Base class for tile sources performing auto tie point extraction. More...
#include <AtpTileSource.h>
Classes | |
| struct | ParallaxInfo |
| Convenience struct for use between filterWithParallax( and computeParallaxStatistics() More... | |
| AtpTileSource (AtpGenerator *generator) | |
| virtual | ~AtpTileSource () |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &origin, ossim_uint32 rLevel=0)=0 |
| Derived classes implement their particular tiepoint matching algorithms for the requested tile. More... | |
| AtpList & | getTiePoints () |
| This list resets with every getTile() call , so make sure tiepoints from previous getTile() calls are being accumulated. More... | |
| void | filterPoints () |
| void | setTiePoints (ossim::TiePointList &atpList) |
| Used for testing. More... | |
Public Member Functions inherited from ossimImageCombiner | |
| ossimImageCombiner () | |
| ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag) | |
| ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| virtual void | updateRects () |
| This will go through and precompute the bounding rects of each input image. More... | |
| Returns the number of bands available from the input. More... | |
| virtual ossim_uint32 | getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to retrieve the number of overlapping images withint the given rect. More... | |
| virtual void | getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to populate the result with the index of the overlapping images. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | hasDifferentInputs () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| AtpTileSource () | |
| AtpTileSource (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual void | allocate () |
| void | filterWithParallax () |
| void | computeParallax () |
| void | computeParallaxStatistics () |
| void | filterWithoutParallax () |
| void | pruneList () |
| Caps the max number of TPs given the list, which is the list of filtered TPs for the tile. More... | |
| void | initializeStaticMembers () |
Protected Member Functions inherited from ossimImageCombiner | |
| virtual | ~ossimImageCombiner () |
| void | precomputeBounds () const |
Static Protected Attributes | |
| static double | s_minVectorResDiff = 0 |
| static double | s_maxDiffRatio = 1.0 |
| static double | s_cosMaxAngleDiff = 0 |
| static double | s_maxPaxDev = 1.0 |
| static double | s_maxPaxPix = 2.0 |
| static unsigned int | s_minNumConsistent = 3 |
| static unsigned int | s_percentConsistent = 50 |
| static unsigned int | s_numTpsPerTile = 2 |
| static bool | s_useRasterMode = false |
| static bool | s_initialized = false |
| static unsigned int | s_numFilterIterations = 0 |
Implemented as a combiner that establishes the overlap between input sources, and computes tie-points in the getTile() call.
Definition at line 26 of file AtpTileSource.h.
| ATP::AtpTileSource::AtpTileSource | ( | AtpGenerator * | generator | ) |
Definition at line 44 of file AtpTileSource.cpp.
References ossimListenerManager::addListener(), ossimConnectableObject::connectMyInputTo(), initialize(), m_generator, and ossimImageCombiner::theComputeFullResBoundsFlag.
inlinevirtual |
Definition at line 31 of file AtpTileSource.h.
protected |
Definition at line 32 of file AtpTileSource.cpp.
protected |
Definition at line 37 of file AtpTileSource.cpp.
protectedvirtual |
Definition at line 70 of file AtpTileSource.cpp.
References ossimImageDataFactory::create(), ossimConnectableObject::getNumberOfInputs(), ossimImageData::initialize(), ossimImageDataFactory::instance(), m_tile, and ossimConnectableObject::theInputObjectList.
Referenced by ATP::ossimCorrelationSource::getTile(), and ATP::ossimDescriptorSource::getTile().
protected |
Definition at line 261 of file AtpTileSource.cpp.
