#include <ossimQuickbirdTiffTileSource.h>
| virtual bool | open () |
| Pure virtual open. More... | |
Public Member Functions inherited from ossimTiffTileSource | |
| ossimTiffTileSource () | |
| virtual bool | open (const ossimFilename &image_file) |
| Returns true if the image_file can be opened and is a valid tiff file. More... | |
| bool | open (std::shared_ptr< ossim::istream > &str, const std::string &connectionString) |
| This open takes a stream and stores/captures the shared pointer on success. More... | |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More... | |
| Returns the number of bands in the image. More... | |
| Initializes bandList to the zero based order of output bands. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| Returns the number of lines in the image. More... | |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| Returns the number of samples in the image. More... | |
| virtual ossim_uint32 | getNumberOfDirectories () const |
| Returns the number of image file directories in the tiff image. More... | |
| Returns the number of reduced resolution data sets (rrds). More... | |
| Returns the output pixel type of the tile source. More... | |
| Returns the width of the output tile. More... | |
| Returns the height of the output tile. More... | |
| bool | hasR0 () const |
| Returns true if the first directory of the tiff image did not have the reduced resolution file type set. More... | |
| virtual ossim_float64 | getMinPixelValue (ossim_uint32 band=0) const |
| virtual ossim_float64 | getMaxPixelValue (ossim_uint32 band=0) const |
| virtual ossim_float64 | getNullPixelValue (ossim_uint32 band=0) const |
| void | setApplyColorPaletteFlag (bool flag) |
| bool | getApplyColorPaletteFlag () const |
| bool | isColorMapped () const |
| virtual std::ostream & | print (std::ostream &os) const |
| TIFF * | tiffPtr () |
| ossimImageHandler () | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Types inherited from ossimTiffTileSource | |
| enum | ReadMethod { UNKNOWN, READ_RGBA_U8_TILE, READ_RGBA_U8_STRIP, READ_RGBA_U8A_STRIP, READ_SCAN_LINE, READ_TILE, READ_U16_STRIP } |
Protected Member Functions inherited from ossimTiffTileSource | |
| virtual | ~ossimTiffTileSource () |
| bool | open () |
| Returns true if no errors initializing object. More... | |
Definition at line 25 of file ossimQuickbirdTiffTileSource.h.
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 77 of file ossimQuickbirdTiffTileSource.cpp.
References ossimString::downcase(), ossimFilename::file(), ossimImageHandler::getExternalImageGeometry(), ossimQuickbirdTile::getInfo(), m_tileInfoFilename, ossimQuickbirdTile::open(), OSSIM_INT_NAN, ossimQuickbirdRpcModel::parseFile(), ossimImageGeometry::setProjection(), ossimString::size(), ossimImageHandler::theGeometry, ossimImageHandler::theImageFile, ossimQuickbirdTileInfo::theUlXOffset, ossimQuickbirdTileInfo::theUlYOffset, and ossimString::upcase().
Pure virtual open.
Derived classes must implement.
Implements ossimImageHandler.
Definition at line 34 of file ossimQuickbirdTiffTileSource.cpp.
protected |
Definition at line 32 of file ossimQuickbirdTiffTileSource.h.
Referenced by getImageGeometry().
