#include <ossimScaleFilter.h>
Public Types | |
| enum | ossimScaleFilterType { ossimScaleFilter_NEAREST_NEIGHBOR = 0, ossimScaleFilter_BOX = 1, ossimScaleFilter_GAUSSIAN = 2, ossimScaleFilter_CUBIC = 3, ossimScaleFilter_HANNING = 4, ossimScaleFilter_HAMMING = 5, ossimScaleFilter_LANCZOS = 6, ossimScaleFilter_MITCHELL = 7, ossimScaleFilter_CATROM = 8, ossimScaleFilter_BLACKMAN = 9, ossimScaleFilter_BLACKMAN_SINC = 10, ossimScaleFilter_BLACKMAN_BESSEL = 11, ossimScaleFilter_QUADRATIC = 12, ossimScaleFilter_TRIANGLE = 13, ossimScaleFilter_HERMITE = 14 } |
| ossimScaleFilter () | |
| ossimScaleFilter (ossimImageSource *inputSource, const ossimDpt &scaleFactor) | |
| void | setFilterType (ossimScaleFilterType filterType) |
| void | setFilterType (ossimScaleFilterType minifyFilterType, ossimScaleFilterType magnifyFilterType) |
| void | setFilterType (const ossimString &minifyType, const ossimString &magnifyType) |
| void | setMinifyFilterType (const ossimString &minifyType) |
| void | setMagnifyFilterType (const ossimString &magnifyType) |
| void | setMinifyFilterType (ossimScaleFilterType filterType) |
| void | setMagnifyFilterType (ossimScaleFilterType filterType) |
| ossimString | getMinifyFilterTypeAsString () const |
| ossimString | getMagnifyFilterTypeAsString () const |
| void | setScaleFactor (const ossimDpt &scale) |
| void | setBlurFactor (ossim_float64 blur) |
| ossim_float64 | getBlurFactor () const |
| const ossimDpt & | getScaleFactor () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimScaleFilter () |
| void | allocate () |
| void | updateGeometry () |
| If this object is maintaining an ossimImageGeometry, this method needs to be called after a scale change so that the geometry's projection is modified accordingly. More... | |
| template<class T > | |
| void | runFilterTemplate (T dummy, const ossimIrect &imageRect, const ossimIrect &viewRect) |
| void | runHorizontalFilterTemplate (T dummy, const ossimRefPtr< ossimImageData > &input, ossimRefPtr< ossimImageData > &output) |
| void | runVerticalFilterTemplate (T dummy, const ossimRefPtr< ossimImageData > &input, ossimRefPtr< ossimImageData > &output) |
| void | runFilter (const ossimIrect &imageRect, const ossimIrect &viewRect) |
| void | getSupport (double &x, double &y) |
| const ossimFilter * | getHorizontalFilter () const |
| const ossimFilter * | getVerticalFilter () const |
| ossimString | getFilterTypeAsString (ossimScaleFilterType type) const |
| ossimScaleFilterType | getFilterType (const ossimString &type) const |
| ossimIrect | scaleRect (const ossimIrect input, const ossimDpt &scaleFactor) const |
| ossimFilter * | createNewFilter (ossimScaleFilterType filterType, ossimScaleFilterType &result) |
Definition at line 22 of file ossimScaleFilter.h.
Definition at line 25 of file ossimScaleFilter.h.
| ossimScaleFilter::ossimScaleFilter | ( | ) |
Definition at line 24 of file ossimScaleFilter.cpp.
References m_InputRect, m_MagnifyFilter, m_MinifyFilter, and ossimIrect::makeNan().
| ossimScaleFilter::ossimScaleFilter | ( | ossimImageSource * | inputSource, |
| const ossimDpt & | scaleFactor | ||
Definition at line 43 of file ossimScaleFilter.cpp.
protectedvirtual |
protected |
Definition at line 639 of file ossimScaleFilter.cpp.