References ATP::AtpTileSource::ParallaxInfo::denom, ATP::AtpTileSource::ParallaxInfo::dx_dH, ATP::AtpTileSource::ParallaxInfo::dy_dH, ossimIrect::getCenter(), ossimDataObject::getDataObjectStatus(), ossimElevManager::getHeightAboveEllipsoid(), ossimImageData::getImageRectangle(), ossimGpt::hgt, ossimElevManager::instance(), ossimGpt::isHgtNan(), ossimImageGeometry::localToWorld(), m_generator, m_paxInfo, m_tiePoints, m_tile, ossim::nan(), OSSIM_STATUS_UNKNOWN, ATP::AtpTileSource::ParallaxInfo::parallaxSlope, ossimImageGeometry::worldToLocal(), ossimDpt::x, and ossimDpt::y.
Referenced by filterPoints().
protected |
Definition at line 313 of file AtpTileSource.cpp.
References ATP::AtpTileSource::ParallaxInfo::denom, distance(), ATP::AtpTileSource::ParallaxInfo::distanceMap, ATP::AtpTileSource::ParallaxInfo::dx_dH, ATP::AtpTileSource::ParallaxInfo::dy_dH, m_paxInfo, m_tiePoints, ATP::AtpTileSource::ParallaxInfo::maxDistance, ATP::AtpTileSource::ParallaxInfo::parallaxOffset, ATP::AtpTileSource::ParallaxInfo::parallaxSlope, s_maxPaxDev, s_maxPaxPix, ossimDpt::x, and ossimDpt::y.
Referenced by filterWithParallax().
| void ATP::AtpTileSource::filterPoints | ( | ) |
Definition at line 84 of file AtpTileSource.cpp.
References ossim::JsonParam::asBool(), CINFO, computeParallax(), ossim::JsonConfig::diagnosticLevel(), ATP::AtpTileSource::ParallaxInfo::dx_dH, ATP::AtpTileSource::ParallaxInfo::dy_dH, filterWithoutParallax(), filterWithParallax(), ossim::JsonConfig::getParameter(), ATP::AtpConfig::instance(), m_considerParallax, m_generator, m_paxInfo, m_tiePoints, ossim::JsonConfig::paramExists(), pruneList(), s_minNumConsistent, s_numFilterIterations, and s_useRasterMode.
Referenced by ATP::ossimCorrelationSource::getTile(), ATP::ossimDescriptorSource::getTile(), and main().
protected |
Definition at line 360 of file AtpTileSource.cpp.
References CINFO, ossim::JsonConfig::diagnosticLevel(), ATP::AtpConfig::instance(), ossimDpt::length(), m_tiePoints, s_cosMaxAngleDiff, s_maxDiffRatio, s_minNumConsistent, s_minVectorResDiff, s_percentConsistent, ossimDpt::x, and ossimDpt::y.
protected |
Definition at line 165 of file AtpTileSource.cpp.
References CINFO, computeParallaxStatistics(), ATP::AtpTileSource::ParallaxInfo::denom, ossim::JsonConfig::diagnosticLevel(), distance(), ATP::AtpTileSource::ParallaxInfo::distanceMap, ATP::AtpTileSource::ParallaxInfo::dx_dH, ATP::AtpConfig::instance(), m_paxInfo, m_tiePoints, ATP::AtpTileSource::ParallaxInfo::maxDistance, ATP::AtpTileSource::ParallaxInfo::parallaxOffset, ATP::AtpTileSource::ParallaxInfo::parallaxSlope, s_maxPaxPix, s_numFilterIterations, ossimDpt::x, and ossimDpt::y.
inlinevirtual |
Definition at line 48 of file AtpTileSource.h.
inlinevirtual |
Reimplemented from ossimImageCombiner.
Definition at line 47 of file AtpTileSource.h.
References OSSIM_DOUBLE.
inline |
Definition at line 45 of file AtpTileSource.h.
pure virtual |
It is not clear what the output tile needs to be, since the product of this filter is the list of tiepoints (available through the getTiePoints() method). Recommend simply passing through the corresponding REF image tile.
Implemented in ATP::ossimCorrelationSource, and ATP::ossimDescriptorSource.
Reimplemented in ATP::ossimCorrelationSource, and ATP::ossimDescriptorSource.
Definition at line 58 of file AtpTileSource.cpp.
