Go to the source code of this file.
Typedefs | |
| typedef char | ossim_int8 |
| Previous DLL import export section. More... | |
| typedef unsigned char | ossim_uint8 |
| typedef signed char | ossim_sint8 |
| typedef short | ossim_int16 |
| typedef unsigned short | ossim_uint16 |
| typedef signed short | ossim_sint16 |
| typedef int | ossim_int32 |
| typedef unsigned int | ossim_uint32 |
| typedef signed int | ossim_sint32 |
| typedef float | ossim_float32 |
| typedef double | ossim_float64 |
| typedef long long | ossim_int64 |
| typedef unsigned long long | ossim_uint64 |
| typedef signed long long | ossim_sint64 |
| typedef ossim_int32 | ossimErrorCode |
| #define DBL_EPSILON __DBL_EPSILON__ |
Definition at line 442 of file ossimConstants.h.
Referenced by ossimLensDistortion::distort(), ossimGeographicAnnotationGrid::draw(), ossimQuadTreeWarp::findClosestVertex(), ossimNBandLutDataObject::findIndex(), ossimInfo::getImageGeometryInfo(), ossimImageCombiner::getMaxPixelValue(), ossimBandSelector::getMaxPixelValue(), ossimPolygon::getMinimumBoundingRect(), ossimImageCombiner::getMinPixelValue(), ossimMapCompositionSource::getProperty(), ossimMatrixProperty::normalize(), ossimPolynomProjection::optimizeFit(), ossimImageData::populateHistogram(), ossimPolygon::removeSmallestContributingVertex(), ossimAdjustableParameterInfo::setOffset(), ossimRpcSolver::solveCoefficients(), ossimColumnVector4d::unit(), ossimH5GridModel::worldToLineSample(), and ossimSensorModel::worldToLineSample().
| #define DEG_PER_RAD ((ossim_float64)(180.0/M_PI)) |
Definition at line 452 of file ossimConstants.h.
Referenced by ossim::acosd(), ossim::asind(), ossim::atan2d(), ossim::atand(), ossimPositionQualityEvaluator::computeElevAzim(), ossimImageGeometry::computeGroundToImagePartials(), ossimUnitConversionTool::computeMeters(), ossimUnitConversionTool::getDegrees(), ossimRpcModel::getForwardDeriv(), ossimPointObservation::getObsCov(), ossimCadrgProjection::inverse(), ossimUpsProjection::inverse(), ossimNewZealandMapGridProjection::inverse(), ossimEckert6Projection::inverse(), ossimBonneProjection::inverse(), ossimPolarStereoProjection::inverse(), ossimCassiniProjection::inverse(), ossimTransMercatorProjection::inverse(), ossimGnomonicProjection::inverse(), ossimUtmProjection::inverse(), ossimMollweidProjection::inverse(), ossimVanDerGrintenProjection::inverse(), ossimMillerProjection::inverse(), ossimEckert4Projection::inverse(), ossimPolyconicProjection::inverse(), ossimStereographicProjection::inverse(), ossimTransCylEquAreaProjection::inverse(), ossimCylEquAreaProjection::inverse(), ossimSinusoidalProjection::inverse(), ossimAzimEquDistProjection::inverse(), ossimObliqueMercatorProjection::inverse(), ossimEquDistCylProjection::inverse(), ossimLambertConformalConicProjection::inverse(), ossimSpaceObliqueMercatorProjection::inverse(), ossimAlbersProjection::inverse(), ossimGpt::latr(), ossimGpt::lonr(), ATP::AutoTiePoint::print(), ossimLambertConformalConicProjection::print(), ossimPositionQualityEvaluator::print(), ossimAdjustmentExecutive::printObservationCorrectionSummary(), ossimInfo::rad2deg(), ossim::radiansToDegrees(), ossimLambertConformalConicProjection::saveState(), ossimAlbersProjection::saveState(), ossimUpsProjection::setDefaults(), ossimAlphaSensor::setFov(), ossimHsiVector::setFromRgb(), ossimWgs72Datum::shiftFromWgs84(), ossimWgs72Datum::shiftToWgs84(), ossimCadrgProjection::worldToLineSample(), ossimDatumFactory::writeCStructure(), and ossimEllipsoid::XYZToLatLonHeight().
| #define FLT_EPSILON __FLT_EPSILON__ |
Definition at line 438 of file ossimConstants.h.