References ossimImageDataFactory::create(), ossimImageSource::getBoundingRect(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimSource::isSourceEnabled(), m_BlankTile, m_InputRect, m_Tile, ossimIrect::makeNan(), and ossimImageSourceFilter::theInputConnection.
Referenced by getTile().
protected |
Definition at line 290 of file ossimScaleFilter.cpp.
References ossimScaleFilter_BLACKMAN, ossimScaleFilter_BLACKMAN_BESSEL, ossimScaleFilter_BLACKMAN_SINC, ossimScaleFilter_BOX, ossimScaleFilter_CATROM, ossimScaleFilter_CUBIC, ossimScaleFilter_GAUSSIAN, ossimScaleFilter_HAMMING, ossimScaleFilter_HANNING, ossimScaleFilter_HERMITE, ossimScaleFilter_LANCZOS, ossimScaleFilter_MITCHELL, ossimScaleFilter_NEAREST_NEIGHBOR, ossimScaleFilter_QUADRATIC, and ossimScaleFilter_TRIANGLE.
Referenced by setFilterType().
inline |
Definition at line 116 of file ossimScaleFilter.h.
This will return the bounding rect of the source.
We can have several sources which are in a chain to modify the bounding image rect. lets say you are next to an image handler then it will return the bounding rect for that image. If you are at the right side of a resampler then you will get a bounding rect along the image view plane. This is going to be a very import method for both image writers, mosaics or anything that needs to operate only within the bounds of an image.
Definition at line 248 of file ossimScaleFilter.cpp.
References ossimImageSource::getBoundingRect(), ossimIrect::hasNans(), and m_ScaleFactor.
inlinevirtual |
Will return the decimation factor for the given resolution level.
the decimation is the scale from Resolution 0 or full res. Usually this is a power of 2 decimation where the decimation result is 1.0/2^resoltion.
Definition at line 55 of file ossimScaleFilter.h.
References ossimDpt::makeNan(), ossimDpt::x, and ossimDpt::y.
inlinevirtual |
Definition at line 66 of file ossimScaleFilter.h.
protected |
Definition at line 779 of file ossimScaleFilter.cpp.
References ossimString::contains(), ossimScaleFilter_BLACKMAN, ossimScaleFilter_BLACKMAN_BESSEL, ossimScaleFilter_BLACKMAN_SINC, ossimScaleFilter_BOX, ossimScaleFilter_CATROM, ossimScaleFilter_CUBIC, ossimScaleFilter_GAUSSIAN, ossimScaleFilter_HAMMING, ossimScaleFilter_HANNING, ossimScaleFilter_HERMITE, ossimScaleFilter_LANCZOS, ossimScaleFilter_MITCHELL, ossimScaleFilter_NEAREST_NEIGHBOR, ossimScaleFilter_QUADRATIC, ossimScaleFilter_TRIANGLE, and ossimString::upcase().
Referenced by loadState().
protected |
Definition at line 709 of file ossimScaleFilter.cpp.
Referenced by saveState().
protected |
Definition at line 861 of file ossimScaleFilter.cpp.
References m_MagnifyFilter, m_MinifyFilter, m_ScaleFactor, and ossimDpt::x.
Referenced by getSupport(), and runHorizontalFilterTemplate().
Returns the image geometry object associated with this tile source or NULL if not defined.
The geometry contains full-to-local image transform as well as projection (image-to-world). Default implementation returns the image geometry object associated with the next
(left) input source (if any) connected to this source in the chain, or NULL.
Definition at line 660 of file ossimScaleFilter.cpp.
References ossimImageSource::getImageGeometry(), m_ScaledGeometry, m_ScaleFactor, ossimImageSourceFilter::theInputConnection, updateGeometry(), ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
inline |
Definition at line 107 of file ossimScaleFilter.h.
inline |
Definition at line 103 of file ossimScaleFilter.h.
inlinevirtual |
Will return the number of resolution levels.
Note: resolution level 0 is included in the return count.
