.
References ossimImageHandler::close(), ossimAppFixedTileCache::deleteCache(), ossimAppFixedTileCache::instance(), theCacheId, theCacheTile, theChannels, theCodestream, theJp2FamilySrc, theJp2Source, theOpenTileThreadQueue, theThreadEnv, and theTile.
Referenced by ~ossimKakaduJp2Reader().
private |
Also set number of bands if channel mapping was successful.
Definition at line 1276 of file ossimKakaduJp2Reader.cpp.
References theChannels, theCodestream, theJp2Source, and theNumberOfBands.
Returns class name.
Definition at line 105 of file ossimKakaduJp2Reader.cpp.
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 875 of file ossimKakaduJp2Reader.cpp.
References ossimImageGeometryRegistry::extendGeometry(), ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), getInternalImageGeometry(), getMetadataImageGeometry(), ossimImageGeometry::getProjection(), ossimImageHandler::initImageParameters(), ossimImageGeometryRegistry::instance(), and ossimImageHandler::theGeometry.
privatevirtual |
| Method | to get geometry from the embedded JP2 GeoTIFF Box. |
Definition at line 956 of file ossimKakaduJp2Reader.cpp.
privatevirtual |
| Method | to get geometry from the embedded JP2 GML Box. |
Definition at line 1073 of file ossimKakaduJp2Reader.cpp.
Implements ossimImageHandler.
Definition at line 768 of file ossimKakaduJp2Reader.cpp.
References ossimIrect::height(), theImageRect, and theJp2TileDims.
Referenced by initializeTile().
Definition at line 754 of file ossimKakaduJp2Reader.cpp.
References theImageRect, theJp2TileDims, and ossimIrect::width().
privatevirtual |
| Method | to get geometry from the embedded JP2 Boxes. |
Definition at line 924 of file ossimKakaduJp2Reader.cpp.
Referenced by getImageGeometry().
Returns long name.
Definition at line 100 of file ossimKakaduJp2Reader.cpp.
private |
| Method | to get geometry from the various external files like .prj, .j2w .xml and so on. |
Definition at line 1156 of file ossimKakaduJp2Reader.cpp.
This returns the total number of decimation levels. It is important to note that res level 0 or full resolution is included in the list and has decimation values 1.0, 1.0
Definition at line 110 of file ossimKakaduJp2Reader.cpp.
References ossimImageHandler::getNumberOfDecimationLevels(), theMinDwtLevels, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by getOverviewTile().
Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 744 of file ossimKakaduJp2Reader.cpp.
References theNumberOfBands.
Overrides ossimJ2kTileSource::getNumberOfLines
| resLevel | Reduced resolution level to return lines of. Default = 0 |
Definition at line 133 of file ossimKakaduJp2Reader.cpp.
References ossimImageHandler::getNumberOfLines(), ossimImageHandler::isValidRLevel(), theJp2Dims, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 749 of file ossimKakaduJp2Reader.cpp.
Referenced by getOverviewTile(), and initializeTile().
Overrides ossimJ2kTileSource::getNumberOfSamples
| resLevel | Reduced resolution level to return samples of. Default = 0 |
Definition at line 151 of file ossimKakaduJp2Reader.cpp.
References ossimImageHandler::getNumberOfSamples(), ossimImageHandler::isValidRLevel(), theJp2Dims, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Definition at line 782 of file ossimKakaduJp2Reader.cpp.
References theScalarType.
protectedvirtual |
Overrides ossimImageHandler::getOverviewTile
| resLevel | The resolution level to pull from with resLevel 0 being full res. |
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. This method will subtract the subImageOffset if needed for external overview call since they do not know about the sub image offset. |
Definition at line 671 of file ossimKakaduJp2Reader.cpp.
References ossim::copyRegionToTile(), ossimImageData::getImageRectangle(), ossimImageData::getNumberOfBands(), getNumberOfDecimationLevels(), getNumberOfOutputBands(), ossimImageSource::getTile(), ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setImageRectangle(), status, theChannels, theCodestream, theJp2Dims, theMinDwtLevels, theOpenTileThreadQueue, ossimImageHandler::theOverview, theThreadEnv, and ossimException::what().
Referenced by getTile(), and loadTile().
Returns short name.