Referenced by ossimBinaryOpDiv::apply(), ossimBinaryOpMod::apply(), ossimImageGeometry::computeGroundToImagePartials(), ossimSrtmSupportData::computeMinMaxTemplate(), ossimShorelineTool::doThreshold(), ossimTopographicCorrectionFilter::executeTopographicCorrectionTemplate(), ossimGeoidNgsHeader::getHeightDelta(), ossimImageViewTransform::getImageToViewScale(), ossimHistoMatchRemapper::getTile(), ossimSFIMFusion::getTile(), ossimHsiRemapper::getTile(), ossimTrimFilter::getValidImageVertices(), ossimImageViewTransform::getViewToImageScale(), ossimGeoidNgsHeader::initialize(), ossimLine::intersectInfinite(), ossimLine::intersectSegment(), ossimRpcSolver::invert(), ossimImageRenderer::ossimRendererSubRectInfo::isIdentity(), ossimLine::isPointOnInfiniteLine(), ossimSpot5Model::lineSampleHeightToWorld(), ossimFilterResampler::loadState(), ossimScaleFilter::loadState(), ossim::matrixToHpr(), ossimLine::normal(), ossimColumnVector3d::operator==(), ossimplugins::ossimGeometricSarSensorModel::optimizeModel(), ossimLsrSpace::ossimLsrSpace(), ossimStatePlaneProjectionInfo::ossimStatePlaneProjectionInfo(), ossimTiledImageHash::ossimTiledImageHash(), ossimTileHash::ossimTileHash(), ossimImageData::populateHistogram(), ossimFilterResampler::resampleBilinearTile(), ossimScaleFilter::runHorizontalFilterTemplate(), ossimScaleFilter::runVerticalFilterTemplate(), ossimHistogram::saveState(), ossimUpsProjection::setDefaults(), ossimHsiVector::setFromRgb(), ossimFilterResampler::setScaleFactor(), ossimScaleFilter::setScaleFactor(), ossimRpcSolver::setupWeightMatrix(), ossim2dLinearRegression::solve(), ossimRpcSolver::solveCoefficients(), ossimImageRenderer::ossimRendererSubRectInfo::transformViewToImage(), ossimMeanRadialLensDistortion::undistort(), ossimColumnVector3d::unit(), ossimImageGeometry::upIsUpAngle(), and ossimTiling::validate().
| #define FT_PER_MILE ((ossim_float64)5280.0) |
Definition at line 467 of file ossimConstants.h.
Referenced by ossimUnitConversionTool::computeMeters(), and ossimUnitConversionTool::getMiles().
| #define FT_PER_MTRS ((ossim_float64)3.280839895013122) |
Definition at line 464 of file ossimConstants.h.
Referenced by ossimUnitConversionTool::getFeet(), and ossimUnitConversionTool::getMiles().
| #define M_PI ((ossim_float64)3.141592653589793238462643) |
Definition at line 446 of file ossimConstants.h.
Referenced by ossimUnaryOpSind::apply(), ossimUnaryOpASind::apply(), ossimUnaryOpACosd::apply(), ossimUnaryOpCosd::apply(), ossimUnaryOpTand::apply(), ossimUnaryOpATand::apply(), ossimPositionQualityEvaluator::atan3(), ossimRpcProjection::buildNormalEquation(), ossimSensorModel::buildNormalEquation(), ossimFont::computeMatrix(), ossimUtmProjection::computeZone(), ossimAlbersProjection::Convert_Albers_To_Geodetic(), ossimAzimEquDistProjection::Convert_Azimuthal_Equidistant_To_Geodetic(), ossimBonneProjection::Convert_Bonne_To_Geodetic(), ossimCassiniProjection::Convert_Cassini_To_Geodetic(), ossimAlbersProjection::Convert_Geodetic_To_Albers(), ossimAzimEquDistProjection::Convert_Geodetic_To_Azimuthal_Equidistant(), ossimBonneProjection::Convert_Geodetic_To_Bonne(), ossimCassiniProjection::Convert_Geodetic_To_Cassini(), ossimMollweidProjection::Convert_Geodetic_To_Mollweide(), ossimNewZealandMapGridProjection::Convert_Geodetic_To_NZMG(), ossimOrthoGraphicProjection::Convert_Geodetic_To_Orthographic(), ossimPolyconicProjection::Convert_Geodetic_To_Polyconic(), ossimTransCylEquAreaProjection::Convert_Geodetic_To_Trans_Cyl_Eq_Area(), ossimUtmProjection::Convert_Geodetic_To_Transverse_Mercator(), ossimTransMercatorProjection::Convert_Geodetic_To_Transverse_Mercator(), ossimVanDerGrintenProjection::Convert_Geodetic_To_Van_der_Grinten(), ossimLambertConformalConicProjection::Convert_Lambert_To_Geodetic(), ossimMercatorProjection::Convert_Mercator_To_Geodetic(), ossimMollweidProjection::Convert_Mollweide_To_Geodetic(), ossimUtmProjection::Convert_Transverse_Mercator_To_Geodetic(), ossimTransMercatorProjection::Convert_Transverse_Mercator_To_Geodetic(), ossimVanDerGrintenProjection::Convert_Van_der_Grinten_To_Geodetic(), ossimPositionQualityEvaluator::extractErrorEllipse(), ossimSincFilter::filter(), ossimBesselFilter::filter(), ossimBlackmanFilter::filter(), ossimGaussianFilter::filter(), ossimHanningFilter::filter(), ossimHammingFilter::filter(), ossimMercatorProjection::forward(), ossimDemHeader::getImageGeometry(), ossimRpcProjection::getInverseDeriv(), ossimSensorModel::getInverseDeriv(), ossimPolygon::getMinimumBoundingRect(), ossimRpcProjection::getResidue(), ossimSensorModel::getResidue(), ossimSlopeFilter::getTile(), ossimMercatorProjection::inverse(), ossimImageSharpenFilter::laplacianOfGaussian(), lat2y_d(), lat2y_m(), ossimplugins::ossimTileMapModel::lineSampleHeightToWorld(), ossimDatum::molodenskyShift(), ossimEquationCombiner::parseFactor(), ossimAlbersProjection::Set_Albers_Parameters(), ossimAzimEquDistProjection::Set_Azimuthal_Equidistant_Parameters(), ossimCassiniProjection::Set_Cassini_Parameters(), ossimCylEquAreaProjection::Set_Cyl_Eq_Area_Parameters(), ossimEckert6Projection::Set_Eckert6_Parameters(), ossimEquDistCylProjection::Set_Equidistant_Cyl_Parameters(), ossimOrthoGraphicProjection::Set_Orthographic_Parameters(), ossimPolarStereoProjection::Set_Polar_Stereographic_Parameters(), ossimPolyconicProjection::Set_Polyconic_Parameters(), ossimStereographicProjection::Set_Stereographic_Parameters(), ossimTransCylEquAreaProjection::Set_Trans_Cyl_Eq_Area_Parameters(), ossimUtmProjection::Set_Transverse_Mercator_Parameters(), ossimTransMercatorProjection::Set_Transverse_Mercator_Parameters(), ossimVanDerGrintenProjection::Set_Van_der_Grinten_Parameters(), ossimWgs72Datum::shiftFromWgs84(), ossimWgs72Datum::shiftToWgs84(), ossimFilter::Sinc(), ossimBngProjection::update(), ossimplugins::ossimTileMapModel::worldToLineSample(), y2lat_d(), and y2lat_m().
| #define MTRS_PER_FT ((ossim_float64)0.3048) |
Definition at line 461 of file ossimConstants.h.
Referenced by ossimUnitConversionTool::computeMeters(), ossimEpsgProjectionDatabase::createProjFromFormatARecord(), ossimWktProjectionFactory::doMapCommon(), ossimStatePlaneProjectionInfo::falseEastingInMeters(), ossimStatePlaneProjectionInfo::falseNorthingInMeters(), ossimUsgsDemTileSource::fillBuffer(), ossim::ft2mtrs(), ossimInfo::ft2mtrs(), ossimMG4LidarReader::getGeoProjection(), ossimNitfUse00aTag::getMeanGsdInMeters(), ossimNitfPiaimcTag::getMeanGsdInMeters(), ossimFgdcXmlDoc::getProjection(), ossimAuxXmlSupportData::initializeProjection(), ossim::mtrs2ft(), and ossimInfo::mtrs2ft().
| #define OSSIM_DEFAULT_MAX_PIX_DOUBLE ((ossim_float64)((1.0/DBL_EPSILON))) |
Definition at line 561 of file ossimConstants.h.
Referenced by ossimKMeansClustering::computeKmeans(), ossim::defaultMax(), ossimTieGptSet::getGroundBoundaries(), ossimBandLutFilter::getTile(), and ossimImageStatisticsSource::setStatsSize().
| #define OSSIM_DEFAULT_MAX_PIX_FLOAT ((ossim_float32)((1.0/FLT_EPSILON))) |
Definition at line 553 of file ossimConstants.h.
