#include <ossimOgrGdalTileSource.h>
| ossimOgrGdalTileSource () | |
| virtual | ~ossimOgrGdalTileSource () |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual bool | open () |
| virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
| virtual ossimObject * | getView () |
| virtual const ossimObject * | getView () const |
| virtual bool | setView (ossimObject *baseObject) |
| Sets the output view. More... | |
| virtual std::multimap< long, ossimAnnotationObject * > | getFeatureTable () |
| Pure virtual getFeatureTable method. More... | |
| virtual void | setQuery (const ossimString &query) |
| Pure virtual setQuery method. More... | |
| virtual void | setGeometryBuffer (ossim_float64 distance, ossimUnitType type) |
| Pure virtual setGeometryBuffer method. More... | |
| ossimImageHandler () | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimViewInterface | |
| ossimViewInterface () | |
| ossimViewInterface (ossimObject *base) | |
| virtual | ~ossimViewInterface () |
| virtual void | refreshView () |
| ossimObject * | getBaseObject () |
Private Attributes | |
| ossimRefPtr< ossimGdalOgrVectorAnnotation > | theAnnotationSource |
Protected Attributes inherited from ossimImageHandler | |
| ossimFilename | theImageFile |
| ossimFilename | theOverviewFile |
| ossimFilename | theSupplementaryDirectory |
| ossimRefPtr< ossimImageHandler > | theOverview |
| vector< ossimIpt > | theValidImageVertices |
| ossimImageMetaData | theMetaData |
| ossimRefPtr< ossimImageGeometry > | theGeometry |
| ossimRefPtr< ossimNBandLutDataObject > | theLut |
| std::vector< ossimDpt > | theDecimationFactors |
| ossimString | theImageID |
| ossim_uint32 | theStartingResLevel |
| theStartingResLevel If set to something other than zero(default) this is indicative that the reader is an overview. More... | |
| bool | theOpenOverviewFlag |
| If true opening of overviews will be attempted. More... | |
| ossimPixelType | thePixelType |
| std::shared_ptr< ossim::ImageHandlerState > | m_state |
Protected Attributes inherited from ossimSource | |
| bool | theEnableFlag |
| bool | theInitializedFlag |
Protected Attributes inherited from ossimConnectableObject | |
| ossimId | theId |
| ossimString | theDescription |
| ossimObject * | theOwner |
| bool | theInputListIsFixedFlag |
| Indicates whether the theInputObjectList is fixed. More... | |
| bool | theOutputListIsFixedFlag |
| Indicates whether the theOutputObjectList is fixed. More... | |
| ConnectableObjectList | theInputObjectList |
| Holds a list of input objects. More... | |
| ConnectableObjectList | theOutputObjectList |
| Holds a list of output objects. More... | |
Protected Attributes inherited from ossimListenerManager | |
| std::list< ossimListener * > | theListenerList |
| bool | theEnabledFlag |
| std::list< ossimListener * > | theDelayedAdd |
| std::list< ossimListener * > | theDelayedRemove |
| bool | theFireEventFlag |
Protected Attributes inherited from ossimViewInterface | |
| ossimObject * | theObject |
Definition at line 40 of file ossimOgrGdalTileSource.h.
| ossimOgrGdalTileSource::ossimOgrGdalTileSource | ( | ) |
Definition at line 25 of file ossimOgrGdalTileSource.cpp.
References OSSIM_PIXEL_IS_AREA, theAnnotationSource, ossimViewInterface::theObject, and ossimImageHandler::thePixelType.
Definition at line 39 of file ossimOgrGdalTileSource.cpp.
References close(), and ossimViewInterface::theObject.
Definition at line 106 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::close(), and theAnnotationSource.
Referenced by ~ossimOgrGdalTileSource().
Implements ossimEsriShapeFileInterface.
Definition at line 237 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::getFeatureTable(), theAnnotationSource, and ossimRefPtr< T >::valid().
Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. Note that rrds 0 is the highest resolution rrds.
Definition at line 156 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::getBoundingRect(), and theAnnotationSource.
Returns the tile width of the image or 0 if the image is not tiled. Note: this is not the same as the ossimImageSource::getTileWidth which returns the output tile width which can be different than the internal image tile width on disk.
Implements ossimImageHandler.
Definition at line 94 of file ossimOgrGdalTileSource.cpp.
Definition at line 89 of file ossimOgrGdalTileSource.cpp.
The geometry contains full-to-local image transform as well as projection (image-to-world)
Definition at line 99 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::getImageGeometry(), theAnnotationSource, and ossimImageHandler::theGeometry.
Definition at line 191 of file ossimOgrGdalTileSource.cpp.
