#include <ossimEastingNorthingCutter.h>
| ossimEastingNorthingCutter (ossimObject *owner, ossimImageSource *inputSource=NULL) | |
| ossimEastingNorthingCutter (ossimImageSource *inputSource=NULL) | |
| void | setEastingNorthingRectangle (const ossimDpt &ul, const ossimDpt &lr) |
| ossimDpt | getUlEastingNorthing () const |
| ossimDpt | getLrEastingNorthing () const |
| virtual bool | setView (ossimObject *baseObject) |
| virtual ossimObject * | getView () |
| virtual const ossimObject * | getView () const |
Public Member Functions inherited from ossimRectangleCutFilter | |
| ossimRectangleCutFilter (ossimObject *owner, ossimImageSource *inputSource=NULL) | |
| ossimRectangleCutFilter (ossimImageSource *inputSource=NULL) | |
| void | setRectangle (const ossimIrect &rect) |
| const ossimIrect & | getRectangle () const |
| ossimRectangleCutType | getCutType () const |
| void | setCutType (ossimRectangleCutType cutType) |
| ossimIrect | getBoundingRect (ossim_uint32 resLevel=0) const |
| ossimRefPtr< ossimImageData > | getTile (const ossimIrect &rect, ossim_uint32 resLevel=0) |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Public Member Functions inherited from ossimViewInterface | |
| ossimViewInterface () | |
| ossimViewInterface (ossimObject *base) | |
| virtual | ~ossimViewInterface () |
| virtual void | refreshView () |
| ossimObject * | getBaseObject () |
| virtual | ~ossimEastingNorthingCutter () |
| void | transformVertices () |
Public Types inherited from ossimRectangleCutFilter | |
| enum | ossimRectangleCutType { OSSIM_RECTANGLE_NULL_INSIDE = 0, OSSIM_RECTANGLE_NULL_OUTSIDE = 1 } |
Definition at line 7 of file ossimEastingNorthingCutter.h.
| ossimEastingNorthingCutter::ossimEastingNorthingCutter | ( | ossimObject * | owner, |
| ossimImageSource * | inputSource = NULL |
Definition at line 23 of file ossimEastingNorthingCutter.cpp.
References ossimDpt::makeNan(), ossimRectangleCutFilter::OSSIM_RECTANGLE_NULL_OUTSIDE, ossimRectangleCutFilter::theCutType, theLrEastingNorthing, and theUlEastingNorthing.
| ossimEastingNorthingCutter::ossimEastingNorthingCutter | ( | ossimImageSource * | inputSource = NULL | ) |
Definition at line 35 of file ossimEastingNorthingCutter.cpp.
protectedvirtual |
Definition at line 45 of file ossimEastingNorthingCutter.cpp.
| ossimDpt ossimEastingNorthingCutter::getLrEastingNorthing | ( | ) | const |
Definition at line 63 of file ossimEastingNorthingCutter.cpp.
References theLrEastingNorthing.
| ossimDpt ossimEastingNorthingCutter::getUlEastingNorthing | ( | ) | const |
Definition at line 58 of file ossimEastingNorthingCutter.cpp.
References theUlEastingNorthing.
Implements ossimViewInterface.
Definition at line 157 of file ossimEastingNorthingCutter.cpp.
References ossimRefPtr< T >::get(), and theViewProjection.
Definition at line 162 of file ossimEastingNorthingCutter.cpp.
Reimplemented from ossimRectangleCutFilter.
Definition at line 69 of file ossimEastingNorthingCutter.cpp.
References ossimRectangleCutFilter::initialize(), and transformVertices().
Definition at line 92 of file ossimEastingNorthingCutter.cpp.
References ossimKeywordlist::find(), ossimDpt::makeNan(), theLrEastingNorthing, theUlEastingNorthing, ossimDpt::x, x, ossimDpt::y, and y.
Definition at line 75 of file ossimEastingNorthingCutter.cpp.
References ossimKeywordlist::add(), ossimRectangleCutFilter::saveState(), theLrEastingNorthing, theUlEastingNorthing, ossimString::toString(), ossimDpt::x, and ossimDpt::y.
| void ossimEastingNorthingCutter::setEastingNorthingRectangle | ( | const ossimDpt & | ul, |
| const ossimDpt & | lr | ||
Definition at line 49 of file ossimEastingNorthingCutter.cpp.
References theLrEastingNorthing, theUlEastingNorthing, and transformVertices().
The derived classes should overrid this method and return true or false whether it was able to cast the past in view to a view that it can interface to. So if you are a projective view you might cast to an ossimProjection. The ownsTheView specifies whether or not it owns the passed in view pointer. This will specifiy whether or not the derived classes need to re-allocate the pointer or just delete its old pointer and set it to the passed in pointer.
Definition at line 140 of file ossimEastingNorthingCutter.cpp.
References PTR_CAST, theViewProjection, and transformVertices().
protected |
Definition at line 167 of file ossimEastingNorthingCutter.cpp.
References ossimMapProjection::eastingNorthingToLineSample(), ossimRefPtr< T >::get(), ossimDpt::hasNans(), ossimIrect::makeNan(), PTR_CAST, theLrEastingNorthing, ossimRectangleCutFilter::theRectangle, theUlEastingNorthing, theViewProjection, ossimDpt::x, and ossimDpt::y.
Referenced by initialize(), setEastingNorthingRectangle(), and setView().
protected |
Definition at line 35 of file ossimEastingNorthingCutter.h.
Referenced by getLrEastingNorthing(), loadState(), ossimEastingNorthingCutter(), saveState(), setEastingNorthingRectangle(), and transformVertices().
protected |
Definition at line 34 of file ossimEastingNorthingCutter.h.
Referenced by getUlEastingNorthing(), loadState(), ossimEastingNorthingCutter(), saveState(), setEastingNorthingRectangle(), and transformVertices().
protected |
Definition at line 37 of file ossimEastingNorthingCutter.h.
Referenced by getView(), setView(), and transformVertices().