Referenced by ossim::defaultMax(), and ossimHdf5ImageDataset::scanForMinMax().
| #define OSSIM_DEFAULT_MAX_PIX_NORM_DOUBLE ((ossim_float64)(1.0)) |
Definition at line 565 of file ossimConstants.h.
Referenced by ossim::defaultMax().
| #define OSSIM_DEFAULT_MAX_PIX_NORM_FLOAT ((ossim_float32)1.0) |
Definition at line 557 of file ossimConstants.h.
Referenced by ossim::defaultMax(), ossimBandClipFilter::runMedianStretch(), and ossimBandClipFilter::setNumberOfValues().
| #define OSSIM_DEFAULT_MAX_PIX_SINT16 ((ossim_sint16)0x7FFF) |
Definition at line 509 of file ossimConstants.h.
Referenced by ossimMultiBandHistogram::create(), ossim::defaultMax(), ossimImageHistogramSource::getBinInformation(), and ossimImageSourceSequencer::getBinInformation().
| #define OSSIM_DEFAULT_MAX_PIX_SINT32 ((ossim_sint32)0x7FFFFFFF) |
Definition at line 517 of file ossimConstants.h.
Referenced by ossim::defaultMax(), and ossimImageSourceSequencer::getTileOrigin().
| #define OSSIM_DEFAULT_MAX_PIX_SINT64 ((ossim_sint32)0x7FFFFFFFFFFFFFFF) |
Definition at line 525 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MAX_PIX_SINT8 ((ossim_sint8)0x7F) |
Definition at line 505 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MAX_PIX_UCHAR ((ossim_uint8)255) |
Definition at line 497 of file ossimConstants.h.
Referenced by ossimMultiBandHistogram::create(), ossimImageHistogramSource::getBinInformation(), ossimImageSourceSequencer::getBinInformation(), ossimHsvToRgbSource::getMaxPixelValue(), and ossimHsiToRgbSource::getMaxPixelValue().
| #define OSSIM_DEFAULT_MAX_PIX_UINT11 ((ossim_uint16)0x07FF) |
Definition at line 533 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MAX_PIX_UINT12 ((ossim_uint16)0x0FFF) |
Definition at line 537 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MAX_PIX_UINT13 ((ossim_uint16)0x1FFF) |
Definition at line 541 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MAX_PIX_UINT14 ((ossim_uint16)0x3FFF) |
Definition at line 545 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MAX_PIX_UINT15 ((ossim_uint16)0x7FFF) |
Definition at line 549 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MAX_PIX_UINT16 ((ossim_uint16)0xFFFF) |
Definition at line 513 of file ossimConstants.h.
Referenced by ossimMultiBandHistogram::create(), ossim::defaultMax(), ossimImageHistogramSource::getBinInformation(), ossimImageSourceSequencer::getBinInformation(), and ossimWriter::writeTiffTags().
| #define OSSIM_DEFAULT_MAX_PIX_UINT32 ((ossim_uint32)0xFFFFFFFF) |
Definition at line 521 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MAX_PIX_UINT64 ((ossim_uint32)0xFFFFFFFFFFFFFFFF) |
Definition at line 529 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MAX_PIX_UINT8 ((ossim_uint8)255) |
Definition at line 501 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MEAN_SEA_LEVEL ((ossim_float64)0.0) |
Definition at line 567 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MIN_PIX_DOUBLE ((ossim_float64)((-1.0/DBL_EPSILON) + 1)) |
Definition at line 560 of file ossimConstants.h.
Referenced by ossimKMeansClustering::computeKmeans(), ossim::defaultMin(), ossimTieGptSet::getGroundBoundaries(), ossimBandLutFilter::getTile(), ossimPolynomProjection::optimizeFit(), and ossimImageStatisticsSource::setStatsSize().
| #define OSSIM_DEFAULT_MIN_PIX_FLOAT ((ossim_float32)((-1.0/FLT_EPSILON) + 1)) |
Definition at line 552 of file ossimConstants.h.
Referenced by ossim::defaultMin(), and ossimHdf5ImageDataset::scanForMinMax().
| #define OSSIM_DEFAULT_MIN_PIX_NORM_DOUBLE ((ossim_float64)((2*DBL_EPSILON))) |
Definition at line 564 of file ossimConstants.h.
