class ossimEdgeFilter More...
#include <ossimEdgeFilter.h>
| ossimEdgeFilter (ossimObject *owner=NULL) | |
| ossimEdgeFilter (ossimImageSource *inputSource) | |
| ossimEdgeFilter (ossimObject *owner, ossimImageSource *inputSource) | |
| virtual void | getFilterTypeNames (std::vector< ossimString > &filterNames) const |
| virtual ossimString | getFilterType () const |
| virtual void | setFilterType (const ossimString &filterType) |
| The filter type can be one of the following strings. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| void | adjustRequestRect (ossimIrect &requestRect) const |
| template<class T > | |
| void | runFilter (T dummyVariable, ossimRefPtr< ossimImageData > inputData) |
| void | runSobelFilter (T dummyVariable, ossimRefPtr< ossimImageData > inputData) |
| void | runPrewittFilter (T dummyVariable, ossimRefPtr< ossimImageData > inputData) |
| void | runLaplacianFilter (T dummyVariable, ossimRefPtr< ossimImageData > inputData) |
| void | runRobertsFilter (T dummyVariable, ossimRefPtr< ossimImageData > inputData) |
| void | runSimpleFilter (T dummyVariable, ossimRefPtr< ossimImageData > inputData) |
| void | runLocalMax8Filter (T dummyVariable, ossimRefPtr< ossimImageData > inputData) |
This has default implementation for the certain filter types. For the different filter type please see method setFilterType.
Definition at line 24 of file ossimEdgeFilter.h.
| ossimEdgeFilter::ossimEdgeFilter | ( | ossimObject * | owner = NULL | ) |
Definition at line 21 of file ossimEdgeFilter.cpp.
| ossimEdgeFilter::ossimEdgeFilter | ( | ossimImageSource * | inputSource | ) |
Definition at line 28 of file ossimEdgeFilter.cpp.
| ossimEdgeFilter::ossimEdgeFilter | ( | ossimObject * | owner, |
| ossimImageSource * | inputSource | ||
Definition at line 35 of file ossimEdgeFilter.cpp.
protected |
Definition at line 236 of file ossimEdgeFilter.cpp.
References ossimString::contains(), ossimString::downcase(), ossimIrect::lr(), theFilterType, ossimIrect::ul(), ossimIpt::x, and ossimIpt::y.
Referenced by getTile().
Definition at line 152 of file ossimEdgeFilter.cpp.
References theFilterType.
Referenced by saveState().
Definition at line 141 of file ossimEdgeFilter.cpp.
Referenced by getProperty().
Definition at line 207 of file ossimEdgeFilter.cpp.
References ossimProperty::clearChangeType(), getFilterTypeNames(), ossimImageSourceFilter::getProperty(), PROP_EDGE_FILTER, ossimProperty::setCacheRefreshBit(), ossimProperty::setReadOnlyFlag(), and theFilterType.
Definition at line 228 of file ossimEdgeFilter.cpp.
References ossimImageSourceFilter::getPropertyNames(), and PROP_EDGE_FILTER.
Definition at line 43 of file ossimEdgeFilter.cpp.
References adjustRequestRect(), ossimImageData::getBuf(), ossimImageData::getNumberOfBands(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), initialize(), ossimSource::isSourceEnabled(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, runFilter(), ossimImageData::setImageRectangleAndBands(), theTile, and ossimRefPtr< T >::valid().
Definition at line 121 of file ossimEdgeFilter.cpp.
References ossimImageDataFactory::create(), ossimImageSourceFilter::initialize(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimSource::isSourceEnabled(), theTile, and ossimRefPtr< T >::valid().
Definition at line 707 of file ossimEdgeFilter.cpp.
References ossimKeywordlist::find(), ossimImageSourceFilter::loadState(), ossimNotify(), ossimNotifyLevel_WARN, PROP_EDGE_FILTER, and setFilterType().
protected |
Definition at line 268 of file ossimEdgeFilter.cpp.
References ossimString::contains(), ossimString::downcase(), ossimImageData::makeBlank(), runLaplacianFilter(), runLocalMax8Filter(), runPrewittFilter(), runRobertsFilter(), runSimpleFilter(), runSobelFilter(), theFilterType, and theTile.
protected |
Definition at line 572 of file ossimEdgeFilter.cpp.
References ossimImageData::getBuf(), ossimImageData::getHeight(), ossimImageData::getMaxPix(), ossimImageData::getMinPix(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), theTile, ossimImageData::validate(), x, and y.
Referenced by runFilter().
protected |
Definition at line 638 of file ossimEdgeFilter.cpp.
References ossimImageData::getBuf(), ossimImageData::getHeight(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), theTile, ossimImageData::validate(), x, and y.
protected |
Definition at line 376 of file ossimEdgeFilter.cpp.
protected |
Definition at line 447 of file ossimEdgeFilter.cpp.
protected |
Definition at line 516 of file ossimEdgeFilter.cpp.
protected |
Definition at line 305 of file ossimEdgeFilter.cpp.
Definition at line 695 of file ossimEdgeFilter.cpp.
References ossimKeywordlist::add(), getFilterType(), PROP_EDGE_FILTER, and ossimImageSourceFilter::saveState().
It is case insensitive for the compares.
Sobel Laplacian Prewitt
Definition at line 157 of file ossimEdgeFilter.cpp.
References ossimString::contains(), ossimString::downcase(), and theFilterType.
Referenced by loadState().
Definition at line 192 of file ossimEdgeFilter.cpp.
References ossimRefPtr< T >::get(), ossimProperty::getName(), PROP_EDGE_FILTER, ossimImageSourceFilter::setProperty(), and theFilterType.
protected |
Definition at line 56 of file ossimEdgeFilter.h.
Referenced by adjustRequestRect(), getFilterType(), getProperty(), runFilter(), setFilterType(), and setProperty().
protected |
Definition at line 55 of file ossimEdgeFilter.h.
Referenced by getTile(), initialize(), runFilter(), runLaplacianFilter(), runLocalMax8Filter(), runPrewittFilter(), runRobertsFilter(), runSimpleFilter(), and runSobelFilter().