Definition at line 70 of file ossimScaleFilter.h.
inline |
Definition at line 120 of file ossimScaleFilter.h.
protected |
Definition at line 849 of file ossimScaleFilter.cpp.
References getHorizontalFilter(), ossimFilter::getSupport(), getVerticalFilter(), m_BlurFactor, m_ScaleFactor, ossim::max(), ossimDpt::x, x, ossimDpt::y, and y.
Definition at line 78 of file ossimScaleFilter.cpp.
References allocate(), getSupport(), ossimImageSource::getTile(), ossimSource::isSourceEnabled(), ossimIrect::lr(), m_BlankTile, m_BlurFactor, m_InverseScaleFactor, m_ScaleFactor, m_Tile, ossimImageData::makeBlank(), runFilter(), ossimImageData::setImageRectangle(), ossimImageSourceFilter::theInputConnection, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
protected |
Definition at line 872 of file ossimScaleFilter.cpp.
References m_MagnifyFilter, m_MinifyFilter, m_ScaleFactor, and ossimDpt::y.
Referenced by getSupport(), and runVerticalFilterTemplate().
Definition at line 628 of file ossimScaleFilter.cpp.
References ossimImageSourceFilter::initialize(), m_BlankTile, m_InputRect, m_Tile, and ossimIrect::makeNan().
Loads the state of this object.
Definition at line 908 of file ossimScaleFilter.cpp.
References ossimKeywordlist::find(), FLT_EPSILON, getFilterType(), ossimImageSourceFilter::loadState(), m_InverseScaleFactor, m_ScaleFactor, ossimKeywordNames::SCALE_X_KW, ossimKeywordNames::SCALE_Y_KW, setFilterType(), ossimString::toDouble(), updateGeometry(), ossimDpt::x, and ossimDpt::y.
protected |
Definition at line 132 of file ossimScaleFilter.cpp.
References ossimRectilinearDataObject::getScalarType(), m_Tile, OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SINT16, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, and runFilterTemplate().
protected |
Definition at line 193 of file ossimScaleFilter.cpp.
References ossimImageDataFactory::create(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getNumberOfBands(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimIrect::height(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimImageData::loadTile(), m_BlurFactor, m_ScaleFactor, m_Tile, OSSIM_EMPTY, runHorizontalFilterTemplate(), runVerticalFilterTemplate(), ossimImageData::setOrigin(), ossimImageSourceFilter::theInputConnection, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIrect::width(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Referenced by runFilter().
protected |
Definition at line 385 of file ossimScaleFilter.cpp.
References ossimFilter::filter(), FLT_EPSILON, ossimImageData::getBuf(), getHorizontalFilter(), ossimImageData::getImageRectangle(), ossimImageData::getMaxPix(), ossimImageData::getMinPix(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimFilter::getSupport(), ossimIrect::height(), ossimIrect::lr(), m_BlurFactor, m_InputRect, m_ScaleFactor, m_Tile, ossim::max(), ossim::min(), ossimIrect::ul(), ossimIrect::width(), ossimIpt::x, ossimDpt::x, x, and y.
Referenced by runFilterTemplate().
protected |
Definition at line 508 of file ossimScaleFilter.cpp.
References ossimFilter::filter(), FLT_EPSILON, ossimImageData::getBuf(), ossimImageData::getImageRectangle(), ossimImageData::getMaxPix(), ossimImageData::getMinPix(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimFilter::getSupport(), getVerticalFilter(), ossimIrect::height(), ossimIrect::lr(), m_BlurFactor, m_InputRect, m_ScaleFactor, m_Tile, ossim::max(), ossim::min(), ossimIrect::ul(), ossimIrect::width(), x, ossimIpt::y, ossimDpt::y, and y.
Saves the state of this object.
Definition at line 885 of file ossimScaleFilter.cpp.
