#include <ossimDtedTileSource.h>
Public Types | |
| enum | { DATA_RECORD_OFFSET_TO_POST = 8, DATA_RECORD_CHECKSUM_SIZE = 4, POST_SIZE = 2, NULL_PIXEL = -32767 } |
| ossimDtedTileSource () | |
| virtual bool | open () |
| Returns true if "theImageFile" can be opened and is a valid adrg file. More... | |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tile_rect, ossim_uint32 resLevel=0) |
| Returns the number of bands in the image. More... | |
| Returns the number of lines in the image. More... | |
| Returns the number of samples in the image. More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
| Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. More... | |
| Returns the output pixel type of the tile source. More... | |
| Returns the width of the output tile. More... | |
| Returns the height of the output tile. More... | |
| void | getPostSpacing (ossimDpt &postSpacing) const |
| Initializes spacing to the post spacing of the cell. More... | |
| Gets a property for name. More... | |
| Adds this class's properties to list. More... | |
| Sets the min/max. More... | |
| ossimImageHandler () | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual | ~ossimDtedTileSource () |
| const ossimDtedTileSource & | operator= (const ossimDtedTileSource &rhs) |
| ossimDtedTileSource (const ossimDtedTileSource &) | |
| void | allocate () |
| Allocated the tiles. More... | |
| bool | fillBuffer (const ossimIrect &tile_rect, const ossimIrect &clip_rect, ossimImageData *tile) |
| Returns true on success, false on error. More... | |
| void | gatherStatistics (bool writeStatsFile) |
| Scans for min and max. More... | |
| ossim_sint16 | convertSignedMagnitude (ossim_uint16 &s) const |
Definition at line 34 of file ossimDtedTileSource.h.
| anonymous enum |
| Enumerator | |
| DATA_RECORD_OFFSET_TO_POST | |
| DATA_RECORD_CHECKSUM_SIZE | |
| POST_SIZE | |
| NULL_PIXEL | |
Definition at line 40 of file ossimDtedTileSource.h.
| ossimDtedTileSource::ossimDtedTileSource | ( | ) |
Definition at line 40 of file ossimDtedTileSource.cpp.
References ossim::byteOrder(), ossim::defaultTileSize(), OSSIM_LITTLE_ENDIAN, theSwapBytesFlag, theTileHeight, and theTileWidth.
protectedvirtual |
Definition at line 71 of file ossimDtedTileSource.cpp.
References close().
protected |
Definition at line 686 of file ossimDtedTileSource.cpp.
protected |
Definition at line 356 of file ossimDtedTileSource.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), theTile, and ossimRefPtr< T >::valid().
Referenced by getTile().
Definition at line 242 of file ossimDtedTileSource.cpp.
References m_fileStr.
Referenced by ~ossimDtedTileSource().
inlineprotected |
Definition at line 246 of file ossimDtedTileSource.h.
References theSwapBytesFlag.
Referenced by fillBuffer().
protected |
Definition at line 167 of file ossimDtedTileSource.cpp.
References convertSignedMagnitude(), DATA_RECORD_OFFSET_TO_POST, ossimImageData::getBuf(), ossimImageData::getWidth(), ossimIrect::lr(), m_fileStr, POST_SIZE, theDataRecordSize, theNumberOfLines, theOffsetToFirstDataRecord, ossimIrect::ul(), ossimImageData::validate(), ossimIpt::x, and ossimIpt::y.
protected |
| writeStatsFile | If true and statistics file does not exists it will write one; else, no file will be written. |
Definition at line 536 of file ossimDtedTileSource.cpp.
Referenced by loadMetaData().
Returns the image geometry object associated with this tile source or NULL if not defined.
The geometry contains full-to-local image transform as well as projection (image-to-world)
Definition at line 402 of file ossimDtedTileSource.cpp.
References ossimDatum::ellipsoid(), ossimRefPtr< T >::get(), ossimImageHandler::initImageParameters(), ossimDatumFactory::instance(), ossimDtedUhl::latInterval(), ossimDtedUhl::latOrigin(), ossimDtedUhl::lonInterval(), ossimDtedUhl::lonOrigin(), m_uhl, ossimDtedUhl::numLatPoints(), ossimMapProjection::setDecimalDegreesPerPixel(), ossimEquDistCylProjection::setOrigin(), ossimImageGeometry::setProjection(), ossimMapProjection::setUlTiePoints(), ossimImageHandler::theGeometry, ossimRefPtr< T >::valid(), and ossimDatumFactory::wgs84().
Note that rrds 0 is the highest resolution rrds.
Definition at line 229 of file ossimDtedTileSource.cpp.
References getNumberOfLines(), and getNumberOfSamples().
Implements ossimImageHandler.
Definition at line 604 of file ossimDtedTileSource.cpp.
Definition at line 599 of file ossimDtedTileSource.cpp.
Definition at line 81 of file ossimDtedTileSource.cpp.
Definition at line 631 of file ossimDtedTileSource.cpp.
References ossimImageMetaData::getMaxPix(), ossimImageMetaData::getNumberOfBands(), theMaxHeight, and ossimImageHandler::theMetaData.
Retuns the min pixel value.
If there was an external eta data file then use the meta data from that file. If not given then we will return the default min
Definition at line 622 of file ossimDtedTileSource.cpp.
References ossimImageMetaData::getMinPix(), ossimImageMetaData::getNumberOfBands(), ossimImageHandler::theMetaData, and theMinHeight.
Definition at line 614 of file ossimDtedTileSource.cpp.