References ossimImageSource::getMaxPixelValue(), and theAnnotationSource.
Retuns the min pixel value.
If there was an external eta data file then use the meta data from that file. If not given then we will return the default min
Definition at line 186 of file ossimOgrGdalTileSource.cpp.
References ossimImageSource::getMinPixelValue(), and theAnnotationSource.
Definition at line 181 of file ossimOgrGdalTileSource.cpp.
References ossimImageSource::getNullPixelValue(), and theAnnotationSource.
Returns the number of reduced resolution data sets (rrds).
Note: Shape files should never have reduced res sets so this method is returns "8" to avoid the question of "Do you want to build res sets".
Definition at line 151 of file ossimOgrGdalTileSource.cpp.
Returns the number of bands in the image. Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 117 of file ossimOgrGdalTileSource.cpp.
References ossimAnnotationSource::getNumberOfOutputBands(), and theAnnotationSource.
Definition at line 127 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::getBoundingRect(), ossimIrect::hasNans(), ossimIrect::height(), theAnnotationSource, ossimIrect::ul(), and ossimIpt::x.
Returns the number of bands in a tile returned from this TileSource. Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 122 of file ossimOgrGdalTileSource.cpp.
Returns the number of bands available from an image. Satisfies pure virtual from ImageHandler class.
Definition at line 139 of file ossimOgrGdalTileSource.cpp.
Definition at line 161 of file ossimOgrGdalTileSource.cpp.
References ossimAnnotationSource::getOutputScalarType(), and theAnnotationSource.
Definition at line 219 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::getProperty(), theAnnotationSource, and ossimRefPtr< T >::valid().
Definition at line 229 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::getPropertyNames(), theAnnotationSource, and ossimRefPtr< T >::valid().
Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. Satisfies pure virtual from TileSource class.
Definition at line 111 of file ossimOgrGdalTileSource.cpp.
References ossimAnnotationSource::getTile(), and theAnnotationSource.
Returns the height of the output tile.
Definition at line 171 of file ossimOgrGdalTileSource.cpp.
References ossimImageSource::getTileHeight(), and theAnnotationSource.
Returns the width of the output tile.
Definition at line 166 of file ossimOgrGdalTileSource.cpp.
References ossimImageSource::getTileWidth(), and theAnnotationSource.
Implements ossimViewInterface.
Definition at line 196 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::getView(), and theAnnotationSource.
Definition at line 201 of file ossimOgrGdalTileSource.cpp.
Definition at line 176 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::isOpen(), and theAnnotationSource.
Definition at line 70 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::loadState(), ossimImageHandler::loadState(), open(), OSSIM_PIXEL_IS_AREA, theAnnotationSource, ossimImageHandler::thePixelType, and ossimRefPtr< T >::valid().
Definition at line 49 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::open(), theAnnotationSource, and ossimImageHandler::theImageFile.
Referenced by loadState().
Definition at line 57 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::saveState(), ossimImageHandler::saveState(), theAnnotationSource, and ossimRefPtr< T >::valid().
| entryIdx | Entry number to select. |
Definition at line 262 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::setCurrentEntry(), theAnnotationSource, and ossimRefPtr< T >::valid().
Definition at line 254 of file ossimOgrGdalTileSource.cpp.
References distance(), ossimGdalOgrVectorAnnotation::setGeometryBuffer(), theAnnotationSource, and ossimRefPtr< T >::valid().
Definition at line 211 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::setProperty(), theAnnotationSource, and ossimRefPtr< T >::valid().
Definition at line 246 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::setQuery(), theAnnotationSource, and ossimRefPtr< T >::valid().
This will transform the shape file points to the view passed in.
| baseObject | This can be a ossimProjection or an ossimImageProjectionModel. If ossimImageProjectionModel this will transform world points to line sample; then, convert any line sample to the correct target rrds point. The target rrds is set via ossimImageModel::setTargetRrds. |
| ownsItFlag | If true the memory will be handled for baseObject by the underlying code. |
Definition at line 206 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::setView(), and theAnnotationSource.
private |
Definition at line 202 of file ossimOgrGdalTileSource.h.
Referenced by close(), getFeatureTable(), getImageRectangle(), getInternalImageGeometry(), getMaxPixelValue(), getMinPixelValue(), getNullPixelValue(), getNumberOfInputBands(), getNumberOfLines(), getNumberOfOutputBands(), getNumberOfSamples(), getOutputScalarType(), getProperty(), getPropertyNames(), getTile(), getTileHeight(), getTileWidth(), getView(), isOpen(), loadState(), open(), ossimOgrGdalTileSource(), saveState(), setCurrentEntry(), setGeometryBuffer(), setProperty(), setQuery(), and setView().
