Performs a spatial blend accross overlapping regions. More...
#include <ossimFeatherMosaic.h>
Classes | |
| class | ossimFeatherInputInformation |
| This is only visible by this class and will remain here unless we want to move it later. More... | |
| ossimFeatherMosaic () | |
| ossimFeatherMosaic (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &origin, ossim_uint32 resLevel=0) |
Public Member Functions inherited from ossimImageMosaic | |
| ossimImageMosaic () | |
| ossimImageMosaic (ossimConnectableObject::ConnectableObjectList &inputSources) | |
Public Member Functions inherited from ossimImageCombiner | |
| ossimImageCombiner () | |
| ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag) | |
| ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual void | updateRects () |
| This will go through and precompute the bounding rects of each input image. More... | |
| Returns the number of bands available from the input. More... | |
| virtual ossim_uint32 | getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to retrieve the number of overlapping images withint the given rect. More... | |
| virtual void | getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to populate the result with the index of the overlapping images. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | hasDifferentInputs () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimFeatherMosaic () |
| template<class T > | |
| ossimRefPtr< ossimImageData > | combine (T dummyVariableNotUsed, const ossimIrect &tileRect, ossim_uint32 resLevel) |
| The dummy variable is used for the template type. More... | |
| virtual double | computeWeight (long index, const ossimDpt &point) const |
Protected Member Functions inherited from ossimImageMosaic | |
| virtual | ~ossimImageMosaic () |
| void | allocate () |
| Called on first getTile, will initialize all data needed. More... | |
| ossimRefPtr< ossimImageData > | combine (T, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| ossimRefPtr< ossimImageData > | combineNorm (T, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
Protected Member Functions inherited from ossimImageCombiner | |
| virtual | ~ossimImageCombiner () |
| void | precomputeBounds () const |
Friends | |
| ostream & | operator<< (ostream &out, const ossimFeatherInputInformation &data) |
Definition at line 24 of file ossimFeatherMosaic.h.
| ossimFeatherMosaic::ossimFeatherMosaic | ( | ) |
Definition at line 24 of file ossimFeatherMosaic.cpp.
| ossimFeatherMosaic::ossimFeatherMosaic | ( | ossimConnectableObject::ConnectableObjectList & | inputSources | ) |
Definition at line 33 of file ossimFeatherMosaic.cpp.
References initialize().
protectedvirtual |
Definition at line 43 of file ossimFeatherMosaic.cpp.
References theFeatherInfoSize, and theInputFeatherInformation.
protected |
See the getTile method for the call.
Definition at line 148 of file ossimFeatherMosaic.cpp.
References computeWeight(), ossimImageData::fill(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getMaxPix(), ossimImageData::getMinPix(), ossimImageCombiner::getNextTile(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getOrigin(), ossimImageData::getWidth(), ossimImageData::isNull(), OSSIM_EMPTY, OSSIM_NULL, OSSIM_PARTIAL, ossimDataObject::setDataObjectStatus(), theAlphaSum, ossimImageCombiner::theLargestNumberOfInputBands, theResult, ossimImageMosaic::theTile, ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIpt::x, and ossimIpt::y.
Referenced by getTile().
protectedvirtual |
Definition at line 327 of file ossimFeatherMosaic.cpp.
References ossimFeatherMosaic::ossimFeatherInputInformation::theAxis1, ossimFeatherMosaic::ossimFeatherInputInformation::theAxis1Length, ossimFeatherMosaic::ossimFeatherInputInformation::theAxis2, ossimFeatherMosaic::ossimFeatherInputInformation::theAxis2Length, ossimFeatherMosaic::ossimFeatherInputInformation::theCenter, theInputFeatherInformation, ossimDpt::x, and ossimDpt::y.
Referenced by combine().
Reimplemented from ossimImageMosaic.
Definition at line 53 of file ossimFeatherMosaic.cpp.
References combine(), ossimImageData::getHeight(), ossimConnectableObject::getNumberOfInputs(), ossimRectilinearDataObject::getScalarType(), ossimImageMosaic::getTile(), ossimImageData::getWidth(), ossimIrect::height(), initialize(), ossimImageData::initialize(), ossimSource::isSourceEnabled(), ossimImageData::makeBlank(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SCALAR_UNKNOWN, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setHeight(), ossimImageData::setImageRectangle(), ossimImageData::setOrigin(), ossimImageData::setWidth(), size, theAlphaSum, theInputFeatherInformation, theResult, ossimImageMosaic::theTile, ossimIrect::ul(), and ossimIrect::width().
Definition at line 350 of file ossimFeatherMosaic.cpp.
References ossimImageMosaic::allocate(), ossimImageData::getHeight(), ossimConnectableObject::getInput(), ossimConnectableObject::getNumberOfInputs(), ossimImageSource::getValidImageVertices(), ossimImageData::getWidth(), ossimImageMosaic::initialize(), ossimImageData::initialize(), OSSIM_CLOCKWISE_ORDER, OSSIM_FLOAT, PTR_CAST, ossimFeatherMosaic::ossimFeatherInputInformation::setVertexList(), theAlphaSum, theFeatherInfoSize, theInputFeatherInformation, ossimImageCombiner::theLargestNumberOfInputBands, theResult, ossimImageMosaic::theTile, and ossimRefPtr< T >::valid().
Referenced by getTile(), and ossimFeatherMosaic().
friend |
Definition at line 466 of file ossimFeatherMosaic.cpp.
protected |
Definition at line 65 of file ossimFeatherMosaic.h.
Referenced by combine(), getTile(), and initialize().
protected |
Will hold the count for the feather information list.
Definition at line 71 of file ossimFeatherMosaic.h.
Referenced by initialize(), and ~ossimFeatherMosaic().
protected |
will hold an array of input information
Definition at line 64 of file ossimFeatherMosaic.h.
Referenced by computeWeight(), getTile(), initialize(), and ~ossimFeatherMosaic().
protected |
Definition at line 66 of file ossimFeatherMosaic.h.