References ossimKeywordlist::add(), getFilterTypeAsString(), m_MagnifyFilterType, m_MinifyFilterType, m_ScaleFactor, ossimImageSourceFilter::saveState(), ossimKeywordNames::SCALE_X_KW, ossimKeywordNames::SCALE_Y_KW, ossimDpt::x, and ossimDpt::y.
protected |
Definition at line 691 of file ossimScaleFilter.cpp.
References ossimIrect::height(), ossimIrect::ul(), ossimIrect::width(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
inline |
Definition at line 112 of file ossimScaleFilter.h.
| void ossimScaleFilter::setFilterType | ( | ossimScaleFilterType | filterType | ) |
Definition at line 261 of file ossimScaleFilter.cpp.
| void ossimScaleFilter::setFilterType | ( | ossimScaleFilterType | minifyFilterType, |
| ossimScaleFilterType | magnifyFilterType | ||
Definition at line 268 of file ossimScaleFilter.cpp.
References createNewFilter(), m_MagnifyFilter, m_MagnifyFilterType, m_MinifyFilter, and m_MinifyFilterType.
inline |
Definition at line 80 of file ossimScaleFilter.h.
inline |
Definition at line 90 of file ossimScaleFilter.h.
inline |
Definition at line 99 of file ossimScaleFilter.h.
inline |
Definition at line 86 of file ossimScaleFilter.h.
inline |
Definition at line 94 of file ossimScaleFilter.h.
| void ossimScaleFilter::setScaleFactor | ( | const ossimDpt & | scale | ) |
Definition at line 363 of file ossimScaleFilter.cpp.
References FLT_EPSILON, m_InverseScaleFactor, m_ScaleFactor, updateGeometry(), ossimDpt::x, and ossimDpt::y.
protected |
Definition at line 949 of file ossimScaleFilter.cpp.
References ossimMapProjection::applyScale(), ossimImageGeometry::getProjection(), m_InverseScaleFactor, m_ScaledGeometry, PTR_CAST, and ossimRefPtr< T >::valid().
Referenced by getImageGeometry(), loadState(), and setScaleFactor().
protected |
Definition at line 142 of file ossimScaleFilter.h.
Referenced by allocate(), getTile(), and initialize().
protected |
Definition at line 152 of file ossimScaleFilter.h.
Referenced by getSupport(), getTile(), runFilterTemplate(), runHorizontalFilterTemplate(), and runVerticalFilterTemplate().
protected |
Definition at line 151 of file ossimScaleFilter.h.
Referenced by allocate(), initialize(), ossimScaleFilter(), runHorizontalFilterTemplate(), and runVerticalFilterTemplate().
protected |
Definition at line 149 of file ossimScaleFilter.h.
Referenced by getTile(), loadState(), setScaleFactor(), and updateGeometry().
protected |
Definition at line 145 of file ossimScaleFilter.h.
Referenced by getHorizontalFilter(), getVerticalFilter(), ossimScaleFilter(), setFilterType(), and ~ossimScaleFilter().
protected |
Definition at line 147 of file ossimScaleFilter.h.
Referenced by saveState(), and setFilterType().
protected |
Definition at line 144 of file ossimScaleFilter.h.
protected |
Definition at line 146 of file ossimScaleFilter.h.
protected |
The input image geometry, altered by the scale.
Definition at line 153 of file ossimScaleFilter.h.
Referenced by getImageGeometry(), and updateGeometry().
protected |
Definition at line 148 of file ossimScaleFilter.h.
Referenced by getBoundingRect(), getHorizontalFilter(), getImageGeometry(), getSupport(), getTile(), getVerticalFilter(), loadState(), runFilterTemplate(), runHorizontalFilterTemplate(), runVerticalFilterTemplate(), saveState(), and setScaleFactor().
protected |
Definition at line 143 of file ossimScaleFilter.h.
Referenced by allocate(), getTile(), initialize(), runFilter(), runFilterTemplate(), runHorizontalFilterTemplate(), and runVerticalFilterTemplate().
protected |
Definition at line 150 of file ossimScaleFilter.h.