References ossimConnectableObject::getNumberOfInputs(), ossimImageCombiner::initialize(), initializeStaticMembers(), m_tiePoints, and s_initialized.
Referenced by AtpTileSource(), ATP::ossimDescriptorSource::initialize(), and ATP::ossimCorrelationSource::initialize().
protected |
Definition at line 473 of file AtpTileSource.cpp.
References ossim::JsonParam::asBool(), ossim::JsonParam::asFloat(), ossim::JsonParam::asUint(), ossim::cosd(), CWARN, ossim::JsonConfig::getParameter(), ATP::AtpConfig::instance(), ossim::isnan(), ossim::JsonConfig::paramExists(), s_cosMaxAngleDiff, s_initialized, s_maxDiffRatio, s_maxPaxDev, s_maxPaxPix, s_minNumConsistent, s_minVectorResDiff, s_numTpsPerTile, s_percentConsistent, and s_useRasterMode.
Referenced by initialize().
protected |
Definition at line 435 of file AtpTileSource.cpp.
References CWARN, ATP::AtpConfig::instance(), m_tiePoints, and s_numTpsPerTile.
| void ATP::AtpTileSource::setTiePoints | ( | ossim::TiePointList & | atpList | ) |
Used for testing.
Definition at line 549 of file AtpTileSource.cpp.
References m_generator, and m_tiePoints.
Referenced by main().
protected |
Definition at line 89 of file AtpTileSource.h.
protected |
Definition at line 85 of file AtpTileSource.h.
Referenced by AtpTileSource(), computeParallax(), ATP::ossimCorrelationSource::correlate(), filterPoints(), ATP::ossimDescriptorSource::getTile(), ATP::ossimCorrelationSource::getTile(), ATP::ossimDescriptorSource::initialize(), ATP::ossimCorrelationSource::initialize(), and setTiePoints().
protected |
Definition at line 88 of file AtpTileSource.h.
Referenced by computeParallax(), computeParallaxStatistics(), filterPoints(), and filterWithParallax().
protected |
Definition at line 86 of file AtpTileSource.h.
Referenced by computeParallax(), computeParallaxStatistics(), filterPoints(), filterWithoutParallax(), filterWithParallax(), ATP::ossimCorrelationSource::getTile(), ATP::ossimDescriptorSource::getTile(), initialize(), pruneList(), and setTiePoints().
protected |
Definition at line 87 of file AtpTileSource.h.
Referenced by allocate(), computeParallax(), ATP::ossimCorrelationSource::getTile(), and ATP::ossimDescriptorSource::getTile().
staticprotected |
Definition at line 94 of file AtpTileSource.h.
Referenced by filterWithoutParallax(), and initializeStaticMembers().
staticprotected |
Definition at line 101 of file AtpTileSource.h.
Referenced by initialize(), and initializeStaticMembers().
staticprotected |
Definition at line 93 of file AtpTileSource.h.
staticprotected |
Definition at line 95 of file AtpTileSource.h.
Referenced by computeParallaxStatistics(), and initializeStaticMembers().
staticprotected |
Definition at line 96 of file AtpTileSource.h.
Referenced by computeParallaxStatistics(), filterWithParallax(), and initializeStaticMembers().
staticprotected |
Definition at line 97 of file AtpTileSource.h.
Referenced by filterPoints(), filterWithoutParallax(), and initializeStaticMembers().
staticprotected |
Definition at line 92 of file AtpTileSource.h.
staticprotected |
Definition at line 102 of file AtpTileSource.h.
Referenced by filterPoints(), and filterWithParallax().
staticprotected |
Definition at line 99 of file AtpTileSource.h.
Referenced by initializeStaticMembers(), and pruneList().
staticprotected |
Definition at line 98 of file AtpTileSource.h.
staticprotected |
Definition at line 100 of file AtpTileSource.h.
Referenced by filterPoints(), and initializeStaticMembers().
