#include <ossimGeneralRasterTileSource.h>
| ossimGeneralRasterTileSource () | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tile_rect, ossim_uint32 resLevel=0) |
| Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More... | |
| Returns the number of bands in the image. More... | |
| Returns the number of lines in the image. More... | |
| Returns the number of samples in the image. More... | |
| Returns the output pixel type of the tile source. More... | |
| Returns the width of the output tile. More... | |
| Returns the height of the output tile. More... | |
| bool | isValidRLevel (ossim_uint32 reduced_res_level) const |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual bool | open () |
| Pure virtual open. More... | |
| virtual bool | open (const ossimGeneralRasterInfo &info) |
| Override base getXXXXPixValue methods since the null/min/max can be set to something different. More... | |
| Initializes bandList to the zero based order of output bands. More... | |
| ossimImageHandler () | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual | ~ossimGeneralRasterTileSource () |
| virtual bool | fillBuffer (const ossimIpt &origin, const ossimIpt &size) |
| Methods return true on succes false on error. More... | |
| virtual bool | fillBIP (const ossimIpt &origin, const ossimIpt &size) |
| virtual bool | fillBIL (const ossimIpt &origin, const ossimIpt &size) |
| virtual bool | fillBSQ (const ossimIpt &origin, const ossimIpt &size) |
| virtual bool | fillBsqMultiFile (const ossimIpt &origin, const ossimIpt &size) |
| virtual ossimKeywordlist | getHdrInfo (ossimFilename hdrFile) |
| virtual ossimKeywordlist | getXmlInfo (ossimFilename xmlFile) |
| bool | initializeHandler () |
Private Member Functions | |
| void | allocateTile () |
| Allocates m_tile. More... | |
| void | allocateBuffer (const ossimImageData *tile) |
| Allocates m_buffer. More... | |
Definition at line 29 of file ossimGeneralRasterTileSource.h.
| ossimGeneralRasterTileSource::ossimGeneralRasterTileSource | ( | ) |
protectedvirtual |
private |
Allocates m_buffer.
Definition at line 1578 of file ossimGeneralRasterTileSource.cpp.
References ossimImageMetaData::getBytesPerPixel(), ossimGeneralRasterInfo::getImageMetaData(), ossimImageMetaData::getNumberOfBands(), ossimImageData::getSize(), ossimImageData::getSizeInBytes(), ossimImageData::getWidth(), ossimGeneralRasterInfo::interleaveType(), m_buffer, m_bufferRect, m_bufferSizeInPixels, m_lineBuffer, m_rasterInfo, and OSSIM_BIP.
private |
Allocates m_tile.
Definition at line 1546 of file ossimGeneralRasterTileSource.cpp.
References ossimImageDataFactory::create(), ossimGeneralRasterInfo::getImageMetaData(), ossimImageMetaData::getMaxPix(), ossimImageMetaData::getMinPix(), ossimImageMetaData::getNullPix(), ossimImageMetaData::getScalarType(), ossimImageData::initialize(), ossimImageDataFactory::instance(), m_outputBandList, m_rasterInfo, m_tile, ossimGeneralRasterInfo::numberOfBands(), ossimImageData::setMaxPix(), ossimImageData::setMinPix(), ossimImageData::setNullPix(), and ossimRefPtr< T >::valid().
Definition at line 1003 of file ossimGeneralRasterTileSource.cpp.
References ossimImageHandler::close(), m_buffer, m_bufferSizeInPixels, m_fileStrList, m_lineBuffer, and m_tile.
protectedvirtual |
protectedvirtual |
protectedvirtual |
protectedvirtual |
protectedvirtual |
protectedvirtual |
Definition at line 1071 of file ossimGeneralRasterTileSource.cpp.
References ossimKeywordlist::add(), ossimKeywordlist::addFile(), ossim::byteOrder(), ossimString::c_str(), ossimKeywordlist::change_delimiter(), ossimKeywordlist::downcaseKeywords(), ossimKeywordlist::find(), ossimKeywordNames::INTERLEAVE_TYPE_KW, ossimKeywordNames::NULL_VALUE_KW, ossimKeywordNames::NUMBER_BANDS_KW, ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, ossimKeywordNames::SCALAR_TYPE_KW, size, ossimImageHandler::theImageFile, ossimString::toFloat32(), ossimString::toInt(), ossimString::toString(), and ossimString::toUInt32().
The geometry contains full-to-local image transform as well as projection (image-to-world).
Reimplemented in ossimLandsatTileSource, ossimEnviTileSource, ossimERSTileSource, ossimSrtmTileSource, and ossimDoqqTileSource.
Definition at line 1336 of file ossimGeneralRasterTileSource.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::DATUM_KW, ossimKeywordNames::DECIMAL_DEGREES_PER_PIXEL_LAT, ossimKeywordNames::DECIMAL_DEGREES_PER_PIXEL_LON, ossimKeywordlist::downcaseKeywords(), ossimFilename::exists(), ossimFilename::ext(), ossimImageGeometryRegistry::extendGeometry(), ossimKeywordlist::find(), ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), ossimFgdcXmlDoc::getGridCoordSysProjection(), ossimFgdcXmlDoc::getProjection(), ossimImageGeometry::getProjection(), ossimImageHandler::initImageParameters(), ossimImageGeometryRegistry::instance(), ossimMapProjectionFactory::instance(), ossimDatumFactory::instance(), ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, ossimFgdcXmlDoc::open(), ossimKeywordNames::ORIGIN_LATITUDE_KW, ossimFilename::setExtension(), ossimImageGeometry::setProjection(), ossimImageHandler::theGeometry, ossimImageHandler::theImageFile, ossimKeywordNames::TIE_POINT_LAT_KW, ossimKeywordNames::TIE_POINT_LON_KW, ossimString::toFloat32(), ossimString::toUInt32(), ossimKeywordNames::TYPE_KW, and ossimRefPtr< T >::valid().
