| | ossimSrtmTileSource () |
| virtual bool | open () |
| | Pure virtual open. More...
| | Returns the image geometry object associated with this tile source or NULL if not defined. More...
| | Method to save the state of an object to a keyword list. More...
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| | Method to the load (recreate) the state of an object from a keyword list. More...
| | Gets a property. More...
| | Adds property names to array. More...
| | ossimGeneralRasterTileSource () |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tile_rect, ossim_uint32 resLevel=0) |
| | Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More...
| | Method to get a tile. More...
| | Returns the number of bands in the image. More...
| | Returns the number of bands in a tile returned from this TileSource. More...
| | Returns the number of lines in the image. More...
| | Returns the number of samples in the image. More...
| | Returns the output pixel type of the tile source. More...
| | Returns the width of the output tile. More...
| | Returns the height of the output tile. More...
| | Returns the tile width of the image or 0 if the image is not tiled. More...
| bool | isValidRLevel (ossim_uint32 reduced_res_level) const |
| | Determines if the passed in reslution level is valid. More...
| virtual void | close () |
| | Deletes the overview and clears the valid image vertices. More...
| | Derived classes must implement this method to be concrete. More...
| virtual bool | open (const ossimGeneralRasterInfo &info) |
| | Override base getXXXXPixValue methods since the null/min/max can be set to something different. More...
| | Retuns the min pixel value. More...
| | Returns the max pixel of the band. More...
| | Indicates whether or not the image handler can control output band selection via the setOutputBandList method. More...
| | If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled. More...
| | Initializes bandList to the zero based order of output bands. More...
Public Member Functions inherited from ossimImageHandler |
| | ossimImageHandler () |
| | Constructor (default): More...
| | Destructor: Derived classes should implement. More...
| | initialize Does nothing in this class. More...
| | Searches for an overview. More...
| | Calls closeOverview(), then attempts to open the overview_file. More...
| | If theOverview is initialized it will be deleted and set to NULL. More...
| | Outputs vertices to file and updates the internal vertex array variable "theValidImageVertices". More...
| | Opens the valid image vertices file and sets theValidImageVerticesFile variable. More...
| | Creates vertices file name based on image, then tries to open. More...
| | Opens the image file. More...
| | Build a histogram for image file. More...
| | Build a histograms for all image entries. More...
| | Will build over file for theImageFile. More...
| | Will build over file for all image entries. More...
| | Will build an over file for filename. More...
| | Fetches the current entry image's histogram. More...
| | Sets the image geometry object. More...
| | Saves the image geometry to a file that will be made based on the image file name. More...
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| | Returns zero-based bounding rectangle of the image. More...
| | This returns all decimation for all levels. More...
| | This returns the total number of decimation levels. More...
| | This method is obsolete. More...
| | Sets the filename. More...
| | Returns the filename. More...
| | Connection rule. More...
| | ordering specifies how the vertices should be arranged. More...
| | If the image handler "isBandSeletor()" then the band selection of the output are set to input or identity. More...
| | Convenience method to see if band list is identity. More...
| | Indicates whether or not the image is tiled internally. More...
| | There is an external file with an omd extension. More...
| | convenience method to set min pixel value. More...
| | convenience method to set max pixel value. More...
| | convenience method to set null pixel value. More...
| | Get the name of entry as a string. More...
| | Convenience method to determine if entry index should be used for support files, e.g. More...
| | Returns the image file with extension set using supplentary directory for dirname if set. More...
| | Sets theOpenOverviewFlag. More...
| | Sets the supplementary directory. More...
| | Returns the supplementary directory. More...
| | Fetches the image ID. More...
| | Sets the image ID in case it is externally generated. More...
| | Returns the raster pixel alignment type. More...
| | Convenience method to get the zero based rgb output band list. More...
| template<class T > |
| | ossimImageSource (ossimObject *owner=0) |
| | ossimImageSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) |
| | For RTTI support. More...
| | Will return an array of all decimations for each resolution level. More...
| | Gets the bounding rectangle of the source. More...
| | Default implementation sets geometry of the first input to the geometry specified. More...
| | ossimSource (ossimObject *owner=0) |
| | ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) |
| virtual | ~ossimSource () |
| | Outputs theErrorStatus as an ossimErrorCode and an ossimString. More...
| | ossimConnectableObject (ossimObject *owner=0) |
| | Base constructor of this object. More...
| | ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) |
| | All connectable objects will have id's. More...
| | Will allow us to get this object's id. More...
| | Fetches the current owner, most likely a container but not limited to one. More...
| | Permits changing the object's owner. More...
| | will check the direction specified to see if all slots are full. More...
| | OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) |
| | OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) |
| | OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) |
| | OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) |
| | Return a valid index of the input list if the passed in object is found else return -1. More...
| | Return a valid index of the input list if the passed id is found else return -1. More...
| | Return a valid index of the output list if the passed in object is found else return -1. More...
| | Should return the first available index to connect to. More...
| | default implementation is to allow anyone to connect to us. More...
| | Will disconnect the object passed in. More...
| | Will disconnect the object at the given input index and generate a connection event. More...
| | Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More...
| | Will disconnect the object at the given output index and generate a connection event. More...
| | Will disconnect the output object. More...
| | Will disconnect all of the input objects. More...
| | Will disconnect all of the output objects. More...
| | Will try to connect this objects input to the passed in object. More...
| | Will connect the specified input to the passed in object. More...
| | Will try to connect this objects output to the passed in object. More...
| | Will disconnect itself from all inputs and reset to the passed in input list. More...
| | Will disconnect itself from all outputs and reset to the passed in output list. More...
| | Returns the number of input objects. More...
| | Return the number of output objects. More...
| | returns the object at the specified index. More...
| | Will set the number of inputs. More...
| | Will set the number of outputs. More...
| | OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) |
| | OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) |
| | Save the state of all inputs to a keyword list. More...
| | Inserts this object and all of its children and inputs into the container provided. More...
| | Moves the input connection matching id up one in the connection list. More...
| | Moves the input connection matching id down one in the connection list. More...
| | Moves the input connection matching id to the top of the connection list. More...
| | Moves the input connection matching id to the bottom of the connection list. More...
| | We will add a visitor interface for all connectable objects. More...
| | ossimObject () |
| | ossimReferenced () |
| | ossimReferenced (const ossimReferenced &) |
| | increment the reference count by one, indicating that this object has another pointer which is referencing it. More...
| | decrement the reference count by one, indicating that a pointer to this object is referencing it. More...
| | ossimListenerManager () |
| | ossimPropertyInterface () |
| | ossimErrorStatusInterface () |
| bool | hasError () const |