References ossimImageMetaData::getNullPix(), ossimImageMetaData::getNumberOfBands(), and ossimImageHandler::theMetaData.
Satisfies pure virtual requirement from ImageHandler class.
Implements ossimImageSource.
Definition at line 609 of file ossimDtedTileSource.cpp.
Referenced by getNumberOfOutputBands().
Definition at line 469 of file ossimDtedTileSource.cpp.
References ossimImageHandler::getNumberOfLines(), theNumberOfLines, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by getImageRectangle().
Definition at line 223 of file ossimDtedTileSource.cpp.
References getNumberOfInputBands().
Definition at line 483 of file ossimDtedTileSource.cpp.
References ossimImageHandler::getNumberOfSamples(), theNumberOfSamps, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Definition at line 454 of file ossimDtedTileSource.cpp.
References OSSIM_SSHORT16.
| void ossimDtedTileSource::getPostSpacing | ( | ossimDpt & | postSpacing | ) | const |
| postSpacing | ossimDpt to initialize with spacing where postspacing.x = longitude interval and postspacing.y = latitude interval. |
Definition at line 640 of file ossimDtedTileSource.cpp.
References thePostSpacing, ossimDpt::x, and ossimDpt::y.
| name | Property name to get. |
Definition at line 646 of file ossimDtedTileSource.cpp.
References ossimImageHandler::getProperty(), m_dtedInfo, and ossimRefPtr< T >::valid().
| propertyNames | list to append to. |
Definition at line 665 of file ossimDtedTileSource.cpp.
References ossimImageHandler::getPropertyNames(), and m_dtedInfo.
Definition at line 76 of file ossimDtedTileSource.cpp.
Definition at line 86 of file ossimDtedTileSource.cpp.
References allocate(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), theTile, and ossimRefPtr< T >::valid().
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands() |
Definition at line 112 of file ossimDtedTileSource.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), fillBuffer(), getImageRectangle(), ossimImageData::getImageRectangle(), ossimImageData::getNumberOfBands(), getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), ossimImageData::makeBlank(), ossimReferenced::ref(), status, and ossimReferenced::unref().
Definition at line 464 of file ossimDtedTileSource.cpp.
References theTileHeight.
Definition at line 459 of file ossimDtedTileSource.cpp.
References theTileWidth.
Definition at line 237 of file ossimDtedTileSource.cpp.
Sets the min/max.
looks for an omd or statistics file for min/max. If not found calls gatherStatistics method. Overrides ossimImageHandler::loadMetaData called by completeOpen.
Definition at line 497 of file ossimDtedTileSource.cpp.
References ossimKeywordlist::addFile(), ossimFilename::exists(), ossimFilename::fileNoExtension(), ossimKeywordlist::find(), gatherStatistics(), ossimKeywordNames::MAX_VALUE_KW, ossimKeywordNames::MIN_VALUE_KW, ossimFilename::setExtension(), ossimImageHandler::theImageFile, theMaxHeight, and theMinHeight.
Definition at line 384 of file ossimDtedTileSource.cpp.
References ossimImageHandler::loadState(), ossimImageHandler::open(), and ossimImageHandler::theImageFile.
Definition at line 247 of file ossimDtedTileSource.cpp.
protected |
Definition at line 681 of file ossimDtedTileSource.cpp.
Definition at line 377 of file ossimDtedTileSource.cpp.
References ossimImageHandler::saveState().
protected |
Definition at line 236 of file ossimDtedTileSource.h.
protected |
Definition at line 235 of file ossimDtedTileSource.h.
mutableprotected |
Definition at line 220 of file ossimDtedTileSource.h.
Referenced by getProperty(), and getPropertyNames().
mutableprotected |
Definition at line 219 of file ossimDtedTileSource.h.
Referenced by close(), fillBuffer(), and isOpen().
protected |
Definition at line 233 of file ossimDtedTileSource.h.
protected |
Definition at line 234 of file ossimDtedTileSource.h.
Referenced by getImageGeometry().
protected |
Definition at line 232 of file ossimDtedTileSource.h.
protected |
Definition at line 227 of file ossimDtedTileSource.h.
protected |
Definition at line 229 of file ossimDtedTileSource.h.
Referenced by getMaxPixelValue(), and loadMetaData().
protected |
Definition at line 228 of file ossimDtedTileSource.h.
Referenced by getMinPixelValue(), and loadMetaData().
protected |
Definition at line 224 of file ossimDtedTileSource.h.
Referenced by fillBuffer(), and getNumberOfLines().
protected |
Definition at line 225 of file ossimDtedTileSource.h.
Referenced by getNumberOfSamples().
protected |
Definition at line 226 of file ossimDtedTileSource.h.
protected |
Definition at line 230 of file ossimDtedTileSource.h.
Referenced by getPostSpacing().
protected |
DTED data is always stored as BIG_ENDIAN.
This flag indicates that byte swapping is needed (LITTLE_ENDIAN machine).
Definition at line 241 of file ossimDtedTileSource.h.
Referenced by convertSignedMagnitude(), and ossimDtedTileSource().
protected |
Definition at line 218 of file ossimDtedTileSource.h.
Referenced by allocate(), and getTile().
protected |
Definition at line 223 of file ossimDtedTileSource.h.
Referenced by getTileHeight(), and ossimDtedTileSource().
protected |
Definition at line 222 of file ossimDtedTileSource.h.
Referenced by getTileWidth(), and ossimDtedTileSource().