Referenced by ossimImageData::copyTileToNormalizedBuffer(), and ossim::defaultMin().
| #define OSSIM_DEFAULT_MIN_PIX_NORM_FLOAT ((ossim_float32)((2*FLT_EPSILON))) |
Definition at line 556 of file ossimConstants.h.
Referenced by ossimImageData::copyTileToNormalizedBuffer(), ossim::defaultMin(), ossimBrightnessContrastSource::processRgbTile(), ossimBandClipFilter::runMedianStretch(), and ossimBandClipFilter::setNumberOfValues().
| #define OSSIM_DEFAULT_MIN_PIX_SINT16 ((ossim_sint16)0x8001) |
Definition at line 508 of file ossimConstants.h.
Referenced by ossimMultiBandHistogram::create(), ossim::defaultMin(), ossimImageHistogramSource::getBinInformation(), and ossimImageSourceSequencer::getBinInformation().
| #define OSSIM_DEFAULT_MIN_PIX_SINT32 ((ossim_sint32)0x80000001) |
Definition at line 516 of file ossimConstants.h.
Referenced by ossim::defaultMin().
| #define OSSIM_DEFAULT_MIN_PIX_SINT64 ((ossim_sint32)0x8000000000000001) |
Definition at line 524 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MIN_PIX_SINT8 ((ossim_sint8)0x81) |
Definition at line 504 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MIN_PIX_UCHAR ((ossim_uint8)1) |
Definition at line 496 of file ossimConstants.h.
Referenced by ossimHsvToRgbSource::getMinPixelValue(), and ossimHsiToRgbSource::getMinPixelValue().
| #define OSSIM_DEFAULT_MIN_PIX_UINT11 ((ossim_uint16)1) |
Definition at line 532 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MIN_PIX_UINT12 ((ossim_uint16)1) |
Definition at line 536 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MIN_PIX_UINT13 ((ossim_uint16)1) |
Definition at line 540 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MIN_PIX_UINT14 ((ossim_uint16)1) |
Definition at line 544 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MIN_PIX_UINT15 ((ossim_uint16)1) |
Definition at line 548 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MIN_PIX_UINT16 ((ossim_uint16)1) |
Definition at line 512 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MIN_PIX_UINT32 ((ossim_uint32)1) |
Definition at line 520 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MIN_PIX_UINT64 ((ossim_uint32)1) |
Definition at line 528 of file ossimConstants.h.
| #define OSSIM_DEFAULT_MIN_PIX_UINT8 ((ossim_uint8)1) |
Definition at line 500 of file ossimConstants.h.
| #define OSSIM_DEFAULT_NULL_PIX_DOUBLE ((ossim_float64)-1.0/DBL_EPSILON) |
Definition at line 559 of file ossimConstants.h.
Referenced by ossim::defaultNull().
| #define OSSIM_DEFAULT_NULL_PIX_FLOAT ((ossim_float32)-1.0/FLT_EPSILON) |
Definition at line 551 of file ossimConstants.h.
Referenced by ossim::defaultNull(), ossimPointCloudImageHandler::getNullPixelValue(), and ossimPointCloudImageHandler::getTile().
| #define OSSIM_DEFAULT_NULL_PIX_NORM_DOUBLE ((ossim_float64)0) |
Definition at line 563 of file ossimConstants.h.
| #define OSSIM_DEFAULT_NULL_PIX_NORM_FLOAT ((ossim_float32)0) |
Definition at line 555 of file ossimConstants.h.
| #define OSSIM_DEFAULT_NULL_PIX_SINT16 ((ossim_sint16)0x8000) |
Definition at line 507 of file ossimConstants.h.
| #define OSSIM_DEFAULT_NULL_PIX_SINT32 ((ossim_sint32)0x80000000) |
Definition at line 515 of file ossimConstants.h.
| #define OSSIM_DEFAULT_NULL_PIX_SINT64 ((ossim_sint32)0x8000000000000000) |
Definition at line 523 of file ossimConstants.h.
| #define OSSIM_DEFAULT_NULL_PIX_SINT8 ((ossim_sint8)0x80) |
Definition at line 503 of file ossimConstants.h.
| #define OSSIM_DEFAULT_NULL_PIX_UCHAR ((ossim_uint8)0) |
Definition at line 495 of file ossimConstants.h.
