#include <ossimSubImageTileSource.h>
| ossimSubImageTileSource () | |
| ossimSubImageTileSource (ossimImageSource *inputSource) | |
| ossimSubImageTileSource (ossimImageSource *inputSource, const ossimIpt &offset) | |
| void | setSubImageOffset (const ossimIpt &offset) |
| ossimIpt | getSubImageOffset () const |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &rect, ossim_uint32 rr_level=0) |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Private Member Functions | |
| virtual | ~ossimSubImageTileSource () |
Private Attributes | |
| ossimIpt | theSubImageOffset |
| ossimRefPtr< ossimImageData > | theTile |
CLASS: ossimSubImageTileSource
This tile source permits specifying an offset that is to be applied to the tile origin for all getTile() requests. It is intended for converting a full-image space coordinate to a sub-image coordinate.
Definition at line 33 of file ossimSubImageTileSource.h.
| ossimSubImageTileSource::ossimSubImageTileSource | ( | ) |
Default constructor initializes the sub-image offset to zero.
Definition at line 34 of file ossimSubImageTileSource.cpp.
| ossimSubImageTileSource::ossimSubImageTileSource | ( | ossimImageSource * | inputSource | ) |
Constructor accepts an input source pointer. Offset is defaulted to (0,0).
Definition at line 41 of file ossimSubImageTileSource.cpp.
| ossimSubImageTileSource::ossimSubImageTileSource | ( | ossimImageSource * | inputSource, |
| const ossimIpt & | offset | ||
Constructs with specified input source and offset.
Definition at line 47 of file ossimSubImageTileSource.cpp.
privatevirtual |
Definition at line 54 of file ossimSubImageTileSource.cpp.
Fetches the sub-image's bounding rect in FULL-IMAGE SPACE.
Definition at line 128 of file ossimSubImageTileSource.cpp.
References ossimImageSource::getBoundingRect(), ossimImageSource::getDecimationFactor(), ossimDpt::hasNans(), ossimDrect::makeNan(), ossimImageSourceFilter::theInputConnection, theSubImageOffset, ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
inline |
Definition at line 57 of file ossimSubImageTileSource.h.
Definition at line 62 of file ossimSubImageTileSource.cpp.
References ossimImageData::dup(), ossimRefPtr< T >::get(), ossimImageSource::getDecimationFactor(), ossimImageSource::getTile(), ossimDpt::hasNans(), ossimImageData::loadTile(), ossimImageData::makeBlank(), ossimImageData::setImageRectangle(), ossimImageData::setOrigin(), ossimImageSourceFilter::theInputConnection, theSubImageOffset, theTile, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Fetches the sub-image's valid image vertices in FULL-IMAGE SPACE.
Definition at line 159 of file ossimSubImageTileSource.cpp.
References ossimImageSource::getValidImageVertices(), ossimImageSourceFilter::theInputConnection, and theSubImageOffset.
Definition at line 183 of file ossimSubImageTileSource.cpp.
References ossimImageSourceFilter::initialize(), and theTile.
Definition at line 190 of file ossimSubImageTileSource.cpp.
References ossimKeywordlist::find().
Definition at line 209 of file ossimSubImageTileSource.cpp.
References ossimKeywordlist::add(), and ossimImageSourceFilter::saveState().
inline |
Permits setting the image's offset relative to the full image space.
Definition at line 55 of file ossimSubImageTileSource.h.
private |
Definition at line 85 of file ossimSubImageTileSource.h.
Referenced by getBoundingRect(), getTile(), and getValidImageVertices().
private |
Definition at line 86 of file ossimSubImageTileSource.h.
Referenced by getTile(), and initialize().
