#include <ossimImageMpiMWriterSequenceConnection.h>
| ossimImageMpiMWriterSequenceConnection (ossimObject *owner=NULL) | |
| ossimImageMpiMWriterSequenceConnection (ossimImageSource *inputSource, ossimObject *owner=NULL) | |
| virtual | ~ossimImageMpiMWriterSequenceConnection () |
| virtual void | setToStartOfSequence () |
| virtual bool | isMaster () const |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 resLevel=0) |
Public Member Functions inherited from ossimImageSourceSequencer | |
| ossimImageSourceSequencer (ossimImageSource *inputSource=NULL, ossimObject *owner=NULL) | |
| virtual | ~ossimImageSourceSequencer () |
| ossim_int64 | getNumberOfTiles () const |
| ossim_int64 | getNumberOfTilesHorizontal () const |
| ossim_int64 | getNumberOfTilesVertical () const |
| virtual void | setAreaOfInterest (const ossimIrect &areaOfInterest) |
| const ossimIrect & | getAreaOfInterest () const |
| virtual bool | getNextTileStream (std::ostream &bos) |
| virtual bool | getTileOrigin (ossim_int64 id, ossimIpt &origin) const |
| bool | getTileRect (ossim_int64 tile_id, ossimIrect &rect) const |
| Establishes a tile rect given tile ID. More... | |
| virtual ossimRefPtr< ossimImageData > | getTile (ossim_int64 id, ossim_uint32 resLevel=0) |
| virtual void | slaveProcessTiles () |
| virtual ossimIpt | getTileSize () const |
| virtual void | setTileSize (const ossimIpt &tileSize) |
| virtual void | setTileSize (ossim_int32 width, ossim_int32 height) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| void | setCreateHistogram (bool create_histogram) |
| bool | loadState (const ossimKeywordlist &kwl, const char *prefix) |
| void | getBinInformation (ossim_uint32 &numberOfBins, ossim_float64 &minValue, ossim_float64 &maxValue, ossimScalarType stype) const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| virtual void | propertyEvent (ossimPropertyEvent &) |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Definition at line 25 of file ossimImageMpiMWriterSequenceConnection.h.
| ossimImageMpiMWriterSequenceConnection::ossimImageMpiMWriterSequenceConnection | ( | ossimObject * | owner = NULL | ) |
Definition at line 67 of file ossimImageMpiMWriterSequenceConnection.cpp.
References ossimImageSourceSequencer::theCurrentTileNumber, theNeedToSendRequest, theNumberOfProcessors, and theRank.
| ossimImageMpiMWriterSequenceConnection::ossimImageMpiMWriterSequenceConnection | ( | ossimImageSource * | inputSource, |
Definition at line 40 of file ossimImageMpiMWriterSequenceConnection.cpp.
Definition at line 92 of file ossimImageMpiMWriterSequenceConnection.cpp.
Will allow you to get the next tile in the sequence.
Reimplemented from ossimImageSourceSequencer.
Definition at line 130 of file ossimImageMpiMWriterSequenceConnection.cpp.
References ossimImageData::getBuf(), ossimImageSourceSequencer::getNextTile(), ossimImageSourceSequencer::getNumberOfTiles(), ossimRectilinearDataObject::getScalarType(), ossimImageData::getSize(), ossimImageData::getSizeInBytes(), ossimEndian::getSystemEndianType(), ossimImageSourceSequencer::getTileOrigin(), initialize(), OSSIM_BIG_ENDIAN, OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SINT16, OSSIM_SINT32, OSSIM_SINT8, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, ossimImageData::setOrigin(), ossimEndian::swap(), ossimImageSourceSequencer::theCurrentTileNumber, theNumberOfProcessors, theOutputTile, and ossimImageData::validate().
This is a virtual method that can be overriden by derived classes (MPI, or PVM or other parallel connections. This method is to indicate whether or not this connection is the master/ controlling connection.
Definition at line 96 of file ossimImageMpiMWriterSequenceConnection.cpp.
References ossimImageDataFactory::create(), ossimImageSourceSequencer::initialize(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimImageSourceSequencer::theCurrentTileNumber, ossimImageSourceSequencer::theInputConnection, theOutputTile, and theRank.
Referenced by getNextTile().
inlinevirtual |
Definition at line 43 of file ossimImageMpiMWriterSequenceConnection.h.
Will set the internal pointers to the upperleft tile number. To go to the next tile in the sequence just call getNextTile.
Definition at line 110 of file ossimImageMpiMWriterSequenceConnection.cpp.
References ossimImageSourceSequencer::setToStartOfSequence(), ossimImageSourceSequencer::theCurrentTileNumber, and theRank.
protected |
Definition at line 54 of file ossimImageMpiMWriterSequenceConnection.h.
Referenced by ossimImageMpiMWriterSequenceConnection().
protected |
Definition at line 52 of file ossimImageMpiMWriterSequenceConnection.h.
Referenced by getNextTile(), and ossimImageMpiMWriterSequenceConnection().
protected |
Definition at line 55 of file ossimImageMpiMWriterSequenceConnection.h.
Referenced by getNextTile(), and initialize().
protected |
Definition at line 53 of file ossimImageMpiMWriterSequenceConnection.h.
Referenced by initialize(), ossimImageMpiMWriterSequenceConnection(), and setToStartOfSequence().
