OSSIM Image handler for video frames. More...
#include <ossimVideoImageHandler.h>
| virtual bool | open ()=0 |
| Pure virtual open. More... | |
| virtual bool | isOpen () const =0 |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual void | initialize ()=0 |
| Common initialization code for all construction methods. More... | |
| virtual bool | setCurrentEntry (ossim_uint32 frame_number) |
| Sets the currently active frame number as count from start of video. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| Pure virtual, derived classes must implement. More... | |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| Currently assuming all videos are RGB. More... | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &rect, ossim_uint32 resLevel=0)=0 |
| ossimRefPtr< ossimVideoHandler > | getVideo () const |
| ossimRefPtr< ossimVideoGeometry > | getVideoGeometry () const |
| ossimImageHandler () | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ossimVideoImageHandler () | |
Notes on video handling in OSSIM:
Definition at line 26 of file ossimVideoImageHandler.h.
protected |
Definition at line 22 of file ossimVideoImageHandler.cpp.
Definition at line 30 of file ossimVideoImageHandler.cpp.
References m_video, and m_videoGeometry.
Definition at line 69 of file ossimVideoImageHandler.cpp.
References m_currentFrameNumber.
| entryList | This is the list to initialize with entry indexes. |
Definition at line 39 of file ossimVideoImageHandler.cpp.
References getNumberOfEntries().
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 116 of file ossimVideoImageHandler.cpp.
References ossimVideoSource::computeFrameTime(), ossimVideoGeometry::getImageGeometry(), m_currentFrameNumber, m_video, m_videoGeometry, ossimImageHandler::theGeometry, and ossimRefPtr< T >::valid().
inlinevirtual |
Implements ossimImageHandler.
Definition at line 49 of file ossimVideoImageHandler.h.
References ossimImageHandler::getNumberOfLines().
inlinevirtual |
Definition at line 48 of file ossimVideoImageHandler.h.
References ossimImageHandler::getNumberOfSamples().
Definition at line 80 of file ossimVideoImageHandler.cpp.
References ossimVideoSource::computeFrameNumber(), ossimVideoHandler::duration(), m_video, and ossimRefPtr< T >::valid().
Referenced by getEntryList().
inlinevirtual |
Implements ossimImageSource.
Definition at line 52 of file ossimVideoImageHandler.h.
| resLevel | Reduced resolution level to return lines of. Default = 0 |
Definition at line 92 of file ossimVideoImageHandler.cpp.
References ossimVideoSource::frameSize(), ossimIpt::line, m_video, and ossimRefPtr< T >::valid().
inlinevirtual |
Definition at line 53 of file ossimVideoImageHandler.h.
| resLevel | Reduced resolution level to return samples of. Default = 0 |
Definition at line 104 of file ossimVideoImageHandler.cpp.
References ossimVideoSource::frameSize(), m_video, ossimIpt::samp, and ossimRefPtr< T >::valid().
inlinevirtual |
Definition at line 54 of file ossimVideoImageHandler.h.
References OSSIM_UINT8.
pure virtual |
inline |
Definition at line 63 of file ossimVideoImageHandler.h.
inline |
Definition at line 64 of file ossimVideoImageHandler.h.
pure virtual |
pure virtual |
pure virtual |
Pure virtual open.
Derived classes must implement.
Returns false if frame time is outside of allowable range.
Returns false if frame count is outside of allowable range.
Definition at line 51 of file ossimVideoImageHandler.cpp.
References ossimVideoSource::computeFrameTime(), m_currentFrameNumber, m_video, ossimVideoHandler::seek(), ossimVideoSource::SEEK_ABSOLUTE, and ossimRefPtr< T >::valid().
protected |
This is the currently active entry.
Definition at line 71 of file ossimVideoImageHandler.h.
Referenced by getCurrentEntry(), getImageGeometry(), and setCurrentEntry().
protected |
Definition at line 72 of file ossimVideoImageHandler.h.
protected |
Definition at line 69 of file ossimVideoImageHandler.h.
Referenced by close(), getImageGeometry(), getNumberOfEntries(), getNumberOfLines(), getNumberOfSamples(), and setCurrentEntry().
protected |
Definition at line 70 of file ossimVideoImageHandler.h.
Referenced by close(), and getImageGeometry().