| #define OSSIM_DEFAULT_NULL_PIX_UINT11 ((ossim_uint16)0) |
Definition at line 531 of file ossimConstants.h.
| #define OSSIM_DEFAULT_NULL_PIX_UINT12 ((ossim_uint16)0) |
Definition at line 535 of file ossimConstants.h.
| #define OSSIM_DEFAULT_NULL_PIX_UINT13 ((ossim_uint16)0) |
Definition at line 539 of file ossimConstants.h.
| #define OSSIM_DEFAULT_NULL_PIX_UINT14 ((ossim_uint16)0) |
Definition at line 543 of file ossimConstants.h.
| #define OSSIM_DEFAULT_NULL_PIX_UINT15 ((ossim_uint16)0) |
Definition at line 547 of file ossimConstants.h.
| #define OSSIM_DEFAULT_NULL_PIX_UINT16 ((ossim_uint16)0) |
Definition at line 511 of file ossimConstants.h.
| #define OSSIM_DEFAULT_NULL_PIX_UINT32 ((ossim_uint32)0) |
Definition at line 519 of file ossimConstants.h.
| #define OSSIM_DEFAULT_NULL_PIX_UINT64 ((ossim_uint32)0) |
Definition at line 527 of file ossimConstants.h.
| #define OSSIM_DEFAULT_NULL_PIX_UINT8 ((ossim_uint8)0) |
Definition at line 499 of file ossimConstants.h.
| #define OSSIM_DEFAULT_TILE_HEIGHT ((ossim_int32)64) |
Definition at line 477 of file ossimConstants.h.
Referenced by ossim::defaultTileSize().
| #define OSSIM_DEFAULT_TILE_WIDTH ((ossim_int32)64) |
Definition at line 478 of file ossimConstants.h.
| #define OSSIM_DEPRECATE_METHOD | ( | func | ) |
WARNINGS SECTION:
Definition at line 38 of file ossimConstants.h.
| #define OSSIM_DLL |
Definition at line 72 of file ossimConstants.h.
| #define OSSIM_DLL_DATA | ( | type | ) | type |
Definition at line 74 of file ossimConstants.h.
| #define OSSIM_INT_NAN ((ossim_sint32)0x80000000) |
Definition at line 493 of file ossimConstants.h.
Referenced by ossimIrect::clipToRect(), ossimQuickbirdTiffTileSource::getImageGeometry(), ossimPolygon::getIntegerBounds(), ossimPolyLine::getIntegerBounds(), ossimIpt::hasNans(), ossimQuickbirdTileInfo::initialize(), ossimIpt::isNan(), ossimIpt::makeNan(), ossimIrect::midPoint(), ossimRationalNumber::operator/(), ossimRationalNumber::operator/=(), operator>>(), ossimIpt::print(), and ossimIpt::toString().
| #define OSSIMDLLEXPORT |
Definition at line 71 of file ossimConstants.h.
| #define OSSIMDLLEXPORT_CTORFN |
Definition at line 75 of file ossimConstants.h.
| #define OSSIMDLLEXPORT_DATA | ( | type | ) | type |
Definition at line 73 of file ossimConstants.h.
| #define OSSIMEXPORT |
DLL IMPORT/EXORT SECTION.
Definition at line 69 of file ossimConstants.h.
| #define OSSIMIMPORT |
Definition at line 70 of file ossimConstants.h.
| #define RAD_PER_DEG ((ossim_float64)(M_PI/180.0)) |
Definition at line 458 of file ossimConstants.h.