Note: this is not the same as the ossimImageSource::getTileWidth which returns the output tile width which can be different than the internal image tile width on disk. Note: This handler will always return 0 for this method.
Implements ossimImageHandler.
Definition at line 1037 of file ossimGeneralRasterTileSource.cpp.
Definition at line 1032 of file ossimGeneralRasterTileSource.cpp.
Reimplemented in ossimEnviTileSource, ossimLandsatTileSource, ossimERSTileSource, ossimSrtmTileSource, and ossimDoqqTileSource.
Definition at line 1047 of file ossimGeneralRasterTileSource.cpp.
Reimplemented in ossimLandsatTileSource.
Retuns the min pixel value.
If there was an external eta data file then use the meta data from that file. If not given then we will return the default min
Currently returns the same value for all bands.
Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 1052 of file ossimGeneralRasterTileSource.cpp.
References ossimGeneralRasterInfo::getImageMetaData(), ossimImageMetaData::getNumberOfBands(), and m_rasterInfo.
Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 1057 of file ossimGeneralRasterTileSource.cpp.
References ossimGeneralRasterInfo::getImageMetaData(), ossimImageMetaData::getNumberOfBands(), isBandSelector(), m_outputBandList, and m_rasterInfo.
Definition at line 1541 of file ossimGeneralRasterTileSource.cpp.
References m_outputBandList.
Reimplemented in ossimERSTileSource, ossimLandsatTileSource, ossimEnviTileSource, ossimSrtmTileSource, and ossimDoqqTileSource.
Definition at line 1042 of file ossimGeneralRasterTileSource.cpp.
Satisfies pure virtual from TileSource class.
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands() |
protectedvirtual |
Definition at line 1247 of file ossimGeneralRasterTileSource.cpp.
References ossimKeywordlist::add(), ossimString::contains(), ossimFilename::fileSize(), ossimFgdcXmlDoc::getImageSize(), ossimFgdcXmlDoc::getNumberOfBands(), ossimFgdcXmlDoc::getPath(), ossimKeywordNames::INTERLEAVE_TYPE_KW, ossimKeywordNames::NUMBER_BANDS_KW, ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, ossimFgdcXmlDoc::open(), ossimKeywordNames::SCALAR_TYPE_KW, size, and ossimImageHandler::theImageFile.
protected |
Indicates whether or not the image handler can control output band selection via the setOutputBandList method.
Overrides: ossimImageHandler::isBandSelector
Definition at line 1505 of file ossimGeneralRasterTileSource.cpp.
References ossimGeneralRasterInfo::interleaveType(), ossimImageHandler::isBandSelector(), m_rasterInfo, OSSIM_BIL, OSSIM_BIP, OSSIM_BSQ_MULTI_FILE, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by getNumberOfOutputBands(), and setOutputBandList().
Definition at line 990 of file ossimGeneralRasterTileSource.cpp.
References m_fileStrList.
Determines if the passed in reslution level is valid.
If this reader is used as an overview the caller should pass in a resLevel relative to the full image.
| resLevel | zero base resolution level. |
Reimplemented in ossimEnviTileSource, ossimLandsatTileSource, ossimSrtmTileSource, ossimERSTileSource, and ossimDoqqTileSource.
Referenced by ossimERSTileSource::loadState().
Pure virtual open.
Derived classes must implement.
Reimplemented in ossimEnviTileSource, ossimLandsatTileSource, and ossimSrtmTileSource.
Referenced by ossimDoqqTileSource::loadState(), ossimERSTileSource::loadState(), ossimDoqqTileSource::open(), and ossimERSTileSource::open().
Reimplemented in ossimDoqqTileSource.
Reimplemented in ossimEnviTileSource, and ossimSrtmTileSource.
If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled.
Overrides: ossimImageHandler::setOutputBandList
Definition at line 1522 of file ossimGeneralRasterTileSource.cpp.
References ossimImageData::getNumberOfBands(), isBandSelector(), m_outputBandList, m_tile, ossimImageHandler::setOutputBandList(), and ossimRefPtr< T >::valid().
protected |
Definition at line 189 of file ossimGeneralRasterTileSource.h.
Referenced by allocateBuffer(), and close().
protected |
Definition at line 191 of file ossimGeneralRasterTileSource.h.
Referenced by if().
protected |
Definition at line 195 of file ossimGeneralRasterTileSource.h.
Referenced by allocateBuffer().
protected |
Definition at line 197 of file ossimGeneralRasterTileSource.h.
protected |
Definition at line 192 of file ossimGeneralRasterTileSource.h.
protected |
Definition at line 190 of file ossimGeneralRasterTileSource.h.
protected |
Definition at line 198 of file ossimGeneralRasterTileSource.h.
Referenced by allocateTile(), getNumberOfOutputBands(), getOutputBandList(), if(), and setOutputBandList().
protected |
Definition at line 194 of file ossimGeneralRasterTileSource.h.
Referenced by allocateBuffer(), allocateTile(), getNumberOfInputBands(), getNumberOfOutputBands(), and isBandSelector().
protected |
Definition at line 196 of file ossimGeneralRasterTileSource.h.
Referenced by if().
protected |
Definition at line 188 of file ossimGeneralRasterTileSource.h.
Referenced by allocateTile(), close(), and setOutputBandList().