Definition at line 95 of file ossimKakaduJp2Reader.cpp.
| rect | The zero based rectangle to grab. |
| resLevel | The reduced resolution level to grab from. |
Definition at line 571 of file ossimKakaduJp2Reader.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimImageData::getImageRectangle(), getOverviewTile(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), loadTile(), ossimImageData::loadTile(), loadTileFromCache(), ossimIrect::lr(), ossimImageData::makeBlank(), OSSIM_BSQ, ossimImageData::setImageRectangle(), ossimIrect::stretchToTileBoundary(), theCacheSize, theCacheTile, theImageRect, theTile, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIpt::x, and ossimIpt::y.
private |
Definition at line 787 of file ossimKakaduJp2Reader.cpp.
References ossim::defaultTileSize(), getImageTileHeight(), getImageTileWidth(), getNumberOfOutputBands(), getOutputScalarType(), ossimImageData::initialize(), ossimImageDataFactory::instance(), theCacheSize, theCacheTile, theTile, ossimIpt::x, and ossimIpt::y.
private |
Definition at line 207 of file ossimKakaduJp2Reader.cpp.
References ossimString::chars(), SIGNATURE_BOX_SIZE, and ossimImageHandler::theImageFile.
Definition at line 510 of file ossimKakaduJp2Reader.cpp.
References theTile, and ossimRefPtr< T >::valid().
Referenced by getTile().
Definition at line 1265 of file ossimKakaduJp2Reader.cpp.
References ossimImageHandler::loadState(), and open().
private |
| origin | Starting position of block to load. |
Definition at line 847 of file ossimKakaduJp2Reader.cpp.
References ossimAppFixedTileCache::addTile(), ossimRefPtr< T >::get(), getOverviewTile(), ossimAppFixedTileCache::instance(), ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setImageRectangle(), theCacheId, theCacheSize, theCacheTile, ossimIpt::x, and ossimIpt::y.
private |
| origin | This is the point used for the cache query. |
| clipRect | The rectangle to fill. |
Definition at line 821 of file ossimKakaduJp2Reader.cpp.
References ossimIrect::clipToRect(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimImageData::getImageRectangle(), ossimAppFixedTileCache::getTile(), ossimAppFixedTileCache::instance(), ossimImageData::loadTile(), OSSIM_BSQ, theCacheId, theTile, and ossimRefPtr< T >::valid().
Open method.
Definition at line 169 of file ossimKakaduJp2Reader.cpp.
Referenced by loadState().
private |
Definition at line 250 of file ossimKakaduJp2Reader.cpp.
private |
Definition at line 317 of file ossimKakaduJp2Reader.h.
Referenced by closeEntry(), loadTile(), and loadTileFromCache().
private |
Definition at line 303 of file ossimKakaduJp2Reader.h.
Referenced by getTile(), initializeTile(), and loadTile().
private |
Definition at line 314 of file ossimKakaduJp2Reader.h.
Referenced by closeEntry(), getTile(), initializeTile(), and loadTile().
private |
Definition at line 296 of file ossimKakaduJp2Reader.h.
Referenced by closeEntry(), configureChannelMapping(), and getOverviewTile().
private |
Definition at line 297 of file ossimKakaduJp2Reader.h.
private |
Definition at line 305 of file ossimKakaduJp2Reader.h.
Referenced by getImageTileHeight(), getImageTileWidth(), and getTile().
private |
Image dimensions for each level.
Definition at line 308 of file ossimKakaduJp2Reader.h.
Referenced by getNumberOfLines(), getNumberOfSamples(), and getOverviewTile().
private |
Definition at line 294 of file ossimKakaduJp2Reader.h.
Referenced by closeEntry().
private |
Definition at line 295 of file ossimKakaduJp2Reader.h.
Referenced by closeEntry(), and configureChannelMapping().
private |
Definition at line 311 of file ossimKakaduJp2Reader.h.
Referenced by getImageTileHeight(), and getImageTileWidth().
private |
Definition at line 301 of file ossimKakaduJp2Reader.h.
Referenced by getNumberOfDecimationLevels(), and getOverviewTile().
private |
Definition at line 302 of file ossimKakaduJp2Reader.h.
Referenced by configureChannelMapping(), getNumberOfInputBands(), and getNumberOfOutputBands().
private |
Definition at line 299 of file ossimKakaduJp2Reader.h.
Referenced by closeEntry(), and getOverviewTile().
private |
Definition at line 304 of file ossimKakaduJp2Reader.h.
Referenced by getOutputScalarType().
private |
Definition at line 298 of file ossimKakaduJp2Reader.h.
private |
Definition at line 313 of file ossimKakaduJp2Reader.h.
Referenced by closeEntry(), getTile(), initializeTile(), isOpen(), and loadTileFromCache().