Referenced by ossimUtmProjection::Convert_Transverse_Mercator_To_Geodetic(), ossimTransMercatorProjection::Convert_Transverse_Mercator_To_Geodetic(), ossim::cosd(), ossimMatrix3x3::createRotationXMatrix(), ossimMatrix4x4::createRotationXMatrix(), ossimMatrix3x3::createRotationYMatrix(), ossimMatrix4x4::createRotationYMatrix(), ossimMatrix3x3::createRotationZMatrix(), ossimMatrix4x4::createRotationZMatrix(), ossimInfo::deg2rad(), ossim::degreesToRadians(), ossimAnnotationEllipseObject::draw(), ossimUnitConversionTool::getRadians(), ossimLambertConformalConicProjection::getStandardParallel1(), ossimAlbersProjection::getStandardParallel1(), ossimLambertConformalConicProjection::getStandardParallel2(), ossimAlbersProjection::getStandardParallel2(), ossimEllipsoid::jacobianWrtEcef(), ossimEllipsoid::jacobianWrtGeo(), ossimGpt::latr(), ossimLambertConformalConicProjection::loadState(), ossimAlbersProjection::loadState(), ossimGpt::lonr(), ossimGpt::metersPerDegree(), ossimNormRgbVector::operator=(), ossimRgbVector::operator=(), ossimAlbersProjection::ossimAlbersProjection(), ossimLambertConformalConicProjection::ossimLambertConformalConicProjection(), ossimRgbVector::ossimRgbVector(), ossimEllipsoid::prinRadiiOfCurv(), ossimSpaceObliqueMercatorProjection::seraz0(), ossimLambertConformalConicProjection::setDefaults(), ossimAlbersProjection::setDefaults(), ossimSpaceObliqueMercatorProjection::setParameters(), ossimLambertConformalConicProjection::setParameters(), ossimAlbersProjection::setParameters(), ossimLambertConformalConicProjection::setStandardParallel1(), ossimAlbersProjection::setStandardParallel1(), ossimLambertConformalConicProjection::setStandardParallel2(), ossimAlbersProjection::setStandardParallel2(), ossimLambertConformalConicProjection::setStandardParallels(), ossimAlbersProjection::setStandardParallels(), ossim::sind(), and ossim::tand().
| #define SEC_PER_RAD ((ossim_float64)206264.8062471) |
Definition at line 455 of file ossimConstants.h.
Referenced by ossimWgs72Datum::shiftFromWgs84(), and ossimWgs72Datum::shiftToWgs84().
| #define SQRT_TWO_PI ((ossim_float64)2.50662827463100050242) |
Definition at line 470 of file ossimConstants.h.
| #define SQRT_TWO_PI_DIV2 ((ossim_float64)7.07106781186547524401E-1) |
Definition at line 473 of file ossimConstants.h.
| #define TIFFTAG_OSSIM_METADATA 50955 |
Definition at line 476 of file ossimConstants.h.
| #define TWO_PI ((ossim_float64)(2.0 * M_PI)) |
Definition at line 449 of file ossimConstants.h.
Referenced by ossimPositionQualityEvaluator::atan3(), ossimAlbersProjection::Convert_Albers_To_Geodetic(), ossimAlbersProjection::Convert_Geodetic_To_Albers(), ossimAzimEquDistProjection::Convert_Geodetic_To_Azimuthal_Equidistant(), ossimBonneProjection::Convert_Geodetic_To_Bonne(), ossimCassiniProjection::Convert_Geodetic_To_Cassini(), ossimUtmProjection::Convert_Geodetic_To_Transverse_Mercator(), ossimTransMercatorProjection::Convert_Geodetic_To_Transverse_Mercator(), ossimUtmProjection::Convert_Transverse_Mercator_To_Geodetic(), ossimTransMercatorProjection::Convert_Transverse_Mercator_To_Geodetic(), ossimRgbImage::drawEllipse(), ossimPositionQualityEvaluator::extractErrorEllipse(), ossimAlbersProjection::Set_Albers_Parameters(), ossimUtmProjection::Set_Transverse_Mercator_Parameters(), and ossimTransMercatorProjection::Set_Transverse_Mercator_Parameters().
| #define US_METERS_PER_FT ((ossim_float64)0.3048006096) |
Definition at line 486 of file ossimConstants.h.
Referenced by ossimUnitConversionTool::computeMeters(), ossimEpsgProjectionDatabase::createProjFromFormatARecord(), ossimStatePlaneProjectionInfo::falseEastingInMeters(), ossimStatePlaneProjectionInfo::falseNorthingInMeters(), ossimInfo::ft2mtrs(), ossimMG4LidarReader::getGeoProjection(), ossimFgdcXmlDoc::getProjection(), ossimUnitConversionTool::getUsSurveyFeet(), ossimAuxXmlSupportData::initializeProjection(), ossimInfo::mtrs2ft(), ossim::mtrs2usft(), and ossim::usft2mtrs().
| typedef float ossim_float32 |
Definition at line 238 of file ossimConstants.h.
| typedef double ossim_float64 |
Definition at line 239 of file ossimConstants.h.
| typedef short ossim_int16 |
Definition at line 230 of file ossimConstants.h.
| typedef int ossim_int32 |
Definition at line 234 of file ossimConstants.h.
| typedef long long ossim_int64 |
Definition at line 242 of file ossimConstants.h.
| typedef char ossim_int8 |
Commented out, but left just in case.
