Filter class for computing the slope image of the input image connection. More...
#include <ossimSlopeFilter.h>
Public Types | |
| enum | SlopeType { RADIANS, DEGREES, RATIO, NORMALIZED } |
| Specifies how the slope quantity is represented. More... | |
| ossimSlopeFilter () | |
| ossimSlopeFilter (ossimImageSource *inputSource) | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tile_rect, ossim_uint32 rLevel=0) |
| Returns the output pixel type of the tile source. More... | |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| void | setSlopeType (SlopeType t) |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimSlopeFilter () |
Static Protected Member Functions | |
| static ossimString | getSlopeTypeString (SlopeType t) |
The slope dP/dR is defined as the maximum change in pixel value for a differential change in ground position. This filter would typically be applied to elevation data (represented as an image), where dP is the change in height when walking some distance dR either straight uphill or downhill. Numerically , this quantity is computed from the dot product of the normal vector with the local vertical.
The output is a floating point single-band image. The input should be a single-band, floating point image. The slope quantity can be represented as an angle from local vertical, i.e., the arccos(dP/dR) (in radians, degrees, or normalized) or as the simple ratio dP/dR.
Definition at line 26 of file ossimSlopeFilter.h.
| Enumerator | |
| RADIANS | |
| DEGREES | |
| RATIO | |
| NORMALIZED | |
Definition at line 30 of file ossimSlopeFilter.h.
| ossimSlopeFilter::ossimSlopeFilter | ( | ) |
Definition at line 19 of file ossimSlopeFilter.cpp.
| ossimSlopeFilter::ossimSlopeFilter | ( | ossimImageSource * | inputSource | ) |
Definition at line 25 of file ossimSlopeFilter.cpp.
protectedvirtual |
Definition at line 32 of file ossimSlopeFilter.cpp.
References m_normals.
Definition at line 199 of file ossimSlopeFilter.cpp.
inlinevirtual |
This override the base class since it simply returns it's input scalar type which is not correct with this object.
Definition at line 53 of file ossimSlopeFilter.h.
References OSSIM_FLOAT32.
Definition at line 126 of file ossimSlopeFilter.cpp.
References DEGREES, ossimImageSourceFilter::getProperty(), getSlopeTypeString(), m_slopeType, NORMALIZED, RADIANS, RATIO, and SLOPE_TYPE_KW.
Definition at line 157 of file ossimSlopeFilter.cpp.
References ossimImageSourceFilter::getPropertyNames(), and SLOPE_TYPE_KW.
Definition at line 205 of file ossimSlopeFilter.cpp.
staticprotected |
Definition at line 186 of file ossimSlopeFilter.cpp.
References DEGREES, NORMALIZED, RADIANS, and RATIO.
Referenced by getProperty(), and saveState().
Definition at line 37 of file ossimSlopeFilter.cpp.
References ossim::acosd(), ossimImageData::getFloatBuf(), ossimImageData::getNullPix(), ossimImageData::getPix(), ossimImageData::getSizePerBand(), ossimImageToPlaneNormalFilter::getTile(), ossimImageSource::getTile(), initialize(), ossimImageData::initialize(), ossimSource::isSourceEnabled(), m_normals, M_PI, m_slopeType, NORMALIZED, OSSIM_FLOAT32, RADIANS, RATIO, ossimImageData::setImageRectangle(), ossimImageSourceFilter::theInputConnection, ossimRefPtr< T >::valid(), and ossimImageData::validate().
Definition at line 92 of file ossimSlopeFilter.cpp.
References ossimImageToPlaneNormalFilter::initialize(), m_normals, ossimImageSourceFilter::theInputConnection, and ossimRefPtr< T >::valid().
Referenced by getTile(), and setProperty().
Definition at line 172 of file ossimSlopeFilter.cpp.
References ossimString::empty(), ossimKeywordlist::find(), ossimImageSourceFilter::loadState(), setProperty(), and SLOPE_TYPE_KW.
Definition at line 163 of file ossimSlopeFilter.cpp.
References ossimKeywordlist::add(), getSlopeTypeString(), m_slopeType, ossimImageSourceFilter::saveState(), and SLOPE_TYPE_KW.
Definition at line 99 of file ossimSlopeFilter.cpp.
References DEGREES, ossimProperty::getName(), initialize(), m_slopeType, NORMALIZED, RADIANS, RATIO, ossimImageSourceFilter::setProperty(), SLOPE_TYPE_KW, ossimString::upcase(), and ossimProperty::valueToString().
Referenced by loadState().
inline |
Definition at line 72 of file ossimSlopeFilter.h.
Referenced by ossimSlopeTool::initProcessingChain(), and ossimHlzTool::initProcessingChain().
protected |
Definition at line 78 of file ossimSlopeFilter.h.
Referenced by getTile(), initialize(), and ~ossimSlopeFilter().
protected |
Definition at line 79 of file ossimSlopeFilter.h.
Referenced by getProperty(), getTile(), saveState(), and setProperty().