Definition at line 226 of file ossimConstants.h.
| typedef signed short ossim_sint16 |
Definition at line 232 of file ossimConstants.h.
| typedef signed int ossim_sint32 |
Definition at line 236 of file ossimConstants.h.
| typedef signed long long ossim_sint64 |
Definition at line 244 of file ossimConstants.h.
| typedef signed char ossim_sint8 |
Definition at line 228 of file ossimConstants.h.
| typedef unsigned short ossim_uint16 |
Definition at line 231 of file ossimConstants.h.
| typedef unsigned int ossim_uint32 |
Definition at line 235 of file ossimConstants.h.
| typedef unsigned long long ossim_uint64 |
Definition at line 243 of file ossimConstants.h.
| typedef unsigned char ossim_uint8 |
Definition at line 227 of file ossimConstants.h.
| typedef ossim_int32 ossimErrorCode |
Definition at line 246 of file ossimConstants.h.
| enum ossimByteOrder |
| Enumerator | |
| OSSIM_LITTLE_ENDIAN | |
| OSSIM_BIG_ENDIAN | |
Definition at line 425 of file ossimConstants.h.
| enum ossimCompareType |
| Enumerator | |
| OSSIM_COMPARE_FULL | |
| OSSIM_COMPARE_IMMEDIATE | |
Definition at line 431 of file ossimConstants.h.
| Enumerator | |
| OSSIM_COORDINATE_SYSTEM_UNKNOWN | |
| OSSIM_IMAGE_SPACE | |
| OSSIM_GEOGRAPHIC_SPACE | |
| OSSIM_PROJECTED_SPACE | |
| OSSIM_GEOCENTRIC_SPACE | |
Definition at line 346 of file ossimConstants.h.
| Enumerator | |
| OSSIM_LEFT_HANDED | |
| OSSIM_RIGHT_HANDED | |
Definition at line 358 of file ossimConstants.h.
Definitions for data object status.
| Enumerator | |
| OSSIM_STATUS_UNKNOWN | |
| OSSIM_NULL | |
| OSSIM_EMPTY | |
| OSSIM_PARTIAL | |
| OSSIM_FULL | |
Definition at line 389 of file ossimConstants.h.
| enum ossimHistogramMode |
| Enumerator | |
| OSSIM_HISTO_MODE_UNKNOWN | |
| OSSIM_HISTO_MODE_NORMAL | |
| OSSIM_HISTO_MODE_FAST | |
Definition at line 258 of file ossimConstants.h.
| enum ossimImageType |
Definitions for image type identification.
Definition at line 399 of file ossimConstants.h.
| enum ossimInterleaveType |
| Enumerator | |
| OSSIM_INTERLEAVE_UNKNOWN | |
| OSSIM_BIL | |
| OSSIM_BIP | |
| OSSIM_BSQ | |
| OSSIM_BSQ_MULTI_FILE | |
Definition at line 321 of file ossimConstants.h.
| enum ossimMetadataType |
Definitions for metadata type identification.
| Enumerator | |
| OSSIM_META_UNKNOWN | |
| OSSIM_META_TFW | |
| OSSIM_META_JGW | |
| OSSIM_META_GEOM | |
| OSSIM_META_README | |
| OSSIM_META_FGDC | |
| OSSIM_META_ENVI | |
Definition at line 414 of file ossimConstants.h.
| Enumerator | |
| OSSIM_ORIGIN_LOCATION_UNKNOWN | |
| OSSIM_CENTER | |
| OSSIM_UPPER_LEFT | |
| OSSIM_UPPER_LEFT_CENTER | |
| OSSIM_LOWER_LEFT | |
| OSSIM_LOWER_LEFT_CENTER | |
Definition at line 333 of file ossimConstants.h.
| enum ossimPixelType |
| Enumerator | |
| OSSIM_PIXEL_IS_POINT | |
| OSSIM_PIXEL_IS_AREA | |
Definition at line 269 of file ossimConstants.h.
| enum ossimScalarType |
Definition at line 278 of file ossimConstants.h.
| enum ossimUnitType |
Definition at line 367 of file ossimConstants.h.
| enum ossimVertexOrdering |
| Enumerator | |
| OSSIM_VERTEX_ORDER_UNKNOWN | |
| OSSIM_CLOCKWISE_ORDER | |
| OSSIM_COUNTERCLOCKWISE_ORDER | |
Definition at line 248 of file ossimConstants.h.
